    4. [gelöst] Nach Docker Umzug keine Updates möglich
      Thomas Braun Most Active @ZoXx last edited by
      @zoxx sagte in Nach Docker Umzug keine Updates / Installationen möglich:
      sudo -u iobroker rm /opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver
      • Z
        ZoXx @Thomas Braun last edited by
        @thomas-braun said in Nach Docker Umzug keine Updates / Installationen möglich:
        nächster Fehler:
        $ iobroker add worx --host iobroker
        NPM version: 6.14.16
        npm install iobroker.worx@1.5.5 --loglevel error --prefix "/opt/iobroker" (System call)
        npm ERR! code EEXISTnpm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake
        npm ERR! Refusing to delete /opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake: is outside /opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan and not a link
        npm ERR! File exists: /opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wakenpm ERR! Remove the existing file and try again, or run npmnpm ERR! with --force to overwrite files recklessly.
        npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2022-03-07T19_23_51_703Z-debug.log
        host.iobroker Cannot install iobroker.worx@1.5.5: 1
        ERROR: Process exited with code 25
          Die gleiche Nummer...
          sudo -u iobroker rm /opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake
          • Z
            und weiter gehts.
            npm ERR! code EEXISTnpm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid
            npm ERR! Refusing to delete /opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid: is outside /opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid and not a link
            npm ERR! File exists: /opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuidnpm ERR! Remove the existing file and try again, or run npmnpm ERR! with --force to overwrite files recklessly.
            npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2022-03-07T19_30_14_048Z-debug.log
            ehrlich gesagt scheint da doch was größeres vorzuliegen?
            Ich kann ja quasi schlecht alels weglöschen jetzt?
              Warum nicht? Wenns hilft...
              Was liegt denn da alles rum?
              ls -la /opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/
              Kannst es dir vielleicht einfacher machen, wenn der komplette Inhalt gelöscht wird:
              sudo -u iobroker rm /opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/*
              • Z
                root@unRAID-Server:/mnt/cache/appdata/iobroker# ls -la node_modules/iobroker.javascript/node_modules/
                total 260
                drwxrwxrwx+ 1 user 1000   1682 Mar  6 18:47 ./
                drwxrwxrwx+ 1 user 1000    220 Mar  6 18:45 ../
                drwxrwxrwx+ 1 user 1000    164 Mar  6 18:45 .bin/
                -rw-rwxrw-+ 1 user 1000 263630 Mar  6 18:43 .package-lock.json*
                drwxrwxrwx+ 1 user 1000     24 Mar  6 18:47 \@iobroker/
                drwxrwxrwx+ 1 user 1000     78 Mar  6 18:47 \@types/
                drwxrwxrwx+ 1 user 1000     88 Mar  6 18:47 acorn-walk/
                drwxrwxrwx+ 1 user 1000    118 Mar  6 18:47 ajv/
                drwxrwxrwx+ 1 user 1000     84 Mar  6 18:47 asn1/
                drwxrwxrwx+ 1 user 1000     94 Mar  6 18:45 assert-plus/
