    4. [Neuer Adapter] EuSec
      Stefan 1 @Stefan 1 last edited by
      @stefan-1 sagte in [Neuer Adapter] EuSec:
      Danach den ioBroker neu starten und den EuSec neu und sauber installieren.
      Marko1974 1 Reply Last reply Reply Quote 0
      • Marko1974
        Marko1974 @Stefan 1 last edited by Marko1974
        @stefan-1 Also...alles gelöscht, den eusec installiert.
        2. Login gemacht, wozu es aber kein Passwort gibt, sondern nur eine Email.
        Der Account steht nun in der App auf warten.
        In der App jetzt PW vergeben und bei Eusec eingetragen.
        Immer noch rot -.-
        2022-03-06 22:56:45.119  - error: host.openhab Caught by controller[0]: internal/modules/cjs/loader.js:329
        2022-03-06 22:56:45.121  - error: host.openhab Caught by controller[0]:       throw err;
        2022-03-06 22:56:45.122  - error: host.openhab Caught by controller[0]:       ^
        2022-03-06 22:56:45.122  - error: host.openhab Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
        2022-03-06 22:56:45.123  - error: host.openhab Caught by controller[0]:     at tryPackage (internal/modules/cjs/loader.js:321:19)
        2022-03-06 22:56:45.123  - error: host.openhab Caught by controller[0]:     at Function.Module._findPath (internal/modules/cjs/loader.js:534:18)
        2022-03-06 22:56:45.124  - error: host.openhab Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:888:27)
        2022-03-06 22:56:45.124  - error: host.openhab Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:746:27)
        2022-03-06 22:56:45.125  - error: host.openhab Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:974:19)
        2022-03-06 22:56:45.126  - error: host.openhab Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:101:18)
        2022-03-06 22:56:45.126  - error: host.openhab Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.eusec/build/main.js:31:32)
        2022-03-06 22:56:45.126  - error: host.openhab Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1085:14)
        2022-03-06 22:56:45.127  - error: host.openhab Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
        2022-03-06 22:56:45.127  - error: host.openhab Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:950:32) {
        2022-03-06 22:56:45.128  - error: host.openhab Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
        2022-03-06 22:56:45.128  - error: host.openhab Caught by controller[0]:   path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
        2022-03-06 22:56:45.129  - error: host.openhab Caught by controller[0]:   requestPath: 'eufy-security-client'
        2022-03-06 22:56:45.129  - error: host.openhab Caught by controller[0]: }
        2022-03-06 22:56:45.130  - error: host.openhab instance system.adapter.eusec.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-03-06 22:56:45.131  - info: host.openhab Rebuild for adapter system.adapter.eusec.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
        2022-03-06 22:56:50.219  - info: web.0 (23119) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.18
        2022-03-06 22:56:50.696  - info: web.0 (23119) Connect extension "eusec/build/lib/web.js"
        2022-03-06 22:56:50.709  - info: web.0 (23119) http server listening on port 8082
        das verzeichnis /opt/iobroker/node_modules/eufy-security-client/build/ gibt es gar nicht
          Stefan 1 @Marko1974 last edited by
          @marko1974
          hast du alle Ordner durchsucht ob noch irgendwo etwas von dem eufy-security-client übrig geblieben ist?
          login wozu es kein Passwort gibt? wo hast du das denn gemacht??
          https://mulpass.eufylife.com/?app=eufy-de da legt man einen Benutzer an, mit passwort.
          ansonsten muss @bropat da vielleicht nochmal etwas zu sagen.
          • Marko1974
            Marko1974 last edited by Marko1974
            @stefan-1 Ich hatte gerade wirklich noch so ein paar Verzeichnisse gefunden und installiere gerade nochmal neu....hab irgendwie wenig hoffnung
            ...so habe ich mir das doch vorgestellt:
            2022-03-06 23:50:42.272  - info: fb-checkpresence.0 (3703) states successfully subscribed
            2022-03-06 23:50:42.275  - info: fb-checkpresence.0 (3703) loop successfully started
            2022-03-06 23:50:54.568  - info: alexa2.0 (3394) Subscribing to states...
            2022-03-06 23:53:46.650  - info: host.openhab iobroker add eusec auto --host openhab
            2022-03-06 23:53:54.280  - info: host.openhab iobroker NPM version: 6.14.16
            2022-03-06 23:53:54.285  - info: host.openhab iobroker Installing iobroker.eusec@0.8.4... (System call)
            2022-03-06 23:55:31.979  - error: host.openhab iobroker host.openhab Cannot install iobroker.eusec@0.8.4: 243
            2022-03-06 23:55:33.038  - info: host.openhab iobroker exit 25
            • Marko1974
              Marko1974 @Marko1974 last edited by
              Ich hab´s geschafft. Adapter in node_modules und auch in den unterverzeichnissen gelöscht. Tauchte selbst in der Übersicht Adapter nicht mehr auf. Dann per shell installiert. Lief sofort
                @marko1974
                gern geschehen.
