    4. [SourceAnalytix 0.4.8-Final] Released !
    • Dutchman
      Dutchman Developer Most Active Administrators @Damrak2022 last edited by
      @damrak2022
      Kommen im log Meldungen wen du SA startest?
      Wen er einem DP nicht verarbeiten kan meldet SA das beim starten
      • Damrak2022
        Damrak2022 @Dutchman last edited by
        @dutchman bin in einer Stunde wieder zuhause. Wie lasse ich mir das Log korrekt anzeigen?
        • Dutchman
          @damrak2022 sagte in [SourceAnalytix 0.4.8-Final] Released !:
          Im Admin links auf Protokolle
          • Damrak2022
            Damrak2022 @Dutchman last edited by Damrak2022
            @dutchman So, hier ist der Log der mir nicht allzuviel sagt, weil ich mich noch zu wenig auskenne.
            host.homebridge
            2022-03-09 08:30:18.372	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            ical.0
            2022-03-09 08:30:16.815	info	Terminated (NO_ERROR): Without reason
            ical.0
            2022-03-09 08:30:10.757	info	processing URL: Marktforschung Andy http://p31-caldav.icloud.com/published/2/MTEwMTMyODc1NzExMDEzMtjBWFA8Rq2ceDMTJ_zYgiMBD9SLY9KKUC4DvOqSramABe1C7Wepvgcyqnos8FOQA2-MOMw7dikJ1LkHvNRVa3Y
            sourceanalytix.0
            2022-03-09 08:30:07.847	info	Successfully activated SourceAnalytix for 3 of 6 states, will do my Job until you stop me!
            sourceanalytix.0
            2022-03-09 08:30:07.847	warn	Cannot handle calculations for 3 of 6 enabled states, check error messages
            sourceanalytix.0
            2022-03-09 08:30:07.834	error	Initialization of sourceanalytix.0.shelly__0__SHPLG-S#EA1400#1__Relay0__Power.currentYear.costs.01_currentDay failed, check warn messages !
            sourceanalytix.0
            2022-03-09 08:30:07.833	error	Cannot handle calculations for sourceanalytix.0.shelly__0__SHPLG-S#EA1400#1__Relay0__Power.currentYear.costs.01_currentDay, check log messages and adjust settings!
            sourceanalytix.0
            2022-03-09 08:30:07.832	error	Please choose unit manually in state configuration
            sourceanalytix.0
            2022-03-09 08:30:07.832	error	No unit defined for sourceanalytix.0.shelly__0__SHPLG-S#EA1400#1__Relay0__Power.currentYear.costs.01_currentDay, cannot execute calculations !
            sourceanalytix.0
            2022-03-09 08:30:07.816	info	Initialising (6 of 6) "sourceanalytix.0.shelly__0__SHPLG-S#EA1400#1__Relay0__Power.currentYear.costs.01_currentDay"
            sourceanalytix.0
            2022-03-09 08:30:07.816	error	Initialization of sourceanalytix.0.shelly__0__SHPLG-S#E423FA#1__Relay0__Power.currentYear.costs.01_currentDay failed, check warn messages !
            sourceanalytix.0
            2022-03-09 08:30:07.815	error	Cannot handle calculations for sourceanalytix.0.shelly__0__SHPLG-S#E423FA#1__Relay0__Power.currentYear.costs.01_currentDay, check log messages and adjust settings!
            sourceanalytix.0
            2022-03-09 08:30:07.814	error	Please choose unit manually in state configuration
            sourceanalytix.0
            2022-03-09 08:30:07.814	error	No unit defined for sourceanalytix.0.shelly__0__SHPLG-S#E423FA#1__Relay0__Power.currentYear.costs.01_currentDay, cannot execute calculations !
            sourceanalytix.0
            2022-03-09 08:30:07.757	info	Initialising (5 of 6) "sourceanalytix.0.shelly__0__SHPLG-S#E423FA#1__Relay0__Power.currentYear.costs.01_currentDay"
            sourceanalytix.0
            2022-03-09 08:30:07.756	error	Initialization of sourceanalytix.0.shelly__0__SHPLG-S#BBA82D#1__Relay0__Power.currentYear.costs.01_currentDay failed, check warn messages !
