    4. [Neuer Adapter] EuSec
      Thomas Braun Most Active @Marko1974 last edited by
      @marko1974
      Mit
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      dann schauen ob das alles senkrecht im System hängt.
      Marko1974 1 Reply Last reply Reply Quote 0
      • Marko1974
        Marko1974 @Thomas Braun last edited by
        @thomas-braun said in [Neuer Adapter] EuSec:
        [16:16:01] openhabian@openhab:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/n        odejs
        ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden:        Die Datei existiert bereits
        [16:17:07] openhabian@openhab:/opt/iobroker$ which nodejs node npm && nodejs -v        && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo ap        t update && apt policy nodejs
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.19.0
        v14.19.0
        6.14.16
        openhabian
        /opt/iobroker
        [16:15:56] openhabian@openhab:/opt/iobroker$ iobroker start
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.19.0
        v14.19.0
        6.14.16
        openhabian
        /opt/iobroker
        OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        OK:2 http://phoscon.de/apt/deconz buster-beta InRelease
        OK:3 http://archive.raspberrypi.org/debian buster InRelease
        OK:4 https://deb.nodesource.com/node_14.x buster InRelease
        OK:5 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
        Aktualisierung für 26 Pakete verfügbar. Führen Sie »apt list --upgradable« aus,        um sie anzuzeigen.
        nodejs:
          Installiert:           14.19.0-deb-1nodesource1
          Installationskandidat: 14.19.0-deb-1nodesource1
          Versionstabelle:
         *** 14.19.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u1 500
        [16:17:59] openhabian@openhab:/opt/iobroker$ [16:15:56] openhabian@openhab:/opt/        iobroker$ iobroker start
        -bash: [16:15:56]: Kommando nicht gefunden.
        [16:18:00] openhabian@openhab:/opt/iobroker$ [16:16:01] openhabian@openhab:/opt/        iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
        -bash: [16:16:01]: Kommando nicht gefunden.
        [16:18:00] openhabian@openhab:/opt/iobroker$ ln: die symbolische Verknüpfung '/u        sr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
        -bash: ln:: Kommando nicht gefunden.
        [16:18:00] openhabian@openhab:/opt/iobroker$ [16:17:07] openhabian@openhab:/opt/        iobroker$ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && p        wd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        -bash: [16:17:07]: Kommando nicht gefunden.
        [16:18:00] openhabian@openhab:/opt/iobroker$ /usr/bin/nodejs
        Welcome to Node.js v14.19.0.
        Type ".help" for more information.
        > /usr/bin/node
        /usr/bin/node
        Uncaught SyntaxError: Invalid regular expression flags
        > /usr/bin/npm
        /usr/bin/npm
        > v14.19.0
        v14.19.0
        Uncaught SyntaxError: Unexpected number
        > v14.19.0
        v14.19.0
        > 6.14.16
        6.14.16
        > openhabian
        Uncaught ReferenceError: openhabian is not defined
        > /opt/iobroker
        /opt/iobroker
          @marko1974 sagte in [Neuer Adapter] EuSec:
          Okay, soweit schaut das sauber aus.
          Die
          würde ich aber auch noch eintüten.
          • Marko1974
            @thomas-braun also bisher läuft da nichts sauber....immer noch das gleiche wie vorher
            eintüten?
              @marko1974
              sudo apt update
              sudo apt full-upgrade
              sudo reboot
              • Marko1974
                Marko1974 @Thomas Braun last edited by Marko1974
                achso ja...das hatte ich soben gemacht...nur noch mal eben rebooten
                • Marko1974
                  Marko1974 @Marko1974 last edited by Marko1974
                  @thomas-braun ursprünglich wollte ich eigentlich nur, wenn ein bild erfasst wird in einer meiner eufy 2c (keine cloud) dieses an telegram schicken. meinentwegen auch ein video. Ich hatte das schonmal probiert mit nem blockly ....klappte aber leider nicht, da keiin http link versendet wurde und somit auch keine vorschau bei telegram angezeigt wurde. Hoffe das geht mittlerweile überhaupt
                    @marko1974
                    Ich kenne den Adapter nicht. Keine Ahnung was der kann oder nicht.
