    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      Bloody @tombox last edited by
      @tombox
      Der Alte ist schon abgelaufen, ich warte.
      Danke.
        Bloody last edited by
        @DJMarc75 @tombox
        Funktioniert jetzt. Danke euch.
          senior1418 @tombox last edited by
          @tombox
          bei der Installation über die Katze wird u.a. dies bei mir gemeldet:
          host.iobroker
          2022-03-08 09:41:52.173	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2022-03-08 09:41:52.173	error	Caught by controller[0]: }
          host.iobroker
          2022-03-08 09:41:52.173	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
          host.iobroker
          2022-03-08 09:41:52.173	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
          host.iobroker
          2022-03-08 09:41:52.173	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
          host.iobroker
          2022-03-08 09:41:52.172	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
          host.iobroker
          2022-03-08 09:41:52.172	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
          host.iobroker
          2022-03-08 09:41:52.172	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
          host.iobroker
          2022-03-08 09:41:52.172	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
          host.iobroker
          2022-03-08 09:41:52.172	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
          host.iobroker
          2022-03-08 09:41:52.172	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
          host.iobroker
          2022-03-08 09:41:52.172	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
          host.iobroker
          2022-03-08 09:41:52.172	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
          host.iobroker
          2022-03-08 09:41:52.172	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
          host.iobroker
          2022-03-08 09:41:52.172	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
          host.iobroker
          2022-03-08 09:41:52.172	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
          host.iobroker
          2022-03-08 09:41:52.172	error	Caught by controller[0]: was compiled against a different Node.js version using
          host.iobroker
          2022-03-08 09:41:52.171	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
          host.iobroker
          2022-03-08 09:41:52.171	error	Caught by controller[0]: ^
          host.iobroker
          2022-03-08 09:41:52.171	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
          host.iobroker
          2022-03-08 09:41:52.171	error	Caught by controller[0]: internal/modules/cjs/loader.js:1144
          host.iobroker
          2022-03-08 09:41:51.437	info	instance system.adapter.parcel.0 started with pid 30738
          host.iobroker
          2022-03-08 09:41:51.146	info	"system.adapter.parcel.0" enabled
          host.iobroker
          2022-03-08 09:41:49.225	info	"system.adapter.parcel.0" disabled
          Dazu noch ne Menge an Info:
          iobroker npm-rebuild: whatwg-url@5.0.0 /opt/iobroker/node_modules/whatwg-urlwinston-syslog@2.5.0 /opt/iobroker/node_modules/winston-syslogcoffee-script@1.12.7 /opt/iobroker/node_modules/coffee-scriptcolor-support@1.1.3 /opt/iobroker/node_modules/color-supportnode-inspect@2.0.0 /opt/iobroker/node_modules/node-inspectnopt@3.0.6 /opt/iobroker/node_modules/noptwake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lanwhich@1.3.1 /opt/iobroker/node_modules/which@types/request@2.48.8 /opt/iobroker/node_modules/@types/requestform-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-datatedious@6.7.1 /opt/iobroker/node_modules/tedious@types/node@12.20.46 /opt/iobroker/node_modules/tedious/node_modules/@types/nodebl@3.0.1 /opt/iobroker/node_modules/tedious/node_modules/blreadable-stream@3.6.0 /opt/iobroker/node_modules/tedious/node_modules/readable-streamdepd@2.0.0 /opt/iobroker/node_modules/tedious/node_modules/depdiconv-lite@0.5.2 /opt/iobroker/node_modules/tedious/node_modules/iconv-litevirtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tscdebug@4.3.3 /opt/iobroker/node_modules/virtual-tsc/node_modules/debugms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/mswinston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updatedseq-logging@0.4.6 /opt/iobroker/node_modules/winston-seq-updated/node_modules/seq-loggingcanvas@2.8.0 /opt/iobroker/node_modules/canvas@mapbox/node-pre-gyp@1.0.6 /opt/iobroker/node_modules/canvas/node_modules/@mapbox/node-pre-gypnode-fetch@2.6.6 /opt/iobroker/node_modules/canvas/node_modules/node-fetchnopt@5.0.0 /opt/iobroker/node_modules/canvas/node_modules/noptnpmlog@5.0.1 /opt/iobroker/node_modules/canvas/node_modules/npmlogare-we-there-yet@2.0.0 /opt/iobroker/node_modules/canvas/node_modules/are-we-there-yetreadable-stream@3.6.0 /opt/iobroker/node_modules/canvas/node_modules/readable-streamgauge@3.0.1 /opt/iobroker/node_modules/canvas/node_modules/gaugerimraf@3.0.2 /opt/iobroker/node_modules/canvas/node_modules/rimrafsemver@7.3.5 /opt/iobroker/node_modules/canvas/node_modules/semvertar@6.1.11 /opt/iobroker/node_modules/canvas/node_modules/tarchownr@2.0.0 /opt/iobroker/node_modules/canvas/node_modules/chownrmkdirp@1.0.4 /opt/iobroker/node_modules/canvas/node_modules/mkdirpmssql@6.4.0 /opt/iobroker/node_modules/mssqldebug@4.3.3 /opt/iobroker/node_modules/mssql/node_modules/debugms@2.1.2 /opt/iobroker/node_modules/mssql/node_modules/msnode-gyp@3.8.0 /opt/iobroker/node_modules/node-gypsemver@5.3.0 /opt/iobroker/node_modules/node-gyp/node_modules/semvertar@2.2.2 /opt/iobroker/node_modules/node-gyp/node_modules/tarvm2@3.9.7 /opt/iobroker/node_modules/vm2acorn@8.7.0 /opt/iobroker/node_modules/vm2/node_modules/acornacorn-walk@8.2.0 /opt/iobroker/node_modules/vm2/node_modules/acorn-walk
            tombox @senior1418 last edited by
            @senior1418 Ich hatte gehofft das canvas raus ist hattest du mal manuell canvas installiert oder
            kannst du mal folgendes ausführen
            cd /opt/iobroker/node_modules
            npm list canvas
            • Christoph1337
              Christoph1337 last edited by
              Die aktuelle Version startet bei mir leider nicht mehr:
              $ iobroker url https://github.com/TA2k/ioBroker.parcel --host iobroker --debug
              install TA2k/ioBroker.parcel#8a9f3d23b8c32b4df17f43a4f0e8a78de91e8159
              NPM version: 6.14.16Installing TA2k/ioBroker.parcel#8a9f3d23b8c32b4df17f43a4f0e8a78de91e8159... (System call)
              > node-aead-crypto@2.2.1 preinstall /opt/iobroker/node_modules/node-aead-crypto> node lib/preinstall.js
              node-aead-crypto not needed on this system, since all ciphers are natively supported
              npm WARN http-cookie-agent@1.0.5 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.2.1 (node_modules/node-aead-crypto):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.2.1 preinstall: `node lib/preinstall.js`npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1+ iobroker.parcel@0.0.10removed 668 packages and updated 1 package in 53.587s
              178 packages are looking for funding run `npm fund` for details
              upload [3] parcel.admin /opt/iobroker/node_modules/iobroker.parcel/admin/index_m.html index_m.html text/html
              upload [2] parcel.admin /opt/iobroker/node_modules/iobroker.parcel/admin/parcel.png parcel.png image/png
              upload [1] parcel.admin /opt/iobroker/node_modules/iobroker.parcel/admin/style.css style.css text/css
              upload [0] parcel.admin /opt/iobroker/node_modules/iobroker.parcel/admin/words.js words.js application/javascript
              Update "system.adapter.parcel.0"
              Process exited with code 0
                tombox @Christoph1337 last edited by
                @christoph1337 Ich sehe bei der Installation kein Fehler
                Christoph1337 1 Reply Last reply Reply Quote 0
                  Gruter last edited by
                  in der allProviderJson ist bei mir aktuell ein Problem bei Hermes,
                  hier fehlt ein Wert für Name, alle anderen Felder sind dadurch eins nach Links gerutscht und die Werte stehen in der falschen Spalte.
