    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      Gruter last edited by Negalein
      Hallo, habe gerade ein Fehler im Log gefunden bzgl Amazon:
      parcel.0
      2022-03-09 09:10:22.003	info	starting. Version 0.0.10 (non-npm: TA2k/ioBroker.parcel#f0b05683d32a7dbdecbbbdd93b1bb45736903364) in /opt/iobroker/node_modules/iobroker.parcel, node: v12.22.10, js-controller: 4.0.15
      parcel.0
      2022-03-09 09:09:44.480	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      parcel.0
      2022-03-09 09:09:44.478	info	terminating
      parcel.0
      2022-03-09 09:09:44.473	error	Cannot read property 'length' of undefined
      parcel.0
      2022-03-09 09:09:44.472	error	TypeError: Cannot read property 'length' of undefined at Parcel.getAmazonPackages (/opt/iobroker/node_modules/iobroker.parcel/main.js:1477:42) at processTicksAndRejections (internal/process/task_queues.js:97:5)
      parcel.0
      2022-03-09 09:09:44.471	error	unhandled promise rejection: Cannot read property 'length' of undefined
      parcel.0
      2022-03-09 09:09:44.470	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      parcel.0
      2022-03-09 09:09:44.463	error	Error: getaddrinfo EAI_AGAIN www.amazon.de
      Mod-Edit: Code in </> Code-Tag gepackt!
        tombox @Gruter last edited by
        @gruter Danke für den hinweis
        • Nashra
          Wenn der Adapter per Schedule neu startet geht alles auf rot und bekomme dies
          parcel.0
          	794152	2022-03-09 18:00:00.062	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          parcel.0
          	794152	2022-03-09 18:00:00.061	info	terminating
          host.ioBroker
          		2022-03-09 18:00:00.060	info	instance system.adapter.ical.0 started with pid 804678
          parcel.0
          	794152	2022-03-09 18:00:00.010	info	Scheduled restart.
          Christoph1337 1 Reply Last reply Reply Quote 0
          • Christoph1337
            Christoph1337 @Nashra last edited by
            Nach dem letzten Update habe ich folgende Fehler im Log.
            parcel.0
            2022-03-10 11:33:21.527	warn	State "parcel.0.amazon.json" has no existing object, this might lead to an error in future versions
            parcel.0
            2022-03-10 11:33:13.441	error	[object Object],[object Object]
            parcel.0
            2022-03-10 11:33:13.437	error	SyntaxError: Unexpected token o in JSON at position 1
            parcel.0
            2022-03-10 11:30:28.803	warn	State "parcel.0.amazon.json" has no existing object, this might lead to an error in future versions
            parcel.0
            2022-03-10 11:30:28.801	warn	State "parcel.0.amazon.json" has no existing object, this might lead to an error in future versions
            parcel.0
            2022-03-10 11:30:19.587	error	[object Object],[object Object]
            parcel.0
            2022-03-10 11:30:19.587	error	SyntaxError: Unexpected token o in JSON at position 1
            parcel.0
            2022-03-10 11:30:19.088	error	[object Object],[object Object]
            parcel.0
            2022-03-10 11:30:19.085	error	SyntaxError: Unexpected token o in JSON at position 1
              tombox @Christoph1337 last edited by
              @christoph1337 ist behoben
              Xsev 1 Reply Last reply Reply Quote 1
              • Bastian Lahrmann
                Bastian Lahrmann last edited by
                Parcel: v0.0.10
                Nodejs: 14.19.0
                NPM: 6.14.16
                1. Ich habe im Parcer immer einen Syntax-Error. Wahrscheinlich kommt das von Hermes. Das stört dem Adapter nicht und er funktioniert trotzdem (wobei ich das bisher mit Hermes nicht ausprobieren konnte), aber im Log taucht es auf.
                parcel.0 2022-03-11 07:52:28.242	debug	hermes merge provider json
                parcel.0 2022-03-11 07:52:28.216	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                parcel.0 2022-03-11 07:52:28.211	error
                parcel.0 2022-03-11 07:52:28.211	error	SyntaxError: Unexpected end of JSON input
                parcel.0 2022-03-11 07:52:28.210	debug	[]
                parcel.0 2022-03-11 07:52:27.852	debug	https://mobile-api.myhermes.de/mobile-api-web/v2/shipments
                parcel.0 2022-03-11 07:52:27.852	debug	ups merge provider json
                1. Jeden Morgen bekomme ich über Telegram alle Pakete von DHL einmal zugeschickt, obwohl sich am Status (abgeschlossen/zugeschickt) nichts geändert hat. Vielleicht kann man diese Meldung noch unterdrücken.