            sourceanalytix.0
            2022-03-09 08:30:07.754	error	Cannot handle calculations for sourceanalytix.0.shelly__0__SHPLG-S#BBA82D#1__Relay0__Power.currentYear.costs.01_currentDay, check log messages and adjust settings!
            sourceanalytix.0
            2022-03-09 08:30:07.753	error	Please choose unit manually in state configuration
            sourceanalytix.0
            2022-03-09 08:30:07.753	error	No unit defined for sourceanalytix.0.shelly__0__SHPLG-S#BBA82D#1__Relay0__Power.currentYear.costs.01_currentDay, cannot execute calculations !
            sourceanalytix.0
            2022-03-09 08:30:07.742	info	Initialising (4 of 6) "sourceanalytix.0.shelly__0__SHPLG-S#BBA82D#1__Relay0__Power.currentYear.costs.01_currentDay"
            sourceanalytix.0
            2022-03-09 08:30:07.741	info	Initialization of shelly.0.SHPLG-S#EA1400#1.Relay0.Power successfully
            sourceanalytix.0
            2022-03-09 08:30:04.854	info	Initialising (3 of 6) "shelly.0.SHPLG-S#EA1400#1.Relay0.Power"
            sourceanalytix.0
            2022-03-09 08:30:04.853	info	Initialization of shelly.0.SHPLG-S#E423FA#1.Relay0.Power successfully
            ical.0
            2022-03-09 08:30:03.936	info	starting. Version 1.11.6 in /opt/iobroker/node_modules/iobroker.ical, node: v14.19.0, js-controller: 4.0.19
            sourceanalytix.0
            2022-03-09 08:30:01.060	info	Initialising (2 of 6) "shelly.0.SHPLG-S#E423FA#1.Relay0.Power"
            sourceanalytix.0
            2022-03-09 08:30:01.059	info	Initialization of shelly.0.SHPLG-S#BBA82D#1.Relay0.Power successfully
            host.homebridge
            2022-03-09 08:30:00.108	info	instance system.adapter.ical.0 started with pid 184038
            sourceanalytix.0
            2022-03-09 08:29:57.789	info	Initialising (1 of 6) "shelly.0.SHPLG-S#BBA82D#1.Relay0.Power"
            sourceanalytix.0
            2022-03-09 08:29:57.789	info	Found 6 SourceAnalytix enabled states
            sourceanalytix.0
            2022-03-09 08:29:57.571	info	Welcome to SourceAnalytix, making things ready ...
            sourceanalytix.0
            2022-03-09 08:29:57.536	info	starting. Version 0.4.14 (non-npm: DrozmotiX/ioBroker.sourceanalytix#42c45d3e9a581869b0ba9cf710dbecb42ca3e574) in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v14.19.0, js-controller: 4.0.19
            host.homebridge
            2022-03-09 08:29:54.650	info	instance system.adapter.sourceanalytix.0 started with pid 184012
            host.homebridge
            2022-03-09 08:29:52.178	info	instance system.adapter.sourceanalytix.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            sourceanalytix.0
            2022-03-09 08:29:51.471	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            sourceanalytix.0
            2022-03-09 08:29:51.470	info	terminating
            sourceanalytix.0
            2022-03-09 08:29:51.470	info	SourceAnalytix stopped, now you have to calculate by yourself :'( ...
            host.homebridge
            2022-03-09 08:29:51.470	info	stopInstance system.adapter.sourceanalytix.0 send kill signal
            sourceanalytix.0
            2022-03-09 08:29:51.468	info	Got terminate signal TERMINATE_YOURSELF
            host.homebridge
            2022-03-09 08:29:51.461	info	stopInstance system.adapter.sourceanalytix.0 (force=false, process=true)
            host.homebridge
            2022-03-09 08:29:38.246	warn	Requested repository "latest" does not exist in config.
            host.homebridge
            2022-03-09 08:26:52.579	warn	Requested repository "latest" does not exist in config.