                  • Christoph1337
                    Christoph1337 @tombox last edited by
                    @tombox Hier noch das Log vom Start.
                      tombox @Gruter last edited by
                      @gruter ist behoben
                        @christoph1337
                        npm list canvas
                        kannst du das bitte ausführen
                        • Christoph1337
                            Thomas Braun Most Active @Christoph1337 last edited by Thomas Braun
                            @christoph1337
                            Kein Problem mit parcel.
                            Dafür mit deinem login und iot / nodejs.
                            Und den Screenshots aus der Konsole. CodeTags verwenden!
                            • Christoph1337
                              Christoph1337 @Thomas Braun last edited by
                              @thomas-braun klär mich doch mal auf, bitte
                                @christoph1337
                                Haben deine Eltern das nicht getan?
                                Also mit den Blümchen und den Bienchen läuft das folgendermaßen...
                                Nicht als root rumeiern. Als Standarduser agieren.
                                Dann muss da ein Modul neugebaut werden. Welches? Könnte ich aus einem Text kopieren, aus einem Screenshot nicht. Das ganze setzt dann noch eine saubere Installlation von nodeJS voraus.
                                Ist aber in diesem Thread OT, weil das mit dem Adapter nichts zu tun hat.
                                • Christoph1337
                                  @thomas-braun Mensch ist das ein netter Umgang hier 😉 da freut man sich doch gleich!
                                  Ich Eier gerne als root rum. Besonders wenn ich in einem docker arbeite.
                                  Mit node.js kenne ich mich leider nicht so richtig aus.
                                  Was es mit dem canvas auf sich hat weiß ich auch nicht.
                                  Da wäre ein Tipp hilfreich.
                                  Fakt ist.
                                  Alle anderen adapter funktionieren. Lediglich der parcel hat nach dem letzten Update den Dienst eingestellt.
                                    @christoph1337 sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                    Hat nichts miteinander zu tun. Auch im Docker muss man nicht automatisch als root rumhampeln.
                                    Wie gesagt, ist OT hier.
                                    parcel hat keine Abhängigkeit zu canvas.
                                    • Christoph1337
                                      Das hilft mir leider alles überhaupt nicht weiter.
                                      Warum sollte ich dann canvas anzeigen lassen? Das ergibt keinen Sinn.
                                      Man darf nicht davon ausgehen, dass sich jeder mit node.js, Javascript und npm in der Tiefe auskennt.
                                      Es gibt einen Fehler nach dem Update. Der Adapter steht.
                                      Er befindet sich in der Entwicklung und Fehler sollten immer gleich reported werden.
                                      Dem bin ich nach bestem Wissen und Gewissen nachgekommen.
                                        Welchen?
                                        LogFile vom Adapter-Start zeigen. Als Text. In CodeTags.
                                        • Christoph1337
                                          root@iobroker:/opt/iobroker/log# tail -f -n 200 iobroker.current.log | grep parcel
                                          2022-03-08 12:40:24.729  - info: host.iobroker "system.adapter.parcel.0" disabled
                                          2022-03-08 12:40:26.075  - info: host.iobroker "system.adapter.parcel.0" enabled
                                          2022-03-08 12:40:26.414  - info: host.iobroker instance system.adapter.parcel.0 started with pid 5088
                                          2022-03-08 12:40:27.196  - error: host.iobroker instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          2022-03-08 12:40:27.196  - info: host.iobroker Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                          Thomas Braun T 2 Replies Last reply Reply Quote 0
                                            @christoph1337
                                            Nicht grepen, dann fehlen u. U. die Zeilen davor.
                                            Und du bist immer noch root.
                                            17track amazon briefe dhl dpd gls ups
                                            122
                                            1534
                                            525579
