Test Alpha Homekit-Controller 0.0.x
@pql ich hab auch einen eve Energy undeniable mir tut alles - aber von nem Mac aus.
Also du könntest jetzt nochmal das hci debugging parallel laufen lassen. Siehe troubleshooting in der readme. Vllt sieht man da noch was.
@apollon77
So bin gerade mal wieder mit Eve am testen aber mit gleichem Ergebnis....
Über BLE zickt er immer noch.2022-02-16 19:05:03.537 - debug: homekit-controller.0 (115079) Redis Objects: Use Redis connection: 127.0.0.1:9001 2022-02-16 19:05:03.642 - debug: homekit-controller.0 (115079) Objects client ready ... initialize now 2022-02-16 19:05:03.647 - debug: homekit-controller.0 (115079) Objects create System PubSub Client 2022-02-16 19:05:03.650 - debug: homekit-controller.0 (115079) Objects create User PubSub Client 2022-02-16 19:05:03.753 - debug: homekit-controller.0 (115079) Objects client initialize lua scripts 2022-02-16 19:05:03.779 - debug: homekit-controller.0 (115079) Objects connected to redis: 127.0.0.1:9001 2022-02-16 19:05:03.816 - debug: homekit-controller.0 (115079) Redis States: Use Redis connection: 127.0.0.1:6379 2022-02-16 19:05:03.828 - debug: homekit-controller.0 (115079) States create System PubSub Client 2022-02-16 19:05:03.830 - debug: homekit-controller.0 (115079) States create User PubSub Client 2022-02-16 19:05:03.846 - debug: homekit-controller.0 (115079) States connected to redis: 127.0.0.1:6379 2022-02-16 19:05:03.913 - debug: homekit-controller.0 (115079) Plugin sentry Initialize Plugin (enabled=true) 2022-02-16 19:05:04.430 - info: homekit-controller.0 (115079) starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.10 2022-02-16 19:05:04.709 - debug: homekit-controller.0 (115079) state homekit-controller.0.info.connection changed: false (ack = true) 2022-02-16 19:05:04.710 - debug: homekit-controller.0 (115079) Init 2 known devices without discovery ... 2022-02-16 19:05:04.711 - debug: homekit-controller.0 (115079) Init IP-10:92:E9:E7:AE:8F as known device 2022-02-16 19:05:04.713 - info: homekit-controller.0 (115079) IP-10:92:E9:E7:AE:8F (Eve Extend C054) found without pairing data but available for pairing: Create basic objects 2022-02-16 19:05:04.714 - debug: homekit-controller.0 (115079) Service: {"name":"Eve Extend C054","address":"192.168.95.50","port":8080,"c#":12,"ff":1,"id":"10:92:E9:E7:AE:8F","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":1,"ci":2,"availableToPair":true} 2022-02-16 19:05:04.765 - debug: homekit-controller.0 (115079) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.connectionType changed: IP (ack = true) 2022-02-16 19:05:04.778 - debug: homekit-controller.0 (115079) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.id changed: 10:92:E9:E7:AE:8F (ack = true) 2022-02-16 19:05:04.792 - debug: homekit-controller.0 (115079) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.address changed: 192.168.95.50 (ack = true) 2022-02-16 19:05:04.804 - debug: homekit-controller.0 (115079) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.connected changed: false (ack = true) 2022-02-16 19:05:04.827 - debug: homekit-controller.0 (115079) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.admin.isPaired changed: false (ack = true) 2022-02-16 19:05:04.841 - debug: homekit-controller.0 (115079) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.lastDiscovered changed: 1645034704716 (ack = true) 2022-02-16 19:05:04.860 - debug: homekit-controller.0 (115079) Init BLE-EA:80:43:5F:2E:FE as known device 2022-02-16 19:05:04.861 - info: homekit-controller.0 (115079) BLE-EA:80:43:5F:2E:FE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects 2022-02-16 19:05:04.862 - debug: homekit-controller.0 (115079) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":true} 2022-02-16 19:05:04.900 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.connectionType changed: BLE (ack = true) 2022-02-16 19:05:04.913 - debug: homekit-controller.0 (115079) Discovered IP device up: 10:92:E9:E7:AE:8F/Eve Extend C054 2022-02-16 19:05:04.914 - debug: homekit-controller.0 (115079) IP-10:92:E9:E7:AE:8F Discovered IP device: {"name":"Eve Extend C054","address":"192.168.95.50","port":8080,"c#":14,"ff":1,"id":"10:92:E9:E7:AE:8F","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false} 2022-02-16 19:05:04.915 - info: homekit-controller.0 (115079) IP-10:92:E9:E7:AE:8F (Eve Extend C054) found without known pairing data and already paired: ignoring 2022-02-16 19:05:04.930 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.id changed: ea:80:43:5f:2e:fe (ack = true) 2022-02-16 19:05:04.943 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.connected changed: false (ack = true) 2022-02-16 19:05:04.966 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.admin.isPaired changed: false (ack = true) 2022-02-16 19:05:04.979 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.lastDiscovered changed: 1645034704863 (ack = true) 2022-02-16 19:05:05.002 - debug: homekit-controller.0 (115079) Discovered IP device up: 47:FB:8F:AA:80:82/Eve Extend 726E 2022-02-16 19:05:05.003 - debug: homekit-controller.0 (115079) IP-47:FB:8F:AA:80:82 Discovered IP device: {"name":"Eve Extend 726E","address":"169.254.182.94","port":8080,"c#":5,"ff":1,"id":"47:FB:8F:AA:80:82","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false} 2022-02-16 19:05:05.004 - info: homekit-controller.0 (115079) IP-47:FB:8F:AA:80:82 (Eve Extend 726E) found without known pairing data and already paired: ignoring 2022-02-16 19:05:05.636 - debug: homekit-controller.0 (115079) Discovered BLE device up: f6:36:ed:19:09:14/Eve Thermo 8FE8 2022-02-16 19:05:05.636 - debug: homekit-controller.0 (115079) BLE-F6:36:ED:19:09:14 Discovered BLE device: {"name":"Eve Thermo 8FE8","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"f6:36:ed:19:09:14","ACID":9,"GSN":8861,"CN":5,"CV":2,"c#":5,"id":"f6:36:ed:19:09:14","ci":9,"availableToPair":false} 2022-02-16 19:05:05.637 - info: homekit-controller.0 (115079) BLE-F6:36:ED:19:09:14 (Eve Thermo 8FE8) found without known pairing data and already paired: ignoring 2022-02-16 19:05:05.951 - debug: homekit-controller.0 (115079) Discovered IP device up: 77:a2:42:96:a1:50/ioBroker B13E 2022-02-16 19:05:05.951 - debug: homekit-controller.0 (115079) IP-77:A2:42:96:A1:50 Discovered IP device: {"name":"ioBroker B13E","address":"192.168.95.212","port":44763,"c#":21,"ff":0,"id":"77:a2:42:96:a1:50","md":"not configured","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false} 2022-02-16 19:05:05.952 - info: homekit-controller.0 (115079) IP-77:A2:42:96:A1:50 (ioBroker B13E) found without known pairing data and already paired: ignoring 2022-02-16 19:05:07.173 - debug: homekit-controller.0 (115079) Discovered BLE device up: ea:80:43:5f:2e:fe/Eve 2022-02-16 19:05:07.174 - debug: homekit-controller.0 (115079) BLE-EA:80:43:5F:2E:FE Discovered BLE device: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":true} 2022-02-16 19:05:07.174 - info: homekit-controller.0 (115079) BLE-EA:80:43:5F:2E:FE (Eve) found without pairing data but available for pairing: Create basic objects 2022-02-16 19:05:07.175 - debug: homekit-controller.0 (115079) Service: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":true} 2022-02-16 19:05:07.218 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.connectionType changed: BLE (ack = true) 2022-02-16 19:05:07.237 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.id changed: ea:80:43:5f:2e:fe (ack = true) 2022-02-16 19:05:07.268 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.connected changed: false (ack = true) 2022-02-16 19:05:07.334 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.admin.isPaired changed: false (ack = true) 2022-02-16 19:05:07.354 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.lastDiscovered changed: 1645034707176 (ack = true) 2022-02-16 19:05:07.736 - debug: homekit-controller.0 (115079) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":51,"ack":false,"time":1645034707733},"_id":61965836}) 