    4. [SourceAnalytix 0.4.8-Final] Released !
    • Damrak2022
      Damrak2022 @Dutchman last edited by
      @dutchman Hier nochmal ein Log
      sourceanalytix.0
      2022-03-10 04:49:45.428	info	Successfully activated SourceAnalytix for 6 of 6 states, will do my Job until you stop me!
      sourceanalytix.0
      2022-03-10 04:49:45.415	info	Initialization of sourceanalytix.0.shelly__0__SHPLG-S#EA1400#1__Relay0__Power.currentYear.costs.01_currentDay successfully
      sourceanalytix.0
      2022-03-10 04:49:43.719	info	Initialising (6 of 6) "sourceanalytix.0.shelly__0__SHPLG-S#EA1400#1__Relay0__Power.currentYear.costs.01_currentDay"
      sourceanalytix.0
      2022-03-10 04:49:43.718	info	Initialization of sourceanalytix.0.shelly__0__SHPLG-S#E423FA#1__Relay0__Power.currentYear.costs.01_currentDay successfully
      sourceanalytix.0
      2022-03-10 04:49:42.017	info	Initialising (5 of 6) "sourceanalytix.0.shelly__0__SHPLG-S#E423FA#1__Relay0__Power.currentYear.costs.01_currentDay"
      sourceanalytix.0
      2022-03-10 04:49:42.016	info	Initialization of sourceanalytix.0.shelly__0__SHPLG-S#BBA82D#1__Relay0__Power.currentYear.costs.01_currentDay successfully
      sourceanalytix.0
      2022-03-10 04:49:40.465	info	Initialising (4 of 6) "sourceanalytix.0.shelly__0__SHPLG-S#BBA82D#1__Relay0__Power.currentYear.costs.01_currentDay"
      sourceanalytix.0
      2022-03-10 04:49:40.464	info	Initialization of shelly.0.SHPLG-S#EA1400#1.Relay0.Power successfully
      sourceanalytix.0
      2022-03-10 04:49:38.645	info	Initialising (3 of 6) "shelly.0.SHPLG-S#EA1400#1.Relay0.Power"
      sourceanalytix.0
      2022-03-10 04:49:38.644	info	Initialization of shelly.0.SHPLG-S#E423FA#1.Relay0.Power successfully
      sourceanalytix.0
      2022-03-10 04:49:36.254	info	Initialising (2 of 6) "shelly.0.SHPLG-S#E423FA#1.Relay0.Power"
      sourceanalytix.0
      2022-03-10 04:49:36.253	info	Initialization of shelly.0.SHPLG-S#BBA82D#1.Relay0.Power successfully
      sourceanalytix.0
      2022-03-10 04:49:33.526	info	Initialising (1 of 6) "shelly.0.SHPLG-S#BBA82D#1.Relay0.Power"
      sourceanalytix.0
      2022-03-10 04:49:33.525	info	Found 6 SourceAnalytix enabled states
      sourceanalytix.0
      2022-03-10 04:49:33.382	info	Welcome to SourceAnalytix, making things ready ...
      sourceanalytix.0
      2022-03-10 04:49:33.347	info	starting. Version 0.4.14 (non-npm: DrozmotiX/ioBroker.sourceanalytix#42c45d3e9a581869b0ba9cf710dbecb42ca3e574) in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v14.19.0, js-controller: 4.0.19
      host.homebridge
      2022-03-10 04:49:30.525	info	instance system.adapter.sourceanalytix.0 started with pid 215751
      admin.0
      2022-03-10 04:49:30.096	info	Adapter rating updated
      Trotzdem bleiben die zwei anderen Shellys ohne Wert
        crunchip Forum Testing Most Active @Damrak2022 last edited by
        @damrak2022 hast du die, welche falsch konfiguriert waren vorher gelöscht, bei gestoppter Instanz, oder einfach nur die unit umgestellt?
        • Damrak2022
          Damrak2022 @crunchip last edited by
          @crunchip Nein, nur umgestellt, aber ich kann das nachher mal so machen. Melde mich dann.
          • Dutchman
            Dutchman Developer Most Active Administrators @Damrak2022 last edited by Dutchman
            @damrak2022 sagte in [SourceAnalytix 0.4.8-Final] Released !:
            und welchen Datenpunkt vom Shelly logs du ist das ein watt oder kWh wert?
            • Damrak2022
              Damrak2022 @Dutchman last edited by Damrak2022
              @dutchman Ich logge wohl Watt. Hier ist ein Screenshot von dem Adapter, welcher von Anfang an direkt funktioniert hat.
              Deswegen verstehe ich nicht warum ich mit den beiden anderen so massive Probleme habe.