            hue-extended.0
            2022-03-09 08:22:49.634	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_max" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:22:49.633	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_min" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:22:49.632	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:22:19.108	info	State value to set for "hue-extended.0.groups.000-all_lights.presence.state.presence_all" has to be type "string" but received type "boolean"
            hue-extended.0
            2022-03-09 08:21:48.785	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_max" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:21:48.782	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_min" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:21:48.781	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:21:48.742	info	State value to set for "hue-extended.0.groups.000-all_lights.presence.state.presence_all" has to be type "string" but received type "boolean"
            hue-extended.0
            2022-03-09 08:21:18.366	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_max" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:21:18.365	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_min" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:21:18.363	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:16:14.770	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_max" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:16:14.768	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_min" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:16:14.725	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:11:11.055	info	State value to set for "hue-extended.0.groups.000-all_lights.action.colormode" has to be type "boolean" but received type "string"
            hue-extended.0
            2022-03-09 08:11:11.051	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_max" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:11:11.051	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_min" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:11:11.048	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:11:10.770	info	State value to set for "hue-extended.0.groups.004-flur.action.colormode" has to be type "boolean" but received type "string"
            hue-extended.0
            2022-03-09 08:11:10.768	info	State value to set for "hue-extended.0.lights.006-deckenlampe.action.colormode" has to be type "boolean" but received type "string"
            hue-extended.0
            2022-03-09 08:07:08.106	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_max" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:07:08.105	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_min" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:07:08.101	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:03:05.001	info	State value to set for "hue-extended.0.groups.000-all_lights.action.colormode" has to be type "boolean" but received type "string"
            hue-extended.0
            2022-03-09 08:03:04.768	info	State value to set for "hue-extended.0.groups.004-flur.action.colormode" has to be type "boolean" but received type "string"
            hue-extended.0
            2022-03-09 08:03:04.766	info	State value to set for "hue-extended.0.lights.006-deckenlampe.action.colormode" has to be type "boolean" but received type "string"
            hue-extended.0
            2022-03-09 08:02:04.186	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_max" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:02:04.184	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_min" has to be type "string" but received type "number"
            hue-extended.0
            2022-03-09 08:02:04.140	info	State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel" has to be type "string" but received type "number"
            host.homebridge
            2022-03-09 08:00:16.671	info	instance system.adapter.ical.0 terminated with
              crunchip Forum Testing Most Active last edited by crunchip
              laut log hast du keine Unit definiert, damit ist nicht die Grundeinstellung gemeint, sondern bei deinem jeweiligen Gerät/Datenpunkt rechts auf das Zahnrad.
              warum in den Einstellungen von SA unter Preis pro Monat die Zahl 15 eingetragen ist.
              das sind vor eingestellte Werte, die du deinem Strompreis entsprechend anpassen musst
              • Dutchman
                "Please choose unit manually in state configuration"
                unit selektieren beim state....
                • Damrak2022
                  @dutchman Ich hatte die Einstellung auf "automatisch" stehen. Habe es jetzt mal auf "kWh" umgestellt.
                  Allerdings war das eine Gerät, welches Daten liefert auch auch"automatisch" eingestellt und trotzdem wurden Daten erfasst.
                  Bildschirmfoto 2022-03-10 um 01.07.49.png Bildschirmfoto 2022-03-10 um 01.05.10.png
                  • Damrak2022
                    @dutchman Hier nochmal ein Log
                    sourceanalytix.0
                    2022-03-10 04:49:45.428	info	Successfully activated SourceAnalytix for 6 of 6 states, will do my Job until you stop me!