                    • Marko1974
                      @thomas-braun aber wir sind doch hier in dem thread des adapters 🙂
                        @marko1974
                        Und? Für eine Installation eines Adapters muss man ja nicht wissen was der macht.
                        • Marko1974
                          @thomas-braun hehe...ja das stimmt schon 🙂
                          zumindest bin ich hier damit dann aber nicht falsch
                            @marko1974
                            Ist der ioBroker jetzt zur Ruhe gekommen? Rebuilds durchgeführt?
                            Ein (Neu)-Start des Adapters schaut jetzt wie aus?
                            • Marko1974
                              @thomas-braun es rödelt noch...melde mich sofort wenn er fertig ist
                              • Marko1974
                                @thomas-braun habe da immer noch die gleichen dinge in schleife drin -.-
                                2022-03-06 16:44:08.612 - info: shuttercontrol.0 (3401) starting. Version 1.4.10 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v14.19.0, js-controller: 4.0.18
                                2022-03-06 16:44:12.273 - info: fb-checkpresence.0 (2760) History function for Konrads-IphoneX disabled. Please select a history adapter in the configuration dialog!
                                2022-03-06 16:44:12.275 - info: fb-checkpresence.0 (2760) createMemberObjects finished successfully
                                2022-03-06 16:44:18.723 - info: wled.0 (3495) Bonjour service started, new devices will be detected automatically
                                2022-03-06 16:44:18.836 - info: wled.0 (3495) WLED connected
                                2022-03-06 16:44:28.738 - info: wled.0 (3495) WLED initialisation finalized, ready to do my job have fun !
                                2022-03-06 16:44:39.445 - info: host.openhab iobroker npm-rebuild: > protobuf-typescript@6.8.8 postinstall /opt/iobroker/node_modules/protobuf-typescript> node scripts/postinstall
                                2022-03-06 16:44:44.187 - info: host.openhab iobroker npm-rebuild: > iobroker.amazon-dash@1.1.0 preinstall /opt/iobroker/node_modules/iobroker.amazon-dash> apt install libpcap-dev -y || true
                                2022-03-06 16:44:44.559 - info: host.openhab iobroker npm-rebuild: > pcap@3.1.0 install /opt/iobroker/node_modules/pcap> node-gyp rebuild
                                2022-03-06 16:44:51.608 - info: host.openhab iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird betreten
                                2022-03-06 16:44:51.623 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
                                2022-03-06 16:45:05.248 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/pcap_binding/pcap_session.o
                                2022-03-06 16:45:08.420 - info: fb-checkpresence.0 (2760) createFbDeviceObjects finished successfully
                                2022-03-06 16:45:08.424 - info: fb-checkpresence.0 (2760) states successfully subscribed
                                2022-03-06 16:45:08.427 - info: fb-checkpresence.0 (2760) loop successfully started
                                2022-03-06 16:45:15.730 - info: host.openhab iobroker npm-rebuild: SOLINK_MODULE(target) Release/obj.target/pcap_binding.node
                                2022-03-06 16:45:17.221 - info: host.openhab iobroker npm-rebuild: COPY Release/pcap_binding.nodemake: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird verlassen
                                2022-03-06 16:45:19.116 - info: host.openhab iobroker npm-rebuild: > @serialport/bindings@9.1.0 install /opt/iobroker/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                2022-03-06 16:45:21.629 - info: alexa2.0 (2498) Subscribing to states...
                                2022-03-06 16:45:25.463 - info: host.openhab iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
                                2022-03-06 16:45:25.471 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport.o
                                2022-03-06 16:45:34.388 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 3.
                                2022-03-06 16:45:34.470 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 3.
                                2022-03-06 16:45:34.529 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 3.
                                2022-03-06 16:45:34.568 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 4.
                                2022-03-06 16:45:34.578 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 4.
                                2022-03-06 16:45:34.585 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 4.
