    4. Homebridge-Adapter: Funktionierende Plugins und Beispiele
      AKuehnemann73 last edited by
      hat vielleicht einer den ham adapter mit dem laundrify plugin am laufen und kann mir die Konfiguration zukommen lassen?
      Bekomme es irgendwie nicht hin das er mir unter den Objekten was anlegt.
      Das Plugin läuft bei mir auf einer Homebridge auf einem pi.
      Hier mal meine Konfiguration:
      "authCode": "XXX-XXX",
      "pollInterval": 60,
      "invertStatus": true,
      "platform": "laundrify"
        apollon77 @AKuehnemann73 last edited by
        @akuehnemann73 Debug Log bitte? und die vollständige Konfig mal bitte zeigen
          AKuehnemann73 @apollon77 last edited by AKuehnemann73
          @apollon77
          ham.0
          	2021-12-20 22:19:31.858	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          ham.0
          	2021-12-20 22:19:31.856	info	terminating
          ham.0
          	2021-12-20 22:19:31.849	info	cleaned everything up...
          ham.0
          	2021-12-20 22:19:31.841	error	Cannot read property 'status' of undefined
          ham.0
          	2021-12-20 22:19:31.841	error	TypeError: Cannot read property 'status' of undefined at LaundrifyApi.register (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-laundrify-official/src/helper/LaundrifyApi.ts:165:21) at processTicksAndRejections (internal/process/task_queues.js:95:5) at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-laundrify-official/src/helper/LaundrifyApi.ts:56:38
          ham.0
          	2021-12-20 22:19:31.805	error	unhandled promise rejection: Cannot read property 'status' of undefined
          ham.0
          	2021-12-20 22:19:31.804	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          ham.0
          	2021-12-20 22:19:29.166	info	All Libraries installed/updated
          ham.0
          	2021-12-20 22:19:29.158	info	Install/Update homebridge-laundrify-official@1.2.0
          ham.0
          	2021-12-20 22:19:29.155	info	Install/Update the following Libraries: homebridge-laundrify-official@1.2.0
          ham.0
          	2021-12-20 22:19:29.105	info	starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v14.18.1, js-controller: 3.3.21
          ham.0
          	2021-12-20 22:18:56.069	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          ham.0
          	2021-12-20 22:18:56.067	info	terminating
          ham.0
          	2021-12-20 22:18:56.062	info	cleaned everything up...
          ham.0
          	2021-12-20 22:18:56.041	error	Cannot read property 'status' of undefined
          ham.0
          	2021-12-20 22:18:56.040	error	TypeError: Cannot read property 'status' of undefined at LaundrifyApi.register (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-laundrify-official/src/helper/LaundrifyApi.ts:165:21) at processTicksAndRejections (internal/process/task_queues.js:95:5) at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-laundrify-official/src/helper/LaundrifyApi.ts:56:38
          ham.0
          	2021-12-20 22:18:56.010	error	unhandled promise rejection: Cannot read property 'status' of undefined
          ham.0
          	2021-12-20 22:18:56.008	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          ham.0
          	2021-12-20 22:18:53.417	info	All Libraries installed/updated
          ham.0
          	2021-12-20 22:18:53.415	info	Install/Update homebridge-laundrify-official@1.2.0
          ham.0
          	2021-12-20 22:18:53.413	info	Install/Update the following Libraries: homebridge-laundrify-official@1.2.0
          ham.0
          	2021-12-20 22:18:53.371	info	starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v14.18.1, js-controller: 3.3.21
          ham.0
          	2021-12-20 22:18:46.811	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          ham.0
          	2021-12-20 22:18:46.808	info	terminating
          ham.0
          	2021-12-20 22:18:46.802	info	cleaned everything up...
          ham.0
          	2021-12-20 22:18:46.798	info	Got terminate signal TERMINATE_YOURSELF
          Konfig:
          "bridge": {
          "name": "Homebridge 365F",
          "username": "0E:62:A1:2D:36:5F",
          "port": 51559,
          "pin": "736-16-448"
          "accessories": [],
          "platforms": [
          "name": "Config",
          "port": 8581,
          "platform": "config"
          "pollInterval": 60,
            @akuehnemann73 sagte in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
            Dann solltest Du dich mal da hin wenden ... Ich denke das der Fehler hier liegt https://github.com/laundrify/homebridge-laundrify-official/blob/master/src/helper/LaundrifyApi.ts#L158 ... typischer Zugriff auf pot nicht initialisierte Variablen
              TT-Tom last edited by
              @apollon77
              Hallo ich habe das Plugin Homebridge-Calendar eingebunden. Ich nutze es, um meine Heizung nach meinen Schichtplan zu steuern.
