    3. Einsteigerfragen
    4. Einbindung elsner P03/ Modbus Wetterstation
      SebastianIV @wendy2702 last edited by
      @wendy2702 ```
      Hallo wendy2702, anbei das Log file. So wie es aussieht, meldet sich die Wetterstation nicht??
      code_text
      2022-03-01 18:12:46.942 - warn: modbus.3 (22629) Error: undefined
      2022-03-01 18:12:46.943 - error: modbus.3 (22629) Request timed out.
      2022-03-01 18:12:46.944 - warn: modbus.3 (22629) Poll error count: 10 code: {"err":"timeout","timeout":5000}
      2022-03-01 18:12:47.944 - info: modbus.3 (22629) Disconnected from slave
      2022-03-01 18:13:47.947 - info: modbus.3 (22629) Connected to slave
      2022-03-01 18:13:52.950 - warn: modbus.3 (22629) Error: undefined
      2022-03-01 18:13:52.951 - error: modbus.3 (22629) Request timed out.
      2022-03-01 18:13:52.952 - warn: modbus.3 (22629) Poll error count: 11 code: {"err":"timeout","timeout":5000}
      2022-03-01 18:13:53.952 - info: modbus.3 (22629) Disconnected from slave
      2022-03-01 18:14:53.956 - info: modbus.3 (22629) Connected to slave
      2022-03-01 18:14:58.960 - warn: modbus.3 (22629) Error: undefined
      2022-03-01 18:14:58.960 - error: modbus.3 (22629) Request timed out.
      2022-03-01 18:14:58.961 - warn: modbus.3 (22629) Poll error count: 12 code: {"err":"timeout","timeout":5000}
      2022-03-01 18:14:59.962 - info: modbus.3 (22629) Disconnected from slave
      2022-03-01 18:15:59.966 - info: modbus.3 (22629) Connected to slave
      2022-03-01 18:16:04.968 - warn: modbus.3 (22629) Error: undefined
      2022-03-01 18:16:04.969 - error: modbus.3 (22629) Request timed out.
      2022-03-01 18:16:04.970 - warn: modbus.3 (22629) Poll error count: 13 code: {"err":"timeout","timeout":5000}
      2022-03-01 18:16:04.971 - error: modbus.3 (22629) Reconnect did not help, restart adapter
      2022-03-01 18:16:04.975 - info: modbus.3 (22629) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-03-01 18:16:05.600 - info: host.raspberrypi instance system.adapter.modbus.3 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2022-03-01 18:16:05.605 - info: host.raspberrypi Restart adapter system.adapter.modbus.3 because enabled
      2022-03-01 18:16:06.672 - info: host.raspberrypi instance system.adapter.modbus.3 started with pid 22729
      2022-03-01 18:16:08.297 - info: modbus.3 (22729) starting. Version 3.4.17 in /opt/iobroker/node_modules/iobroker.modbus, node: v14.18.3, js-controller: 3.3.22
      2022-03-01 18:16:08.703 - info: modbus.3 (22729) Connected to slave
      2022-03-01 18:16:13.714 - warn: modbus.3 (22729) Error: undefined
      2022-03-01 18:16:13.715 - error: modbus.3 (22729) Request timed out.
      2022-03-01 18:16:13.716 - warn: modbus.3 (22729) Poll error count: 1 code: {"err":"timeout","timeout":5000}
      2022-03-01 18:16:14.725 - info: modbus.3 (22729) Disconnected from slave
      2022-03-01 18:16:35.365 - info: host.raspberrypi stopInstance system.adapter.modbus.3 (force=false, process=true)
      2022-03-01 18:16:35.383 - info: host.raspberrypi stopInstance system.adapter.modbus.3 send kill signal
      2022-03-01 18:16:35.383 - info: modbus.3 (22729) Got terminate signal TERMINATE_YOURSELF
      2022-03-01 18:16:35.395 - info: modbus.3 (22729) terminating
      2022-03-01 18:16:35.398 - info: modbus.3 (22729) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-03-01 18:16:35.969 - info: host.raspberrypi instance system.adapter.modbus.3 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-03-01 18:16:38.501 - info: host.raspberrypi instance system.adapter.modbus.3 started with pid 22744
      2022-03-01 18:16:39.655 - debug: modbus.3 (22744) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-03-01 18:16:39.704 - debug: modbus.3 (22744) Objects client ready ... initialize now
      2022-03-01 18:16:39.707 - debug: modbus.3 (22744) Objects create System PubSub Client
      2022-03-01 18:16:39.708 - debug: modbus.3 (22744) Objects create User PubSub Client
      2022-03-01 18:16:39.710 - debug: modbus.3 (22744) Objects client initialize lua scripts
      2022-03-01 18:16:39.723 - debug: modbus.3 (22744) Objects connected to redis: 127.0.0.1:9001
