    4. js-controller 4.0.x jetzt für alle User im STABLE!
    • Basti97
      Basti97 Most Active @apollon77 last edited by
      @apollon77 ok ich probiere es. Danke
      • Basti97
        Basti97 Most Active @apollon77 last edited by Basti97
        @apollon77
        das kommt raus
        pi@Media04:~ $ npm cache clean --force
        npm WARN using --force I sure hope you know what you are doing.
        pi@Media04:~ $ sudo -u iobroker -H npm cache clean --force
        pi@Media04:~ $
        update
           │      New major version of npm available! 6.14.16 → 8.5.4      │
           │   Changelog: https://github.com/npm/cli/releases/tag/v8.5.4   │
           │               Run npm install -g npm to update!               │
        pi@Media04:~ $ npm install -g npm
          apollon77 @Basti97 last edited by
          @basti97 sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
          Wer hat gesagt Du sollst das tun? Naja egal ...
          Jetzt neu versuchen
          Basti97 1 Reply Last reply Reply Quote 0
          • Basti97
            @apollon77 na das habe ich nicht gemacht. Die Meldung kam beim zweiten mal Ausführen von.
            • Basti97
              Basti97 Most Active last edited by
              Funktoniert trotzdem irgendwie nicht
              pi@Media04:~ $ iob update
              Used repository: stable
              hash changed or no sources cached => force download of new sources
              update done
              Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/iobroker.backitup/io-package.json: /opt/iobroker/node_modules/iobroker.backitup/io-package.json: Unexpected token � in JSON at position 0
              Adapter    "admin"         : 5.3.1    , installed 5.2.3 [Updateable]
              Adapter    "discovery"     : 2.7.5    , installed 2.7.5
              Adapter    "ds18b20"       : 1.6.0    , installed 1.6.0
              Adapter    "javascript"    : 5.2.21   , installed 5.3.1
              Controller "js-controller" : 4.0.21   , installed 3.3.22 [Updateable]
              Adapter    "radar2"        : 2.0.3    , installed 2.0.3
              Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
              pi@Media04:~ $ iob upgrade self
              Update js-controller from @3.3.22 to @4.0.21
              NPM version: 6.14.16
              npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
              npm ERR! Unexpected token  in JSON at position 966657 while parsing near '...6GgiGOvl7CY/KNh8rxS�'�&�&�'�&�&�'�...'
              npm ERR!     /home/iobroker/.npm/_logs/2022-03-14T15_40_52_691Z-debug.log
              pi@Media04:~ $
                Dann schau mal da welches File es betrifft ... irgendwas hat es dir das zersemmelt ... Wenn SD Kartenbasiert dann stirbt die Karte gerade
                • Basti97
                  @apollon77 Ja ist eine SD Karte drinnen 🙂 Das könnte auch der Grund sein das wieder der zigbee Adapter nach einem neustart des Raspberrys auf einmal nicht mehr funktioniert. Seit gestern schalten die Relais sporadisch aus auch wenn die nicht mit den rpi Adapter angesteuert wurden.
                    Thomas Braun Most Active @Basti97 last edited by
                    @basti97
                    Schau mal per
                    dmesg -T | grep -i ext4
                    nach dem Dateisystem. Da könnten u. U. ein paar Meldungen drin sein.
                    • Basti97
                      Basti97 Most Active @Thomas Braun last edited by
                      @thomas-braun said in js-controller 4.0.x jetzt für alle User im STABLE!:
                      raus kommt das hier
                      pi@Media04:~ $ dmesg -T | grep -i ext4
                      [Mo Mär 14 14:58:36 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=832c4200-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                      [Mo Mär 14 14:58:39 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                      [Mo Mär 14 14:58:39 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Mo Mär 14 14:58:42 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                      Thomas Braun 1 Reply Last reply Reply Quote -1
                        @basti97
                        Nix wildes drin.
                        • Basti97
                          @thomas-braun Also ist es mit der SD Karte noch nicht am Ende. Ist trotzdem komisch ich starte den Slave neu und plötzlich geht der Zigbee Adapter nicht mehr. (Wie schon mal). Dann möchte ich den JS aktualisieren das will er auch nicht. Der läuft zwar mit 3.3.22 wollte ihn aber trotzdem mal aktualisieren. Bei meinem Master (VM) hat es gleich beim ersten mal funktioniert.