2022-02-16 19:05:07.738 - debug: homekit-controller.0 (115079) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-EA:80:43:5F:2E:FE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-10:92:E9:E7:AE:8F","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend C054","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-47:FB:8F:AA:80:82","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend 726E","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"BLE-F6:36:ED:19:09:14","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Thermo 8FE8","discoveredCategory":"Thermostat","pairedWithThisInstance":false},{"id":"IP-77:A2:42:96:A1:50","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"ioBroker B13E","discoveredCategory":"Bridge","pairedWithThisInstance":false}]} 2022-02-16 19:05:12.329 - debug: homekit-controller.0 (115079) Message identify received: {"command":"identify","message":{"deviceId":"BLE-EA:80:43:5F:2E:FE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-EA:80:43:5F:2E:FE"},"id":52,"ack":false,"time":1645034712328},"_id":61965837}) 2022-02-16 19:05:12.330 - debug: homekit-controller.0 (115079) Device BLE-EA:80:43:5F:2E:FE: Identify triggered 2022-02-16 19:05:17.002 - debug: homekit-controller.0 (115079) Response to Command identify: {"success":true,"error":false} 2022-02-16 19:05:18.514 - debug: homekit-controller.0 (115079) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":53,"ack":false,"time":1645034718512},"_id":61965838}) 2022-02-16 19:05:18.515 - debug: homekit-controller.0 (115079) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-EA:80:43:5F:2E:FE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-10:92:E9:E7:AE:8F","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend C054","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-47:FB:8F:AA:80:82","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend 726E","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"BLE-F6:36:ED:19:09:14","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Thermo 8FE8","discoveredCategory":"Thermostat","pairedWithThisInstance":false},{"id":"IP-77:A2:42:96:A1:50","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"ioBroker B13E","discoveredCategory":"Bridge","pairedWithThisInstance":false}]} 2022-02-16 19:05:34.097 - debug: homekit-controller.0 (115079) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-EA:80:43:5F:2E:FE","pin":"843-54-008"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-EA:80:43:5F:2E:FE","pin":"843-54-008"},"id":54,"ack":false,"time":1645034734094},"_id":61965839}) 2022-02-16 19:05:38.076 - info: homekit-controller.0 (115079) Use PairMethod 0 to pair BLE-EA:80:43:5F:2E:FE 2022-02-16 19:05:38.078 - debug: homekit-controller.0 (115079) BLE-EA:80:43:5F:2E:FE Start Homekit Device Client initialization 2022-02-16 19:05:47.900 - debug: homekit-controller.0 (115079) Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-EA:80:43:5F:2E:FE because of error undefined (undefined): undefined"} 2022-02-16 19:05:48.355 - debug: homekit-controller.0 (115079) Discovered BLE device changed: ea:80:43:5f:2e:fe/Eve Degree 5980 2022-02-16 19:05:48.357 - debug: homekit-controller.0 (115079) BLE-EA:80:43:5F:2E:FE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":false} 2022-02-16 19:05:48.358 - info: homekit-controller.0 (115079) BLE-EA:80:43:5F:2E:FE (Eve Degree 5980) found without known pairing data and already paired: ignoring 2022-02-16 19:06:32.001 - debug: homekit-controller.0 (115079) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":58,"ack":false,"time":1645034791999},"_id":61965843}) 2022-02-16 19:06:32.002 - debug: homekit-controller.0 (115079) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"IP-10:92:E9:E7:AE:8F","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend C054","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"BLE-EA:80:43:5F:2E:FE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-47:FB:8F:AA:80:82","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend 726E","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"BLE-F6:36:ED:19:09:14","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Thermo 8FE8","discoveredCategory":"Thermostat","pairedWithThisInstance":false},{"id":"IP-77:A2:42:96:A1:50","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"ioBroker B13E","discoveredCategory":"Bridge","pairedWithThisInstance":false}]} 2022-02-16 19:06:58.307 - info: homekit-controller.0 (115079) Got terminate signal TERMINATE_YOURSELF 2022-02-16 19:06:58.322 - info: homekit-controller.0 (115079) terminating 2022-02-16 19:06:58.325 - debug: homekit-controller.0 (115079) Plugin sentry destroyed 2022-02-16 19:06:58.326 - info: homekit-controller.0 (115079) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2022-02-16 19:07:04.162 - debug: homekit-controller.0 (115115) Redis Objects: Use Redis connection: 127.0.0.1:9001 2022-02-16 19:07:04.275 - debug: homekit-controller.0 (115115) Objects client ready ... initialize now 2022-02-16 19:07:04.282 - debug: homekit-controller.0 (115115) Objects create System PubSub Client 2022-02-16 19:07:04.286 - debug: homekit-controller.0 (115115) Objects create User PubSub Client 2022-02-16 19:07:04.375 - debug: homekit-controller.0 (115115) Objects client initialize lua scripts 2022-02-16 19:07:04.393 - debug: homekit-controller.0 (115115) Objects connected to redis: 127.0.0.1:9001 2022-02-16 19:07:04.471 - debug: homekit-controller.0 (115115) Redis States: Use Redis connection: 127.0.0.1:6379 2022-02-16 19:07:04.489 - debug: homekit-controller.0 (115115) States create System PubSub Client 2022-02-16 19:07:04.490 - debug: homekit-controller.0 (115115) States create User PubSub Client 2022-02-16 19:07:04.501 - debug: homekit-controller.0 (115115) States connected to redis: 127.0.0.1:6379 2022-02-16 19:07:04.551 - debug: homekit-controller.0 (115115) Plugin sentry Initialize Plugin (enabled=true) 2022-02-16 19:07:05.037 - info: homekit-controller.0 (115115) starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.10 2022-02-16 19:07:05.299 - debug: homekit-controller.0 (115115) state homekit-controller.0.info.connection changed: false (ack = true) 2022-02-16 19:07:05.311 - debug: homekit-controller.0 (115115) Init 2 known devices without discovery ... 2022-02-16 19:07:05.312 - debug: homekit-controller.0 (115115) Init IP-10:92:E9:E7:AE:8F as known device 2022-02-16 19:07:05.314 - info: homekit-controller.0 (115115) IP-10:92:E9:E7:AE:8F (Eve Extend C054) found without pairing data but available for pairing: Create basic objects 2022-02-16 19:07:05.315 - debug: homekit-controller.0 (115115) Service: {"name":"Eve Extend C054","address":"192.168.95.50","port":8080,"c#":12,"ff":1,"id":"10:92:E9:E7:AE:8F","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":1,"ci":2,"availableToPair":true} 2022-02-16 19:07:05.367 - debug: homekit-controller.0 (115115) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.connectionType changed: IP (ack = true) 2022-02-16 19:07:05.384 - debug: homekit-controller.0 (115115) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.id changed: 10:92:E9:E7:AE:8F (ack = true) 2022-02-16 19:07:05.405 - debug: homekit-controller.0 (115115) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.address changed: 192.168.95.50 (ack = true) 2022-02-16 19:07:05.417 - debug: homekit-controller.0 (115115) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.connected changed: false (ack = true) 2022-02-16 19:07:05.441 - debug: homekit-controller.0 (115115) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.admin.isPaired changed: false (ack = true) 2022-02-16 19:07:05.456 - debug: homekit-controller.0 (115115) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.lastDiscovered changed: 1645034825317 (ack = true) 2022-02-16 19:07:05.485 - debug: homekit-controller.0 (115115) Init BLE-EA:80:43:5F:2E:FE as known device 2022-02-16 19:07:05.486 - info: homekit-controller.0 (115115) BLE-EA:80:43:5F:2E:FE (Eve) found without pairing data