                drwxrwxrwx+ 1 user 1000    184 Mar  6 18:47 asynckit/
                drwxrwxrwx+ 1 user 1000     72 Mar  6 18:45 aws-sign2/
                drwxrwxrwx+ 1 user 1000    118 Mar  6 18:47 aws4/
                drwxrwxrwx+ 1 user 1000    102 Mar  6 18:45 bcrypt-pbkdf/
                drwxrwxrwx+ 1 user 1000    198 Mar  6 18:47 call-bind/
                drwxrwxrwx+ 1 user 1000     86 Mar  6 18:45 caseless/
                drwxrwxrwx+ 1 user 1000    172 Mar  6 18:47 coffee-compiler/
                drwxrwxrwx+ 1 user 1000    104 Mar  6 18:50 coffee-script/
                drwxrwxrwx+ 1 user 1000     80 Mar  6 18:47 combined-stream/
                drwxrwxrwx+ 1 user 1000    178 Mar  6 18:47 cron-parser/
                drwxrwxrwx+ 1 user 1000     96 Mar  6 18:47 dashdash/
                drwxrwxrwx+ 1 user 1000     62 Mar  6 18:47 debug/
                drwxrwxrwx+ 1 user 1000    190 Mar  6 18:47 define-properties/
                drwxrwxrwx+ 1 user 1000     98 Mar  6 18:47 delayed-stream/
                drwxrwxrwx+ 1 user 1000     92 Mar  6 18:47 ecc-jsbn/
                drwxrwxrwx+ 1 user 1000    210 Mar  6 18:45 extend/
                drwxrwxrwx+ 1 user 1000    172 Mar  6 18:47 extsprintf/
                drwxrwxrwx+ 1 user 1000    134 Mar  6 18:47 fast-deep-equal/
                drwxrwxrwx+ 1 user 1000    194 Mar  6 18:47 fast-json-stable-stringify/
                drwxrwxrwx+ 1 user 1000     72 Mar  6 18:45 forever-agent/
                drwxrwxrwx+ 1 user 1000    108 Mar  6 18:47 form-data/
                drwxrwxrwx+ 1 user 1000    220 Mar  6 18:47 function-bind/
                drwxrwxrwx+ 1 user 1000    174 Mar  6 18:47 get-intrinsic/
                drwxrwxrwx+ 1 user 1000    104 Mar  6 18:47 getpass/
                drwxrwxrwx+ 1 user 1000     62 Mar  6 18:47 har-schema/
                drwxrwxrwx+ 1 user 1000     62 Mar  6 18:47 har-validator/
                drwxrwxrwx+ 1 user 1000     78 Mar  6 18:47 has/
                drwxrwxrwx+ 1 user 1000    190 Mar  6 18:47 has-symbols/
                drwxrwxrwx+ 1 user 1000    160 Mar  6 18:47 http-signature/
                drwxrwxrwx+ 1 user 1000    258 Mar  6 18:47 is-nan/
                drwxrwxrwx+ 1 user 1000     92 Mar  6 18:45 is-typedarray/
                drwxrwxrwx+ 1 user 1000    158 Mar  6 18:45 isstream/
                drwxrwxrwx+ 1 user 1000    136 Mar  6 18:45 jsbn/
                drwxrwxrwx+ 1 user 1000     62 Mar  6 18:47 json-schema/
                drwxrwxrwx+ 1 user 1000    128 Mar  6 18:47 json-schema-traverse/
                drwxrwxrwx+ 1 user 1000    148 Mar  6 18:47 json-stringify-safe/
                drwxrwxrwx+ 1 user 1000    216 Mar  6 18:45 jsonata/
                drwxrwxrwx+ 1 user 1000    112 Mar  6 18:47 jsprim/
                drwxrwxrwx+ 1 user 1000  16160 Mar  6 18:47 lodash/
                drwxrwxrwx+ 1 user 1000     78 Mar  6 18:45 long-timeout/
                drwxrwxrwx+ 1 user 1000     72 Mar  6 18:45 lru-cache/
                drwxrwxrwx+ 1 user 1000     78 Mar  6 18:50 luxon/
                drwxrwxrwx+ 1 user 1000    106 Mar  6 18:45 mime-db/
                drwxrwxrwx+ 1 user 1000     92 Mar  6 18:45 mime-types/
                drwxrwxrwx+ 1 user 1000    128 Mar  6 18:47 minimist/
                drwxrwxrwx+ 1 user 1000     78 Mar  6 18:45 ms/
