    4. JavaScript
    5. [Vorlage] HP Drucker Füllstände (Javascript).
    • Dolomiti
      Dolomiti @Clown007 last edited by Dolomiti
      @Christian-4
      Habe dein Skript 1:1 kopiert und nur IP & Druckernamen angepasst.
       * Read informations from HP Printers;
       * 2021-04-16 @ TheAlphaGhost;
      var url = 'http://192.168.1.118/DevMgmt/ConsumableConfigDyn.xml';
      var request = require('request');
      var parseString = require('xml2js').parseString;
      // Create datapoints;
      createState('Drucker.HP.M277dw.Black.ConsumableFamilyName');
      createState('Drucker.HP.M277dw.Black.ConsumableLabelCode');
      createState('Drucker.HP.M277dw.Black.ConsumablePercentageLevelRemaining');
      createState('Drucker.HP.M277dw.Black.ProductNumber');
      createState('Drucker.HP.M277dw.Cyan.ConsumableFamilyName');
      createState('Drucker.HP.M277dw.Cyan.ConsumableLabelCode');
      createState('Drucker.HP.M277dw.Cyan.ConsumablePercentageLevelRemaining');
      createState('Drucker.HP.M277dw.Cyan.ProductNumber');
      createState('Drucker.HP.M277dw.Magenta.ConsumableFamilyName');
      createState('Drucker.HP.M277dw.Magenta.ConsumableLabelCode');
      createState('Drucker.HP.M277dw.Magenta.ConsumablePercentageLevelRemaining');
      createState('Drucker.HP.M277dw.Magenta.ProductNumber');
      createState('Drucker.HP.M277dw.Yellow.ConsumableFamilyName');
      createState('Drucker.HP.M277dw.Yellow.ConsumableLabelCode');
      createState('Drucker.HP.M277dw.Yellow.ConsumablePercentageLevelRemaining');
      createState('Drucker.HP.M277dw.Yellow.ProductNumber');
      function GetData() {
          request(url, function (error, response, body) {
              var xml, result;
              parseString(body, function (err, result) {
                  xml = JSON.stringify(result);
                  var json = JSON.parse(xml);
                  for (var i in json['ccdyn:ConsumableConfigDyn']['ccdyn:ConsumableInfo']) {
                      let node = json['ccdyn:ConsumableConfigDyn']['ccdyn:ConsumableInfo'][i];
                      let ConsumableFamilyName = node['dd:ConsumableFamilyName'];
                      let ConsumableLabelCode = node['dd:ConsumableLabelCode'];
                      let ConsumablePercentageLevelRemaining = node['dd:ConsumablePercentageLevelRemaining'];
                      let ProductNumber = node['dd:ProductNumber'];
                      var ColorDataPoint = "";
                      switch (String(ConsumableLabelCode)) {
                          case "K":
                              ColorDataPoint = "Black";
                              break;
                          case "C":
                              ColorDataPoint = "Cyan";
                              break;
                          case "M":
                              ColorDataPoint = "Magenta";
                              break;
                          case "Y":
                              ColorDataPoint = "Yellow";
                              break;
                         case "CMYK":
                              continue;
                              break;
                          default:
                              continue;
                              log("[ERROR] ColorDataPoint not found for " + ConsumableLabelCode + "!");
                      log(ConsumablePercentageLevelRemaining);
                      setState('javascript.0.Drucker.HP.M277dw.' + ColorDataPoint + '.ConsumableFamilyName', ConsumableFamilyName);
                      setState('javascript.0.Drucker.HP.M277dw.' + ColorDataPoint + '.ConsumableLabelCode', ConsumableLabelCode);
                      setState('javascript.0.Drucker.HP.M277dw.' + ColorDataPoint + '.ConsumablePercentageLevelRemaining', ConsumablePercentageLevelRemaining);
                      setState('javascript.0.Drucker.HP.M277dw.' + ColorDataPoint + '.ProductNumber', ProductNumber);
      schedule('*/1 * * * *', function () {
          GetData();
      Allerdings steht bei mir in den DP´s die Werte in eckigen Klammern und Hochkomma. So funktioniert meine Anzeige natürlich nicht. Kann mir einer auf die Sprünge helfen. Das XML sieht ok aus.
