    4. Neue Installationsroutine (für Linux)
      apollon77 @DokBiz last edited by
      @dokbiz Auch selbe stelle von den Zeilen davor?
        DokBiz @apollon77 last edited by
        @apollon77
        ja: 1800/2492
        host.Dok2021 Processed 1800/2492 objects
        Server Objects 127.0.0.1:33106 Error from InMemDB: Error: EXEC without MULTI
          @dokbiz Und nochmal der vollständigkeit halber: JS-Controller ist die 4.0.19?? (iob version).
          Dann versuchen wir mal mehr rauszufinden:
          • Editiere mal /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js (ANnahme liegt auch bei dir, sonst Basispfad anpassen)
          • Über Zeile 496 (https://github.com/ioBroker/ioBroker.js-controller/blob/ef364284a964d6854558dc6ce16647f2993ed126/packages/controller/lib/setup/setupBackup.js#L496) ein console.log(JSON.stringify(_objects[i])); einfügen
          • Dann kommen da gaaanz viele Ausgaben ... Bitte mal die Paar zeilen über dem Fehler posten wenn er wieder kommt
          D 3 Replies Last reply Reply Quote 0
            @apollon77 said in Neue Installationsroutine (für Linux):
            bei mir unterscheiden sich die dateien ein wenig, es war zeile 489.. aber ich hab was du wolltest:
            tended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448}}
            Server Objects 127.0.0.1:33568 Error from InMemDB: Error: EXEC without MULTI
              4.0.18
                @dokbiz Naja mal paaaaaar Zeilen davor bitte mehr 🙂
                  @apollon77
                  achja:
                  ich hatte eben ein restore machen wollen, und dann kam die meldung:
                      ~  iobroker restore /opt/iobroker/backups/2022_03_10-15_30_03_backupiobroker.tar.gz         ✔  system 
                  iobroker controller daemon is not running
                  host.Dok2012(SmartHome) OK.
                  The current version of js-controller differs from the version in the backup.
                  The js-controller version of the backup can not be restored automatically.
                  To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@4.0.18 --production" inside your ioBroker directory
                  If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                  ich hatte jetzt nochmal auf die 4.0.19 geselfupgraded, und jetzt kommt dieselbe meldung nochmal...
                  {"id":"system.certificates","value":{"_id":"system.certificates","type":"config","common":{"name":"System certificates","icon":"data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgMUwzIDV2NmMwIDUuNTUgMy44NCAxMC43NCA5IDEyIDUuMTYtMS4yNiA5LTYuNDUgOS0xMlY1bC05LTR6bTAgMTAuOTloN2MtLjUzIDQuMTItMy4yOCA3Ljc5LTcgOC45NFYxMkg1VjYuM2w3LTMuMTF2OC44eiIvPg0KPC9zdmc+"},"native":{"certificates":{"defaultPrivate":"-----BEGIN RSA PRIVATE KEY-----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\r\nAHD96EOigyzYb6ffoGboUYt1/wzO2eSTC5xTsN+nYn/1lrhctXfDY30=\r\n-----END RSA PRIVATE KEY-----\r\n","defaultPublic":"-----BEGIN CERTIFICATE-----\r\nMIIDhzCCAm+gAwIBAgIJA2LvdSDDn+EXMA0GCSqGSIb3DQEBCwUAMD4xETAPBgNV\r\nBAMTCGlvYnJva2VyMRYwFAYDVQQKEw1pb0Jyb2tlciBHbWJIMREwDwYDVQQLEwhp\r\nb2Jyb2tlcjAeFw0yMjAzMDUxMzM3MzNaFw0yMzAzMDUxMzM3MzNaMEgxGzAZBgNV\r\nBAMTEkRvazIwMTIoU21hcnRIb21lKTEWMBQGA1UEChMNaW9Ccm9rZXIgR21iSDER\r\nMA8GA1UECxMIaW9icm9rZXIwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIB\r\nAQDajP4ZL+/xkmnymezAh5RJ15MML0pHS3xbLD5PTQ/FtvUHfLeW1pSSgVYPjR8z\r\nVWOwWdVsYoPzkjIHhk39iS4PvVnvU2BTEZFal2EPxbbf1oX9RccyN6HKqbQ5Zcn3\r\nquE/VBGPtgabirgwuyWRmDtlKQiHdnHrxy8iyyaE+U0yTUgY1vUaFQO1tdloYwy7\r\nHTKAjgKmAKN+5eXT7KrwrK5xkNZW5UdUmIbYZeDvtcsxZmbTaJ+5fKxIAfJ42KEC\r\n74wX9AlFCzL5MWD5fYziewpJlZY6gCdnVGlx2/1PYaM3Bsa99NBjPyIObsi1UCQD\r\naX8C3Gi9j2brnUPMIl1vJgBjAgMBAAGjfjB8MAwGA1UdEwEB/wQCMAAwDwYDVR0P\r\nAQH/BAUDAwe/gDASBgNVHREECzAJggdEb2syMDEyMB0GA1UdDgQWBBTL1nw9mS9e\r\nxfU4ppIdJHXr6Zib/zAdBgNVHSUEFjAUBggrBgEFBQcDAQYIKwYBBQUHAwIwCQYD\r\nVR0jBAIwADANBgkqhkiG9w0BAQsFAAOCAQEAH+rVK8m7D6DXH229CHOi3ZtsjqtV\r\n4puDHKZC4eUI64c2ytIlZT0Jtc9lKMavpfhStnisoiStlaklVv4qjXijqWjZm+n7\r\n81fGyAz9RYlx0fuoA12fGstTquN7e6xr7U0rJ2oR0j8iNTSbTN/QdGVW5RYP5BUp\r\n5m6C93bhDaI0MQzsDsnCak/40woEMRLhO7KUdVGsHiHTdwO+X5wD2UtkQP1EiMxd\r\n9GjtTSVrH55WzSicEVUPeLv16e2vA5x1VQd1FSqFDnIGaqn0x3PMQl7/jjZuVwZ6\r\nNCQty6MoBZjgHRxcNYMtdjDT1GwUAvpucPS7Rd1abkRv7XOu45NngJrZKA==\r\n-----END CERTIFICATE-----\r\n"},"letsEncrypt":{"path":"letsencrypt","email":"","domains":""}},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1536},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866479},"doc":{"_id":"system.certificates","type":"config","common":{"name":"System certificates","icon":"data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgMUwzIDV2NmMwIDUuNTUgMy44NCAxMC43NCA5IDEyIDUuMTYtMS4yNiA5LTYuNDUgOS0xMlY1bC05LTR6bTAgMTAuOTloN2MtLjUzIDQuMTItMy4yOCA3Ljc5LTcgOC45NFYxMkg1VjYuM2w3LTMuMTF2OC44eiIvPg0KPC9zdmc+"},"native":{"certificates":{"defaultPrivate":"-----BEGIN RSA PRIVATE KEY-----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\r\nAHD96EOigyzYb6ffoGboUYt1/wzO2eSTC5xTsN+nYn/1lrhctXfDY30=\r\n-----END RSA PRIVATE KEY-----\r\n","defaultPublic":"-----BEGIN CERTIFICATE-----\r\nMIIDhzCCAm+gAwIBAgIJA2LvdSDDn+EXMA0GCSqGSIb3DQEBCwUAMD4xETAPBgNV\r\nBAMTCGlvYnJva2VyMRYwFAYDVQQKEw1pb0Jyb2tlciBHbWJIMREwDwYDVQQLEwhp\r\nb2Jyb2tlcjAeFw0yMjAzMDUxMzM3MzNaFw0yMzAzMDUxMzM3MzNaMEgxGzAZBgNV\r\nBAMTEkRvazIwMTIoU21hcnRIb21lKTEWMBQGA1UEChMNaW9Ccm9rZXIgR21iSDER\r\nMA8GA1UECxMIaW9icm9rZXIwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIB\r\nAQDajP4ZL+/xkmnymezAh5RJ15MML0pHS3xbLD5PTQ/FtvUHfLeW1pSSgVYPjR8z\r\nVWOwWdVsYoPzkjIHhk39iS4PvVnvU2BTEZFal2EPxbbf1oX9RccyN6HKqbQ5Zcn3\r\nquE/VBGPtgabirgwuyWRmDtlKQiHdnHrxy8iyyaE+U0yTUgY1vUaFQO1tdloYwy7\r\nHTKAjgKmAKN+5eXT7KrwrK5xkNZW5UdUmIbYZeDvtcsxZmbTaJ+5fKxIAfJ42KEC\r\n74wX9AlFCzL5MWD5fYziewpJlZY6gCdnVGlx2/1PYaM3Bsa99NBjPyIObsi1UCQD\r\naX8C3Gi9j2brnUPMIl1vJgBjAgMBAAGjfjB8MAwGA1UdEwEB/wQCMAAwDwYDVR0P\r\nAQH/BAUDAwe/gDASBgNVHREECzAJggdEb2syMDEyMB0GA1UdDgQWBBTL1nw9mS9e\r\nxfU4ppIdJHXr6Zib/zAdBgNVHSUEFjAUBggrBgEFBQcDAQYIKwYBBQUHAwIwCQYD\r\nVR0jBAIwADANBgkqhkiG9w0BAQsFAAOCAQEAH+rVK8m7D6DXH229CHOi3ZtsjqtV\r\n4puDHKZC4eUI64c2ytIlZT0Jtc9lKMavpfhStnisoiStlaklVv4qjXijqWjZm+n7\r\n81fGyAz9RYlx0fuoA12fGstTquN7e6xr7U0rJ2oR0j8iNTSbTN/QdGVW5RYP5BUp\r\n5m6C93bhDaI0MQzsDsnCak/40woEMRLhO7KUdVGsHiHTdwO+X5wD2UtkQP1EiMxd\r\n9GjtTSVrH55WzSicEVUPeLv16e2vA5x1VQd1FSqFDnIGaqn0x3PMQl7/jjZuVwZ6\r\nNCQty6MoBZjgHRxcNYMtdjDT1GwUAvpucPS7Rd1abkRv7XOu45NngJrZKA==\r\n-----END CERTIFICATE-----\r\n"},"letsEncrypt":{"path":"letsencrypt","email":"","domains":""}},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1536},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866479}}
                  {"id":"system.config","value":{"_id":"system.config","type":"config","common":{"name":"System configuration","city":"Trier","country":"Germany","longitude":"6.6441878","latitude":"49.7596208","language":"de","tempUnit":"°C","currency":"€","dontDelete":true,"dateFormat":"DD.MM.YYYY","isFloatComma":false,"licenseConfirmed":true,"defaultHistory":"history.0","activeRepo":"stable","diag":"extended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448},"doc":{"_id":"system.config","type":"config","common":{"name":"System configuration","city":"Trier","country":"Germany","longitude":"6.6441878","latitude":"49.7596208","language":"de","tempUnit":"°C","currency":"€","dontDelete":true,"dateFormat":"DD.MM.YYYY","isFloatComma":false,"licenseConfirmed":true,"defaultHistory":"history.0","activeRepo":"stable","diag":"extended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448}}