                                2022-03-06 16:45:35.204 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                                2022-03-06 16:45:40.405 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/poller.o
                                2022-03-06 16:45:50.021 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport_linux.o SOLINK_MODULE(target) Release/obj.target/bindings.node COPY Release/bindings.nodemake: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen> @serialport/bindings@9.2.8 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                2022-03-06 16:45:57.423 - info: host.openhab iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build“ wird betreten CXX(target) Release/obj.target/bindings/src/serialport.o
                                2022-03-06 16:46:07.980 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                                2022-03-06 16:46:13.766 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/poller.o
                                2022-03-06 16:46:23.360 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport_linux.o SOLINK_MODULE(target) Release/obj.target/bindings.node
                                2022-03-06 16:46:23.864 - info: host.openhab iobroker npm-rebuild: COPY Release/bindings.node
                                2022-03-06 16:46:23.960 - info: host.openhab iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build“ wird verlassen
                                2022-03-06 16:46:24.508 - info: host.openhab iobroker npm-rebuild:
                                2022-03-06 16:46:24.510 - info: host.openhab iobroker npm-rebuild: > ffmpeg-static@4.4.0 install /opt/iobroker/node_modules/ffmpeg-static> node install.js
                                  @marko1974
                                  Da läuft noch diverses rebuild-Zeuch. Abwarten bis da Ruhe ist.
                                  • Marko1974
                                    @thomas-braun yo...web adapter lüft noch nicht. bei eufy security geht immer noch die passwort eingabe weg...somit kann keins eingegeben werden und der eufy sec bleibt rot
                                    2022-03-06 16:53:33.472 - info: host.openhab Adapter system.adapter.eufy-security.0 needs rebuild and will be restarted afterwards.
                                    2022-03-06 16:53:33.473 - info: host.openhab system.adapter.eufy-security.0 will be rebuilt
                                    2022-03-06 16:53:33.474 - warn: host.openhab adapter "eufy-security" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                    2022-03-06 16:53:33.474 - info: host.openhab iobroker rebuild
                                    2022-03-06 16:53:33.548 - error: host.openhab Caught by controller[0]: internal/modules/cjs/loader.js:329
                                    2022-03-06 16:53:33.549 - error: host.openhab Caught by controller[0]: throw err;
                                    2022-03-06 16:53:33.550 - error: host.openhab Caught by controller[0]: ^
                                    2022-03-06 16:53:33.551 - error: host.openhab Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
                                    2022-03-06 16:53:33.552 - error: host.openhab Caught by controller[0]: at tryPackage (internal/modules/cjs/loader.js:321:19)
                                    2022-03-06 16:53:33.553 - error: host.openhab Caught by controller[0]: at Function.Module._findPath (internal/modules/cjs/loader.js:534:18)
                                    2022-03-06 16:53:33.553 - error: host.openhab Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:888:27)
                                    2022-03-06 16:53:33.554 - error: host.openhab Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                    2022-03-06 16:53:33.565 - error: host.openhab Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                                    2022-03-06 16:53:33.566 - error: host.openhab Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                                    2022-03-06 16:53:33.566 - error: host.openhab Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.eusec/build/main.js:31:32)
                                    2022-03-06 16:53:33.567 - error: host.openhab Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                                    2022-03-06 16:53:33.568 - error: host.openhab Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                    2022-03-06 16:53:33.569 - error: host.openhab Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
                                    2022-03-06 16:53:33.569 - error: host.openhab Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                    2022-03-06 16:53:33.570 - error: host.openhab Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
                                    2022-03-06 16:53:33.570 - error: host.openhab Caught by controller[0]: requestPath: 'eufy-security-client'
                                    2022-03-06 16:53:33.571 - error: host.openhab Caught by controller[0]: }
                                    2022-03-06 16:53:33.572 - error: host.openhab instance system.adapter.eusec.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2022-03-06 16:53:33.573 - info: host.openhab Adapter system.adapter.eusec.0 needs rebuild and will be restarted afterwards.
                                    2022-03-06 16:53:33.574 - info: host.openhab system.adapter.eusec.0 will be rebuilt
                                    2022-03-06 16:53:37.432 - info: host.openhab iobroker npm-rebuild: Rebuilding native modules ...
