    4. js-controller 4.0.x jetzt für alle User im STABLE!
    • Fabio
      Fabio @apollon77 last edited by
      @apollon77 vielen Dank das Update auf 4.0.21 lief fehlerfrei durch.👍 😊 ☺
        apollon77 @Chaot last edited by
        @chaot @crunchip nee lasst mal. Auch gute Dinge müssen mal ein Ende finden ;-))
        Ben1983 O 2 Replies Last reply Reply Quote 2
        • O
          oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
          @apollon77
          Nach Upgrade von .19 auf .21 (ohne Änderung an Node!):
          2022-03-14 10:16:08.191  - error: ham.0 (24984) uncaught exception: Cannot find module './homekit.js'
          Require stack:
          - /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-hs100/lib/plug.js
          - /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-hs100/lib/platform.js
          - /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-hs100/index.js
          - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/plugin.js
          - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManager.js
          - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js
          - /opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js
          - /opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js
          - /opt/iobroker/node_modules/iobroker.ham/main.js
          2022-03-14 10:16:08.197  - error: ham.0 (24984) Error: Cannot find module './homekit.js'
          Require stack:
             at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
             at Function.Module._load (internal/modules/cjs/loader.js:746:27)
             at Function.Module._load (/opt/iobroker/node_modules/mock-require/index.js:30:22)
             at Module.require (internal/modules/cjs/loader.js:974:19)
             at require (internal/modules/cjs/helpers.js:101:18)
             at new PlugAccessory (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-hs100/lib/plug.js:37:28)
             at Hs100Platform.addAccessory (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-hs100/lib/platform.js:113:27)
             at Client.<anonymous> (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-hs100/lib/platform.js:56:12)
             at Client.emit (events.js:400:28)
             at Client.emit (/opt/iobroker/node_modules/iobroker.ham/node_modules/hs100-api/lib/client.js:348:18)
          2022-03-14 10:16:08.197  - error: ham.0 (24984) Exception-Code: MODULE_NOT_FOUND: Cannot find module './homekit.js'
          Require stack:
          2022-03-14 10:16:11.273  - error: host.iobroker Caught by controller[1]: [14.3.2022, 10:16:07] [eWeLink] ***** Disabling plugin. *****
          2022-03-14 10:16:11.274  - error: host.iobroker Caught by controller[2]: [14.3.2022, 10:16:07] [eWeLink] ***** Cannot find module './connection/http'
          2022-03-14 10:16:11.274  - error: host.iobroker Caught by controller[2]: Require stack:
          2022-03-14 10:16:11.275  - error: host.iobroker Caught by controller[2]: - /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-ewelink/lib/index.js
          2022-03-14 10:16:11.275  - error: host.iobroker Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/plugin.js
          2022-03-14 10:16:11.276  - error: host.iobroker Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManager.js
          2022-03-14 10:16:11.277  - error: host.iobroker Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js
          2022-03-14 10:16:11.277  - error: host.iobroker Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js
          2022-03-14 10:16:11.278  - error: host.iobroker Caught by controller[2]: - /opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js
          2022-03-14 10:16:11.278  - error: host.iobroker Caught by controller[2]: - /opt/iobroker/node_modules/iobroker.ham/main.jsRequire stack:. *****
          2022-03-14 10:16:11.279  - error: host.iobroker instance system.adapter.ham.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2022-03-14 10:16:11.279  - info: host.iobroker Adapter system.adapter.ham.0 needs rebuild and will be restarted afterwards.
          2022-03-14 10:16:11.282  - info: host.iobroker system.adapter.ham.0 will be rebuilt
          2022-03-14 10:16:11.283  - warn: host.iobroker adapter "ham" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
          2022-03-14 10:16:11.284  - info: host.iobroker iobroker rebuild
          2022-03-14 10:16:12.488  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
          2022-03-14 10:16:31.542  - info: host.iobroker iobroker npm-rebuild:
          2022-03-14 10:16:31.543  - info: host.iobroker iobroker npm-rebuild: > ffmpeg-for-homebridge@0.0.9 install /opt/iobroker/node_modules/ffmpeg-for-homebridge> node install.js
          2022-03-14 10:16:33.231  - info: host.iobroker iobroker npm-rebuild: ffmpeg has been downloaded to /opt/iobroker/node_modules/ffmpeg-for-homebridge/ffmpeg
          2022-03-14 10:16:33.237  - info: host.iobroker iobroker npm-rebuild: Thank you for using https://github.com/homebridge/ffmpeg-for-homebridge
          2022-03-14 10:16:33.239  - info: host.iobroker iobroker npm-rebuild:
          2022-03-14 10:16:33.871  - info: host.iobroker iobroker npm-rebuild:
          2022-03-14 10:16:33.874  - info: host.iobroker iobroker npm-rebuild: > core-js@2.6.12 postinstall /opt/iobroker/node_modules/core-js> node -e "try{require('./postinstall')}catch(e){}"
          2022-03-14 10:16:35.485  - info: host.iobroker iobroker npm-rebuild: > iobroker.javascript@5.2.21 postinstall /opt/iobroker/node_modules/iobroker.javascript> node ./install/installTypings.js
          2022-03-14 10:16:35.770  - info: host.iobroker iobroker npm-rebuild: Installing NodeJS typings...