      2022-03-01 18:16:39.733 - debug: modbus.3 (22744) objectDB connected
      2022-03-01 18:16:39.735 - debug: modbus.3 (22744) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-03-01 18:16:39.743 - debug: modbus.3 (22744) States create System PubSub Client
      2022-03-01 18:16:39.745 - debug: modbus.3 (22744) States create User PubSub Client
      2022-03-01 18:16:39.752 - debug: modbus.3 (22744) States connected to redis: 127.0.0.1:9000
      2022-03-01 18:16:39.754 - debug: modbus.3 (22744) statesDB connected
      2022-03-01 18:16:39.959 - debug: modbus.3 (22744) Plugin sentry Initialize Plugin (enabled=true)
      2022-03-01 18:16:40.203 - info: modbus.3 (22744) starting. Version 3.4.17 in /opt/iobroker/node_modules/iobroker.modbus, node: v14.18.3, js-controller: 3.3.22
      2022-03-01 18:16:40.507 - debug: modbus.3 (22744) Initialize Objects for disInputs: []
      2022-03-01 18:16:40.508 - debug: modbus.3 (22744) Initialize Objects for coils: []
      2022-03-01 18:16:40.509 - debug: modbus.3 (22744) Initialize Objects for inputRegs: []
      2022-03-01 18:16:40.509 - debug: modbus.3 (22744) Initialize Objects for holdingRegs: [{"_address":"40003","name":"Temp","description":"Außentemperatur","unit":"C","type":"int8le","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":2,"deviceId":1,"id":"holdingRegisters.40003_Temp"}]
      2022-03-01 18:16:40.510 - debug: modbus.3 (22744) Add holdingRegisters.40003_Temp: {"_id":"holdingRegisters.40003_Temp","type":"state","common":{"name":"Außentemperatur","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"C"},"native":{"regType":"holdingRegs","address":2,"deviceId":1,"type":"int8le","len":1,"offset":0,"factor":1,"poll":true}}
      2022-03-01 18:16:40.794 - debug: modbus.3 (22744) connect to serial /dev/ttyAMA0 with 19200
      2022-03-01 18:16:40.802 - info: modbus.3 (22744) Connected to slave
      2022-03-01 18:16:40.803 - debug: modbus.3 (22744) [DevID_1] Poll start ---------------------
      2022-03-01 18:16:40.806 - debug: modbus.3 (22744) Initialization of scale factors done!
      2022-03-01 18:16:40.806 - debug: modbus.3 (22744) [DevID_1/holdingRegs] Poll address 2 - 1 registers
      2022-03-01 18:16:45.818 - warn: modbus.3 (22744) Error: undefined
      2022-03-01 18:16:45.819 - error: modbus.3 (22744) Request timed out.
      2022-03-01 18:16:45.820 - warn: modbus.3 (22744) Poll error count: 1 code: {"err":"timeout","timeout":5000}
      2022-03-01 18:16:46.822 - info: modbus.3 (22744) Disconnected from slave
      2022-03-01 18:16:46.827 - debug: modbus.3 (22744) Clearing timeout of the current request.
      2022-03-01 18:16:46.828 - debug: modbus.3 (22744) Cleaning up request fifo.
      2022-03-01 18:17:46.825 - debug: modbus.3 (22744) connect to serial /dev/ttyAMA0 with 19200
      2022-03-01 18:17:46.833 - info: modbus.3 (22744) Connected to slave
      2022-03-01 18:17:46.835 - debug: modbus.3 (22744) [DevID_1] Poll start ---------------------
      2022-03-01 18:17:46.837 - debug: modbus.3 (22744) [DevID_1/holdingRegs] Poll address 2 - 1 registers
      2022-03-01 18:17:51.841 - warn: modbus.3 (22744) Error: undefined
      2022-03-01 18:17:51.843 - error: modbus.3 (22744) Request timed out.
      2022-03-01 18:17:51.845 - warn: modbus.3 (22744) Poll error count: 2 code: {"err":"timeout","timeout":5000}
      2022-03-01 18:17:52.844 - info: modbus.3 (22744) Disconnected from slave
      2022-03-01 18:17:52.847 - debug: modbus.3 (22744) Clearing timeout of the current request.
      2022-03-01 18:17:52.848 - debug: modbus.3 (22744) Cleaning up request fifo.
      2022-03-01 18:18:52.847 - debug: modbus.3 (22744) connect to serial /dev/ttyAMA0 with 19200
      2022-03-01 18:18:52.851 - info: modbus.3 (22744) Connected to slave
      2022-03-01 18:18:52.852 - debug: modbus.3 (22744) [DevID_1] Poll start ---------------------
      2022-03-01 18:18:52.854 - debug: modbus.3 (22744) [DevID_1/holdingRegs] Poll address 2 - 1 registers
      2022-03-01 18:18:57.857 - warn: modbus.3 (22744) Error: undefined
      2022-03-01 18:18:57.858 - error: modbus.3 (22744) Request timed out.