              • Dutchman
                @dutchman Ich logge wohl Watt. Hier ist ein Screenshot, welcher von Anfang an direkt funktioniert hat.
                du loggst watt und stellst als unit kWh ein, das kan ja nicht funktionieren 🙂
                Nimmt bitte energy anstatt watt, Wh nach kWh ist genauer als watt nach kWh berechnen
                • Damrak2022
                  @dutchman Ja, aber der erste steht auf automatisch und funktioniert. Aber ich stelle es trotzdem mal um
                  • Dutchman
                    und von dem logst du auch power oder energy ? Wie bereits erwähnt besser de Wh wert nehmen 🙂
                    • Damrak2022
                      @dutchman Okay, ich versuche es
                      Damrak2022 1 Reply Last reply Reply Quote 1
                      • Damrak2022
                        Damrak2022 @Damrak2022 last edited by
                        @damrak2022 So allmählich verzweifele ich.
                        Ich habe eben den SA Adapter runtergeschmissen, nachdem ich ihn gestoppt habe und dann neu installiert. Als Datenpunkt habe ich Energy genommen und als Einstellung wh
                        Jetzt zeigt er mir auf einmal diesen Preis an:
                        Woher kommt der denn nun?
                        Die beiden anderen Datenpunkte von den beiden anderen Shellys zeigen mir folgendes an, obwohl ich den Ventilator die ganze Zeit schon laufen habe.
                        Ich sehe aber gerade das im Log lauter Fehler sind
                        [calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903112945,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903112945} | stateDetails {"alias":"Shelly-Drucker","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#EA1400#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Drucker","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                        sourceanalytix.0
                        2022-03-10 10:05:04.929	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903104917,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903104917} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                        sourceanalytix.0
                        2022-03-10 10:05:02.922	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903102909,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903102909} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                        sourceanalytix.0
                        2022-03-10 10:04:57.934	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903097925,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903097925} | stateDetails {"alias":"Shelly-Drucker","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#EA1400#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Drucker","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                        sourceanalytix.0
                        2022-03-10 10:04:49.002	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903088989,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903088989} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                        sourceanalytix.0
                        2022-03-10 10:04:42.931	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903082925,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903082925} | stateDetails {"alias":"Shelly-Drucker","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#EA1400#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Drucker","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                        sourceanalytix.0
                        2022-03-10 10:04:33.993	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903073985,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903073985} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                        sourceanalytix.0
                        2022-03-10 10:04:27.926	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903067920,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903067920} | stateDetails {"alias":"Shelly-Drucker","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#EA1400#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Drucker","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                        sourceanalytix.0
                        2022-03-10 10:04:18.987	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903058976,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903058976} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                        sourceanalytix.0
                        2022-03-10 10:04:12.921	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903052913,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903052913} | stateDetails {"alias":"Shelly-Drucker","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#EA1400#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Drucker","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                        sourceanalytix.0
                        2022-03-10 10:04:03.977	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903043968,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903043968} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                        sourceanalytix.0
                        2022-03-10 10:03:57.905	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903037899,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903037899} | stateDetails {"alias":"Shelly-Drucker","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#EA1400#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Drucker","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                        sourceanalytix.0
                        2022-03-10 10:03:49.015	error	[calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":true,"ts":1646903029009,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1646903029009} | stateDetails {"alias":"Shelly-Ventilator","consumption":true,"costs":true,"deviceName":"shelly__0__SHPLG-S#E423FA#1__Relay0__Energy","financialCategory":"costs","headCategory":"consumed","name":"Shelly-Ventilator","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1}
                        Was bedeuten die genau?
                        • Dutchman
                          wen du keine start werte eingetragen hast, berechnet er halt mit den jetzigen wh wert
                            liv-in-sky @Dutchman last edited by liv-in-sky
                            @dutchman
                            mal ne frage
                            ich habe einen dp, der alle watt (power) dp der sonoff pows addiert - wert ung. 543W
                            dann habe ich sourceanalytics auf diesen Watt-Wert
                            definiert
                            das führt zu diesen werten:
                            das jkann aber nicht stimmen - das sind im jahr 1.277,5 €uro
                            der verbrauch ist schon nicht wirklich richtig:
                            was mach ich da falsch bzw was verstehe ich nicht
                            das hier wird via internet berechnet - pro tag ist der wert
                            crunchip BananaJoe 2 Replies Last reply Reply Quote 0
                              crunchip Forum Testing Most Active @liv-in-sky last edited by
                              @liv-in-sky sagte in [SourceAnalytix 0.4.8-Final] Released !:
                              könnte mir vorstellen, das durch das addieren ein Berechnungsfehler entsteht, da der Wattverbrauch ja nur eine Moment Anzeige ist, die Daten werden ja (default) alle 15 sec übermittelt.