                    sourceanalytix.0
                    2022-03-10 04:49:45.415	info	Initialization of sourceanalytix.0.shelly__0__SHPLG-S#EA1400#1__Relay0__Power.currentYear.costs.01_currentDay successfully
                    sourceanalytix.0
                    2022-03-10 04:49:43.719	info	Initialising (6 of 6) "sourceanalytix.0.shelly__0__SHPLG-S#EA1400#1__Relay0__Power.currentYear.costs.01_currentDay"
                    sourceanalytix.0
                    2022-03-10 04:49:43.718	info	Initialization of sourceanalytix.0.shelly__0__SHPLG-S#E423FA#1__Relay0__Power.currentYear.costs.01_currentDay successfully
                    sourceanalytix.0
                    2022-03-10 04:49:42.017	info	Initialising (5 of 6) "sourceanalytix.0.shelly__0__SHPLG-S#E423FA#1__Relay0__Power.currentYear.costs.01_currentDay"
                    sourceanalytix.0
                    2022-03-10 04:49:42.016	info	Initialization of sourceanalytix.0.shelly__0__SHPLG-S#BBA82D#1__Relay0__Power.currentYear.costs.01_currentDay successfully
                    sourceanalytix.0
                    2022-03-10 04:49:40.465	info	Initialising (4 of 6) "sourceanalytix.0.shelly__0__SHPLG-S#BBA82D#1__Relay0__Power.currentYear.costs.01_currentDay"
                    sourceanalytix.0
                    2022-03-10 04:49:40.464	info	Initialization of shelly.0.SHPLG-S#EA1400#1.Relay0.Power successfully
                    sourceanalytix.0
                    2022-03-10 04:49:38.645	info	Initialising (3 of 6) "shelly.0.SHPLG-S#EA1400#1.Relay0.Power"
                    sourceanalytix.0
                    2022-03-10 04:49:38.644	info	Initialization of shelly.0.SHPLG-S#E423FA#1.Relay0.Power successfully
                    sourceanalytix.0
                    2022-03-10 04:49:36.254	info	Initialising (2 of 6) "shelly.0.SHPLG-S#E423FA#1.Relay0.Power"
                    sourceanalytix.0
                    2022-03-10 04:49:36.253	info	Initialization of shelly.0.SHPLG-S#BBA82D#1.Relay0.Power successfully
                    sourceanalytix.0
                    2022-03-10 04:49:33.526	info	Initialising (1 of 6) "shelly.0.SHPLG-S#BBA82D#1.Relay0.Power"
                    sourceanalytix.0
                    2022-03-10 04:49:33.525	info	Found 6 SourceAnalytix enabled states
                    sourceanalytix.0
                    2022-03-10 04:49:33.382	info	Welcome to SourceAnalytix, making things ready ...
                    sourceanalytix.0
                    2022-03-10 04:49:33.347	info	starting. Version 0.4.14 (non-npm: DrozmotiX/ioBroker.sourceanalytix#42c45d3e9a581869b0ba9cf710dbecb42ca3e574) in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v14.19.0, js-controller: 4.0.19
                    host.homebridge
                    2022-03-10 04:49:30.525	info	instance system.adapter.sourceanalytix.0 started with pid 215751
                    admin.0
                    2022-03-10 04:49:30.096	info	Adapter rating updated
                    Trotzdem bleiben die zwei anderen Shellys ohne Wert
                      crunchip Forum Testing Most Active @Damrak2022 last edited by
                      @damrak2022 hast du die, welche falsch konfiguriert waren vorher gelöscht, bei gestoppter Instanz, oder einfach nur die unit umgestellt?
                      • Damrak2022
                        Damrak2022 @crunchip last edited by
                        @crunchip Nein, nur umgestellt, aber ich kann das nachher mal so machen. Melde mich dann.
                        • Dutchman
                          Dutchman Developer Most Active Administrators @Damrak2022 last edited by Dutchman
                          und welchen Datenpunkt vom Shelly logs du ist das ein watt oder kWh wert?
                          • Damrak2022
                            @dutchman Ich logge wohl Watt. Hier ist ein Screenshot von dem Adapter, welcher von Anfang an direkt funktioniert hat.
                            Deswegen verstehe ich nicht warum ich mit den beiden anderen so massive Probleme habe.
                            • Dutchman
                              @dutchman Ich logge wohl Watt. Hier ist ein Screenshot, welcher von Anfang an direkt funktioniert hat.
