    4. Influx arbeitet nicht mehr stabil
      Thomas Braun Most Active @Altersrentner last edited by
      @altersrentner
      systemctl status influxd influxdb
      anschauen.
        Altersrentner @Thomas Braun last edited by
        @thomas-braun Bitte
        pi@raspberrypi:~ $ systemctl status influxd influxdb
        ● influxdb.service - InfluxDB is an open-source, distributed, time series database
           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
           Active: active (running) since Sat 2022-03-12 14:40:27 CET; 1h 10min ago
             Docs: man:influxd(1)
         Main PID: 478 (influxd)
            Tasks: 14 (limit: 4915)
           CGroup: /system.slice/influxdb.service
                   └─478 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
        Mar 12 15:50:37 raspberrypi influxd[478]: ts=2022-03-12T14:50:37.353213Z lvl=info msg="Aborted compaction" log_id=0_BaaK70000
        Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.345574Z lvl=info msg="TSM compaction (end)" log_id=0_BaaK700
        Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346336Z lvl=info msg="TSM compaction (start)" log_id=0_BaaK7
        Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346381Z lvl=info msg="Beginning compaction" log_id=0_BaaK700
        Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346403Z lvl=info msg="Compacting file" log_id=0_BaaK70000 en
        Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346425Z lvl=info msg="Compacting file" log_id=0_BaaK70000 en
        Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346445Z lvl=info msg="Compacting file" log_id=0_BaaK70000 en
        Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346465Z lvl=info msg="Compacting file" log_id=0_BaaK70000 en
        Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346824Z lvl=info msg="Aborted compaction" log_id=0_BaaK70000
        Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.353357Z lvl=info msg="TSM compaction (end)" log_id=0_BaaK700
        lines 1-23
          Wildbill @Altersrentner last edited by
          @altersrentner Hast Du den influx-Adapter im iobroker geupdated? Dann musst Du dort einmal das Passwort neu eintragen.
          Also das Passwort der Influx-DB.
          Gruss, Jürgen
            Altersrentner @Wildbill last edited by
            @wildbill Hallo Jürgen,
            Da steht doch ein Passwort drin.?
            MfG Michael
              @altersrentner
              Das nochmal neueintragen. Evtl. zuvor mal bewusst ein falsches angeben.
              A 2 Replies Last reply Reply Quote 0
                @thomas-braun sagte in Influx arbeitet nicht mehr stabil:
                Kann ich das irgendwo auslesen?
                Habs vergessen😧
                  @thomas-braun gefunden😊
                  Habe das Passwort eingegeben und Verbindung Prüfen aktiviert.
                  Antwort OK.
                  Jetzt ist der Adapter grün.
                  Wie kann es sein, das sich das Passwort verstellt?
                  MfG Michael
                  A W 2 Replies Last reply Reply Quote 0
                    Altersrentner @Altersrentner last edited by
                    @altersrentner
                    Ich bedanke mich für Eure schnelle Hilfe
                    und Unterstützung👍 👍 👍
                    Mit freundlichen Grüßen
                    Michael
                      @altersrentner Das Passwort hat sich nicht verstellt, sondern der Adapter hat es beim Update schlicht „vergessen“. Warum, weiss ich auch nicht, hatte das aber gestern hier irgendwo gelesen.
                      Gruss, Jürgen
                        Danke für die Info.
                        Das kann doch aber nicht richtig sein.
                        MfG Michael
                        • OliverIO
                          OliverIO @Altersrentner last edited by
                          @altersrentner
                          dann mach ein issue beim adapter auf
                          https://github.com/ioBroker/ioBroker.influxdb/issues
                            Guten Morgen,
                            Wieder dieselbe Situation,
                            Influx.0 Adapter geht wie gehabt seit ca. 60 min kurzzeitig auf Unterbrechung.
                            Alle Punkte wie in den vergangenen Posts angeraten überprüft.
                            Auch Passwort neu gesetzt.
                            Es wird nur nachts ein Backup gemacht.
                            Sonst nichts.
                            Das ist doch nicht normal.
                            Michael
                              crunchip Forum Testing Most Active @Altersrentner last edited by
                              @altersrentner noch mal zusammenfassend
                              Wo läuft die InfluxDb?