                            Das kann man so nicht sagen.
                            Die eine SD-Karte, die mir mal abgenippelt ist hat sich auch nicht in logs verewigt. Da hat sich nur das System 'komisch' verhalten.
                            • Basti97
                              Basti97 Most Active @Thomas Braun last edited by Basti97
                              @thomas-braunIch habe das nochmal eingegeben ob es nun funktoniert. Aber scheint wieder nicht
                              pi@Media04:~ $ iobroker upgrade self
                              npm ERR!     /home/iobroker/.npm/_logs/2022-03-14T17_17_58_023Z-debug.log
                              pi@Media04:~ $
                              Ich habe noch ein Backup von Anfang Februar. Da muss ich das mal auf eine andere SDKarte machen.
                                @basti97
                                Lösch mal den npm cache:
                                cd /opt/iobroker
                                sudo -H -u iobroker npm cache clear --force
                                Dann nochmal
                                iobroker update
                                iobroker stop
                                iobroker upgrade
                                iobroker fix
                                iobroker start
                                • Basti97
                                  Es kommt wieder das gleiche
                                    Welches file ist denn kaputt?? Was steht in dem npm log?
                                    • Basti97
                                      @apollon77 Wie muss ich das gleich nochmal aufrufen. Geht das auch per console?
                                      • wendy2702
                                        wendy2702 @Basti97 last edited by
                                        @basti97 zum Beispiel:
                                        cat /home/iobroker/.npm/_logs/2022-03-14T17_17_58_023Z-debug.log
                                        • Basti97
                                          Basti97 Most Active @wendy2702 last edited by
                                          @wendy2702 Super hat geklappt Danke dir ich poste gleichmal das Log
                                          • Basti97
                                            @wendy2702 @apollon77 @thomas braun
                                            pi@Media04:/opt/iobroker $ cat /home/iobroker/.npm/_logs/2022-03-14T17_17_58_023Z-debug.log
                                            0 info it worked if it ends with ok
                                            1 verbose cli [
                                            1 verbose cli   '/usr/bin/node',
                                            1 verbose cli   '/usr/bin/npm',
                                            1 verbose cli   'install',
                                            1 verbose cli   'iobroker.js-controller@4.0.21',
                                            1 verbose cli   '--loglevel',
                                            1 verbose cli   'error',
                                            1 verbose cli   '--unsafe-perm',
                                            1 verbose cli   '--prefix',
                                            1 verbose cli   '/opt/iobroker'
                                            1 verbose cli ]
                                            2 info using npm@6.14.16
                                            3 info using node@v14.19.0
                                            4 verbose npm-session fd4e95419961ed17
                                            5 silly install loadCurrentTree
                                            6 silly install readLocalPackageData
                                            7 http fetch GET 304 https://registry.npmjs.org/iobroker.js-controller 614ms (from cache)
                                            8 silly pacote version manifest for iobroker.js-controller@4.0.21 fetched in 695ms
                                            9 timing stage:loadCurrentTree Completed in 18129ms
                                            10 silly install loadIdealTree
                                            11 silly install cloneCurrentTreeToIdealTree
                                            12 timing stage:loadIdealTree:cloneCurrentTree Completed in 262ms
                                            13 silly install loadShrinkwrap
                                            14 timing stage:rollbackFailedOptional Completed in 2ms
                                            15 timing stage:runTopLevelLifecycles Completed in 18457ms
                                            16 silly saveTree iobroker.inst@3.0.0
                                            16 silly saveTree ├─┬ iobroker.admin@5.2.3
                                            16 silly saveTree │ ├─┬ @iobroker/adapter-core@2.5.1