                drwxrwxrwx+ 1 user 1000     98 Mar  6 18:47 node-inspect/
                drwxrwxrwx+ 1 user 1000    126 Mar  6 18:47 node-schedule/
                drwxrwxrwx+ 1 user 1000     72 Mar  6 18:45 oauth-sign/
                drwxrwxrwx+ 1 user 1000    232 Mar  6 18:47 object-keys/
                drwxrwxrwx+ 1 user 1000    154 Mar  6 18:47 performance-now/
                drwxrwxrwx+ 1 user 1000    170 Mar  6 18:45 picocolors/
                drwxrwxrwx+ 1 user 1000    130 Mar  6 18:47 psl/
                drwxrwxrwx+ 1 user 1000    124 Mar  6 18:45 punycode/
                drwxrwxrwx+ 1 user 1000    226 Mar  6 18:47 qs/
                drwxrwxrwx+ 1 user 1000    146 Mar  6 18:50 request/
                drwxrwxrwx+ 1 user 1000     98 Mar  6 18:47 request-promise-core/
                drwxrwxrwx+ 1 user 1000     80 Mar  6 18:47 request-promise-native/
                drwxrwxrwx+ 1 user 1000     92 Mar  6 18:45 safe-buffer/
                drwxrwxrwx+ 1 user 1000    146 Mar  6 18:45 safer-buffer/
                drwxrwxrwx+ 1 user 1000      0 Mar  7 20:23 semver/
                drwxrwxrwx+ 1 user 1000    128 Mar  6 18:45 sorted-array-functions/
                drwxrwxrwx+ 1 user 1000    118 Mar  6 18:50 sshpk/
                drwxrwxrwx+ 1 user 1000     82 Mar  6 18:47 stealthy-require/
                drwxrwxrwx+ 1 user 1000    114 Mar  6 18:45 suncalc2/
                drwxrwxrwx+ 1 user 1000     62 Mar  6 18:47 tough-cookie/
                drwxrwxrwx+ 1 user 1000     72 Mar  6 18:45 tunnel-agent/
                drwxrwxrwx+ 1 user 1000    278 Mar  6 18:45 tweetnacl/
                drwxrwxrwx+ 1 user 1000    246 Mar  6 18:53 typescript/
                drwxrwxrwx+ 1 user 1000     82 Mar  6 18:50 uri-js/
                drwxrwxrwx+ 1 user 1000    168 Mar  6 18:47 uuid/
                drwxrwxrwx+ 1 user 1000    156 Mar  6 18:50 verror/
                drwxrwxrwx+ 1 user 1000     66 Mar  6 18:50 virtual-tsc/
                drwxrwxrwx+ 1 user 1000    208 Mar  6 18:50 vm2/
                drwxrwxrwx+ 1 user 1000     20 Mar  7 20:29 wake_on_lan/
                drwxrwxrwx+ 1 user 1000     98 Mar  6 18:45 yallist/
                root@unRAID-Server:/mnt/cache/appdata/iobroker# ls -la node_modules/iobroker.javascript/node_modules/.bin/
                total 56
                drwxrwxrwx+ 1 user 1000  164 Mar  6 18:45 ./
                drwxrwxrwx+ 1 user 1000 1682 Mar  6 18:47 ../
                -rw-rwxrw-+ 1 user 1000  543 Mar  6 18:45 cake*
                -rw-rwxrw-+ 1 user 1000  546 Mar  6 18:45 coffee*
                -rw-rwxrw-+ 1 user 1000   45 Mar  6 18:45 node-inspect*
                -rw-rwxrw-+ 1 user 1000 4363 Mar  6 18:45 semver*
                -rw-rwxrw-+ 1 user 1000 5738 Mar  6 18:45 sshpk-conv*
                -rw-rwxrw-+ 1 user 1000 4011 Mar  6 18:45 sshpk-sign*
                -rw-rwxrw-+ 1 user 1000 3553 Mar  6 18:45 sshpk-verify*
                -rw-rwxrw-+ 1 user 1000   45 Mar  6 18:45 tsc*
                -rw-rwxrw-+ 1 user 1000   50 Mar  6 18:45 tsserver*
                -rw-rwxrw-+ 1 user 1000 1579 Mar  6 18:45 uuid*
                -rw-rwxrw-+ 1 user 1000   59 Mar  6 18:45 vm2*
                -rw-rwxrw-+ 1 user 1000 1611 Mar  6 18:45 wake*
                • Z
                  ZoXx @ZoXx last edited by
                  habe den ordner .bin mal komplett gelöscht.
