    4. Test Adapter sureflap v3.4.0
      Thomas Braun Most Active last edited by Thomas Braun
      @matis
      Der Adapter liegt im Beta-Repo vor.
      pi@chet:~ $ iobroker add sureflap
      NPM version: 8.1.4
      npm install iobroker.sureflap@1.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
      host.chet install adapter sureflap
      upload [5] sureflap.admin /opt/iobroker/node_modules/iobroker.sureflap/admin/words.js words.js application/javascript
      upload [4] sureflap.admin /opt/iobroker/node_modules/iobroker.sureflap/admin/sureflap.png sureflap.png image/png
      upload [3] sureflap.admin /opt/iobroker/node_modules/iobroker.sureflap/admin/style.css style.css text/css
      upload [2] sureflap.admin /opt/iobroker/node_modules/iobroker.sureflap/admin/index_m.html index_m.html text/html
      upload [1] sureflap.admin /opt/iobroker/node_modules/iobroker.sureflap/admin/admin.d.ts admin.d.ts video/mp2t
      upload [0] sureflap.admin /opt/iobroker/node_modules/iobroker.sureflap/admin/SureFlap_Pet_Door_Connect_Hub_Phone.png SureFlap_Pet_Door_Connect_Hub_Phone.png image/png
      host.chet object system.adapter.sureflap created/updated
      host.chet create instance sureflap
      host.chet object sureflap.0.info.last_update created
      host.chet object sureflap.0.info.all_devices_online created
      host.chet object sureflap.0.info.connection created
      host.chet object sureflap.0.info created
      host.chet object system.adapter.sureflap.0.logLevel created
      host.chet object system.adapter.sureflap.0.sigKill created
      host.chet object system.adapter.sureflap.0.eventLoopLag created
      host.chet object system.adapter.sureflap.0.outputCount createdhost.chet object system.adapter.sureflap.0.inputCount created
      host.chet object system.adapter.sureflap.0.uptime created
      host.chet object system.adapter.sureflap.0.memRss created
      host.chet object system.adapter.sureflap.0.memHeapTotal created
      host.chet object system.adapter.sureflap.0.memHeapUsed createdhost.chet object system.adapter.sureflap.0.cputime created
      host.chet object system.adapter.sureflap.0.cpu created
      host.chet object system.adapter.sureflap.0.compactMode createdhost.chet object system.adapter.sureflap.0.connected created
      host.chet object system.adapter.sureflap.0.alive created
      host.chet Set default value of sureflap.0.info.last_update: false
      host.chet Set default value of sureflap.0.info.all_devices_online: false
      host.chet Set default value of sureflap.0.info.connection: false
      host.chet object system.adapter.sureflap.0 created
      pi@chet:~ $
      Ergo:
      pi@chet:~ $ iobroker list adapters | grep sureflap
      system.adapter.sureflap                : sureflap       - v1.0.8
      pi@chet:~ $
      Ganz ohne git.
        Matis @Thomas Braun last edited by
        @thomas-braun ... habs auf Beta umgestellt, dann ist das in der Tat einfacher, merci.
        • Sickboy78
          Sickboy78 @Matis last edited by
          @matis Pull Request für die Aufnahme ins Stable Repository ist schon gestellt und wartet aufs Review: https://github.com/ioBroker/ioBroker.repositories/pull/1479
          Sickboy78 created this issue in ioBroker/ioBroker.repositories
          closed add sureflap:1.0.5 to stable #1479
          Sickboy78 1 Reply Last reply Reply Quote 0
          • Sickboy78
            Sickboy78 @Sickboy78 last edited by Sickboy78
            Version 1.1.0 is officially in the stable repository!
            It contains a bugfix for remaining food in feeder not updating, some dependency security updates and some minor code improvements.