                                            16 silly saveTree │ │ └─┬ @types/iobroker@3.3.4
                                            16 silly saveTree │ │   └── @types/node@17.0.16
                                            16 silly saveTree │ ├─┬ body-parser@1.19.1
                                            16 silly saveTree │ │ ├── bytes@3.1.1
                                            16 silly saveTree │ │ ├── content-type@1.0.4
                                            16 silly saveTree │ │ ├─┬ debug@2.6.9
                                            16 silly saveTree │ │ │ └── ms@2.0.0
                                            16 silly saveTree │ │ ├── depd@1.1.2
                                            16 silly saveTree │ │ ├─┬ http-errors@1.8.1
                                            16 silly saveTree │ │ │ ├── inherits@2.0.4
                                            16 silly saveTree │ │ │ ├── setprototypeof@1.2.0
                                            16 silly saveTree │ │ │ ├── statuses@1.5.0
                                            16 silly saveTree │ │ │ └── toidentifier@1.0.1
                                            16 silly saveTree │ │ ├─┬ iconv-lite@0.4.24
                                            16 silly saveTree │ │ │ └── safer-buffer@2.1.2
                                            16 silly saveTree │ │ ├─┬ on-finished@2.3.0
                                            16 silly saveTree │ │ │ └── ee-first@1.1.1
                                            16 silly saveTree │ │ ├── qs@6.9.6
                                            16 silly saveTree │ │ ├─┬ raw-body@2.4.2
                                            16 silly saveTree │ │ │ └── unpipe@1.0.0
                                            16 silly saveTree │ │ └─┬ type-is@1.6.18
                                            16 silly saveTree │ │   ├── media-typer@0.3.0
                                            16 silly saveTree │ │   └─┬ mime-types@2.1.34
                                            16 silly saveTree │ │     └── mime-db@1.51.0
                                            16 silly saveTree │ ├── connect-flash@0.1.1
                                            16 silly saveTree │ ├─┬ cookie-parser@1.4.6
                                            16 silly saveTree │ │ ├── cookie-signature@1.0.6
                                            16 silly saveTree │ │ └── cookie@0.4.1
                                            16 silly saveTree │ ├─┬ express-fileupload@1.3.1
                                            16 silly saveTree │ │ └─┬ busboy@0.3.1
                                            16 silly saveTree │ │   └─┬ dicer@0.3.0
                                            16 silly saveTree │ │     └── streamsearch@0.1.2
                                            16 silly saveTree │ ├─┬ express-session@1.17.2
                                            16 silly saveTree │ │ ├── cookie@0.4.1
                                            16 silly saveTree │ │ ├── depd@2.0.0
                                            16 silly saveTree │ │ ├── on-headers@1.0.2
                                            16 silly saveTree │ │ ├── parseurl@1.3.3
                                            16 silly saveTree │ │ ├── safe-buffer@5.2.1
                                            16 silly saveTree │ │ └─┬ uid-safe@2.1.5
                                            16 silly saveTree │ │   └── random-bytes@1.0.0
                                            16 silly saveTree │ ├─┬ express@4.17.2
                                            16 silly saveTree │ │ ├─┬ accepts@1.3.8
                                            16 silly saveTree │ │ │ └── negotiator@0.6.3
                                            16 silly saveTree │ │ ├── array-flatten@1.1.1
                                            16 silly saveTree │ │ ├── content-disposition@0.5.4
                                            16 silly saveTree │ │ ├── encodeurl@1.0.2
                                            16 silly saveTree │ │ ├── escape-html@1.0.3
                                            16 silly saveTree │ │ ├── etag@1.8.1
                                            16 silly saveTree │ │ ├─┬ finalhandler@1.1.2
                                            16 silly saveTree │ │ │ └─┬ debug@2.6.9
                                            16 silly saveTree │ │ ├── fresh@0.5.2
                                            16 silly saveTree │ │ ├── merge-descriptors@1.0.1
                                            16 silly saveTree │ │ ├── methods@1.1.2
                                            16 silly saveTree │ │ ├── path-to-regexp@0.1.7
                                            16 silly saveTree │ │ ├─┬ proxy-addr@2.0.7
                                            16 silly saveTree │ │ │ ├── forwarded@0.2.0
                                            16 silly saveTree │ │ │ └── ipaddr.js@1.9.1