                              Schalte die Instanz mal auf debug um zu sehen was für ein Problem vorliegt
                              F A 2 Replies Last reply Reply Quote 0
                                funky4t @crunchip last edited by funky4t
                                @crunchip @Altersrentner
                                Ich muss mich hier mal kurz "ranhängen", wenn ich darf ... 😉
                                Ich hab den influx adapter gestern auch upgedatet und dabei hat er scheinbar ebenfalls mein PW für die InfluxDB shell version: 1.8.10 "vergessen".
                                Ich hab dann das alte PW vom User neu eingegeben. Danach hat mir der Broker im Log einen Error von wegen "retention policy" im Log ausgegeben. Nach etwas Googeln hab ich mich dann entschieden, den admin der Influx im Adapter mitsamt PW zu hinterlegen, danach lief er fehlerfrei hoch.
                                Heut sehe ich wieder ein verfügbares Update auf 2.6.3 im Broker und hab upgedatet. Nun kommt IMMER ein "Error: authorization failed", im Test und im Log des Brokers.
                                Ich habe 1. das PW und 2. den User nach dem Update nicht geändert.
                                Interessant ist, wenn ich das erste Passwort Influx PW "admin" eingebe, dann variert es JEDESMAL von der zweiten Abfrage in der Adapter Konfiguration. Sprich ich kann dem Admin beide Passworte gleich eingeben, speichern und wenn ich die Konfiguration dann erneut öffne und das GLEICHE PW wie vorher eingebe, ergibt die PW Prüfung einen Fehler......als wenn durch erneutes Öffnen der Konfiguration ein altes PW wieder eingesetzt wird...
                                Irgendwo ist da meines Erachtens ein Bug und leider krieg ich den Adapter trotz 100% richtigem Passwort jetzt in 2.6.3 überhaupt nicht mehr auf grün!
                                Habt ihr eventuell noch einen Tip? Ich mach als Noobie immer ungern nen Issue auf Git auf... Der Broker liegt in einer VM auf Proxmox, Influx und Grafana im CT. Lief Monate ohne Probleme......
                                LG funky4t
                                • wendy2702
                                  wendy2702 @funky4t last edited by
                                  @funky4t kannst du dich mit dem User/PW denn noch in Influx einloggen?
                                  Sonst möglicherweise User geblockt wegen zu vielen Fehlversuchen
                                    funky4t @wendy2702 last edited by
                                    @wendy2702
                                    Würd sagen über die Shell geht es definitiv....
                                    wendy2702 F 2 Replies Last reply Reply Quote 0
                                    • wendy2702
                                      @funky4t Wenn du auf dem iobroker Rechner mal in einem Fenster User und PW eintippst, passt das dann?
                                      Groß/klein usw.
                                        funky4t @funky4t last edited by funky4t
                                        !!!UPDATE!!!
                                        Ich hab des Spaßeshalber mal die IP der influx im Adapter "überschrieben", also wirklich exakt die gleiche IP eingegeben und evoila auf einmal wird der Adapter grün!
                                        Wirkt als würde die Konfiguration angezeigt, aber im Hintergrund war gestern nach Update das PW weg und heut die IP.... Jetzt rennt es...
                                        Ich hab aber noch ein Feeling, das nach dem letzen MacOS Update mein Mac sich manchmal seltsam verhält, vielleicht war da noch was im Safari Browser Cache?!? Die Nummer mit den neu einzugebenden Passworten hatte ich gestern aber auf ner Windows Kiste in Firefox.... Also so richtig schlau werd ich daraus nicht....
                                          Altersrentner @funky4t last edited by
                                          @funky4t Hallo,
                                          Warum auch immer; es funktioniert wieder.
                                          Unerklärlich
                                          Michael
                                            Altersrentner @crunchip last edited by
                                            @crunchip sagte in Influx arbeitet nicht mehr stabil:
                                            Wie muss ich das machen?
                                            Wieder extreme Ausfälle.
                                            Alle Punkte wie hier vorgegeben geprüft.
                                            MfG Michael
                                            influx grafana vis
                                            15314