but available for pairing: Create basic objects 2022-02-16 19:07:05.487 - debug: homekit-controller.0 (115115) Service: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":true} 2022-02-16 19:07:05.527 - debug: homekit-controller.0 (115115) Discovered IP device up: 10:92:E9:E7:AE:8F/Eve Extend C054 2022-02-16 19:07:05.528 - debug: homekit-controller.0 (115115) IP-10:92:E9:E7:AE:8F Discovered IP device: {"name":"Eve Extend C054","address":"192.168.95.50","port":8080,"c#":14,"ff":1,"id":"10:92:E9:E7:AE:8F","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false} 2022-02-16 19:07:05.529 - info: homekit-controller.0 (115115) IP-10:92:E9:E7:AE:8F (Eve Extend C054) found without known pairing data and already paired: ignoring 2022-02-16 19:07:05.547 - debug: homekit-controller.0 (115115) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.connectionType changed: BLE (ack = true) 2022-02-16 19:07:05.553 - debug: homekit-controller.0 (115115) Discovered IP device up: 47:FB:8F:AA:80:82/Eve Extend 726E 2022-02-16 19:07:05.554 - debug: homekit-controller.0 (115115) IP-47:FB:8F:AA:80:82 Discovered IP device: {"name":"Eve Extend 726E","address":"169.254.182.94","port":8080,"c#":5,"ff":1,"id":"47:FB:8F:AA:80:82","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false} 2022-02-16 19:07:05.555 - info: homekit-controller.0 (115115) IP-47:FB:8F:AA:80:82 (Eve Extend 726E) found without known pairing data and already paired: ignoring 2022-02-16 19:07:05.571 - debug: homekit-controller.0 (115115) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.id changed: ea:80:43:5f:2e:fe (ack = true) 2022-02-16 19:07:05.585 - debug: homekit-controller.0 (115115) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.connected changed: false (ack = true) 2022-02-16 19:07:05.606 - debug: homekit-controller.0 (115115) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.admin.isPaired changed: false (ack = true) 2022-02-16 19:07:05.618 - debug: homekit-controller.0 (115115) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.lastDiscovered changed: 1645034825487 (ack = true) 2022-02-16 19:07:05.750 - debug: homekit-controller.0 (115115) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":59,"ack":false,"time":1645034825748},"_id":61965844}) 2022-02-16 19:07:05.752 - debug: homekit-controller.0 (115115) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-EA:80:43:5F:2E:FE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-10:92:E9:E7:AE:8F","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend C054","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-47:FB:8F:AA:80:82","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend 726E","discoveredCategory":"Bridge","pairedWithThisInstance":false}]} 2022-02-16 19:07:06.006 - debug: homekit-controller.0 (115115) Discovered IP device up: 77:a2:42:96:a1:50/ioBroker B13E 2022-02-16 19:07:06.007 - debug: homekit-controller.0 (115115) IP-77:A2:42:96:A1:50 Discovered IP device: {"name":"ioBroker B13E","address":"192.168.95.212","port":44763,"c#":21,"ff":0,"id":"77:a2:42:96:a1:50","md":"not configured","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false} 2022-02-16 19:07:06.008 - info: homekit-controller.0 (115115) IP-77:A2:42:96:A1:50 (ioBroker B13E) found without known pairing data and already paired: ignoring 2022-02-16 19:07:07.862 - debug: homekit-controller.0 (115115) Discovered BLE device up: ea:80:43:5f:2e:fe/Eve Degree 5980 2022-02-16 19:07:07.863 - debug: homekit-controller.0 (115115) BLE-EA:80:43:5F:2E:FE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":false} 2022-02-16 19:07:07.864 - info: homekit-controller.0 (115115) BLE-EA:80:43:5F:2E:FE (Eve Degree 5980) found without known pairing data and already paired: ignoring 2022-02-16 19:07:12.512 - debug: homekit-controller.0 (115115) Message identify received: {"command":"identify","message":{"deviceId":"BLE-EA:80:43:5F:2E:FE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-EA:80:43:5F:2E:FE"},"id":60,"ack":false,"time":1645034832511},"_id":61965845}) 2022-02-16 19:07:12.514 - debug: homekit-controller.0 (115115) Device BLE-EA:80:43:5F:2E:FE: Identify triggered 2022-02-16 19:07:23.539 - debug: homekit-controller.0 (115115) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-EA:80:43:5F:2E:FE because of error undefined: Identify returned error status: 5"} 2022-02-16 19:07:27.848 - debug: homekit-controller.0 (115115) Discovered BLE device up: f6:36:ed:19:09:14/Eve Thermo 8FE8 2022-02-16 19:07:27.849 - debug: homekit-controller.0 (115115) BLE-F6:36:ED:19:09:14 Discovered BLE device: {"name":"Eve Thermo 8FE8","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"f6:36:ed:19:09:14","ACID":9,"GSN":8861,"CN":5,"CV":2,"c#":5,"id":"f6:36:ed:19:09:14","ci":9,"availableToPair":false} 2022-02-16 19:07:27.850 - info: homekit-controller.0 (115115) BLE-F6:36:ED:19:09:14 (Eve Thermo 8FE8) found without known pairing data and already paired: ignoring 2022-02-16 19:07:27.861 - debug: homekit-controller.0 (115115) Discovered BLE device changed: f6:36:ed:19:09:14/Eve Thermo 8FE8 2022-02-16 19:07:27.862 - debug: homekit-controller.0 (115115) BLE-F6:36:ED:19:09:14 Discovered BLE device: {"name":"Eve Thermo 8FE8","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"f6:36:ed:19:09:14","ACID":9,"GSN":8862,"CN":5,"CV":2,"c#":5,"id":"f6:36:ed:19:09:14","ci":9,"availableToPair":false} 2022-02-16 19:07:27.862 - info: homekit-controller.0 (115115) BLE-F6:36:ED:19:09:14 (Eve Thermo 8FE8) found without known pairing data and already paired: ignoring 2022-02-16 19:08:47.689 - debug: homekit-controller.0 (115115) Discovered BLE device changed: f6:36:ed:19:09:14/Eve Thermo 8FE8 2022-02-16 19:08:47.691 - debug: homekit-controller.0 (115115) BLE-F6:36:ED:19:09:14 Discovered BLE device: {"name":"Eve Thermo 8FE8","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"f6:36:ed:19:09:14","ACID":9,"GSN":8863,"CN":5,"CV":2,"c#":5,"id":"f6:36:ed:19:09:14","ci":9,"availableToPair":false} 2022-02-16 19:08:47.692 - info: homekit-controller.0 (115115) BLE-F6:36:ED:19:09:14 (Eve Thermo 8FE8) found without known pairing data and already paired: ignoring 2022-02-16 19:09:35.906 - debug: homekit-controller.0 (115115) Discovered BLE device up: 9b:3d:c6:d0:82:9b/Eve 2022-02-16 19:09:35.907 - debug: homekit-controller.0 (115115) BLE-9B:3D:C6:D0:82:9B Discovered BLE device: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"9b:3d:c6:d0:82:9b","ACID":9,"GSN":8239,"CN":5,"CV":2,"c#":5,"id":"9b:3d:c6:d0:82:9b","ci":9,"availableToPair":false} 2022-02-16 19:09:35.907 - info: homekit-controller.0 (115115) BLE-9B:3D:C6:D0:82:9B (Eve) found without known pairing data and already paired: ignoring 2022-02-16 19:09:51.356 - debug: homekit-controller.0 (115115) Discovered BLE device up: 91:90:ed:a6:89:85/Eve 2022-02-16 19:09:51.357 - debug: homekit-controller.0 (115115) BLE-91:90:ED:A6:89:85 Discovered BLE device: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"91:90:ed:a6:89:85","ACID":9,"GSN":6582,"CN":5,"CV":2,"c#":5,"id":"91:90:ed:a6:89:85","ci":9,"availableToPair":false} 2022-02-16 19:09:51.357 - info: homekit-controller.0 (115115) BLE-91:90:ED:A6:89:85 (Eve) found without known pairing data and already paired: ignoring 2022-02-16 19:10:59.889 - debug: homekit-controller.0 (115115) Discovered BLE device changed: ea:80:43:5f:2e:fe/Eve Degree 5980 2022-02-16 19:10:59.891 - debug: homekit-controller.0 (115115) BLE-EA:80:43:5F:2E:FE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":3,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":false} 2022-02-16 19:10:59.893 - info: homekit-controller.0 (115115) BLE-EA:80:43:5F:2E:FE (Eve Degree 5980) found without known pairing data and already paired: ignoring -
@fortune95 sagte in Test Alpha Homekit-Controller 0.0.x:
Also Fehler 5 sagt laut Specs
Server reached its maximum number of authentication attempts.
Resette mal ...
@apollon77
So kurz zum setup, habe jetzt eine VM mit externen USB BLE von Edimax. Debian Bullseye und js-controller 4.0.10.