                                            16 silly saveTree │ │ ├── range-parser@1.2.1
                                            16 silly saveTree │ │ ├─┬ send@0.17.2
                                            16 silly saveTree │ │ │ ├─┬ debug@2.6.9
                                            16 silly saveTree │ │ │ │ └── ms@2.0.0
                                            16 silly saveTree │ │ │ ├── destroy@1.0.4
                                            16 silly saveTree │ │ │ ├── mime@1.6.0
                                            16 silly saveTree │ │ │ └── ms@2.1.3
                                            16 silly saveTree │ │ ├── serve-static@1.14.2
                                            16 silly saveTree │ │ ├── utils-merge@1.0.1
                                            16 silly saveTree │ │ └── vary@1.1.2
                                            16 silly saveTree │ ├─┬ passport-local@1.0.0
                                            16 silly saveTree │ │ └── passport-strategy@1.0.0
                                            16 silly saveTree │ ├─┬ passport.socketio@3.7.0
                                            16 silly saveTree │ │ └── xtend@4.0.2
                                            16 silly saveTree │ ├─┬ passport@0.5.2
                                            16 silly saveTree │ │ └── pause@0.0.1
                                            16 silly saveTree │ ├─┬ request@2.88.2
                                            16 silly saveTree │ │ ├── aws-sign2@0.7.0
                                            16 silly saveTree │ │ ├── aws4@1.11.0
                                            16 silly saveTree │ │ ├── caseless@0.12.0
                                            16 silly saveTree │ │ ├─┬ combined-stream@1.0.8
                                            16 silly saveTree │ │ │ └── delayed-stream@1.0.0
                                            16 silly saveTree │ │ ├── extend@3.0.2
                                            16 silly saveTree │ │ ├── forever-agent@0.6.1
                                            16 silly saveTree │ │ ├─┬ form-data@2.3.3
                                            16 silly saveTree │ │ │ └── asynckit@0.4.0
                                            16 silly saveTree │ │ ├─┬ har-validator@5.1.5
                                            16 silly saveTree │ │ │ ├─┬ ajv@6.12.6
                                            16 silly saveTree │ │ │ │ ├── fast-deep-equal@3.1.3
                                            16 silly saveTree │ │ │ │ ├── fast-json-stable-stringify@2.1.0
                                            16 silly saveTree │ │ │ │ ├── json-schema-traverse@0.4.1
                                            16 silly saveTree │ │ │ │ └─┬ uri-js@4.4.1
                                            16 silly saveTree │ │ │ │   └── punycode@2.1.1
                                            16 silly saveTree │ │ │ └── har-schema@2.0.0
                                            16 silly saveTree │ │ ├─┬ http-signature@1.2.0
                                            16 silly saveTree │ │ │ ├── assert-plus@1.0.0
                                            16 silly saveTree │ │ │ ├─┬ jsprim@1.4.2
                                            16 silly saveTree │ │ │ │ ├── extsprintf@1.3.0
                                            16 silly saveTree │ │ │ │ ├── json-schema@0.4.0
                                            16 silly saveTree │ │ │ │ └─┬ verror@1.10.0
                                            16 silly saveTree │ │ │ │   └── core-util-is@1.0.2
                                            16 silly saveTree │ │ │ └─┬ sshpk@1.17.0
                                            16 silly saveTree │ │ │   ├── asn1@0.2.6
                                            16 silly saveTree │ │ │   ├─┬ bcrypt-pbkdf@1.0.2
                                            16 silly saveTree │ │ │   │ └── tweetnacl@0.14.5
                                            16 silly saveTree │ │ │   ├── dashdash@1.14.1
                                            16 silly saveTree │ │ │   ├─┬ ecc-jsbn@0.1.2
                                            16 silly saveTree │ │ │   │ └── jsbn@0.1.1
                                            16 silly saveTree │ │ │   ├── getpass@0.1.7
                                            16 silly saveTree │ │ │   ├── jsbn@0.1.1
                                            16 silly saveTree │ │ │   └── tweetnacl@0.14.5
                                            16 silly saveTree │ │ ├── is-typedarray@1.0.0
                                            16 silly saveTree │ │ ├── isstream@0.1.2
                                            16 silly saveTree │ │ ├── json-stringify-safe@5.0.1
                                            16 silly saveTree │ │ ├── oauth-sign@0.9.0
                                            16 silly saveTree │ │ ├── performance-now@2.1.0
