    4. Neue Installationsroutine (für Linux)
      apollon77 @DokBiz last edited by
      @dokbiz Und nochmal der vollständigkeit halber: JS-Controller ist die 4.0.19?? (iob version).
      Dann versuchen wir mal mehr rauszufinden:
      • Editiere mal /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js (ANnahme liegt auch bei dir, sonst Basispfad anpassen)
      • Über Zeile 496 (https://github.com/ioBroker/ioBroker.js-controller/blob/ef364284a964d6854558dc6ce16647f2993ed126/packages/controller/lib/setup/setupBackup.js#L496) ein console.log(JSON.stringify(_objects[i])); einfügen
      • Dann kommen da gaaanz viele Ausgaben ... Bitte mal die Paar zeilen über dem Fehler posten wenn er wieder kommt
      D 3 Replies Last reply Reply Quote 0
        DokBiz @apollon77 last edited by
        @apollon77 said in Neue Installationsroutine (für Linux):
        bei mir unterscheiden sich die dateien ein wenig, es war zeile 489.. aber ich hab was du wolltest:
        tended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448}}
        Server Objects 127.0.0.1:33568 Error from InMemDB: Error: EXEC without MULTI
          4.0.18
            @dokbiz Naja mal paaaaaar Zeilen davor bitte mehr 🙂
              @apollon77
              achja:
              ich hatte eben ein restore machen wollen, und dann kam die meldung:
                  ~  iobroker restore /opt/iobroker/backups/2022_03_10-15_30_03_backupiobroker.tar.gz         ✔  system 
              iobroker controller daemon is not running
              host.Dok2012(SmartHome) OK.
              The current version of js-controller differs from the version in the backup.
              The js-controller version of the backup can not be restored automatically.
              To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@4.0.18 --production" inside your ioBroker directory
              If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
              ich hatte jetzt nochmal auf die 4.0.19 geselfupgraded, und jetzt kommt dieselbe meldung nochmal...
              {"id":"system.certificates","value":{"_id":"system.certificates","type":"config","common":{"name":"System certificates","icon":"data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgMUwzIDV2NmMwIDUuNTUgMy44NCAxMC43NCA5IDEyIDUuMTYtMS4yNiA5LTYuNDUgOS0xMlY1bC05LTR6bTAgMTAuOTloN2MtLjUzIDQuMTItMy4yOCA3Ljc5LTcgOC45NFYxMkg1VjYuM2w3LTMuMTF2OC44eiIvPg0KPC9zdmc+"},"native":{"certificates":{"defaultPrivate":"-----BEGIN RSA PRIVATE KEY-----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\r\nAHD96EOigyzYb6ffoGboUYt1/wzO2eSTC5xTsN+nYn/1lrhctXfDY30=\r\n-----END RSA PRIVATE KEY-----\r\n","defaultPublic":"-----BEGIN CERTIFICATE-----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\r\nNCQty6MoBZjgHRxcNYMtdjDT1GwUAvpucPS7Rd1abkRv7XOu45NngJrZKA==\r\n-----END CERTIFICATE-----\r\n"},"letsEncrypt":{"path":"letsencrypt","email":"","domains":""}},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1536},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866479},"doc":{"_id":"system.certificates","type":"config","common":{"name":"System certificates","icon":"data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgMUwzIDV2NmMwIDUuNTUgMy44NCAxMC43NCA5IDEyIDUuMTYtMS4yNiA5LTYuNDUgOS0xMlY1bC05LTR6bTAgMTAuOTloN2MtLjUzIDQuMTItMy4yOCA3Ljc5LTcgOC45NFYxMkg1VjYuM2w3LTMuMTF2OC44eiIvPg0KPC9zdmc+"},"native":{"certificates":{"defaultPrivate":"-----BEGIN RSA PRIVATE KEY-----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\r\nAHD96EOigyzYb6ffoGboUYt1/wzO2eSTC5xTsN+nYn/1lrhctXfDY30=\r\n-----END RSA PRIVATE KEY-----\r\n","defaultPublic":"-----BEGIN CERTIFICATE-----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\r\nNCQty6MoBZjgHRxcNYMtdjDT1GwUAvpucPS7Rd1abkRv7XOu45NngJrZKA==\r\n-----END CERTIFICATE-----\r\n"},"letsEncrypt":{"path":"letsencrypt","email":"","domains":""}},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1536},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866479}}