Den Eve Degree kann ich im adapter sehen (habe ihn zuvor frisch resettet)kann ihn aber nicht identifizieren.
Erhalte dann diese Fehlermeldung:
Danach habe ich den Adapter gestoppt.
Und über die Shell den Debug wie oben erwähnt gestartet.
Hier das Log:iobroker@iobroker:~DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debugug 2022-02-17 18:44:50.094 - debug: homekit-controller.0 (2380) Redis Objects: Use Redis connection: 127.0.0.1:9001 2022-02-17 18:44:50.129 - debug: homekit-controller.0 (2380) Objects client ready ... initialize now 2022-02-17 18:44:50.130 - debug: homekit-controller.0 (2380) Objects create System PubSub Client 2022-02-17 18:44:50.131 - debug: homekit-controller.0 (2380) Objects create User PubSub Client 2022-02-17 18:44:50.147 - debug: homekit-controller.0 (2380) Objects client initialize lua scripts 2022-02-17 18:44:50.149 - debug: homekit-controller.0 (2380) Objects connected to redis: 127.0.0.1:9001 2022-02-17 18:44:50.162 - debug: homekit-controller.0 (2380) Redis States: Use Redis connection: 127.0.0.1:6379 2022-02-17 18:44:50.164 - debug: homekit-controller.0 (2380) States create System PubSub Client 2022-02-17 18:44:50.165 - debug: homekit-controller.0 (2380) States create User PubSub Client 2022-02-17 18:44:50.168 - debug: homekit-controller.0 (2380) States connected to redis: 127.0.0.1:6379 2022-02-17 18:44:50.182 - debug: homekit-controller.0 (2380) Plugin sentry Initialize Plugin (enabled=true) 2022-02-17 18:44:50.244 - error: homekit-controller.0 (2380) adapter disabled 2022-02-17 18:44:50.299 - info: homekit-controller.0 (2380) starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.10 2022-02-17 18:44:50.370 - debug: homekit-controller.0 (2380) state homekit-controller.0.info.connection changed: false (ack = true) 2022-02-17 18:44:50.373 - debug: homekit-controller.0 (2380) Init 1 known devices without discovery ... 2022-02-17 18:44:50.373 - debug: homekit-controller.0 (2380) Init BLE-BA:0A:DB:84:F2:CE as known device 2022-02-17 18:44:50.374 - info: homekit-controller.0 (2380) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects 2022-02-17 18:44:50.374 - debug: homekit-controller.0 (2380) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true} 2022-02-17 18:44:50.384 - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true) 2022-02-17 18:44:50.388 - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true) 2022-02-17 18:44:50.391 - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true) 2022-02-17 18:44:50.395 - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true) 2022-02-17 18:44:50.399 - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645119890375 (ack = true) 2022-02-17 18:44:51.467 - debug: homekit-controller.0 (2380) Discovered BLE device up: ba:0a:db:84:f2:ce/Eve Degree 5980 2022-02-17 18:44:51.467 - debug: homekit-controller.0 (2380) BLE-BA:0A:DB:84:F2:CE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true} 2022-02-17 18:44:51.467 - info: homekit-controller.0 (2380) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects 2022-02-17 18:44:51.468 - debug: homekit-controller.0 (2380) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true} 2022-02-17 18:44:51.476 - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true) 2022-02-17 18:44:51.479 - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true) 2022-02-17 18:44:51.482 - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true) 2022-02-17 18:44:51.487 - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true) 2022-02-17 18:44:51.490 - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645119891468 (ack = true) 2022-02-17 18:45:09.680 - debug: homekit-controller.0 (2380) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":25,"ack":false,"time":1645119909679},"_id":16181572}) 2022-02-17 18:45:09.680 - debug: homekit-controller.0 (2380) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]} 2022-02-17 18:45:11.831 - debug: homekit-controller.0 (2380) Message identify received: {"command":"identify","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"id":26,"ack":false,"time":1645119911830},"_id":16181573}) 2022-02-17 18:45:11.831 - debug: homekit-controller.0 (2380) Device BLE-BA:0A:DB:84:F2:CE: Identify triggered hap-controller:gatt-connection connect peripheral +0ms hap-controller:gatt-connection disconnect peripheral +3s hap-controller:gatt-connection Peripheral disconnected +47ms 2022-02-17 18:45:14.949 - debug: homekit-controller.0 (2380) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-BA:0A:DB:84:F2:CE because of error undefined: undefined"}Kannst Du damit was anfangen?
@apollon77
So habe noch eine Ergänzung nach Google Recherche... im Bluetooth Service vorgenommen.
Zumindest lieferte der Bluetooth Service danach keine Fehler mehr.
Und auch das identifizieren ging dann wieder.Habe diese Zeile so abgeändert
ExecStart=/usr/lib/bluetooth/bluetoothd --noplugin=sapNur das pairen will einfach nicht.
Hier das Log:iobroker@iobroker:~$ sudo systemctl status bluetooth.service ● bluetooth.service - Bluetooth service Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled) Active: active (running) since Thu 2022-02-17 18:58:26 CET; 13s ago Docs: man:bluetoothd(8) Main PID: 2443 (bluetoothd) Status: "Running" Tasks: 1 (limit: 7090) Memory: 740.0K CPU: 9ms CGroup: /system.slice/bluetooth.service └─2443 /usr/libexec/bluetooth/bluetoothd --noplugin=sap Feb 17 18:58:26 iobroker systemd[1]: Starting Bluetooth service... Feb 17 18:58:26 iobroker bluetoothd[2443]: Bluetooth daemon 5.55 Feb 17 18:58:26 iobroker systemd[1]: Started Bluetooth service. Feb 17 18:58:26 iobroker bluetoothd[2443]: Starting SDP server Feb 17 18:58:26 iobroker bluetoothd[2443]: Excluding (cli) sap Feb 17 18:58:26 iobroker bluetoothd[2443]: Bluetooth management interface 1.18 initialized iobroker@iobroker:~$ DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debug 2022-02-17 19:00:01.818 - debug: homekit-controller.0 (2501) Redis Objects: Use Redis connection: 127.0.0.1:9001 2022-02-17 19:00:01.856 - debug: homekit-controller.0 (2501) Objects client ready ... initialize now 2022-02-17 19:00:01.857 - debug: homekit-controller.0 (2501) Objects create System PubSub Client 2022-02-17 19:00:01.858 - debug: homekit-controller.0 (2501) Objects create User PubSub Client 2022-02-17 19:00:01.879 - debug: homekit-controller.0 (2501) Objects client initialize lua scripts 2022-02-17 19:00:01.881 - debug: homekit-controller.0 (2501) Objects connected to redis: 127.0.0.1:9001 2022-02-17 19:00:01.896 - debug: homekit-controller.0 (2501) Redis States: Use Redis connection: 127.0.0.1:6379 2022-02-17 19:00:01.898 - debug: homekit-controller.0 (2501) States create System PubSub Client 2022-02-17 19:00:01.899 - debug: homekit-controller.0 (2501) States create User PubSub Client 2022-02-17 19:00:01.901 - debug: homekit-controller.0 (2501) States connected to redis: 127.0.0.1:6379 2022-02-17 19:00:01.917 - debug: homekit-controller.0 (2501) Plugin sentry Initialize Plugin (enabled=true) 2022-02-17 19:00:01.992 - error: homekit-controller.0 (2501) adapter disabled 2022-02-17 19:00:02.039 - info: homekit-controller.0 (2501) starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.10 2022-02-17 19:00:02.112 - debug: homekit-controller.0 (2501) state homekit-controller.0.info.connection changed: false (ack = true) 2022-02-17 19:00:02.114 - debug: homekit-controller.0 (2501) Init 1 known devices without discovery ... 