                • Marko1974
                  @stefan-1 Besten Dank Dir 😉
                    al10b last edited by
                    Ich habe ein eufyCam 2C Pro System mit zwei Kameras. Der Adapter (v 0.8.4) funktioniert soweit ganz gut, aber beide Kameras zeigen unter "battery" 0% an. Die Batterien sind aber sicher nicht leer. Hat jemand eine Idee?
                    LG, Andreas
                      al10b @al10b last edited by
                      @al10b
                      Hallo? Ist jemand zu Hause?
                      cash 1 Reply Last reply Reply Quote 0
                      • cash
                        cash Most Active @al10b last edited by
                        @al10b Hast Du ein Issue auf github dazu aufgemacht? Ich habe zwar nicht Deine Kamera aber auch eine mit Batterie. Auch bei mir 0%. Mir persönlich völlig egal…
                          al10b @cash last edited by
                          @cash
                          Gerade geöffnet: https://github.com/bropat/ioBroker.eusec/issues/239
                          al10b created this issue in bropat/ioBroker.eusec
                          closed [Bug]: eufyCam 2C Pro - battery 0% #239
                            loverz last edited by loverz
                            Hat es jemand von euch geschafft die Eufy Kameras über YAHKA Homekit fähig zu machen?
                            Meine Kameras werden im EuSec Adapter einwandfrei aufgelistet und reagieren auch auf Befehle.
                            Was ich noch nicht so ganz rausgefunden habe sind die ganzen URLs für die gespeicherten Videos, Livestreams und Schnappschüsse.
                            Wenn diese funktionieren, sollte es doch keine Probleme geben diese über YAHKA in Homekit einzubinden.
                            Hat da jemand eine Ahnung, oder kann mir erklären, wie ich auf die URLs zugreifen kann?
                            Also der Link
                            http://192.168.1.xxx:8082/eusec.0/xxxxx/live/xxxxx.m3u8 funktioniert schonmal im VLC.
                            Es scheint aber, dass YAHKA bzw. Homekit damit nichts anfangen kann 😞
                            entavio 1 Reply Last reply Reply Quote 0
                            • entavio
                              entavio @loverz last edited by
                              @loverz said in [Neuer Adapter] EuSec:
                              Also der Link
                              das würde mich ebenfalls brennend interessieren ob und wenn ja wie sich über den Adapter Kameras in HomeKit abbilden lassen.
                              Speziell bei der sehr neuen Kamera EUFY S40 wäre das interessant die out of the box zu meinem Unverständnis kein HomeKit / RTSP o.a. mehr unterstützt
                                @bropat
                                Ich möchte mir ein Script im ioBroker bauen wo zu einer bestimmten Uhrzeit ein Foto von der Kamera per PushOver versendet wird. Jetzt ist die Frage ob man mit dem EuSec Adapter ein Foto auslösen kann? Ich habe bisher nichts gefunden in den Objekten.
                                Irgendwie kann ich einen Livestream auslösen, mir reicht aber ein einzelnes Bild.
                                  worxweis last edited by
                                  Hallo!
                                  Ich besitze eine Doorbell T8210 mit direkter Stromversorgung..
                                  Habe Iobroker am Raspberry Pi4 laufen.
                                  Alle Adapter aktuell, Eusec läuft in der version 0.8.4.
                                  Node.js v14.19.1
                                  NPM 6.14.16
                                  Host läuft auf 4.0.21
                                  Ich hatte jedoch auch schon den Vorgänger Eufy Adapter im Einsatz.
                                  Jedoch ist es mir bis jetzt noch nicht gelungen, ein Livebild in meiner VIS darzustellen.
                                  Geschweige denn überhaupt ein Livebild auch im Browser zu bekommen!
                                  Wird der Livestream gestartet kommt der Link /eusec.0/T8010P23204831AD/live/T8210P0020482249.m3u8.
                                  Wie bekomme ich den nun ins VIS? Welches Widget verwendet ihr? Wie muss der gesamte Link (IP-Adresse, usw.) aussehen?
                                  Ich wäre euch echt dankbar, wenn mir hier jemand weiterhelfen könnte!
                                  Danke schon mal vorab!
                                    guitardoc @worxweis last edited by
                                    Ich wollte gerade den Adapter in Version 0.8.5 in Betrieb nehmen, jedoch scheitere ich schon an der Eingabe des authentication codes. So wie in der Beschreibung beschrieben sehen die Eingabefelder für den authentication code bei mir gar nicht aus? Ich kann nirgendwo einen Code eingeben? Kann mir da jemand weiterhelfen? Danke schon mal im Voraus!
                                      guitardoc @guitardoc last edited by
                                      Niemand?
                                        hohmannc @guitardoc last edited by
                                        @guitardoc hast du den code per mail bekommen - den 2 Faktoren code?
                                          hohmannc @hohmannc last edited by hohmannc
                                          da wo verify_code die (null) auf meinem bild steht, klickst du rauf und gibst den code ein.
                                            guitardoc @hohmannc last edited by
                                            @hohmannc Grmpf… ich bin auf den Stift gegangen, da konnte man natürlich nichts eingeben… jetzt hab ich’s gefunden. Danke für die Hilfe!!
                                            adapter cameras doorbell eufy eufycam security
                                            158
                                            1171
                                            445903