              Matt77CHE @Sickboy78 last edited by
              @sickboy78
              Hallo;
              Ich habe - gefühlt seit dem letzten App-Update - im Log den Eintrag "undefined is not a valid state value for id "sureflap.0.Home.Home_Cat_Hub.Buero_neu.assigned_pets.Charlie.control.type""
              Habe auf Github einen Eintag (#18) gemacht.
              Habt Ihr seit dem Update (App) auch immer wieder Verbindungsprobleme zum Konto?
              Wie kann man eigentlich den Hub updaten? - Falls es denn je einmal ein update gibt - die stehen ja in diesem Bereich so ziemlich aufm Schlauch bei denen....
              Gruss
              Matt
              • Sickboy78
                Sickboy78 @Matt77CHE last edited by
                Hallo @matt77che ,
                wie auf github erwähnt, kam der Eintrag im Log daher, dass ich die Funktion, ein Tier als Wohnungstier oder Freigänger zu setzen, in Version 1.0.6 ergänzt hatte. Allerdings ist erst später aufgefallen, dass das nur von der Katzenklappe, aber nicht von der Haustierklappe unterstützt wird. Daher kam bei Haustierklappen diese Fehlermeldung.
                Ich hab das in Version 1.1.1 korrigiert und die Funktion für Haustierklappen wieder entfernt.
                Meinst du mit App die Smartphone App oder den Adapter? Wie äußern sich die Verbindungsprobleme?
                Ich glaube, der Hub updated sich selbstständig, zumindest finde ich im Handbuch nur folgende Info dazu:
                "Beide Ohren leuchten durchgehend rot: Die Firmware Ihres Hubs wird gerade aktualisiert. Haben Sie etwas Geduld. Ihr Hub wird in Kürze neu gestartet und funktioniert dann wie gewohnt." Beobachtet habe ich es allerdings noch nicht ...
                VG
                Sebastian
                  Das War die App - die hatten wieder einmal Probleme mit den Servern. - Hatte sich aber auch auf den Adapter ausgewirkt..
                    Matt77CHE last edited by Matt77CHE
                    Ich habe ein kniffliges Problem:
                    Topographisch bedingt musste ich einen zweiten Hub bei mir Zuhause zulegen (um dort dann den Felaqua zu verbinden).
                    Meines Wissens ist es nicht möglich in einem Haushalt mehr als einen Hub zu haben (richtig?).
                    Also habe ich unter einer anderen Emailadresse ein weiteres Home (Home 2) erstellt, dort den Hub hinzugefügt, den Felaqua damit verbunden und nun im Ersten Home das Zweite hinzugefügt. (man kann ja auch nicht 2 mal die selbe App auf dem Smartphone haben..)
                    Im Home 2 musste ich natürlich alle Katzen auch hinzufügen (die Selben wie im Home).
                    Wenn ich nun im iobroker den Adapter öffne (die Instanz), werden mir die Katzen nun doppelt angezeigt (Fotos) (von Home und Home 2). - Das leuchtet mir noch ein.
                    Unter den Objekten wird nun auch Home 2 mit dem Hub 2 aufgeführt, inkl. den Katzen.
                    ABER: unter Home werden die Datenpunkte unter pets / Katzenname / inside & since nicht mehr aktualisiert......
                    Ich habe mal den Adapter auf debug gestellt und das Log angehängt: (höllisch viel)
                    Sureflap.txt
                    Wenn der Sureflap Adapter den Felaqua unterstützen würde, könnte ich das zusammenführen der beiden Haushalte weglassen, da ich dann ja 2 Adapter im iobroker installieren könnte (1 x Home mit Klappe; 1 x Home 2 mit Felaqua) und mir das Ganze in der Vis anzeigen lassen.... 😬
                    Gibt es eine Erklärung, wieso die Datenpunkte nicht aktualisiert werden?
                    Ist dies ein bis anhin unbekannter Bug (noch keiner 2 Haushalte Verknüpft)?
                    Gibt es eine Möglichkeit 2 Hubs in einem Haushalt zu betreiben?