2022-02-17 19:00:02.115 - debug: homekit-controller.0 (2501) Init BLE-BA:0A:DB:84:F2:CE as known device 2022-02-17 19:00:02.116 - info: homekit-controller.0 (2501) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects 2022-02-17 19:00:02.116 - debug: homekit-controller.0 (2501) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true} 2022-02-17 19:00:02.128 - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true) 2022-02-17 19:00:02.134 - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true) 2022-02-17 19:00:02.138 - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true) 2022-02-17 19:00:02.145 - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true) 2022-02-17 19:00:02.149 - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645120802117 (ack = true) 2022-02-17 19:00:02.689 - debug: homekit-controller.0 (2501) Discovered BLE device up: ba:0a:db:84:f2:ce/Eve Degree 5980 2022-02-17 19:00:02.689 - debug: homekit-controller.0 (2501) BLE-BA:0A:DB:84:F2:CE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true} 2022-02-17 19:00:02.690 - info: homekit-controller.0 (2501) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects 2022-02-17 19:00:02.690 - debug: homekit-controller.0 (2501) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true} 2022-02-17 19:00:02.698 - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true) 2022-02-17 19:00:02.701 - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true) 2022-02-17 19:00:02.705 - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true) 2022-02-17 19:00:02.710 - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true) 2022-02-17 19:00:02.714 - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645120802690 (ack = true) 2022-02-17 19:00:07.994 - debug: homekit-controller.0 (2501) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":33,"ack":false,"time":1645120807993},"_id":16181580}) 2022-02-17 19:00:07.994 - debug: homekit-controller.0 (2501) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]} 2022-02-17 19:00:09.643 - debug: homekit-controller.0 (2501) Message identify received: {"command":"identify","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"id":34,"ack":false,"time":1645120809642},"_id":16181581}) 2022-02-17 19:00:09.643 - debug: homekit-controller.0 (2501) Device BLE-BA:0A:DB:84:F2:CE: Identify triggered hap-controller:gatt-connection connect peripheral +0ms hap-controller:tlv Add 1 bytes for tag 1: 01 +0ms hap-controller:gatt-connection ff4feaecc339/ff:4f:ea:ec:c3:39 Write for characteristic 000000140000100080000026bb765291 00020003000300010101 +4s hap-controller:gatt-connection ff4feaecc339/ff:4f:ea:ec:c3:39 Received data for characteristic 000000140000100080000026bb765291 020000 +224ms hap-controller:gatt-connection disconnect peripheral +1ms hap-controller:gatt-connection Peripheral disconnected +45ms 2022-02-17 19:00:13.890 - debug: homekit-controller.0 (2501) Response to Command identify: {"success":true,"error":false} 2022-02-17 19:00:15.413 - debug: homekit-controller.0 (2501) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":35,"ack":false,"time":1645120815413},"_id":16181582}) 2022-02-17 19:00:15.414 - debug: homekit-controller.0 (2501) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]} 2022-02-17 19:00:25.994 - debug: homekit-controller.0 (2501) Message identify received: {"command":"identify","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"id":36,"ack":false,"time":1645120825994},"_id":16181583}) 2022-02-17 19:00:25.995 - debug: homekit-controller.0 (2501) Device BLE-BA:0A:DB:84:F2:CE: Identify triggered hap-controller:gatt-connection connect peripheral +12s hap-controller:gatt-connection disconnect peripheral +5s 2022-02-17 19:01:00.829 - debug: homekit-controller.0 (2501) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-BA:0A:DB:84:F2:CE because of error undefined: Unknown Connection Identifier (0x2)"} ^Ciobroker@iobroker:~$ DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debug 2022-02-17 19:01:16.958 - debug: homekit-controller.0 (2526) Redis Objects: Use Redis connection: 127.0.0.1:9001 2022-02-17 19:01:16.994 - debug: homekit-controller.0 (2526) Objects client ready ... initialize now 2022-02-17 19:01:16.995 - debug: homekit-controller.0 (2526) Objects create System PubSub Client 2022-02-17 19:01:16.996 - debug: homekit-controller.0 (2526) Objects create User PubSub Client 2022-02-17 19:01:17.016 - debug: homekit-controller.0 (2526) Objects client initialize lua scripts 2022-02-17 19:01:17.018 - debug: homekit-controller.0 (2526) Objects connected to redis: 127.0.0.1:9001 2022-02-17 19:01:17.031 - debug: homekit-controller.0 (2526) Redis States: Use Redis connection: 127.0.0.1:6379 2022-02-17 19:01:17.033 - debug: homekit-controller.0 (2526) States create System PubSub Client 2022-02-17 19:01:17.034 - debug: homekit-controller.0 (2526) States create User PubSub Client 2022-02-17 19:01:17.036 - debug: homekit-controller.0 (2526) States connected to redis: 127.0.0.1:6379 2022-02-17 19:01:17.049 - debug: homekit-controller.0 (2526) Plugin sentry Initialize Plugin (enabled=true) 2022-02-17 19:01:17.110 - error: homekit-controller.0 (2526) adapter disabled 2022-02-17 19:01:17.159 - info: homekit-controller.0 (2526) starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.10 2022-02-17 19:01:17.232 - debug: homekit-controller.0 (2526) state homekit-controller.0.info.connection changed: false (ack = true) 2022-02-17 19:01:17.235 - debug: homekit-controller.0 (2526) Init 1 known devices without discovery ... 2022-02-17 19:01:17.236 - debug: homekit-controller.0 (2526) Init BLE-BA:0A:DB:84:F2:CE as known device 2022-02-17 19:01:17.237 - info: homekit-controller.0 (2526) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects 2022-02-17 19:01:17.238 - debug: homekit-controller.0 (2526) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true} 2022-02-17 19:01:17.248 - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true) 2022-02-17 19:01:17.252 - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true) 2022-02-17 19:01:17.255 - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true) 2022-02-17 19:01:17.259 - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true) 2022-02-17 19:01:17.262 - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645120877239 (ack = true) 2022-02-17 19:01:20.744 - debug: homekit-controller.0 (2526) Discovered BLE device up: ba:0a:db:84:f2:ce/Eve Degree 5980 2022-02-17 19:01:20.745 - debug: homekit-controller.0 (2526) BLE-BA:0A:DB:84:F2:CE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true} 2022-02-17 19:01:20.745 - info: homekit-controller.0 (2526) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects 2022-02-17 19:01:20.745 - debug: homekit-controller.0 (2526) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true} 2022-02-17 19:01:20.752 - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true) 2022-02-17 19:01:20.755 - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true) 2022-02-17 19:01:20.759 - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true) 2022-02-17 19:01:20.766 - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true) 2022-02-17 19:01:20.769 - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645120880745 (ack = true) 2022-02-17 19:01:25.279 - debug: homekit-controller.0 (2526) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":37,"ack":false,"time":1645120885278},"_id":16181584}) 2022-02-17 19:01:25.280 - debug: homekit-controller.0 (2526) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]} 2022-02-17 19:01:26.989 - debug: homekit-controller.0 (2526) Message identify received: {"command":"identify","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"id":38,"ack":false,"time":1645120886988},"_id":16181585}) 2022-02-17 19:01:26.990 - debug: homekit-controller.0 (2526) Device BLE-BA:0A:DB:84:F2:CE: Identify triggered hap-controller:gatt-connection connect peripheral +0ms hap-controller:tlv Add 1 bytes for tag 1: 01 +0ms hap-controller:gatt-connection ff4feaecc339/ff:4f:ea:ec:c3:39 Write for characteristic 000000140000100080000026bb765291 00020003000300010101 +3s hap-controller:gatt-connection ff4feaecc339/ff:4f:ea:ec:c3:39 Received data for characteristic 000000140000100080000026bb765291 020000 +225ms hap-controller:gatt-connection disconnect peripheral +0ms hap-controller:gatt-connection Peripheral disconnected +45ms 2022-02-17 19:01:30.649 - debug: homekit-controller.0 (2526) Response to Command identify: {"success":true,"error":false} 2022-02-17 19:01:32.166 - debug: homekit-controller.0 (2526) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":39,"ack":false,"time":1645120892163},"_id":16181586}) 2022-02-17 19:01:32.167 - debug: homekit-controller.0 (2526) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]} 2022-02-17 19:01:51.108 - debug: homekit-controller.0 (2526) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE","pin":"843-54-008"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE","pin":"843-54-008"},"id":40,"ack":false,"time":1645120911107},"_id":16181587}) hap-controller:gatt-connection connect peripheral +20s hap-controller:gatt-connection disconnect peripheral +7s 2022-02-17 19:02:27.867 - info: homekit-controller.0 (2526) Cannot retrieve BLE PairMethod for device BLE-BA:0A:DB:84:F2:CE because of error undefined: Unknown Connection Identifier (0x2), try default 2022-02-17 19:02:27.868 - info: homekit-controller.0 (2526) Use PairMethod 0 to pair BLE-BA:0A:DB:84:F2:CE 2022-02-17 19:02:27.868 - debug: homekit-controller.0 (2526) BLE-BA:0A:DB:84:F2:CE Start Homekit Device Client initialization hap-controller:gatt-connection disconnect peripheral to reconnect +30s 2022-02-17 19:02:57.870 - debug: homekit-controller.0 (2526) Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-BA:0A:DB:84:F2:CE because of error undefined (undefined): undefined"} -