              Version 0.4.0 HAM 4.0.2
                    "platform": "Calendar",
                    "calendars": [
                        "name": "Cal 1",
                        "url": "webcal://",
                        "pollingInterval": 5,
                        "offset": "-8h",
                        "sensors": [
                          "Sensor 1",
                          "Sensor 2"
              PS: vielleicht könnte man diese Funktion in iCal einbinden.
              Gruß Tom
                apollon77 @TT-Tom last edited by
                @tt-tom wie meinen? iCal kann auf Text reagieren und States passend setzen. Der calendar adapter kann sowas ähnliches nur ohne iCal Kalender… aber ich weiß nicht mal genau was du meinst
                  TT-Tom @apollon77 last edited by
                  @apollon77 der Adapter bildet ein SensorContact nach und setzt zur Startzeit des Termins ein State auf 1 / true und beim Beenden wieder zurück. Der Termin wird genauso wie bei iCal gefiltert. Zusätzlich kann man zur Startzeit ein Offset setzen, was die Startzeit plus / minus verschiebt.
                  Ich kenne diesen Adapter von der Homebridge noch und konnte es in iCal nicht einstellen. Kann man das mit iCal auch bauen?
                  Gruß Tom
                    @tt-tom ohne den Offset kann das iCal auch. Heißt dort „Events“. Du definierst einen Text der in dem termin vorkommt und dann geht ein state auf true wenn Stein termin läuft und auf false wenn nicht mehr.
                      @apollon77
                      Okay danke für die Info. Ich benötige aber diesen Offset für die Steuerung meiner Badheizung. Frühdienst beginnt um x Uhr, plus offset geht meine Heizung an.
                      Kannst du das als Option in iCal einbauen?
                        @tt-tom Mach ein Feature Request ... keine Ahnung wann jemand dafür zeit findet ... das ist recht schwierig dafür wie ical arbeitet
                          @apollon77 okay muss ich in GitHub machen, oder? Benötige ich dort dann ein Account oder kann man das ohne machen?
                            @tt-tom Ja bitte im Github. Und ja brauchst einen Account (Email/Passwort) ... geht fix 🙂
                              Hallo @apollon77 habe Account angelegt und Feature Request angelegt. Da mein Englisch nicht das beste ist, hoffe ich es ist richtig platziert.
                              PS: my englisch is not the yellow from the egg
                              Gruß Tom
                                @tt-tom Koi Stress, Doitsch geht auch
                                • iPhilBln
                                  iPhilBln last edited by
                                  Gibt es hier jemanden, der das "homebridge-xiaomi-fan" Plugin erfolgreich zum laufen bekommen hat?
                                  Bekomme zwar alle Datenpunkte rein und rudimentäres Ein- / Ausschalten funktioniert auch, jedoch lässt sich die Geschwindigkeit nicht verändern. Der Adapter übermittelt nicht den Wert, sodass er beim nächsten Polling auf den Ursprungswert zurückspringt. Aus dem Log ("Debug") werde ich nicht so wirklich schlau, da auch keine Fehler angezeigt werden. Der Adapter funktioniert in meiner externen Homebridge installation aber einwandfrei.
                                  ham.1
                                  2022-08-07 15:52:33.620	debug	lookup id: Standventilator.Standventilator.Rotation-Speed
                                  ham.1
                                  2022-08-07 15:52:33.620	info	stateChange ham.1.Standventilator.Standventilator.Rotation-Speed {"val":36,"ack":true,"ts":1659880353615,"q":0,"from":"system.adapter.ham.1","user":"system.user.admin","lc":1659880353615}
                                  ham.1
                                  2022-08-07 15:52:33.619	debug	lookup id: Standventilator.Standventilator.Active
                                  ham.1
                                  2022-08-07 15:52:33.619	info	stateChange ham.1.Standventilator.Standventilator.Active {"val":1,"ack":true,"ts":1659880353615,"q":0,"from":"system.adapter.ham.1","user":"system.user.admin","lc":1659880118500}
                                  ham.1
                                  2022-08-07 15:52:29.533	debug	lookup id: Standventilator.Standventilator.Rotation-Speed
                                  ham.1
                                  2022-08-07 15:52:29.532	info	stateChange ham.1.Standventilator.Standventilator.Rotation-Speed {"val":30,"ack":true,"ts":1659880349530,"q":0,"from":"system.adapter.ham.1","user":"system.user.admin","lc":1659880349524}
                                  ham.1
                                  2022-08-07 15:52:29.526	debug	ack is not set!