                                            16 silly saveTree │ │ ├── qs@6.5.3
                                            16 silly saveTree │ │ ├─┬ tough-cookie@2.5.0
                                            16 silly saveTree │ │ │ └── psl@1.8.0
                                            16 silly saveTree │ │ ├── tunnel-agent@0.6.0
                                            16 silly saveTree │ │ └── uuid@3.4.0
                                            16 silly saveTree │ ├─┬ semver@7.3.5
                                            16 silly saveTree │ │ └─┬ lru-cache@6.0.0
                                            16 silly saveTree │ │   └── yallist@4.0.0
                                            16 silly saveTree │ └── ws@8.5.0
                                            16 silly saveTree ├─┬ iobroker.backitup@2.3.3
                                            16 silly saveTree │ ├─┬ @googleapis/drive@2.2.0
                                            16 silly saveTree │ │ └─┬ googleapis-common@5.1.0
                                            16 silly saveTree │ │   ├─┬ gaxios@4.3.2
                                            16 silly saveTree │ │   │ ├─┬ abort-controller@3.0.0
                                            16 silly saveTree │ │   │ │ └── event-target-shim@5.0.1
                                            16 silly saveTree │ │   │ ├─┬ https-proxy-agent@5.0.0
                                            16 silly saveTree │ │   │ │ ├─┬ agent-base@6.0.2
                                            16 silly saveTree │ │   │ │ │ └─┬ debug@4.3.3
                                            16 silly saveTree │ │   │ │ │   └── ms@2.1.2
                                            16 silly saveTree │ │   │ │ └─┬ debug@4.3.3
                                            16 silly saveTree │ │   │ │   └── ms@2.1.2
                                            16 silly saveTree │ │   │ ├── is-stream@2.0.1
                                            16 silly saveTree │ │   │ └─┬ node-fetch@2.6.7
                                            16 silly saveTree │ │   │   └─┬ whatwg-url@5.0.0
                                            16 silly saveTree │ │   │     ├── tr46@0.0.3
                                            16 silly saveTree │ │   │     └── webidl-conversions@3.0.1
                                            16 silly saveTree │ │   ├─┬ google-auth-library@7.14.0
                                            16 silly saveTree │ │   │ ├── arrify@2.0.1
                                            16 silly saveTree │ │   │ ├── base64-js@1.5.1
                                            16 silly saveTree │ │   │ ├── ecdsa-sig-formatter@1.0.11
                                            16 silly saveTree │ │   │ ├── fast-text-encoding@1.0.3
                                            16 silly saveTree │ │   │ ├─┬ gcp-metadata@4.3.1
                                            16 silly saveTree │ │   │ │ └─┬ json-bigint@1.0.0
                                            16 silly saveTree │ │   │ │   └── bignumber.js@9.0.2
                                            16 silly saveTree │ │   │ ├─┬ gtoken@5.3.2
                                            16 silly saveTree │ │   │ │ ├─┬ google-p12-pem@3.1.3
                                            16 silly saveTree │ │   │ │ │ └── node-forge@1.2.1
                                            16 silly saveTree │ │   │ │ └─┬ jws@4.0.0
                                            16 silly saveTree │ │   │ │   └─┬ jwa@2.0.0
                                            16 silly saveTree │ │   │ │     └── buffer-equal-constant-time@1.0.1
                                            16 silly saveTree │ │   │ └─┬ jws@4.0.0
                                            16 silly saveTree │ │   │   └── jwa@2.0.0
                                            16 silly saveTree │ │   ├─┬ qs@6.10.3
                                            16 silly saveTree │ │   │ └─┬ side-channel@1.0.4
                                            16 silly saveTree │ │   │   ├─┬ call-bind@1.0.2
                                            16 silly saveTree │ │   │   │ ├── function-bind@1.1.1
                                            16 silly saveTree │ │   │   │ └─┬ get-intrinsic@1.1.1
                                            16 silly saveTree │ │   │   │   ├── has-symbols@1.0.2
                                            16 silly saveTree │ │   │   │   └── has@1.0.3
                                            16 silly saveTree │ │   │   ├── get-intrinsic@1.1.1
                                            16 silly saveTree │ │   │   └── object-inspect@1.12.0
                                            16 silly saveTree │ │   ├── url-template@2.0.8
                                            16 silly saveTree │ │   └── uuid@8.3.2
                                            16 silly saveTree │ ├─┬ axios@0.25.0
                                            16 silly saveTree │ │ └── follow-redirects@1.14.8
