    4. [Neuer Adapter] EuSec
      Thomas Braun Most Active @Marko1974 last edited by
      @marko1974
      Ich denke es sollte nur einer der beiden eufy-Adapter installiert sein.
      Und der web-Adapter muss wohl laufen, wenn ich das richtig sehe.
      Marko1974 1 Reply Last reply Reply Quote 0
      • Marko1974
        Marko1974 @Thomas Braun last edited by
        @thomas-braun der web adapter bleibt mit nem gelben ausrufezeichen auf funktioniert nicht. und eufy sec auf rot. brauche ich vielleicht die cloud?
          @marko1974 sagte in [Neuer Adapter] EuSec:
          Warum nicht? Startvorgang des Adapters?
          Welche cloud?
          • Marko1974
            Marko1974 @Thomas Braun last edited by Marko1974
            @thomas-braun die eufy cloud.
            2022-03-06 17:06:08.141 - error: host.openhab Caught by controller[0]: internal/modules/cjs/loader.js:329
            2022-03-06 17:06:08.142 - error: host.openhab Caught by controller[0]: throw err;
            2022-03-06 17:06:08.143 - error: host.openhab Caught by controller[0]: ^
            2022-03-06 17:06:08.144 - error: host.openhab Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
            2022-03-06 17:06:08.144 - error: host.openhab Caught by controller[0]: at tryPackage (internal/modules/cjs/loader.js:321:19)
            2022-03-06 17:06:08.145 - error: host.openhab Caught by controller[0]: at Function.Module._findPath (internal/modules/cjs/loader.js:534:18)
            2022-03-06 17:06:08.146 - error: host.openhab Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:888:27)
            2022-03-06 17:06:08.146 - error: host.openhab Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
            2022-03-06 17:06:08.147 - error: host.openhab Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
            2022-03-06 17:06:08.148 - error: host.openhab Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
            2022-03-06 17:06:08.148 - error: host.openhab Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.eufy-security/build/main.js:31:32)
            2022-03-06 17:06:08.149 - error: host.openhab Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
            2022-03-06 17:06:08.150 - error: host.openhab Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
            2022-03-06 17:06:08.150 - error: host.openhab Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32) {
            2022-03-06 17:06:08.151 - error: host.openhab Caught by controller[0]: code: 'MODULE_NOT_FOUND',
            2022-03-06 17:06:08.151 - error: host.openhab Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
            2022-03-06 17:06:08.152 - error: host.openhab Caught by controller[0]: requestPath: 'eufy-security-client'
            2022-03-06 17:06:08.152 - error: host.openhab Caught by controller[0]: }
            2022-03-06 17:06:08.153 - error: host.openhab instance system.adapter.eufy-security.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2022-03-06 17:06:08.154 - info: host.openhab Rebuild for adapter system.adapter.eufy-security.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
            2022-03-06 17:06:13.925 - info: web.0 (20195) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.18
            2022-03-06 17:06:14.710 - info: web.0 (20195) socket.io server listening on port 8112
            2022-03-06 17:06:14.767 - info: web.0 (20195) Connect extension "eufy-security/build/lib/web.js"
            2022-03-06 17:06:14.790 - info: web.0 (20195) http server listening on port 8112
              @marko1974
              Ja, klar. Der Adapter kommuniziert ausschließlich mit der eufy-Cloud, wenn ich das richtig gelesen habe. Deswegen kam ja bei mir auch die Fehlermeldung mit dem falschen Token (siehe mein Install-Log oben).
              • Marko1974
                @thomas-braun die cloud habe ich nicht, sondern nur die lokalen geräte....der lief aber vorher zumindest mit dem adapter eufy security
                  @marko1974
                  Schaust du in die ReadMe:
                  You need to provide your Cloud login credentials. The adapter connects to your cloud account and polls for all device data via HTTPS. Now a local or remote P2P connection to the Eufy stations/devices is also supported.
                  However, a connection to the Eufy Cloud is always a prerequisite.
                  • Marko1974
                    @thomas-braun said in [Neuer Adapter] EuSec:
                      @marko1974
                      Ja, aber erst nach dem Login in der eufy-Cloud.
                      • Marko1974
                        @thomas-braun beim eufy-security hat das funktioniert. beim eu-sec von bropat nie.
                        der web adapter läuft aber auch nicht für vis.
                        und im eufy-security kann ich meine userdaten gar nicht richtig eingeben, da die passwort eingabe beim anklicken immer verschwindet. das ist im eu-sec gefixed. im anderen adapter nicht...
                          @marko1974
                          Hast du die jetzt noch beide installiert?
                          • Marko1974
                            @thomas-braun nein, nur noch einen
                              @marko1974
                              Gut. Und wie sehen die (Neu)-Starts der Adapter nun aus?
                              Zuerst mal den web-Adapter ans schwingen bringen.
                              • Marko1974
                                @thomas-braun ein weiteres phänomen ist nun langsame verbindung erkannt im browser
                                2022-03-06 17:21:39.171 - info: host.openhab instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2022-03-06 17:21:42.219 - info: host.openhab "system.adapter.web.0" enabled
                                2022-03-06 17:21:42.586 - info: host.openhab instance system.adapter.web.0 started with pid 29774
                                2022-03-06 17:21:50.102 - info: web.0 (29774) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.18
                                2022-03-06 17:21:50.814 - info: web.0 (29774) socket.io server listening on port 8112
                                2022-03-06 17:21:50.831 - info: web.0 (29774) http server listening on port 8112
                                ist jedoch gelb
                                  Das darf nicht zeitgleich auf dem gleichen Port laufen. Der web-Adapter läuft default auf 8082.
                                  • Marko1974
                                    @thomas-braun auf 8082 läuft bei mir homebridge
                                      @marko1974
                                      Mag ja sein. Trotzdem darf ein Port nicht doppelt verwendet werden.
                                      • Marko1974
                                        @thomas-braun hab ich aber gar nicht so hinterlegt...man kann den port ja nur einmal hinterlegen
                                          @marko1974
                                          Dann schieb den halt irgendwo anders hin. Gibt ja 65535 davon.
                                          • Marko1974
                                            @thomas-braun hab ich ja schon...vis läuft...und das ausrufezeichen in gelb kommt bestimmt daher da eufy nicht läuft. verbunden mit host und lebenszeichen funktioniert. verbindung ist rot.
                                            adapter cameras doorbell eufy eufycam security
                                            158
                                            1171
                                            445720