                              • BananaJoe
                                BananaJoe Most Active @liv-in-sky last edited by BananaJoe
                                @liv-in-sky du vergleichst Äpfel und Birnen. Die Watt-Zahl ist ja nur der aktuelle Verbrauch. Eine kWh ist aber Leistung über die Zeit. Du müsstest für eine Kostenberechnung also nicht die aktuelle Watt-Zahl nehmen sondern eine Verbrauchszahl:
                                Hier eine Tasmota-Steckdose mit Verbrauchsmessung:
                                Zur Berechnung von Kosten taugen nur die letzten 3.
                                Aus der Leistung den Verbrauch zu ermitteln ... pfft müsstest du die Durchschnittsleistung von 1 Stunde nehmen, so genau wie möglich. Das wäre dann etwa die Leistung in Wh oder kWh
                                  @crunchip
                                  was meinst du mit default 15 sek - das der sourceanalytics alle 15 sec liest ? dann sollte aber eine richtige rechnung kommen.
                                  hier ein bild meines alten scriptes - dort sieht man bei den Now werten auch das richtige - es solte doch egal sein, anstatt einzelne wird halt nur ein wert abgefragt und berechnet
                                  wenn du die preise zusammenaddierst von heit, kommt ungefähr der wertraus, denn ich im internet ermittelt habe - ich werde mal sourceanalytics auf nur einen wert einstellen und nicht die summe aller werte - mal sehen, was dann kommt
                                    liv-in-sky @BananaJoe last edited by liv-in-sky
                                    @bananajoe
                                    aber wenn ich doch W angeben kann in den sourceanalytics einstellungen, sollte das doch berechnet werden - das macht mein script auch - ich nehme die watt und berechne die kwh für die minute - das wird minütlich zusammenaddiert, bis es eine stunde wird
                                    das macht der adapter wohl nicht - aber warum gibt es dann die W einstellung ? wann nutzt man die
                                    energie gesamt : ist ja überhaupt nicht richtig zum verstehen (wenn man seine energiebilanz richtig darstellen will , um evtl etwas einzusparen) - was soll ich mit einer berechnung, die mir anzeigt, was über das gerät gelaufen ist, wenn doch der bezug der tag ist, an dem ich es zum erstenmal eingeschalten habe
                                    die energie heute: was macht der adapter mit dieser zahl - das ist doch von heute 0:00 uhr bis jetzt - also nimmt er das und multipliziert mit dem strompreis - das ist dann wohl der richtige wert zur berechnung - täglich aufgenommen und dann gespeichert um die wochen, monatsübersichten zu generieren - oder ?
                                      @bananajoe
                                      @crunchip
                                      was mich noch verwirrt - ElectricityDay kann ich nur mit einheit kW eingeben - der dp von sonoff ist aber kwh
                                      also muus ich da kw eingeben und den sonoff energy_today (der kwh hat ) als dp auswählen)
                                      ist das dann so richtig ?
                                      BananaJoe crunchip 2 Replies Last reply Reply Quote 0
                                      • BananaJoe
                                        @liv-in-sky also ich kann bei mir auch kWh auswählen .. wobei ich meine eigenen Preisdefinitionen angelegt habe.
                                        Und keine Ahnung ob man das nachträglich ändern kann
                                          nein wann tasmota übermittelt, bzw was du unter (teleperiod) eingestellt hast,
                                          war falsch mit 15 sec default, 300 sec sind default, max runter kann man auf 10 sec
                                          Abstand wann Telemetry an den Server Daten gesendet werden (10 bis 32000, 0 = aus)
                                          das wird wahrscheinlich eher funktionieren aber wie gesagt, watt ist nur ein "Schätzwert"
                                          daher ist es sinnvoll kwh zu nehmen, was der sonoff ja von Haus aus mitbringt
                                          wenn du zusammenfassend auf einen DP sourceanalytics ansetzt, müsstest du per Script nicht die Watt addieren, sondern sonoff.0.deingerät.ENERGY_Total
                                            @bananajoe
                                            @crunchip
                                            habe mal das neuste von git installiert - ich kann auch kwh auswählen, was ich gemacht habe - alle dp gelöscht und adapter neugestartet -
                                            browser cache hatte auch seine probleme - habe mein sammelscript (alle energy_todays aller pows) auch umgestellt
                                            jetzt sehen die daten auch besser aus - aber das mit der W einstellung würde mich auch noch interessieren
                                            lasse das mal bis morgen laufen und checke die zahlen nochmal
                                            danke euch - jetzt sieht es besser aus
                                            2302
                                            1130995