              {"id":"system.config","value":{"_id":"system.config","type":"config","common":{"name":"System configuration","city":"Trier","country":"Germany","longitude":"6.6441878","latitude":"49.7596208","language":"de","tempUnit":"°C","currency":"€","dontDelete":true,"dateFormat":"DD.MM.YYYY","isFloatComma":false,"licenseConfirmed":true,"defaultHistory":"history.0","activeRepo":"stable","diag":"extended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448},"doc":{"_id":"system.config","type":"config","common":{"name":"System configuration","city":"Trier","country":"Germany","longitude":"6.6441878","latitude":"49.7596208","language":"de","tempUnit":"°C","currency":"€","dontDelete":true,"dateFormat":"DD.MM.YYYY","isFloatComma":false,"licenseConfirmed":true,"defaultHistory":"history.0","activeRepo":"stable","diag":"extended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-enums","tab-events","tab-hosts","tab-users","tab-zigbee-0"],"wizard":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-info","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-zigbee-0","visible":true},{"name":"tab-backitup-0","visible":true}],"expertMode":true},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"7ae62e985b5b8ad330c95d189b5938ad7e5db0c7c2e1f04d"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1638195866448}}
              ^C
              reicht das so? ich dachte, der fehler wäre in den letzten paar einträgen 🙈
                DokBiz @DokBiz last edited by DokBiz
                @dokbiz said in Neue Installationsroutine (für Linux):
                reicht das so?
                in der konsole füllt das den kompletten monitor 😕
                wieviele zeilen willst du??
                  @dokbiz Reicht so. Aber am besten schau mal PN und schicke es mir als email.
                    @apollon77
                    ich hab dir die mail geschickt!
                    falls das irgendwie relevanz hat: ich hab den iobroker noch lauffähig unter windows im zugriff
                    apollon77 2 Replies Last reply Reply Quote 1
                      @dokbiz Wir versuchen mal
                        @dokbiz Nice one :-)) Bei dir war was "Zu schnell" und hast damit nen Bug gefunden 🙂
                        Willst Du mal versuchen ob der Fix tut? 🙂
                        Am Ende musst du diese Änderung machen https://github.com/ioBroker/ioBroker.js-controller/pull/1853/files
                        File suchst Du am besten mit cd /opt/iobroker und dann `find . -name redisHandler.js´ ich würde es erwarten in /opt/iobroker/node_modules/@iobroker/db-base/lib/redisHandler.js aber bei npm weiss man nie.
                        Tut es danach?
                        foxriver76 created this issue in ioBroker/ioBroker.js-controller
                        closed ensure to not send answer to multi call without exec call beeing proc… #1853
                          Nice one :-))
                          Da freut er sich, dass ich alles kaputt bekomme... Das hatte ich auch selten 😂
                          Also restore an sich lief nach der Korrektur der Datei (die übrigens genau dort lag, wo du sie vermutet hattest) fehlerfrei durch (soweit ich das beurteilen kann).
                          Vielen Dank schon mal dafür!!
                          Ich komme allerdings nicht auf die Weboberfläche. und was mich auch wundert, ist, dass er dieses mal gar nicht wegen der Version 'gemeckert' hat.. iob -v ergibt 4.0.19, das Backup war 4.0.18
                          D apollon77 2 Replies Last reply Reply Quote 0
                            @dokbiz
                            Update:
                            nach
                            iobroker stop
                            iobroker host this
                            iobroker fix
                            iobroker start
                            komme ich auf die Oberfläche und sehe zumindest schon mal meine ganzen Instanzen 👏 😍
                              @dokbiz sagte in Neue Installationsroutine (für Linux):
                              Interessant ... müssen wir beobachten. Laut coce müssen sich die daten irgendwie doch einig gewesen sein 🙂
                                js-controller 4.0.20 kommt später heute in Beta ... da sollte das dann generell gefixt sein.
                                installation
                                64
                                415
                                114681