                              du loggst watt und stellst als unit kWh ein, das kan ja nicht funktionieren 🙂
                              Nimmt bitte energy anstatt watt, Wh nach kWh ist genauer als watt nach kWh berechnen
                              • Damrak2022
                                @dutchman Ja, aber der erste steht auf automatisch und funktioniert. Aber ich stelle es trotzdem mal um
                                • Dutchman
                                  und von dem logst du auch power oder energy ? Wie bereits erwähnt besser de Wh wert nehmen 🙂
                                  • Damrak2022
                                    @dutchman Okay, ich versuche es
                                    Damrak2022 1 Reply Last reply Reply Quote 1
                                    • Damrak2022
                                      Damrak2022 @Damrak2022 last edited by
                                      @damrak2022 So allmählich verzweifele ich.
                                      Ich habe eben den SA Adapter runtergeschmissen, nachdem ich ihn gestoppt habe und dann neu installiert. Als Datenpunkt habe ich Energy genommen und als Einstellung wh
                                      Jetzt zeigt er mir auf einmal diesen Preis an:
                                      Woher kommt der denn nun?
                                      Die beiden anderen Datenpunkte von den beiden anderen Shellys zeigen mir folgendes an, obwohl ich den Ventilator die ganze Zeit schon laufen habe.
                                      Ich sehe aber gerade das im Log lauter Fehler sind
                                      [calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903112945,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903112945} | stateDetails {"alias":"Shelly-Drucker","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#EA1400#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Drucker","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                                      sourceanalytix.0
                                      2022-03-10 10:05:04.929	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903104917,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903104917} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                                      sourceanalytix.0
                                      2022-03-10 10:05:02.922	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903102909,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903102909} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                                      sourceanalytix.0
                                      2022-03-10 10:04:57.934	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903097925,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903097925} | stateDetails {"alias":"Shelly-Drucker","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#EA1400#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Drucker","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                                      sourceanalytix.0
                                      2022-03-10 10:04:49.002	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903088989,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903088989} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                                      sourceanalytix.0
                                      2022-03-10 10:04:42.931	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903082925,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903082925} | stateDetails {"alias":"Shelly-Drucker","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#EA1400#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Drucker","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                                      sourceanalytix.0
                                      2022-03-10 10:04:33.993	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903073985,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903073985} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                                      sourceanalytix.0
                                      2022-03-10 10:04:27.926	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903067920,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903067920} | stateDetails {"alias":"Shelly-Drucker","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#EA1400#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Drucker","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                                      sourceanalytix.0
                                      2022-03-10 10:04:18.987	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903058976,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903058976} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                                      sourceanalytix.0
                                      2022-03-10 10:04:12.921	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903052913,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903052913} | stateDetails {"alias":"Shelly-Drucker","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#EA1400#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Drucker","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                                      sourceanalytix.0
                                      2022-03-10 10:04:03.977	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903043968,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903043968} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                                      sourceanalytix.0
                                      2022-03-10 10:03:57.905	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903037899,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903037899} | stateDetails {"alias":"Shelly-Drucker","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#EA1400#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Drucker","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                                      sourceanalytix.0
                                      2022-03-10 10:03:49.015	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903029009,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903029009} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                                      Was bedeuten die genau?
                                      • Dutchman
                                        wen du keine start werte eingetragen hast, berechnet er halt mit den jetzigen wh wert
                                          liv-in-sky @Dutchman last edited by liv-in-sky
                                          @dutchman
                                          mal ne frage
                                          ich habe einen dp, der alle watt (power) dp der sonoff pows addiert - wert ung. 543W
                                          dann habe ich sourceanalytics auf diesen Watt-Wert
                                          definiert
                                          das führt zu diesen werten:
                                          das jkann aber nicht stimmen - das sind im jahr 1.277,5 €uro
                                          der verbrauch ist schon nicht wirklich richtig:
                                          was mach ich da falsch bzw was verstehe ich nicht
                                          das hier wird via internet berechnet - pro tag ist der wert
                                          crunchip BananaJoe 2 Replies Last reply Reply Quote 0
                                            crunchip Forum Testing Most Active @liv-in-sky last edited by
                                            @liv-in-sky sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                            könnte mir vorstellen, das durch das addieren ein Berechnungsfehler entsteht, da der Wattverbrauch ja nur eine Moment Anzeige ist, die Daten werden ja (default) alle 15 sec übermittelt.
                                            2302
                                            1130853