      </dd:ConsumableStateAvailableActions>
      <dd:ConsumableLowThreshold>5</dd:ConsumableLowThreshold>
      <dd:ConsumablePercentageLevelRemaining>70</dd:ConsumablePercentageLevelRemaining>
      <dd:ConsumableReplaceabilityType>userReplaceable</dd:ConsumableReplaceabilityType>
      <dd:ConsumableSelectibilityNumber>201A</dd:ConsumableSelectibilityNumber>
      <dd:ConsumableTypeEnum>toner</dd:ConsumableTypeEnum>
      C 3 Replies Last reply Reply Quote 0
        Clown007 @Dolomiti last edited by
        @dolomiti Okay, dann entfernen wir diese Zeichen einfach:
        var url = 'http://HP983B82.fritz.box/DevMgmt/ConsumableConfigDyn.xml';
        createState('Drucker.HP.983B82.Black.ConsumableFamilyName');
        createState('Drucker.HP.983B82.Black.ConsumableLabelCode');
        createState('Drucker.HP.983B82.Black.ConsumablePercentageLevelRemaining');
        createState('Drucker.HP.983B82.Black.ProductNumber');
        createState('Drucker.HP.983B82.Cyan.ConsumableFamilyName');
        createState('Drucker.HP.983B82.Cyan.ConsumableLabelCode');
        createState('Drucker.HP.983B82.Cyan.ConsumablePercentageLevelRemaining');
        createState('Drucker.HP.983B82.Cyan.ProductNumber');
        createState('Drucker.HP.983B82.Magenta.ConsumableFamilyName');
        createState('Drucker.HP.983B82.Magenta.ConsumableLabelCode');
        createState('Drucker.HP.983B82.Magenta.ConsumablePercentageLevelRemaining');
        createState('Drucker.HP.983B82.Magenta.ProductNumber');
        createState('Drucker.HP.983B82.Yellow.ConsumableFamilyName');
        createState('Drucker.HP.983B82.Yellow.ConsumableLabelCode');
        createState('Drucker.HP.983B82.Yellow.ConsumablePercentageLevelRemaining');
        createState('Drucker.HP.983B82.Yellow.ProductNumber');
        createState('Drucker.HP.983B82.CMY.ConsumableFamilyName');
        createState('Drucker.HP.983B82.CMY.ConsumableLabelCode');
        createState('Drucker.HP.983B82.CMY.ConsumablePercentageLevelRemaining');
        createState('Drucker.HP.983B82.CMY.ProductNumber');
                var xml, result;
                            case "K":
                                break;
                            case "C":
                                break;
                            case "M":
                                break;
                            case "Y":
                                break;
                            case "CMY":
                                ColorDataPoint = "CMY";
                                break;
                            case "CMYK":
                                continue;
                                break;
                            default:
                                continue;
                        ConsumableFamilyName = String(ConsumableFamilyName).replace((/[^*a-zA-Z0-9]/g), "");
                        setState('javascript.0.Drucker.HP.983B82.' + ColorDataPoint + '.ConsumableFamilyName', String(ConsumableFamilyName).replace((/[^*a-zA-Z0-9]/g), ""));
                        setState('javascript.0.Drucker.HP.983B82.' + ColorDataPoint + '.ConsumableLabelCode', String(ConsumableLabelCode).replace((/[^*a-zA-Z0-9]/g), ""));
                        setState('javascript.0.Drucker.HP.983B82.' + ColorDataPoint + '.ConsumablePercentageLevelRemaining', String(ConsumablePercentageLevelRemaining).replace((/[^*a-zA-Z0-9]/g), ""));
                        setState('javascript.0.Drucker.HP.983B82.' + ColorDataPoint + '.ProductNumber', String(ProductNumber).replace((/[^*a-zA-Z0-9]/g), ""));
        schedule("42 23 * * *", function () {
            GetData();
        Dolomiti 1 Reply Last reply Reply Quote 1
          @dolomiti Eine andere Möglichkeit ist übrigens das SNMP Modul. Die entsprechenden OIDs sind bei meinem Drucker:
          Farbe: .1.3.6.1.2.1.43.11.1.1.9.1.1
          S/W :.1.3.6.1.2.1.43.11.1.1.9.1.2