                  ^C
                  reicht das so? ich dachte, der fehler wäre in den letzten paar einträgen 🙈
                    DokBiz @DokBiz last edited by DokBiz
                    @dokbiz said in Neue Installationsroutine (für Linux):
                    reicht das so?
                    in der konsole füllt das den kompletten monitor 😕
                    wieviele zeilen willst du??
                      @dokbiz Reicht so. Aber am besten schau mal PN und schicke es mir als email.
                        @apollon77
                        ich hab dir die mail geschickt!
                        falls das irgendwie relevanz hat: ich hab den iobroker noch lauffähig unter windows im zugriff
                        apollon77 2 Replies Last reply Reply Quote 1
                          @dokbiz Wir versuchen mal
                            @dokbiz Nice one :-)) Bei dir war was "Zu schnell" und hast damit nen Bug gefunden 🙂
                            Willst Du mal versuchen ob der Fix tut? 🙂
                            Am Ende musst du diese Änderung machen https://github.com/ioBroker/ioBroker.js-controller/pull/1853/files
                            File suchst Du am besten mit cd /opt/iobroker und dann `find . -name redisHandler.js´ ich würde es erwarten in /opt/iobroker/node_modules/@iobroker/db-base/lib/redisHandler.js aber bei npm weiss man nie.
                            Tut es danach?
                            foxriver76 created this issue in ioBroker/ioBroker.js-controller
                            closed ensure to not send answer to multi call without exec call beeing proc… #1853
                              Nice one :-))
                              Da freut er sich, dass ich alles kaputt bekomme... Das hatte ich auch selten 😂
                              Also restore an sich lief nach der Korrektur der Datei (die übrigens genau dort lag, wo du sie vermutet hattest) fehlerfrei durch (soweit ich das beurteilen kann).
                              Vielen Dank schon mal dafür!!
                              Ich komme allerdings nicht auf die Weboberfläche. und was mich auch wundert, ist, dass er dieses mal gar nicht wegen der Version 'gemeckert' hat.. iob -v ergibt 4.0.19, das Backup war 4.0.18
                              D apollon77 2 Replies Last reply Reply Quote 0
                                @dokbiz
                                Update:
                                nach
                                iobroker stop
                                iobroker host this
                                iobroker fix
                                iobroker start
                                komme ich auf die Oberfläche und sehe zumindest schon mal meine ganzen Instanzen 👏 😍
                                  @dokbiz sagte in Neue Installationsroutine (für Linux):
                                  Interessant ... müssen wir beobachten. Laut coce müssen sich die daten irgendwie doch einig gewesen sein 🙂
                                    js-controller 4.0.20 kommt später heute in Beta ... da sollte das dann generell gefixt sein.
                                    installation
                                    64
                                    415
                                    115371