Interessant, den Fehler hatte ich in einem Issue schonmal gesehen, aber tja dann wirds ganz interessant. Bitte schaumal da durch https://github.com/Apollon77/ioBroker.homekit-controller/#for-ble-devices und versuche es blt mach dieses Log parallel
@apollon77
Habe den Adapter wie im Issue beschrieben von Gihub installiert und das Log erstellt:iobroker@iobroker:~$ DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debug --logs 2022-02-18 16:07:47.793 - debug: homekit-controller.0 (6682) Redis Objects: Use Redis connection: 127.0.0.1:9001 2022-02-18 16:07:47.815 - debug: homekit-controller.0 (6682) Objects client ready ... initialize now 2022-02-18 16:07:47.816 - debug: homekit-controller.0 (6682) Objects create System PubSub Client 2022-02-18 16:07:47.817 - debug: homekit-controller.0 (6682) Objects create User PubSub Client 2022-02-18 16:07:47.838 - debug: homekit-controller.0 (6682) Objects client initialize lua scripts 2022-02-18 16:07:47.840 - debug: homekit-controller.0 (6682) Objects connected to redis: 127.0.0.1:9001 2022-02-18 16:07:47.854 - debug: homekit-controller.0 (6682) Redis States: Use Redis connection: 127.0.0.1:6379 2022-02-18 16:07:47.856 - debug: homekit-controller.0 (6682) States create System PubSub Client 2022-02-18 16:07:47.857 - debug: homekit-controller.0 (6682) States create User PubSub Client 2022-02-18 16:07:47.860 - debug: homekit-controller.0 (6682) States connected to redis: 127.0.0.1:6379 2022-02-18 16:07:47.872 - debug: homekit-controller.0 (6682) Plugin sentry Initialize Plugin (enabled=true) 2022-02-18 16:07:47.933 - error: homekit-controller.0 (6682) adapter disabled 2022-02-18 16:07:47.978 - info: homekit-controller.0 (6682) starting. Version 0.4.3 (non-npm: Apollon77/ioBroker.homekit-controller#c614463e84bfe9c4e7d5d6038d0babdbcb55b852) in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.12 2022-02-18 16:07:48.050 - debug: homekit-controller.0 (6682) state homekit-controller.0.info.connection changed: false (ack = true) 2022-02-18 16:07:53.221 - debug: homekit-controller.0 (6682) Discovered BLE device up: 25:3e:f0:cc:4c:64/Eve 2022-02-18 16:07:53.221 - debug: homekit-controller.0 (6682) BLE-25:3E:F0:CC:4C:64 Discovered BLE device: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"25:3e:f0:cc:4c:64","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"25:3e:f0:cc:4c:64","ci":10,"availableToPair":true} 2022-02-18 16:07:53.222 - info: homekit-controller.0 (6682) BLE-25:3E:F0:CC:4C:64 (Eve) found without pairing data but available for pairing: Create basic objects 2022-02-18 16:07:53.222 - debug: homekit-controller.0 (6682) Service: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"25:3e:f0:cc:4c:64","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"25:3e:f0:cc:4c:64","ci":10,"availableToPair":true} 2022-02-18 16:07:53.235 - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.connectionType changed: BLE (ack = true) 2022-02-18 16:07:53.237 - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.connectionType changed: BLE (ack = true) 2022-02-18 16:07:53.240 - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.id changed: 25:3e:f0:cc:4c:64 (ack = true) 2022-02-18 16:07:53.243 - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.connected changed: false (ack = true) 2022-02-18 16:07:53.248 - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.admin.isPaired changed: false (ack = true) 2022-02-18 16:07:53.251 - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.lastDiscovered changed: 1645196873223 (ack = true) 2022-02-18 16:07:53.255 - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.admin.pairWithPin changed: (ack = true) 2022-02-18 16:07:53.258 - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.admin.identify changed: false (ack = true) 2022-02-18 16:08:10.833 - debug: homekit-controller.0 (6682) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":112,"ack":false,"time":1645196890832},"_id":85128405}) 2022-02-18 16:08:10.833 - debug: homekit-controller.0 (6682) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-25:3E:F0:CC:4C:64","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve","discoveredCategory":"Sensor","pairedWithThisInstance":false}]} 2022-02-18 16:08:12.873 - debug: homekit-controller.0 (6682) Message identify received: {"command":"identify","message":{"deviceId":"BLE-25:3E:F0:CC:4C:64"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-25:3E:F0:CC:4C:64"},"id":113,"ack":false,"time":1645196892872},"_id":85128406}) 2022-02-18 16:08:12.873 - debug: homekit-controller.0 (6682) Device BLE-25:3E:F0:CC:4C:64: Identify triggered hap-controller:gatt-connection connect peripheral +0ms hap-controller:tlv Add 1 bytes for tag 1: 01 +0ms hap-controller:gatt-connection e60614286935/e6:06:14:28:69:35 Write for characteristic 000000140000100080000026bb765291 00020003000300010101 +6s hap-controller:gatt-connection e60614286935/e6:06:14:28:69:35 Received data for characteristic 000000140000100080000026bb765291 020000 +180ms hap-controller:gatt-connection disconnect peripheral +0ms hap-controller:gatt-connection Peripheral disconnected +45ms 2022-02-18 16:08:18.600 - debug: homekit-controller.0 (6682) Response to Command identify: {"success":true,"error":false} 2022-02-18 16:08:20.110 - debug: homekit-controller.0 (6682) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":114,"ack":false,"time":1645196900109},"_id":85128407}) 2022-02-18 16:08:20.110 - debug: homekit-controller.0 (6682) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-25:3E:F0:CC:4C:64","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve","discoveredCategory":"Sensor","pairedWithThisInstance":false}]} 2022-02-18 16:08:46.277 - debug: homekit-controller.0 (6682) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-25:3E:F0:CC:4C:64","pin":"843-54-008"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-25:3E:F0:CC:4C:64","pin":"843-54-008"},"id":115,"ack":false,"time":1645196926277},"_id":85128408}) hap-controller:gatt-connection connect peripheral +28s hap-controller:gatt-connection e60614286935/e6:06:14:28:69:35 Write for characteristic 0000004f0000100080000026bb765291 0003000f00 +4s hap-controller:gatt-connection e60614286935/e6:06:14:28:69:35 Received data for characteristic 0000004f0000100080000026bb765291 0200000300010101 +225ms hap-controller:gatt-connection disconnect peripheral +0ms hap-controller:gatt-connection Peripheral disconnected +46ms 2022-02-18 16:08:50.462 - info: homekit-controller.0 (6682) Use PairMethod 0 to pair BLE-25:3E:F0:CC:4C:64 2022-02-18 16:08:50.463 - debug: homekit-controller.0 (6682) BLE-25:3E:F0:CC:4C:64 Start Homekit Device Client initialization hap-controller:gatt-connection connect peripheral +2ms 2022-02-18 16:08:55.788 - debug: homekit-controller.0 (6682) Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-25:3E:F0:CC:4C:64 because of error undefined (undefined): Unknown Connection Identifier (0x2)"} 2022-02-18 16:11:45.843 - debug: homekit-controller.0 (6682) Discovered BLE device changed: 25:3e:f0:cc:4c:64/Eve Degree 5980 2022-02-18 16:11:45.843 - debug: homekit-controller.0 (6682) BLE-25:3E:F0:CC:4C:64 Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"25:3e:f0:cc:4c:64","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"25:3e:f0:cc:4c:64","ci":10,"availableToPair":true} 2022-02-18 16:11:45.843 - info: homekit-controller.0 (6682) BLE-25:3E:F0:CC:4C:64 (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects 2022-02-18 16:11:45.844 - debug: homekit-controller.0 (6682) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"25:3e:f0:cc:4c:64","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"25:3e:f0:cc:4c:64","ci":10,"availableToPair":true} 2022-02-18 16:11:45.852 - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.connectionType changed: BLE (ack = true) 2022-02-18 16:11:45.854 - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.id changed: 25:3e:f0:cc:4c:64 (ack = true) 2022-02-18 16:11:45.858 - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.connected changed: false (ack = true) 2022-02-18 16:11:45.863 - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.admin.isPaired changed: false (ack = true) 2022-02-18 16:11:45.866 - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.lastDiscovered changed: 1645197105844 (ack = true) -
@fortune95 Hi,
sorry für die späte Antwort ... Kannst Du es nochmal machen und das zweite log mit dem hcitool auch parallel holen? Das ist denke ich dann interessant in Kombi
Hi, hab es jetzt mal über die Shell versucht, hier bekomme ich ein Authentication Fehler.