          Ich glaube der Status soll auch nicht mehr in javascript.0 sondern in 0_userdata. Aber diese kleine Änderung schaffst Du selber 😉
            @dolomiti Ich habe das Script jetzt noch mal etwas (für mich) optimiert. In Userdata "umgezogen". Als Drucker reicht es jetzt den FQDN oben zu ändern und ich habe die Stati ohne Funktion entfernt:
            var printername = 'HP983B82.fritz.box';
            var url = 'http://' + printername + '/DevMgmt/ConsumableConfigDyn.xml';
            var datapointname = printername.split('.')[0];
            createState('0_userdata.0.Drucker.' + datapointname + '.Black.ConsumableLabelCode');
            createState('0_userdata.0.Drucker.' + datapointname + '.Black.ConsumablePercentageLevelRemaining');
            createState('0_userdata.0.Drucker.' + datapointname + '.CMY.ConsumableLabelCode');
            createState('0_userdata.0.Drucker.' + datapointname + '.CMY.ConsumablePercentageLevelRemaining');
                    var xml, result;
                                case "K":
                                    break;
                                case "CMY":
                                    break;
                                default:
                                    continue;
                            setState('0_userdata.0.Drucker.' + datapointname + '.' + ColorDataPoint + '.ConsumableLabelCode', String(ConsumableLabelCode).replace((/[^*a-zA-Z0-9]/g), ""));
                            setState('0_userdata.0.Drucker.' + datapointname + '.' + ColorDataPoint + '.ConsumablePercentageLevelRemaining', String(ConsumablePercentageLevelRemaining).replace((/[^*a-zA-Z0-9]/g), ""));
                GetData();
            • amg_666
              amg_666 @Clown007 last edited by amg_666
              @clown007 Steilvorlage 🙂
              Wenn schon SNMP dann aber auch das volle Programm...
              1.3.6.1.2.1.43.11.1.1.9.1.1 Farbe 1 (gibt die Anzahl Seiten an die mit der Farbe 1 noch gedruckt werden können)
              1.3.6.1.2.1.43.11.1.1.9.1.2 Farbe 2
              1.3.6.1.2.1.43.11.1.1.9.1.3 Farbe 3
              1.3.6.1.2.1.43.11.1.1.9.1.4 Farbe 4
              1.3.6.1.2.1.43.11.1.1.6.1.1 Name Farbe 1 (z.B. Black)
              1.3.6.1.2.1.43.11.1.1.6.1.2 Name Farbe 2
              1.3.6.1.2.1.43.11.1.1.6.1.3 Name Farbe 3
              1.3.6.1.2.1.43.11.1.1.6.1.4 Name Farbe 4
              1.3.6.1.2.1.43.11.1.1.8.1.1 Kapazität F1 (Wie viele Seiten können max gedruckt werden)
              1.3.6.1.2.1.43.11.1.1.8.1.2 Kapazität F2
              1.3.6.1.2.1.43.11.1.1.8.1.3 Kapazität F3
              1.3.6.1.2.1.43.11.1.1.8.1.4 Kapazität F4
              C 1 Reply Last reply Reply Quote 2
              • Dolomiti
                @clown007
                Danke für die Anpassung. Ich hatte mir das auch schon überlegt. Meiner Meinung nach konvertiert xml2js nicht richtig.
                Im ersten Beispiel wird der Text angezeigt wie erwartet.
                var xml = "<aaaa>Ein Text</aaaa>"
                parseString(xml, function (err, result) {
                    log(result);
                Ergebnis bei mir:
                {'aaaa':'Ein Text'}
                Ab der zweiten Ebene kommen die eckigen Klammern hinzu
                var xml = "<aaaa><bbbb>Ein Text</bbbb></aaaa>"
                    log(result);
                Ergebnis
                {'aaaa':{'bbbb':['Ein Text']}}
                Bei einem Onlinekonverter wie z.B. hier ist das Ergebnis wie erwartet.
                  "aaaa": {
                    "bbbb": "Ein Text"
                Ist dein geparstes Ergebnis auch mit eckigen Klammern? Ich dachte schon, es liegt an meiner ioBroker-Installation mit einer alten oder falschen xml2js, aber in einem neuen Proxmox-Container mit ganz frischem ioBroker ist das Ergebnis das gleiche. Anscheinend macht er bei mir ein Array aus dem einzelnen Wert.
                Mit deiner Version läuft es jetzt jedenfalls, aber ich würde das Problem gerne verstehen und nachvollziehen können.