                                            16 silly saveTree │ ├── dropbox-v2-api@2.4.53
                                            16 silly saveTree │ ├─┬ fs-extra@10.0.1
                                            16 silly saveTree │ │ ├── graceful-fs@4.2.9
                                            16 silly saveTree │ │ ├─┬ jsonfile@6.1.0
                                            16 silly saveTree │ │ │ └── universalify@2.0.0
                                            16 silly saveTree │ │ └── universalify@2.0.0
                                            16 silly saveTree │ ├─┬ ftp@0.3.10
                                            16 silly saveTree │ │ ├─┬ readable-stream@1.1.14
                                            16 silly saveTree │ │ │ ├── core-util-is@1.0.3
                                            16 silly saveTree │ │ │ ├── isarray@0.0.1
                                            16 silly saveTree │ │ │ └── string_decoder@0.10.31
                                            16 silly saveTree │ │ └── xregexp@2.0.0
                                            16 silly saveTree │ ├── google-auth-library@7.14.0
                                            16 silly saveTree │ ├─┬ node-schedule@2.1.0
                                            16 silly saveTree │ │ ├─┬ cron-parser@3.5.0
                                            16 silly saveTree │ │ │ ├─┬ is-nan@1.3.2
                                            16 silly saveTree │ │ │ │ └─┬ define-properties@1.1.3
                                            16 silly saveTree │ │ │ │   └── object-keys@1.1.1
                                            16 silly saveTree │ │ │ └── luxon@1.28.0
                                            16 silly saveTree │ │ ├── long-timeout@0.1.1
                                            16 silly saveTree │ │ └── sorted-array-functions@1.3.0
                                            16 silly saveTree │ ├── node-wol@0.1.1
                                            16 silly saveTree │ ├─┬ tar-fs@2.1.1
                                            16 silly saveTree │ │ ├── chownr@1.1.4
                                            16 silly saveTree │ │ ├── mkdirp-classic@0.5.3
                                            16 silly saveTree │ │ ├─┬ pump@3.0.0
                                            16 silly saveTree │ │ │ ├─┬ end-of-stream@1.4.4
                                            16 silly saveTree │ │ │ │ └─┬ once@1.4.0
                                            16 silly saveTree │ │ │ │   └── wrappy@1.0.2
                                            16 silly saveTree │ │ │ └── once@1.4.0
                                            16 silly saveTree │ │ └─┬ tar-stream@2.2.0
                                            16 silly saveTree │ │   ├─┬ bl@4.1.0
                                            16 silly saveTree │ │   │ ├─┬ buffer@5.7.1
                                            16 silly saveTree │ │   │ │ └── ieee754@1.2.1
                                            16 silly saveTree │ │   │ └─┬ readable-stream@3.6.0
                                            16 silly saveTree │ │   │   ├─┬ string_decoder@1.1.1
                                            16 silly saveTree │ │   │   │ └── safe-buffer@5.1.2
                                            16 silly saveTree │ │   │   └── util-deprecate@1.0.2
                                            16 silly saveTree │ │   ├── fs-constants@1.0.0
                                            16 silly saveTree │ │   └── readable-stream@3.6.0
                                            16 silly saveTree │ └─┬ webdav@4.8.0
                                            16 silly saveTree │   ├── axios@0.24.0
                                            16 silly saveTree │   ├── base-64@1.0.0
                                            16 silly saveTree │   ├─┬ fast-xml-parser@3.21.1
                                            16 silly saveTree │   │ └── strnum@1.0.5
                                            16 silly saveTree │   ├── he@1.2.0
                                            16 silly saveTree │   ├── hot-patcher@0.5.0
                                            16 silly saveTree │   ├── layerr@0.1.2
                                            16 silly saveTree │   ├─┬ md5@2.3.0
                                            16 silly saveTree │   │ ├── charenc@0.0.2
                                            16 silly saveTree │   │ ├── crypt@0.0.2
                                            16 silly saveTree │   │ └── is-buffer@1.1.6
                                            16 silly saveTree │   ├─┬ minimatch@3.0.5
                                            16 silly saveTree │   │ └─┬ brace-expansion@1.1.11
                                            16 silly saveTree │   │   ├── balanced-match@1.0.2
                                            16 silly saveTree │   │   └── concat-map@0.0.1