Hast Du eine Idee wie ich den beheben kann.iobroker@iobroker:~$ bluetoothctl Agent registered [CHG] Controller 08:BE:AC:20:8E:F2 Pairable: yes [bluetooth]# devices Device 4D:C8:A4:58:F8:96 4D-C8-A4-58-F8-96 Device 09:CB:9E:AF:84:DF 09-CB-9E-AF-84-DF Device FE:4F:B0:DD:AA:22 Eve Degree 5980 Device 71:B7:B8:6D:37:1D 71-B7-B8-6D-37-1D Device 51:DA:80:04:EA:0C 51-DA-80-04-EA-0C Device 50:2D:26:B8:7F:B1 50-2D-26-B8-7F-B1 [DEL] Device 50:2D:26:B8:7F:B1 50-2D-26-B8-7F-B1 [DEL] Device 71:B7:B8:6D:37:1D 71-B7-B8-6D-37-1D [DEL] Device 09:CB:9E:AF:84:DF 09-CB-9E-AF-84-DF [DEL] Device 51:DA:80:04:EA:0C 51-DA-80-04-EA-0C [DEL] Device 4D:C8:A4:58:F8:96 4D-C8-A4-58-F8-96 [bluetooth]# pair FE:4F:B0:DD:AA:22 Attempting to pair with FE:4F:B0:DD:AA:22 [CHG] Device FE:4F:B0:DD:AA:22 Connected: yes Failed to pair: org.bluez.Error.AuthenticationFailed [CHG] Device FE:4F:B0:DD:AA:22 Connected: no -
@fortune95 Denke diese bluetooth kommandos brauchen root ... also rum das mit sudo auf
@apollon77
Mit sudo bekomme ich die gleiche Fehlermeldung
@fortune95 aber duuuuuuu. In der obigen Anleitung steht nichts von dem Kommando oder?‘
Ich meine das du das parallel zum Adapter laufen lassen sollst: „ sudo hcidump -t -x >log.txt“
@apollon77
hab mich wohl verrannt, hab versucht den treiber des BLE adatpters zu updaten.
Jetzt findet bluetoothctl keinen Controller mehr. -
@fortune95 uuups ... was hast Du getan?
@apollon77
Wie gesagt hatte versucht den Treiber zu updaten... leider war mein letztes Image Backup ein Monat alt..., hab jetzt alles wieder auf Stand und der BLE Adapter ist auch wieder auffindbar.Habe den Adapter über den Admin gestartet und vorab über die Shell den hcidump angeworfen. Im Admin bekam ich beim Versuch das BLE zu identifizieren, die folgende Fehlermeldung:
HCI sniffer - Bluetooth packet analyzer ver 5.55 device: hci0 snap_len: 1500 filter: 0xffffffffffffffff 2022-03-14 20:06:06.432692 < HCI Command: Set Event Mask (0x03|0x0001) plen 8 Mask: 0xfffffbff07f8bf3d 2022-03-14 20:06:06.433869 > HCI Event: Command Complete (0x0e) plen 4 Set Event Mask (0x03|0x0001) ncmd 2 status 0x00 2022-03-14 20:06:06.433896 < HCI Command: LE Set Event Mask (0x08|0x0001) plen 8 mask 0x1f00000000000000 (Reserved) 2022-03-14 20:06:06.434835 > HCI Event: Command Complete (0x0e) plen 4 LE Set Event Mask (0x08|0x0001) ncmd 2 status 0x00 2022-03-14 20:06:06.434858 < HCI Command: Read Local Version Information (0x04|0x0001) plen 0 2022-03-14 20:06:06.435878 > HCI Event: Command Complete (0x0e) plen 12 Read Local Version Information (0x04|0x0001) ncmd 2 status 0x00 HCI Version: 5.1 (0xa) HCI Revision: 0xb LMP Version: 5.1 (0xa) LMP Subversion: 0x8761 Manufacturer: Realtek Semiconductor Corporation (93) 2022-03-14 20:06:06.435902 < HCI Command: Write LE Host Supported (0x03|0x006d) plen 2 01 00 2022-03-14 20:06:06.436832 > HCI Event: Command Complete (0x0e) plen 4 Write LE Host Supported (0x03|0x006d) ncmd 2 00 2022-03-14 20:06:06.436858 < HCI Command: Read LE Host Supported (0x03|0x006c) plen 0 2022-03-14 20:06:06.437836 > HCI Event: Command Complete (0x0e) plen 6 Read LE Host Supported (0x03|0x006c) ncmd 2 00 01 00 2022-03-14 20:06:06.437860 < HCI Command: LE Read Buffer Size (0x08|0x0002) plen 0 2022-03-14 20:06:06.438834 > HCI Event: Command Complete (0x0e) plen 7 LE Read Buffer Size (0x08|0x0002) ncmd 2 status 0x00 pktlen 0x00fb maxpkt 0x08 2022-03-14 20:06:06.438858 < HCI Command: Read BD ADDR (0x04|0x0009) plen 0 2022-03-14 20:06:06.439837 > HCI Event: Command Complete (0x0e) plen 10 Read BD ADDR (0x04|0x0009) ncmd 2 status 0x00 bdaddr 08:BE:AC:20:8E:F2 2022-03-14 20:06:06.442284 < HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 value 0x00 (scanning disabled) filter duplicates 0x01 (enabled) 2022-03-14 20:06:06.443833 > HCI Event: Command Complete (0x0e) plen 4 LE Set Scan Enable (0x08|0x000c) ncmd 2 status 0x00 2022-03-14 20:06:06.443859 < HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7 type 0x01 (active) interval 10.000ms window 10.000ms own address: 0x00 (Public) policy: All 2022-03-14 20:06:06.444827 > HCI Event: Command Complete (0x0e) plen 4 LE Set Scan Parameters (0x08|0x000b) ncmd 2 status 0x00 2022-03-14 20:06:06.447855 < HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 value 0x00 (scanning disabled) filter duplicates 0x01 (enabled) 2022-03-14 20:06:06.448834 > HCI Event: Command Complete (0x0e) plen 4 LE Set Scan Enable (0x08|0x000c) ncmd 2 status 0x00 2022-03-14 20:06:06.448861 < HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7 type 0x01 (active) interval 10.000ms window 10.000ms -
@fortune95 Hasdt DU passend dazu auch das ausführliche Debug log des Adapters (Also adapter manuell starten mit DEBUG= ....? Idealerweise brauche ich beides Parallel das ich über die Zeitstempel mappen kann ... sonst rate ich wieder nur rum
@apollon77
Wie kann ich denn beide Befehle über die Shell zeitgleich starten? Hast du da einen Tipp für mich. Wenn ich einen von beiden Befehle absetze, ist die Shell blockiert und lässt nur mit STRG - C abbrechen. -
@fortune95 Indem du zwei Shell Fenster parallel öffnest?
@apollon77
Manchmal ist es so einfach...