                    Kann dies im Adapter behoben werden?
                    andere Lösungsvorschläge?
                    • Als kurzfristige Übergangslösung werde ich jetzt mal das Home 2 im Home 1 löschen und mit einem Tablet arbeiten welches nur das Home 2 bedient (nebst dem Smatphone mit Home 1).
                    • Sickboy78
                      Hallo @matt77che ,
                      ich hab versucht den Adapter so universell wie möglich zu programmieren und auch theoretisch auf mehrere Haushalte vorbereitet. Praktisch konnte ich allerdings nur raten, wie die Datenstrukturen bei mehreren Haushalten aussehen.
                      Das es generell funktioniert, ist schonmal gut. Warum es bei den Pets hapert, müsste ich mir genauer anschauen.
                      Dazu bräuchte ich mal die vom Aufruf https://app.api.surehub.io/api/me/start zurückgelieferte Datenstruktur.
                      Wie man diese mittels des Browsers und der Entwicklerkonsole bekommt, hab ich hier im 2. Kommentar beschrieben: https://github.com/Sickboy78/ioBroker.sureflap/issues/22
                      Wäre super, wenn du mir die komplett als Text zukommen lassen könntest. (Private Daten wie Email etc. kannst du gerne rauslöschen)
                      VG
                      Sebastian
                      Strobelix80 created this issue in Sickboy78/ioBroker.sureflap
                      closed Error setting states with js controller 4.0.12 #22
                        @sickboy78
                        Ok, werde ich dir liefern - dauert aber leider mind. 3 Wochen, da ich selber in dieser Zeit keinen Zugang zum Tablet mit dem Home 2 habe (bin abwesend).....
                        • Sickboy78
                          Version 1.1.4 unterstützt jetzt auch den Felaqua Wasserspender.
                          Ähnlich wie beim Futterautomat wird die verbleibende Menge Wasser in ml angezeigt und beim Tier wie oft und wieviel heute getrunken wurde.
                          Sickboy78 1 Reply Last reply Reply Quote 2
                          • Sickboy78
                            Noch ein kleines Update hinterher.
                            Version 1.1.5 zeigt jetzt die Seriennummern des Hub und der Geräte an.
                              berryforhome last edited by
                              Hallo @Sickboy78
                              vielen Dank für den Adapter, ich habe zwei Mietzen und beide lassen sich damit sozusagen steuern; hier eine kleine Seite, die auf kleines Display passt, was immer auf dem Schreibtisch steht und an ist.
                              Der Zugriff über den Adapter / VIS ist um Welten besser als per App von Sureflap .. da habe ich immer ohne Ende gesucht, wenn ich
                              die Klappe sperren wollte z.B. wenn mal wieder einer der Mietzen mit einer Maus in Richtung Klappe untwerwegs ist.
                              Jetzt gibt es einfach einen schnellen Mausalarm-Schalter !
                              Und IOBroker sendet mir eine Pushover-Nachricht, wenn die Batterie zur Neige geht .. etwas, was ich immer in der App übersehe
                              Z 1 Reply Last reply Reply Quote 1
                              • Z
                                zariomahn last edited by
                                Hallo @Sickboy78
                                bin begeistert von deiner Arbeit und habe auch schon so manches umgesetzt.
                                Leider bekomme ich seit ein paar Tagen eine Fehlermeldung 😞
                                Die Instant zeigt aber:
                                Was stimmt jetzt 🙂 , Benutzer und Passwort sind die selben wie in der App...
                                Dann noch eine Frage, auf Github existiert eine Version 1.1.6, im Iobroker aber noch nicht..