          2022-03-14 10:16:39.259  - info: host.iobroker iobroker npm-rebuild: latest @types: 17, installed node: 14
          2022-03-14 10:16:46.189  - info: host.iobroker iobroker npm-rebuild: > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
          2022-03-14 10:16:46.191  - info: host.iobroker iobroker npm-rebuild: > node lib/preinstallCheck.js
          2022-03-14 10:16:46.943  - info: host.iobroker iobroker npm-rebuild: NPM version: 6.14.16
          2022-03-14 10:16:46.991  - info: host.iobroker iobroker npm-rebuild:
          2022-03-14 10:16:46.992  - info: host.iobroker iobroker npm-rebuild: > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller> node iobroker.js setup first
          2022-03-14 10:16:56.941  - info: host.iobroker iobroker npm-rebuild: Successfully migrated 23520 objects to Redis Sets
          2022-03-14 10:16:57.386  - info: host.iobroker iobroker npm-rebuild: object _design/system updated
          2022-03-14 10:16:58.225  - info: host.iobroker iobroker npm-rebuild: {
          2022-03-14 10:16:58.228  - info: host.iobroker iobroker npm-rebuild:   "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r
          2022-03-14 10:16:58.235  - info: host.iobroker iobroker npm-rebuild: The object "system.certificates" was updated successfully.Update certificate defaultPublic
          2022-03-14 10:16:58.239  - info: host.iobroker iobroker npm-rebuild: The object "system.certificates" was updated successfully.
          2022-03-14 10:16:59.630  - info: host.iobroker iobroker npm-rebuild:
          2022-03-14 10:16:59.631  - info: host.iobroker iobroker npm-rebuild: > esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild> node install.js
          2022-03-14 10:17:02.675  - info: host.iobroker iobroker npm-rebuild: > iobroker.vis@1.4.12 install /opt/iobroker/node_modules/iobroker.vis> node main.js --install
          Ist ein gekürztes Log, weil das Forum nicht mehr zulässt.
            apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by
            @ofbeqnpolkkl6mby5e13 SD Karten System? Wenn ja schau mal nach der SD Karte. Das plötzlich ein File fehlt ist strange.
            ggf mal das homebridge-hs100 Plugin entfernen und neu beim Adapter einfügen das es neu installiert wird. Kann an sich mit dem Update nichts zu tun haben.
            Gleiches dann bei homebridge-ewelink ... das scheint es ja irgendwie auch getroffen zu haben. Und irgendeine ausgabe scheint das system denken zu lassen das ein rebuild nötig ist. Schaden am ende nicht 🙂
            • O
              @apollon77
              Container auf NAS (RAID5).
              Es läuft ohne mein Zutun alles wieder, nachdem alle Rebuilds durchgelaufen sind. Aber da wurden unglaublich viele Abhängigkeiten neu gebaut...
                @ofbeqnpolkkl6mby5e13 Strange ... aber Selbstheilung ist doch cool gg
                • Basti97
                  Basti97 Most Active last edited by Basti97
                  Auf meinem Master ging die Installation Fehlerfrei aber auf meinem Slave bekomme ich diese Meldung. Und der JS wird nicht von 3.3.22 auf 4.0.21 aktualisiert.
                  pi@Media04:~ $ iob upgrade self
                  Update js-controller from @3.3.22 to @4.0.21
                  npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefi                                          x "/opt/iobroker" (System call)
                  npm ERR! Unexpected token  in JSON at position 966657 while parsing near '...6Gg                                          iGOvl7CY/KNh8rxS�'�&�&�'�&�&�'�...'
                  npm ERR!     /home/iobroker/.npm/_logs/2022-03-14T14_06_53_816Z-debug.log
                  Ich probiere mal mit den Befehl npm install iobroker.js-controller@4.0.21 --production
                    apollon77 @Basti97 last edited by
                    @basti97 Das sieht nah einesm FileSystem Error aus ... mal npm cache clean --force bzw sudo -u iobroker -H npm cache clean --force versuchen. Und dann nochmals
                    Basti97 2 Replies Last reply Reply Quote 0
                    • Basti97
                      Basti97 Most Active @apollon77 last edited by
                      @apollon77 ok ich probiere es. Danke
                      • Basti97
                        Basti97 Most Active @apollon77 last edited by Basti97
                        @apollon77
                        das kommt raus
                        pi@Media04:~ $ npm cache clean --force
                        npm WARN using --force I sure hope you know what you are doing.