                  Installation klappt nun, Fehler gibt es trotzdem:
                  $ iobroker upgrade shelly@5.3.2
                  Update shelly from @4.0.7 to @5.3.2
                  npm install iobroker.shelly@5.3.2 --loglevel error --prefix "/opt/iobroker" (System call)
                  internal/modules/cjs/loader.js:905
                  throw err; ^Error: Cannot find module '../lib/main'Require stack:- /opt/iobroker/node_modules/.bin/node-pre-gyp at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15) at Function.Module._load (internal/modules/cjs/loader.js:746:27) at Module.require (internal/modules/cjs/loader.js:974:19) at require (internal/modules/cjs/helpers.js:101:18) at Object.<anonymous> (/opt/iobroker/node_modules/.bin/node-pre-gyp:4:1) at Module._compile (internal/modules/cjs/loader.js:1085:14) at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10) at Module.load (internal/modules/cjs/loader.js:950:32) at Function.Module._load (internal/modules/cjs/loader.js:790:12) at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/.bin/node-pre-gyp' ]}
                  upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                  Update "system.adapter.shelly.0"
                  upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                  upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
                  upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                  upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  Adapter "shelly" updated
                  Process exited with code 0
                  • Z
                    niemand sonst eine Idee? 😞
                    • Z
                      Heute wieder Fehler beim Update des js-controller
                      root@iobroker:/opt/iobroker# iobroker upgrade self
                      Update js-controller from @3.3.22 to @4.0.19
                      npm install iobroker.js-controller@4.0.19 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                      npm ERR! path /opt/iobroker/node_modules/.bin/iobroker
                      npm ERR! Refusing to delete /opt/iobroker/node_modules/.bin/iobroker: is outside /opt/iobroker/node_modules/iobroker.js-controller and not a link
                      npm ERR! File exists: /opt/iobroker/node_modules/.bin/iobroker
                      npm ERR!     /opt/iobroker/.npm/_logs/2022-03-11T17_55_39_912Z-debug.log
                      es wäre klasse, wenn mir wer helfen könnte 😞
                        Thomas Braun Most Active last edited by Thomas Braun
                        root@iobroker
                        Erste Hilfe: Nicht als root agieren.
                        Zweite Hilfe:
                        Als user:
                        sudo -u iobroker rm /opt/iobroker/node_modules/.bin/iobroker
                        Was ist das eigentlich für ein komisches Verzeichnis
                        da?
                        • Z
                          Werde ich die Tage einen neuen User anlegen.
                          Zweite Hilfe:
                          Als user:
                          Erledigt.
                          Fehler danach beim ausführen von "iobroker upgrade self"
                          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller/node_modules/.bin/mime
                          npm ERR! Refusing to delete /opt/iobroker/node_modules/iobroker.js-controller/node_modules/.bin/mime: is outside /opt/iobroker/node_modules/iobroker.js-controller/node_modules/mime and not a link
                          npm ERR! File exists: /opt/iobroker/node_modules/iobroker.js-controller/node_modules/.bin/mime
                          npm ERR!     /opt/iobroker/.npm/_logs/2022-03-11T18_07_56_004Z-debug.log
                          da?
                          Verzeichnis von meinem unRAID-Server
                            Mach das JETZT und verfummel dir nicht weiter das System durch das rumgeeier als root.
                            • Z
                              alles klar. Ist angelegt.
                              Was mache ich bzgl. der Fehler weiter?
                                @zoxx Remove the existing file
                                • Z
                                  @thomas-braun das habe ich doch bereits oben erledigt?
                                    @zoxx
                                    Kiste neugestartet wg. der Rechte des neuen users?
                                    Als user angemeldet?
                                    Was sagt
                                    iobroker update -u
                                    • Z
                                      ZoXx @Thomas Braun last edited by ZoXx
                                      @zoxx
                                      Was sagt
                                      iobroker update -u
                                      meckert mit dem anderen user.
                                      Da muss ich die Tage schauen, warum ich mich nicht via putty verbinden kann (ob unraid überhaupt andere user zulässt).
                                      Habe es als root wieder ausgeführt:
                                      root@iobroker:/opt/iobroker# iobroker update -u
                                      Used repository: stable
                                      hash unchanged, use cached sources
                                      update done
                                      Controller "js-controller" : 4.0.19   , installed 3.3.22 [Updateable]
                                        Dann bin ich raus.
                                        Z 1 Reply Last reply Reply Quote 1
                                        • Z
                                          Dann bin ich raus.
                                          Ehrlich? 👎
                                          Danke für deine Bemühungen trotzdem.
                                          Schade, dass es an sowas scheitert. Hätte ja trotzdem weiter schauen können 😉
                                            @zoxx
                                            Ja.
                                            1614