                                viele Grüße
                                und Danke für deine Arbeit
                                MZ
                                • Z
                                  zariomahn @berryforhome last edited by
                                  @berryforhome sagte in Test Adapter sureflap v1.0.x GitHub:
                                  Hallo @Sickboy78
                                  Hallo @berryforhome
                                  ich arbeite ebenfalls mit VIS und Blockly, stehe auch vor dem Problem mit den Mäusen 🙂
                                  Meinst Du könntest mir das Skript zukommen lassen, wäre super nett 😉
                                  liebe Grüße
                                  Mario
                                  • Z
                                    zariomahn @zariomahn last edited by
                                    @berryforhome
                                    Hi, habe es nun geschafft den Adapter so zu benutzen dass ich die Klappe steuern kann .
                                    Was ich noch nicht herausgefunden habe, wie kann ich einzelne Katzen zum Hausarrest verdonnern 🙂
                                    viele Grüße
                                    Mario
                                    • Sickboy78
                                      Sickboy78 @zariomahn last edited by
                                      Hallo @zariomahn,
                                      da war noch ein Bug drin, wenn kein Foto für das Tier hinterlegt war.
                                      Die Fehlermeldung war irreführend, Adapter sollte aber trotzdem funktioniert haben.
                                      Ist in Version 1.1.7 korrigiert.
                                      ioBroker bietet dir standardmäßig die aktuelle stable Version (1.1.5) an.
                                      Du kannst aber in den Systemeinstellungen – Repositories auf Beta (latest) wechseln – auf eigene Gefahr. Dann bekommst du immer die neuesten, aber evtl. noch nicht ausgereiften Versionen angeboten. Wenn ich eine neue Version erstelle, lasse ich sie immer erst ein paar Wochen bei mir laufen, bevor ich sie zu stable hinzufüge, um halbwegs sicher zugehen, dass ich nichts verschlimmbessert hab.
                                      Alternativ kannst du im Adapter Menu auch in den Experten-Modus wechseln, dann erscheint ein neuer Button „Installieren aus eigener URL“. Dort kannst du über Auswahl oder Benutzerdefiniert und URL (z.B. https://github.com/Sickboy78/ioBroker.sureflap/) auch direkt einen Adapter aktualisieren.
                                      VG
                                      • Sickboy78
                                        Hallo @zariomahn,
                                        Das geht leider nur mit der Katzenklappe. Die größere Haustierklappe hat das Feature leider nicht.
                                        Wenn deine Klappe es unterstützt, dann findest du bei Objekte unterhalb der Klappe assigned_pets dann dein Tier und dann control und type. Den type kannst du von OUTDOOR PET auf INDOOR PET ändern.
                                        VG
                                        • M-A Hueb
                                          M-A Hueb last edited by M-A Hueb
                                          Guten Morgen,
                                          seit gestern Mittag 15:51 Uhr funktioniert der Adaptert nicht mehr.
                                          Adapter steht auf Logstufe Debug. Das steht im Log. Logindaten habe ich verifiziert. Das passt, es werden die Katzen aufgelistet.
                                          Wenn man in die Sureflap-App schaut passt alles.
                                          An was kann das liegen?
                                          S Sickboy78 2 Replies Last reply Reply Quote 1
                                            Strobelix @M-A Hueb last edited by Strobelix
                                            @m-a-hueb kann ich bestätigen! Liegt aber nicht wirklich am Adapter, denn ich bekomme die Fehlermeldung auch, wenn ich per javascript eine API Abfrage mache unter iobroker.
                                            Allerdings kann ich von einem anderen Gerät mit api call zugreifen. Ich vermute, dass iobroker geblockt wird!?
                                            Ich habe schon einen Fehler gefunden:
                                            Der API Post Header muss einen User-Agent enthalten, das war bisher nicht so
                                            mit 'User-Agent': 'Mozilla/5.0' funktioniert zumindest die Tokenabfrage wieder
                                            Schnelle Lösung:
                                            Diese Datei unter /opt/iobroker/node_modules/iobroker.sureflap austauschen
                                            main.js
                                            oder diesen fork von github installieren
                                            https://github.com/Strobelix80/ioBroker.sureflap
                                            M-A Hueb 1 Reply Last reply Reply Quote 1
                                            153
                                            32544