                        pi@Media04:~ $ sudo -u iobroker -H npm cache clean --force
                        pi@Media04:~ $
                        update
                           │      New major version of npm available! 6.14.16 → 8.5.4      │
                           │   Changelog: https://github.com/npm/cli/releases/tag/v8.5.4   │
                           │               Run npm install -g npm to update!               │
                        pi@Media04:~ $ npm install -g npm
                          @basti97 sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                          Wer hat gesagt Du sollst das tun? Naja egal ...
                          Jetzt neu versuchen
                          Basti97 1 Reply Last reply Reply Quote 0
                          • Basti97
                            @apollon77 na das habe ich nicht gemacht. Die Meldung kam beim zweiten mal Ausführen von.
                            • Basti97
                              Funktoniert trotzdem irgendwie nicht
                              pi@Media04:~ $ iob update
                              Used repository: stable
                              hash changed or no sources cached => force download of new sources
                              update done
                              Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/iobroker.backitup/io-package.json: /opt/iobroker/node_modules/iobroker.backitup/io-package.json: Unexpected token � in JSON at position 0
                              Adapter    "admin"         : 5.3.1    , installed 5.2.3 [Updateable]
                              Adapter    "discovery"     : 2.7.5    , installed 2.7.5
                              Adapter    "ds18b20"       : 1.6.0    , installed 1.6.0
                              Adapter    "javascript"    : 5.2.21   , installed 5.3.1
                              Controller "js-controller" : 4.0.21   , installed 3.3.22 [Updateable]
                              Adapter    "radar2"        : 2.0.3    , installed 2.0.3
                              Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
                              npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                              npm ERR! Unexpected token  in JSON at position 966657 while parsing near '...6GgiGOvl7CY/KNh8rxS�'�&�&�'�&�&�'�...'
                              npm ERR!     /home/iobroker/.npm/_logs/2022-03-14T15_40_52_691Z-debug.log
                              pi@Media04:~ $
                                Dann schau mal da welches File es betrifft ... irgendwas hat es dir das zersemmelt ... Wenn SD Kartenbasiert dann stirbt die Karte gerade
                                • Basti97
                                  @apollon77 Ja ist eine SD Karte drinnen 🙂 Das könnte auch der Grund sein das wieder der zigbee Adapter nach einem neustart des Raspberrys auf einmal nicht mehr funktioniert. Seit gestern schalten die Relais sporadisch aus auch wenn die nicht mit den rpi Adapter angesteuert wurden.
                                    Thomas Braun Most Active @Basti97 last edited by
                                    @basti97
                                    Schau mal per
                                    dmesg -T | grep -i ext4
                                    nach dem Dateisystem. Da könnten u. U. ein paar Meldungen drin sein.
                                    • Basti97
                                      Basti97 Most Active @Thomas Braun last edited by
                                      @thomas-braun said in js-controller 4.0.x jetzt für alle User im STABLE!:
                                      raus kommt das hier
                                      pi@Media04:~ $ dmesg -T | grep -i ext4
                                      [Mo Mär 14 14:58:36 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=832c4200-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                      [Mo Mär 14 14:58:39 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                      [Mo Mär 14 14:58:39 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                      [Mo Mär 14 14:58:42 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                      Thomas Braun 1 Reply Last reply Reply Quote -1
                                        @basti97
                                        Nix wildes drin.
                                        • Basti97
                                          @thomas-braun Also ist es mit der SD Karte noch nicht am Ende. Ist trotzdem komisch ich starte den Slave neu und plötzlich geht der Zigbee Adapter nicht mehr. (Wie schon mal). Dann möchte ich den JS aktualisieren das will er auch nicht. Der läuft zwar mit 3.3.22 wollte ihn aber trotzdem mal aktualisieren. Bei meinem Master (VM) hat es gleich beim ersten mal funktioniert.
                                            Das kann man so nicht sagen.
                                            Die eine SD-Karte, die mir mal abgenippelt ist hat sich auch nicht in logs verewigt. Da hat sich nur das System 'komisch' verhalten.
                                            501
                                            138653