                                            16 silly saveTree │   ├── nested-property@4.0.0
                                            16 silly saveTree │   ├── path-posix@1.0.0
                                            16 silly saveTree │   ├── url-join@4.0.1
                                            16 silly saveTree │   └─┬ url-parse@1.5.10
                                            16 silly saveTree │     ├── querystringify@2.2.0
                                            16 silly saveTree │     └── requires-port@1.0.0
                                            16 silly saveTree ├─┬ iobroker.discovery@2.7.5
                                            16 silly saveTree │ ├─┬ mdns-discovery@0.2.6
                                            16 silly saveTree │ │ ├─┬ debug@2.2.0
                                            16 silly saveTree │ │ │ └── ms@0.7.1
                                            16 silly saveTree │ │ ├── dgram@1.0.1
                                            16 silly saveTree │ │ └─┬ dns-packet@1.3.4
                                            16 silly saveTree │ │   └── ip@1.1.5
                                            16 silly saveTree │ ├── netmask@2.0.2
                                            16 silly saveTree │ ├── node-mndp@0.0.3
                                            16 silly saveTree │ ├─┬ node-ssdp@4.0.1
                                            16 silly saveTree │ │ ├─┬ async@2.6.3
                                            16 silly saveTree │ │ │ └── lodash@4.17.21
                                            16 silly saveTree │ │ ├── bluebird@3.7.2
                                            16 silly saveTree │ │ └─┬ debug@3.2.7
                                            16 silly saveTree │ │   └── ms@2.1.2
                                            16 silly saveTree │ └─┬ serialport@9.2.8
                                            16 silly saveTree │   ├─┬ @serialport/binding-mock@9.2.4
                                            16 silly saveTree │   │ ├─┬ @serialport/binding-abstract@9.2.3
                                            16 silly saveTree │   │ │ └── debug@4.3.3
                                            16 silly saveTree │   │ └── debug@4.3.3
                                            16 silly saveTree │   ├─┬ @serialport/bindings@9.2.8
                                            16 silly saveTree │   │ ├─┬ @serialport/parser-readline@9.2.4
                                            16 silly saveTree │   │ │ └── @serialport/parser-delimiter@9.2.4
                                            16 silly saveTree │   │ ├─┬ bindings@1.5.0
                                            16 silly saveTree │   │ │ └── file-uri-to-path@1.0.0
                                            16 silly saveTree │   │ ├── nan@2.15.0
                                            16 silly saveTree │   │ └─┬ prebuild-install@7.0.1
                                            16 silly saveTree │   │   ├── detect-libc@2.0.1
                                            16 silly saveTree │   │   ├── expand-template@2.0.3
                                            16 silly saveTree │   │   ├── github-from-package@0.0.0
                                            16 silly saveTree │   │   ├── minimist@1.2.5
                                            16 silly saveTree │   │   ├── napi-build-utils@1.0.2
                                            16 silly saveTree │   │   ├── node-abi@3.8.0
                                            16 silly saveTree │   │   ├─┬ npmlog@4.1.2
                                            16 silly saveTree │   │   │ ├─┬ are-we-there-yet@1.1.7
                                            16 silly saveTree │   │   │ │ ├── delegates@1.0.0
                                            16 silly saveTree │   │   │ │ └─┬ readable-stream@2.3.7
                                            16 silly saveTree │   │   │ │   ├── isarray@1.0.0
                                            16 silly saveTree │   │   │ │   ├── process-nextick-args@2.0.1
                                            16 silly saveTree │   │   │ │   ├── safe-buffer@5.1.2
                                            16 silly saveTree │   │   │ │   └── string_decoder@1.1.1
                                            16 silly saveTree │   │   │ ├── console-control-strings@1.1.0
                                            16 silly saveTree │   │   │ ├─┬ gauge@2.7.4
                                            16 silly saveTree │   │   │ │ ├── aproba@1.2.0
                                            16 silly saveTree │   │   │ │ ├── has-unicode@2.0.1
                                            16 silly saveTree │   │   │ │ ├── object-assign@4.1.1
                                            16 silly saveTree │   │   │ │ ├── signal-exit@3.0.7
                                            16 silly saveTree │   │   │ │ ├─┬ string-width@1.0.2
