    4. Probleme nach Stromausfall
      Thomas Braun Most Active @pbroker last edited by Thomas Braun
      @pbroker
      Update js-controller from @3.3.22 to @4.0.15
      Das kann nicht sein, denn:
      github:	4.1.0
      latest:	4.0.19 for 5 days
      stable:	4.0.19 for 5 days
      iobroker update -u
      bringt?
        @pbroker
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        versuchen.
          pbroker @Thomas Braun last edited by
          ja - das geht auch aus dem Aufruf bei mir hervor.
           iobroker update -u
          Used repository: Stable (default)
          hash changed or no sources cached => force download of new sources
          update done
          Controller "js-controller" : 4.0.19   , installed 3.3.22 [Updateable]
            führe ich gerade aus 🙂
              pbroker @pbroker last edited by pbroker
              @pbroker
              OK es kommt trotz sudo ein permission error
              pi@raspberrypi:~ $ iobroker update -u
              update done
              pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
              npm ERR! code EACCES
              npm ERR! syscall mkdir
              npm ERR! path /home/pi/node_modules
              npm ERR! errno -13
              npm ERR! Error: EACCES: permission denied, mkdir '/home/pi/node_modules'
              npm ERR!  [Error: EACCES: permission denied, mkdir '/home/pi/node_modules'] {
              npm ERR!   errno: -13,
              npm ERR!   code: 'EACCES',
              npm ERR!   syscall: 'mkdir',
              npm ERR!   path: '/home/pi/node_modules'
              npm ERR! }
              npm ERR!
              npm ERR! The operation was rejected by your operating system.
              npm ERR! It is likely you do not have the permissions to access this file as the current user
              npm ERR!
              npm ERR! If you believe this might be a permissions issue, please double-check the
              npm ERR! permissions of the file and its containing directories, or try running
              npm ERR! the command again as root/Administrator.
              npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T14_07_08_959Z-debug-0.log
              iobroker fix hat das Problem leider auch nicht gelöst
              Homoran Thomas Braun 4 Replies Last reply Reply Quote 0
                Homoran Global Moderator Administrators @pbroker last edited by
                @pbroker hast du mal als root gearbeitet?
                  pbroker @Homoran last edited by
                  nicht bewusst. Ich vermeide es, mich zum root zu machen
                    @pbroker
                    als "pi" kann ich die mkdir befehle manuell an der Stelle ausführen
                      @pbroker sagte in Probleme nach Stromausfall:
                      aber du hast mal node im falschen Verzeichnis installiert?
                      einen npm Befehl im home des pi statt unter /opt/iobroker aufgerufen?
                        nach einem Neustart und dem erneuten ausführen der Befehle inkl. Ordnerwechsel hat es funktioniert.
                        ich denke, dass ich unbemerkt das Verzeichnis gewechselt habe.
                          Du stehst im falschen Verzeichnis.
                          cd /opt/iobroker
                          Das cd ist wichtig!
                            pbroker @Thomas Braun last edited by pbroker
                            @thomas-braun ja - ich vermute, dass ich mit Pfeil hoch in der Historie unbemerkt aus dem Verzeichnis gesprungen bin. Ich stand zuvor in /opt/iobroker und hatte es daher nicht ausgeführt
                              Nein, es kommt WEGEN des sudo -u iobroker zum permission error.
                              Der user iobroker darf nicht im Home des users pi herumschreiben. Zu recht.
                              In allen Postings zuvor stehst du immer in
                              pi@raspberrypi:~
                              Deswegen hatte ich den cd /opt/iobroker mitgegeben.
                              P 2 Replies Last reply Reply Quote 0
                                pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                removed 4 packages in 10s
                                35 packages are looking for funding
                                  run `npm fund` for details
                                der Befehl wurde nun erfolgreich ausgeführt.
                                dieser Befehl schlägt dennoch fehl.
                                pi@raspberrypi:/opt/iobroker $ iobroker upgrade self
                                Update js-controller from @3.3.22 to @4.0.19
                                NPM version: 8.3.1
                                npm install iobroker.js-controller@4.0.19 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                npm ERR! code 1
                                npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                                npm ERR! command failed
                                npm ERR! command sh -c node iobroker.js setup first
                                npm ERR! /opt/iobroker/node_modules/winston/node_modules/readable-stream/errors.js:44
                                npm ERR!  0  rel5r. `of $kthing} $sStrinf(expeb�ed)}`;
                                npm ERR!     ^^^^^
                                npm ERR!
                                npm ERR! SyntaxError: Unexpected identifier
                                npm ERR!     at Object.compileFunction (node:vm:352:18)
                                npm ERR!     at wrapSafe (node:internal/modules/cjs/loader:1032:15)
                                npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1067:27)
                                npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1155:10)
                                npm ERR!     at Module.load (node:internal/modules/cjs/loader:981:32)
                                npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                npm ERR!     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)
                                npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/internal/streams/state.js:3:29)
                                npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1103:14)
                                npm ERR!     /home/iobroker/.npm/_logs/2022-03-11T14_19_35_681Z-debug-0.log
                                  ja - jetzt sehe ich es auch. Ich habe nicht bemerkt, dass ich aus /opt/iobroker gerutscht bin. Das hatte ich nach dem CLI login direkt ausgeführt.
                                    Homoran Global Moderator Administrators @pbroker last edited by Homoran
                                    Update js-controller from @3.3.22 to @4.0.19 NPM version: 8.3.1
                                    npm v8 und controller v3 vertragen sich nicht!
                                    hatte ich vorhin schon geschrieben. Da dachte ich du seiest schon auf controller v4
                                      mit den Update Befehlen komme ich hier ja nicht weiter.
                                      Sehe aktuell nicht, wie ich auf 4.0.19 hochziehen kann
                                        @pbroker
                                        Geh mal mit nodeJS auf Version 14 inkl. npm@6 runter.
                                          gibt es keine Möglichkeit den controller anderweitig auf 4.0.19 hoch zu ziehen?
                                            @pbroker
                                            node14 inkl. npm6 ist eh die zur Zeit empfohlene Version.
                                            1968