      2022-03-01 18:18:57.860 - warn: modbus.3 (22744) Poll error count: 3 code: {"err":"timeout","timeout":5000}
      2022-03-01 18:18:58.860 - info: modbus.3 (22744) Disconnected from slave
      2022-03-01 18:18:58.864 - debug: modbus.3 (22744) Clearing timeout of the current request.
      2022-03-01 18:18:58.865 - debug: modbus.3 (22744) Cleaning up request fifo.
      • wendy2702
        wendy2702 @SebastianIV last edited by
        @sebastianiv Kannst du das loggen mal auf Debug stellen:
        Die Adapter Einstellungen hier posten und auch das Logfile nach Adapter start.
          @wendy2702
          Hallo wendy, sorry hat ein wenig länger gedauert. Anebi das log in debug. Ich hatte den Adapter schon das letzte Mal umgestellt aber erst nach deinem Psot gesehen, das es veraltete Daten waren...
          code_text
          2022-03-06 10:39:07.887 - info: host.raspberrypi "system.adapter.modbus.3" enabled
          2022-03-06 10:39:07.994 - info: host.raspberrypi instance system.adapter.modbus.3 started with pid 12198
          2022-03-06 10:39:09.118 - debug: modbus.3 (12198) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2022-03-06 10:39:09.168 - debug: modbus.3 (12198) Objects client ready ... initialize now
          2022-03-06 10:39:09.171 - debug: modbus.3 (12198) Objects create System PubSub Client
          2022-03-06 10:39:09.172 - debug: modbus.3 (12198) Objects create User PubSub Client
          2022-03-06 10:39:09.173 - debug: modbus.3 (12198) Objects client initialize lua scripts
          2022-03-06 10:39:09.193 - debug: modbus.3 (12198) Objects connected to redis: 127.0.0.1:9001
          2022-03-06 10:39:09.202 - debug: modbus.3 (12198) objectDB connected
          2022-03-06 10:39:09.205 - debug: modbus.3 (12198) Redis States: Use Redis connection: 127.0.0.1:9000
          2022-03-06 10:39:09.213 - debug: modbus.3 (12198) States create System PubSub Client
          2022-03-06 10:39:09.215 - debug: modbus.3 (12198) States create User PubSub Client
          2022-03-06 10:39:09.222 - debug: modbus.3 (12198) States connected to redis: 127.0.0.1:9000
          2022-03-06 10:39:09.223 - debug: modbus.3 (12198) statesDB connected
          2022-03-06 10:39:09.386 - debug: modbus.3 (12198) Plugin sentry Initialize Plugin (enabled=true)
          2022-03-06 10:39:09.623 - info: modbus.3 (12198) starting. Version 3.4.17 in /opt/iobroker/node_modules/iobroker.modbus, node: v14.18.3, js-controller: 3.3.22
          2022-03-06 10:39:09.782 - debug: modbus.3 (12198) Initialize Objects for disInputs: []
          2022-03-06 10:39:09.782 - debug: modbus.3 (12198) Initialize Objects for coils: []
          2022-03-06 10:39:09.783 - debug: modbus.3 (12198) Initialize Objects for inputRegs: []
          2022-03-06 10:39:09.783 - debug: modbus.3 (12198) Initialize Objects for holdingRegs: [{"_address":"40003","name":"Temp","description":"Außentemperatur","unit":"C","type":"int8le","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":2,"deviceId":1,"id":"holdingRegisters.40003_Temp"}]
          2022-03-06 10:39:09.784 - debug: modbus.3 (12198) Add holdingRegisters.40003_Temp: {"_id":"holdingRegisters.40003_Temp","type":"state","common":{"name":"Außentemperatur","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"C"},"native":{"regType":"holdingRegs","address":2,"deviceId":1,"type":"int8le","len":1,"offset":0,"factor":1,"poll":true}}
          2022-03-06 10:39:10.059 - debug: modbus.3 (12198) connect to serial /dev/ttyAMA0 with 19200
          2022-03-06 10:39:10.067 - info: modbus.3 (12198) Connected to slave
          2022-03-06 10:39:10.068 - debug: modbus.3 (12198) [DevID_1] Poll start ---------------------
          2022-03-06 10:39:10.070 - debug: modbus.3 (12198) Initialization of scale factors done!
          2022-03-06 10:39:10.070 - debug: modbus.3 (12198) [DevID_1/holdingRegs] Poll address 2 - 1 registers
          2022-03-06 10:39:15.079 - warn: modbus.3 (12198) Error: undefined
          2022-03-06 10:39:15.080 - error: modbus.3 (12198) Request timed out.