                                    2022-03-06 16:53:40.823 - info: web.0 (11120) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.18
                                    2022-03-06 16:53:41.701 - info: web.0 (11120) socket.io server listening on port 8102
                                    2022-03-06 16:53:41.765 - info: web.0 (11120) Connect extension "eusec/build/lib/web.js"
                                    2022-03-06 16:53:41.826 - info: web.0 (11120) Connect extension "eufy-security/build/lib/web.js"
                                    2022-03-06 16:53:41.876 - info: web.0 (11120) http server listening on port 8102
                                    2022-03-06 16:53:42.712 - warn: web.0 (11120) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                                    2022-03-06 16:54:06.269 - info: host.openhab iobroker npm-rebuild:
                                    2022-03-06 16:54:06.272 - info: host.openhab iobroker npm-rebuild: > protobuf-typescript@6.8.8 postinstall /opt/iobroker/node_modules/protobuf-typescript> node scripts/postinstall
                                    2022-03-06 16:54:09.558 - info: host.openhab iobroker npm-rebuild: > iobroker.amazon-dash@1.1.0 preinstall /opt/iobroker/node_modules/iobroker.amazon-dash> apt install libpcap-dev -y || true
                                    2022-03-06 16:54:09.719 - info: host.openhab iobroker npm-rebuild: > pcap@3.1.0 install /opt/iobroker/node_modules/pcap> node-gyp rebuild
                                      @marko1974
                                      Ich denke es sollte nur einer der beiden eufy-Adapter installiert sein.
                                      Und der web-Adapter muss wohl laufen, wenn ich das richtig sehe.
                                      • Marko1974
                                        @thomas-braun der web adapter bleibt mit nem gelben ausrufezeichen auf funktioniert nicht. und eufy sec auf rot. brauche ich vielleicht die cloud?
                                          Warum nicht? Startvorgang des Adapters?
                                          Welche cloud?
                                          • Marko1974
                                            @thomas-braun die eufy cloud.
                                            2022-03-06 17:06:08.141 - error: host.openhab Caught by controller[0]: internal/modules/cjs/loader.js:329
                                            2022-03-06 17:06:08.142 - error: host.openhab Caught by controller[0]: throw err;
                                            2022-03-06 17:06:08.143 - error: host.openhab Caught by controller[0]: ^
                                            2022-03-06 17:06:08.144 - error: host.openhab Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
                                            2022-03-06 17:06:08.144 - error: host.openhab Caught by controller[0]: at tryPackage (internal/modules/cjs/loader.js:321:19)
                                            2022-03-06 17:06:08.145 - error: host.openhab Caught by controller[0]: at Function.Module._findPath (internal/modules/cjs/loader.js:534:18)
                                            2022-03-06 17:06:08.146 - error: host.openhab Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:888:27)
                                            2022-03-06 17:06:08.146 - error: host.openhab Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                            2022-03-06 17:06:08.147 - error: host.openhab Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                                            2022-03-06 17:06:08.148 - error: host.openhab Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                                            2022-03-06 17:06:08.148 - error: host.openhab Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.eufy-security/build/main.js:31:32)
                                            2022-03-06 17:06:08.149 - error: host.openhab Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                                            2022-03-06 17:06:08.150 - error: host.openhab Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                            2022-03-06 17:06:08.150 - error: host.openhab Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
                                            2022-03-06 17:06:08.151 - error: host.openhab Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                            2022-03-06 17:06:08.151 - error: host.openhab Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
                                            2022-03-06 17:06:08.152 - error: host.openhab Caught by controller[0]: requestPath: 'eufy-security-client'
                                            2022-03-06 17:06:08.152 - error: host.openhab Caught by controller[0]: }
                                            2022-03-06 17:06:08.153 - error: host.openhab instance system.adapter.eufy-security.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                            2022-03-06 17:06:08.154 - info: host.openhab Rebuild for adapter system.adapter.eufy-security.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                            2022-03-06 17:06:13.925 - info: web.0 (20195) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.18
                                            2022-03-06 17:06:14.710 - info: web.0 (20195) socket.io server listening on port 8112
                                            2022-03-06 17:06:14.767 - info: web.0 (20195) Connect extension "eufy-security/build/lib/web.js"
                                            2022-03-06 17:06:14.790 - info: web.0 (20195) http server listening on port 8112
                                            adapter cameras doorbell eufy eufycam security
                                            158
                                            1171
                                            445720