                • Xsev
                  Xsev @tombox last edited by
                  @tombox Hi tombox, ich hab heute mal aktualisiert um zu schauen ob das Problem weg ist aber anscheinend nicht.
                  DPD aktualisiert den Status nicht mehr automatisch, nur wenn man den Adapter neu startet aktualisiert er die Daten, da scheint evtl. was faul zu sein.
                  • David G.
                    Habe jetzt mein erstes DPD Paket.
                    Da wollte ich mal fragen, wie oft der Adapter das aktualisiert.
                    Die App hat mir vor ca 30min einen neuen Status gesendet. Im Adapter ist dieser noch nicht angekommen.
                    Bei den verbundenen Geräten sehe ich den Adapter nicht (nur mein Smartphone).
                    Edit: Erste Frage hat sich erledigt.
                    • DJMarc75
                      DJMarc75 last edited by
                      Falls ihr Fehler im LOG bzgl DHL habt, DHL hat grad Probleme .... hat nix mit dem Adapter zu tun
                        tombox @Bastian Lahrmann last edited by
                        @bastian-lahrmann Ja ich bin noch auf der Suche was da manchmal bei hermes schief geht.
                        Mal die aktuelle Version installieren und schauen ob es weg geht.
                        Es wird der ganze Status überprüft ist der exakt der gleiche. Gerade wenn sich was von heute auf Datum ändert
                        Bastian Lahrmann 1 Reply Last reply Reply Quote 1
                          tombox @Xsev last edited by
                          @xsev Ich habe bei dpd noch anpassungen gemacht bitte mal prüfen. Und schauen ob die Aktualisierung sofort kommt oder erst nach 1h.
                          Xsev 1 Reply Last reply Reply Quote 0
                          • Bastian Lahrmann
                            Bastian Lahrmann @tombox last edited by
                            @tombox
                            Zumindest sind die Json-Meldungen weg, dafür kommt bei mir seit gestern abend DHL dazu. Mein Anfrageintervall steht auf 20min.
                            parcel.0
                            2022-03-12 06:11:59.540	error	[{"message":"Bitte versuchen Sie es zu einem späteren Zeitpunkt erneut.","headline":"Es ist leider ein Fehler aufgetreten."}]
                            parcel.0
                            2022-03-12 06:11:59.540	error	Error: Request failed with status code 500
                            parcel.0
                            2022-03-12 06:11:59.538	error	https://www.dhl.de/int-aviseanzeigen/advices?width=414
                            • Xsev
                              @tombox Danke! Ich kanns aktuell nur nicht testen, da ich grad keine Sendung mehr im Zulauf habe.
                              • DJMarc75
                                @bastian-lahrmann
                                Seit gestern Störung bei DHL
                                https://allestörungen.de/stoerung/dhl/
                                  Thomas Braun Most Active @Bastian Lahrmann last edited by
                                  @bastian-lahrmann
                                  https://stadt-bremerhaven.de/post-dhl-app-briefankuendigung-ausgesetzt-datenschutzpanne/
                                  @tombox
                                  Kann man die Briefankündigung nicht optional in den Einstellungen machen?
                                  Bastian Lahrmann Chaot T 3 Replies Last reply Reply Quote 2
                                  • Bastian Lahrmann
                                    Bastian Lahrmann @Thomas Braun last edited by
                                    @thomas-braun Interessant, danke. Über GMX habe ich weiterhin die Briefankündigung erhalten, deshalb meine Verwirrung. Dann hat sich das ja jetzt geklärt.
                                    • Chaot
                                      Chaot @Thomas Braun last edited by
                                      @thomas-braun Hihi, habe ich auch schon gestern gelesen.
                                      Lustigerweise kann ich bestätigen das es auch bei Paketen zu solchen Pannen kommt. Ich hatte kürzlich ein Paket meiner Lebensgefährtin in der Ankündigung. Gleiche Adresse, aber anderer Name.
                                      • DJMarc75
                                        @tombox
                                        Meinste man könnte im Backend die Briefankündigung bei DHL schaltbar machen ? Wer weiss wie lange die "Störung" noch existiert. Es wird halt der LOG je nach Intervall immer leicht belastet 😊
                                          tombox @Thomas Braun last edited by
                                          @thomas-braun Habe eine Erkennung eingebaut falls die Briefankündigung nicht geht wird sie für updates ignoriert.
                                          DJMarc75 1 Reply Last reply Reply Quote 3
                                          • DJMarc75
                                            DJMarc75 @tombox last edited by
                                            @tombox
                                            Sehr gut gemacht !
                                            17track amazon briefe dhl dpd gls ups
                                            122
                                            1534
                                            525648