                C 1 Reply Last reply Reply Quote 1
                  Clown007 @amg_666 last edited by
                  @amg_666 ... Die OIDs für für Farbe 1-4 sind identisch und gibt mir den % Wert (90) 😉
                  Name Farbe 1 gibt es bei mir nicht, Farbe 2 ist dann black, Farbe 3 und Farbe 4 gibt es wieder nicht.
                  1.3.6.1.2.1.43.11.1.1.8.1.1 Kapazität F2 ist bei mir 100?
                  Kapazität 1,3,4 gibt es bei mir nicht.
                  Damit bleibt es bei mir bei den o.g. OIDs 😉
                    @dolomiti sagte in [Vorlage] HP Drucker Füllstände (Javascript).:
                    xml2js
                    Ich gebe zu, dass ich es mir einfach gemacht habe, und darüber nicht weiter nachgedacht habe. Eventuell hilft Dir das weiter?
                    https://www.npmjs.com/package/xml2js
                    • amg_666
                      @clown007 Hab meinen Post korrigiert, da waren copy&paste Fehler drin 😞
                      Die OID habe ich aus meinem snmp Adapter rauskopiert, damit lese ich meinen Drucker aus, es ist ein Samsung C48x und die Samsung haben normalerweise gleiche OID wie HP, in den Objekten sieht das dann so aus:
                      Die Werte bei Kapazität z.B. 1000 oder 1500 sagen aus wieviele Kapazität die Farbkartusche hat (wieviele Seiten er in der Farbe drucken kann).
                      "Name Farbe 1 gibt es bei mir nicht, Farbe 2 ist dann black, Farbe 3 und Farbe 4 gibt es wieder nicht."
                      Hast du einen Schwarzweiß-Drucker? Dann hast du natürlich nur 1* Farbe und 1* Kapazität
                        @amg_666 Ich habe einen Farbdrucker mit einer SW und einer Farbpatrone. Kapazität gibt es aber anscheinend bei HP nicht, nur die Füllstände in %.
                          jwedenig Most Active last edited by
                          Hi!
                          Gibt es eine Möglichkeit das Abo Modell von HP Instant Ink auszulesen um zu sehen, wieviele Seiten man pro Monat noch drucken kann?
                          Liebe Grüße
                          Jürgen
                          • amg_666
                            amg_666 @jwedenig last edited by
                            @jwedenig sagte in [Vorlage] HP Drucker Füllstände (Javascript).:
                            ich denke mal, nein. Die Füllstände liest du ja aus dem Drucker aus und der Drucker kennt dein Abo-Modell ja nicht. Du kannst höchstens am Drucker die Anzahl gedruckter Seiten auslesen und die Veränderungen auswerten, das Abo-Modell hängt ja von der Anzahl Seiten ab und dann könntest du es abschätzen.
                              jwedenig Most Active @amg_666 last edited by
                              @amg_666
                              ah, ok alles klar!
                              Dann lese ich mich mal hier ein, dh ich brauche ein Skript und die IP des Druckers, richtig?
                              Liebe Grüße
                              • amg_666
                                @jwedenig Du brauchst den snmp-Adapter. Da trägst du unter "Geräte" den Drucker mit IP ein und unter "OID Sets" den Parameter.
                                Bei meinem Drucker ist das die OID 1.3.6.1.2.1.43.10.2.1.4.1.1 für Anzahl gedruckter Seiten (keine Ahnung ob das bei deinem Drucker passt, einfach mal ausprobieren).
                                Dann hast du den Wert als Datenpunkt im iobroker und dann kannst du ein Skript basteln, was die Anzahl gedruckter Seiten pro Tag oder pro Wocher oder oder oder ermittelt.
                                Welche OID bei Deinem Drucker für welchen Wert steht musst du ausprobieren. Du kannst mal hier schaun, was so Standard OID sind: oidref.com oder du lädst dir den Free MIB Browser runter, den fand ich aber vorsichtig ausgedrückt etwas gewöhnungsbedürftig http://www.ireasoning.com/mibbrowser.shtml
                                  @amg_666
                                  ja danke dir, ich check mal
                                    @amg_666
                                    Das hätte ich gemacht. ich kann aber nicht SPeichern:
                                    Bildschirmfoto 2023-05-12 um 14.50.57.png Bildschirmfoto 2023-05-12 um 14.50.48.png
                                      jwedenig Most Active @jwedenig last edited by
                                      @jwedenig
                                      War ein Browser Problem, funktioniert!!
                                      DankeDir
                                      5277