          2022-03-06 10:39:15.084 - warn: modbus.3 (12198) Poll error count: 1 code: {"err":"timeout","timeout":5000}
          2022-03-06 10:39:16.082 - info: modbus.3 (12198) Disconnected from slave
          2022-03-06 10:39:16.086 - debug: modbus.3 (12198) Clearing timeout of the current request.
          2022-03-06 10:39:16.088 - debug: modbus.3 (12198) Cleaning up request fifo.
          2022-03-06 10:40:16.084 - debug: modbus.3 (12198) connect to serial /dev/ttyAMA0 with 19200
          2022-03-06 10:40:16.091 - info: modbus.3 (12198) Connected to slave
          2022-03-06 10:40:16.093 - debug: modbus.3 (12198) [DevID_1] Poll start ---------------------
          2022-03-06 10:40:16.094 - debug: modbus.3 (12198) [DevID_1/holdingRegs] Poll address 2 - 1 registers
          2022-03-06 10:40:21.096 - warn: modbus.3 (12198) Error: undefined
          2022-03-06 10:40:21.097 - error: modbus.3 (12198) Request timed out.
          2022-03-06 10:40:21.099 - warn: modbus.3 (12198) Poll error count: 2 code: {"err":"timeout","timeout":5000}
          2022-03-06 10:40:22.098 - info: modbus.3 (12198) Disconnected from slave
          2022-03-06 10:40:22.101 - debug: modbus.3 (12198) Clearing timeout of the current request.
          2022-03-06 10:40:22.102 - debug: modbus.3 (12198) Cleaning up request fifo.
          2022-03-06 10:41:22.100 - debug: modbus.3 (12198) connect to serial /dev/ttyAMA0 with 19200
          2022-03-06 10:41:22.104 - info: modbus.3 (12198) Connected to slave
          2022-03-06 10:41:22.105 - debug: modbus.3 (12198) [DevID_1] Poll start ---------------------
          2022-03-06 10:41:22.106 - debug: modbus.3 (12198) [DevID_1/holdingRegs] Poll address 2 - 1 registers
          2022-03-06 10:41:27.108 - warn: modbus.3 (12198) Error: undefined
          2022-03-06 10:41:27.109 - error: modbus.3 (12198) Request timed out.
          2022-03-06 10:41:27.110 - warn: modbus.3 (12198) Poll error count: 3 code: {"err":"timeout","timeout":5000}
          2022-03-06 10:41:28.110 - info: modbus.3 (12198) Disconnected from slave
          2022-03-06 10:41:28.112 - debug: modbus.3 (12198) Clearing timeout of the current request.
          2022-03-06 10:41:28.114 - debug: modbus.3 (12198) Cleaning up request fifo.
            @wendy2702
            code_text
            • wendy2702
              @sebastianiv Poste mal einen Screenshot der Adapter Einstellungen.
              Ist das RS485 Shield auch wirklich das Device „ttyAMA0“ ?
                @wendy2702
                Hallo wendy, hier die Einstellungen vom Adapter. Ich hScreenshot 2022-03-07 165903.png abe mir parallel noch ein weiteres Shield bzw. Adapter für RS485 via USB gekauft, vielleicht funktioniert dieser besser....
                • wendy2702
                  Mach mal den Haken bei „Use Aliases“ weg. Kontrolliere danach die Register und poste dann mal das logfile.
                    @wendy2702
                    Hallo wendy, ich habe nun Tests mit dem USB Adapter gemacht. Hier stellt sich die Thematik so dar, dass ich keine Antwort von der Wetterstation erhalte. Also die TX LED am Adapter geht an, die COM an der Wetterstation auch aber die RX am Adapter nicht. Um die Funktion der Wetterstation zu prüfen, wurde nun mit einem PC, dem Adapter via Docklight eine Kommunikation aufgebaut. Hier funktioniert alles, also auch die RX LED vom Adapter.
                      @wendy2702
                      Hallo wendy, die Wetterstation läuft mittlerweile. Mit Hilfe des USB Adapter, dem richtigenm Einstellungen und Regsitern steht die Kommunikation. Einzig den Parameter des Regens bekomme ich nicht ausgelesen. Hast du hier vielleicht noch einen Tipp? Die Register zuvor funktionieren auch weil der Typ Signed 16bit (Big Endian) aus der Anleitung klar ist. Bei Regen habe ich alles möglich versucht aber nichts funktioniert?? Der WErt bleibt konstant bei 0..
                      Vielen Dank
                      Screenshot 2022-03-08 180505.png Screenshot 2022-03-08 180441.png Screenshot 2022-03-08 180415.png
                      • wendy2702
                        @sebastianiv Blöde Frage, regnet es denn?
                          @wendy2702
                          🙂 Nein ich habe aber versucht den Regen mit einem feuchten Lappen zu simulieren.
                          1302