                                  ham.1
                                  2022-08-07 15:52:29.526	debug	lookup id: Standventilator.Standventilator.Rotation-Speed
                                  ham.1
                                  2022-08-07 15:52:29.526	info	stateChange ham.1.Standventilator.Standventilator.Rotation-Speed {"val":30,"ack":false,"ts":1659880349524,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1659880349524}
                                    apollon77 @iPhilBln last edited by
                                    @iphilbln Also ddie Infos sagen jetzt was? 🙂
                                    Ich sehe das du den Wert 30 setzt. Der wird dann bestätigt und active wird auf 1 gesetzt und direkt drauf kommt die 36 ... Das ist falsch? Oder was sollte es sein? Sollte es die 30sein?
                                    Setze Loglevel bitte mal auf Silly und poste das Log von so einer Aktion damit bitte
                                    iPhilBln 1 Reply Last reply Reply Quote 0
                                    • iPhilBln
                                      iPhilBln @apollon77 last edited by iPhilBln
                                      @apollon77 Ja das habe ich mich auch gefragt um ehrlich zu sein. Hab es jetzt nochmal auf silly gesetzt anstatt debug und direkt mit der Konsole für den Adapter gefiltert. Sprengt nur leider die Anzahl der Zeichen hier. Reicht es dir als log file?
                                      ham1.log
                                      Im Prinzip hast du es richtig verstanden. Der Wert der Lüftergeschwindigkeit war 36. Diesen wollte ich über den DP auf 30 ändern aber die Änderung wird nicht im Lüfter übernommen. Über die Homekit App kann ich den Wert aber problemlos setzen.
                                      Im jetzigen Versuch den Weert zu ändern wollte ich den Wert 1 auf 50 setzen.
                                        @iphilbln Und um sicherzugehen? Die Ham version ist die aktuellste 5.0.2 aus Beta? Oder noch ne 4? Wenn 4 dann bitte mit 5 versuchen bevor ich Geister suche. Musst dann aber ggf auch homebridge updaten und plugin oder so. Siehe Readme
                                        • iPhilBln
                                          iPhilBln last edited by iPhilBln
                                          @apollon77 hab es jetzt mal auf beta gestellt und die 5.0.2 installiert. Unter changelog zu 5.0.0 steht, dass homebridge v1.4 mindestens benötigt wird und die Plugins geupdatet werden sollen. Passiert das Homebridge Update für den Wrapper Modus auch automatisch? Laut Ausgabe sollte dem so sein oder? Die Checkbox für die Plugin Updates hatte ich aktiviert in den Einstellungen der Instanz und neugestartet.
                                          iobroker@iobroker:/opt/iobroker/node_modules/iobroker.ham/node_modules$ sudo npm outdated
                                          Package                    Current  Wanted  Latest  Location
                                          homebridge-plugin-wrapper  MISSING   2.2.1   2.2.1  iobroker.ham
                                          string-argv                MISSING   0.3.1   0.3.1  iobroker.ham
                                          homebridge                   1.4.1   1.5.0   1.5.0  iobroker.ham
                                          iobroker@iobroker:/opt/iobroker/node_modules/iobroker.ham/node_modules$ npm update
                                          iobroker@iobroker:/opt/iobroker/node_modules/iobroker.ham/node_modules$ npm outdated
                                          Leider funktioniert jetzt nicht mal mehr simples Ein- / Ausschalten. Ich hab dir nochmal ein Log vom Start des Adapter bis zum ändern von Datenpunkten erstellt. Es wird aktuell wie gesagt gar keine Änderung mehr übernommen. Hoffe es hilft dir.
                                          ham1.log
                                            @iphilbln naja, KEINER hat gesagt du sollst irgendwas mit npm befehlen anstellen ... wenn Du jetzt homebriddge 1.5.0 installiert hast dann geht natürlich ggf nix mehr weil ham auf homebridge 1.4 aufsetzt. Also Adapter komplett entfernen und neu installieren bitte das du das mal fixt.
                                            Und ehrlich: Ich suche auch im Log gerade nichts weil homebridge 1.5 falsch ist.
                                            Meine Aussage war darauf bezogen das Du schauen musst ob ggf neuere Versionen deiner genutzten Plugins nötig sind wegen der 1.4...
                                            238
                                            55988