Hier die Logs:
log.txtiobroker@iobroker:~$ DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debug --logs 2022-03-16 05:17:11.668 - debug: homekit-controller.0 (16117) Redis Objects: Use Redis connection: 127.0.0.1:9001 2022-03-16 05:17:11.708 - debug: homekit-controller.0 (16117) Objects client ready ... initialize now 2022-03-16 05:17:11.709 - debug: homekit-controller.0 (16117) Objects create System PubSub Client 2022-03-16 05:17:11.710 - debug: homekit-controller.0 (16117) Objects create User PubSub Client 2022-03-16 05:17:11.733 - debug: homekit-controller.0 (16117) Objects client initialize lua scripts 2022-03-16 05:17:11.735 - debug: homekit-controller.0 (16117) Objects connected to redis: 127.0.0.1:9001 2022-03-16 05:17:11.749 - debug: homekit-controller.0 (16117) Redis States: Use Redis connection: 127.0.0.1:6379 2022-03-16 05:17:11.751 - debug: homekit-controller.0 (16117) States create System PubSub Client 2022-03-16 05:17:11.751 - debug: homekit-controller.0 (16117) States create User PubSub Client 2022-03-16 05:17:11.754 - debug: homekit-controller.0 (16117) States connected to redis: 127.0.0.1:6379 2022-03-16 05:17:11.766 - debug: homekit-controller.0 (16117) Plugin sentry Initialize Plugin (enabled=true) 2022-03-16 05:17:11.818 - error: homekit-controller.0 (16117) adapter disabled 2022-03-16 05:17:11.866 - info: homekit-controller.0 (16117) starting. Version 0.4.3 (non-npm: Apollon77/ioBroker.homekit-controller#b7c7f7174ee7700864d870c2125c4d00aba85aa5) in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.21 2022-03-16 05:17:11.936 - debug: homekit-controller.0 (16117) state homekit-controller.0.info.connection changed: false (ack = true) 2022-03-16 05:17:11.940 - debug: homekit-controller.0 (16117) Init 1 known devices without discovery ... 2022-03-16 05:17:11.940 - debug: homekit-controller.0 (16117) Init BLE-6E:B1:4A:68:AA:BB as known device 2022-03-16 05:17:11.940 - info: homekit-controller.0 (16117) BLE-6E:B1:4A:68:AA:BB (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects 2022-03-16 05:17:11.941 - debug: homekit-controller.0 (16117) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"6e:b1:4a:68:aa:bb","ACID":10,"GSN":6,"CN":3,"CV":2,"c#":3,"id":"6e:b1:4a:68:aa:bb","ci":10,"availableToPair":true} 2022-03-16 05:17:11.952 - debug: homekit-controller.0 (16117) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.connectionType changed: BLE (ack = true) 2022-03-16 05:17:11.955 - debug: homekit-controller.0 (16117) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.id changed: 6e:b1:4a:68:aa:bb (ack = true) 2022-03-16 05:17:11.958 - debug: homekit-controller.0 (16117) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.connected changed: false (ack = true) 2022-03-16 05:17:11.963 - debug: homekit-controller.0 (16117) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.admin.isPaired changed: false (ack = true) 2022-03-16 05:17:11.967 - debug: homekit-controller.0 (16117) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.lastDiscovered changed: 1647404231941 (ack = true) 2022-03-16 05:17:29.918 - debug: homekit-controller.0 (16117) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":119,"ack":false,"time":1647404249917},"_id":67504295}) 2022-03-16 05:17:29.919 - debug: homekit-controller.0 (16117) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-6E:B1:4A:68:AA:BB","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]} 2022-03-16 05:17:35.645 - debug: homekit-controller.0 (16117) Message identify received: {"command":"identify","message":{"deviceId":"BLE-6E:B1:4A:68:AA:BB"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-6E:B1:4A:68:AA:BB"},"id":120,"ack":false,"time":1647404255644},"_id":67504296}) 2022-03-16 05:17:35.645 - debug: homekit-controller.0 (16117) Device BLE-6E:B1:4A:68:AA:BB: Identify triggered 2022-03-16 05:17:35.646 - debug: homekit-controller.0 (16117) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-6E:B1:4A:68:AA:BB because of error undefined: Cannot read property 'state' of undefined"} ^Ciobroker@iobroker:~$ DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debug --logs 2022-03-16 05:19:05.630 - debug: homekit-controller.0 (16134) Redis Objects: Use Redis connection: 127.0.0.1:9001 2022-03-16 05:19:05.650 - debug: homekit-controller.0 (16134) Objects client ready ... initialize now 2022-03-16 05:19:05.656 - debug: homekit-controller.0 (16134) Objects create System PubSub Client 2022-03-16 05:19:05.657 - debug: homekit-controller.0 (16134) Objects create User PubSub Client 2022-03-16 05:19:05.688 - debug: homekit-controller.0 (16134) Objects client initialize lua scripts 2022-03-16 05:19:05.690 - debug: homekit-controller.0 (16134) Objects connected to redis: 127.0.0.1:9001 2022-03-16 05:19:05.703 - debug: homekit-controller.0 (16134) Redis States: Use Redis connection: 127.0.0.1:6379 2022-03-16 05:19:05.705 - debug: homekit-controller.0 (16134) States create System PubSub Client 2022-03-16 05:19:05.706 - debug: homekit-controller.0 (16134) States create User PubSub Client 2022-03-16 05:19:05.708 - debug: homekit-controller.0 (16134) States connected to redis: 127.0.0.1:6379 2022-03-16 05:19:05.720 - debug: homekit-controller.0 (16134) Plugin sentry Initialize Plugin (enabled=true) 2022-03-16 05:19:05.770 - error: homekit-controller.0 (16134) adapter disabled 2022-03-16 05:19:05.824 - info: homekit-controller.0 (16134) starting. Version 0.4.3 (non-npm: Apollon77/ioBroker.homekit-controller#b7c7f7174ee7700864d870c2125c4d00aba85aa5) in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.21 2022-03-16 05:19:05.893 - debug: homekit-controller.0 (16134) state homekit-controller.0.info.connection changed: false (ack = true) 2022-03-16 05:19:05.897 - debug: homekit-controller.0 (16134) Init 1 known devices without discovery ... 2022-03-16 05:19:05.897 - debug: homekit-controller.0 (16134) Init BLE-6E:B1:4A:68:AA:BB as known device 2022-03-16 05:19:05.898 - info: homekit-controller.0 (16134) BLE-6E:B1:4A:68:AA:BB (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects 2022-03-16 05:19:05.899 - debug: homekit-controller.0 (16134) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"6e:b1:4a:68:aa:bb","ACID":10,"GSN":6,"CN":3,"CV":2,"c#":3,"id":"6e:b1:4a:68:aa:bb","ci":10,"availableToPair":true} 2022-03-16 05:19:05.909 - debug: homekit-controller.0 (16134) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.connectionType changed: BLE (ack = true) 2022-03-16 05:19:05.913 - debug: homekit-controller.0 (16134) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.id changed: 6e:b1:4a:68:aa:bb (ack = true) 2022-03-16 05:19:05.915 - debug: homekit-controller.0 (16134) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.connected changed: false (ack = true) 2022-03-16 05:19:05.920 - debug: homekit-controller.0 (16134) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.admin.isPaired changed: false (ack = true) 2022-03-16 05:19:05.923 - debug: homekit-controller.0 (16134) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.lastDiscovered changed: 1647404345899 (ack = true) 2022-03-16 05:19:30.853 - debug: homekit-controller.0 (16134) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":121,"ack":false,"time":1647404370852},"_id":67504297}) 2022-03-16 05:19:30.853 - debug: homekit-controller.0 (16134) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-6E:B1:4A:68:AA:BB","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]} 2022-03-16 05:19:32.854 - debug: homekit-controller.0 (16134) Message identify received: {"command":"identify","message":{"deviceId":"BLE-6E:B1:4A:68:AA:BB"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-6E:B1:4A:68:AA:BB"},"id":122,"ack":false,"time":1647404372853},"_id":67504298}) 2022-03-16 05:19:32.854 - debug: homekit-controller.0 (16134) Device BLE-6E:B1:4A:68:AA:BB: Identify triggered 2022-03-16 05:19:32.855 - debug: homekit-controller.0 (16134) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-6E:B1:4A:68:AA:BB because of error undefined: Cannot read property 'state' of undefined"} -
@fortune95 Ich glaube jetzt warste zu schnell ... der Adapter hatte das Gerät noch nicht mal gefunden als Du schon getriggert hast ... damit gaaaaanz anderer Fehler (aber fixe ich) ... Also gibt dem Adapter mal Zeit bis er auch BLE discovered hat