                                            16 silly saveTree │   │   │ │ │ ├── code-point-at@1.1.0
                                            16 silly saveTree │   │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
                                            16 silly saveTree │   │   │ │ │ │ └── number-is-nan@1.0.1
                                            16 silly saveTree │   │   │ │ │ └─┬ strip-ansi@3.0.1
                                            16 silly saveTree │   │   │ │ │   └── ansi-regex@2.1.1
                                            16 silly saveTree │   │   │ │ ├── strip-ansi@3.0.1
                                            16 silly saveTree │   │   │ │ └── wide-align@1.1.5
                                            16 silly saveTree │   │   │ └── set-blocking@2.0.0
                                            16 silly saveTree │   │   ├─┬ rc@1.2.8
                                            16 silly saveTree │   │   │ ├── deep-extend@0.6.0
                                            16 silly saveTree │   │   │ ├── ini@1.3.8
                                            16 silly saveTree │   │   │ └── strip-json-comments@2.0.1
                                            16 silly saveTree │   │   └─┬ simple-get@4.0.1
                                            16 silly saveTree │   │     ├─┬ decompress-response@6.0.0
                                            16 silly saveTree │   │     │ └── mimic-response@3.1.0
                                            16 silly saveTree │   │     └── simple-concat@1.0.1
                                            16 silly saveTree │   ├── @serialport/parser-byte-length@9.2.4
                                            16 silly saveTree │   ├── @serialport/parser-cctalk@9.2.4
                                            16 silly saveTree │   ├── @serialport/parser-delimiter@9.2.4
                                            16 silly saveTree │   ├── @serialport/parser-inter-byte-timeout@9.2.4
                                            16 silly saveTree │   ├── @serialport/parser-readline@9.2.4
                                            16 silly saveTree │   ├── @serialport/parser-ready@9.2.4
                                            16 silly saveTree │   ├── @serialport/parser-regex@9.2.4
                                            16 silly saveTree │   ├── @serialport/stream@9.2.4
                                            16 silly saveTree │   └── debug@4.3.3
                                            16 silly saveTree ├─┬ iobroker.ds18b20@1.6.0
                                            16 silly saveTree │ └── core-decorators@0.20.0
                                            16 silly saveTree ├─┬ iobroker.javascript@5.3.1
                                            16 silly saveTree │ ├─┬ @iobroker/adapter-core@2.6.0
                                            16 silly saveTree │ │ └─┬ @types/iobroker@4.0.1
                                            16 silly saveTree │ │   └── @types/node@14.18.12
                                            16 silly saveTree │ ├── @types/node@14.18.12
                                            16 silly saveTree │ ├─┬ @types/request@2.48.8
                                            16 silly saveTree │ │ ├── @types/caseless@0.12.2
                                            16 silly saveTree │ │ ├── @types/tough-cookie@4.0.1
                                            16 silly saveTree │ │ └── form-data@2.5.1
                                            16 silly saveTree │ ├── coffee-compiler@0.3.2
                                            16 silly saveTree │ ├── coffee-script@1.12.7
                                            16 silly saveTree │ ├── jsonata@1.8.6
                                            16 silly saveTree │ ├── node-inspect@2.0.0
                                            16 silly saveTree │ ├── suncalc2@1.8.1
                                            16 silly saveTree │ ├── typescript@4.6.2
                                            16 silly saveTree │ ├─┬ virtual-tsc@0.6.2
                                            16 silly saveTree │ │ └── picocolors@1.0.0
                                            16 silly saveTree │ ├─┬ vm2@3.9.9
                                            16 silly saveTree │ │ ├── acorn-walk@8.2.0
                                            16 silly saveTree │ │ └── acorn@8.7.0
                                            16 silly saveTree │ └── wake_on_lan@1.0.0
                                            16 silly saveTree ├─┬ iobroker.js-controller@3.3.22
                                            16 silly saveTree │ ├─┬ @alcalzone/esbuild-register@2.5.1-1
                                            16 silly saveTree │ │ ├── esbuild@0.11.23
                                            16 silly saveTree │ │ └── jsonc-parser@3.0.0
                                            16 silly saveTree │ ├─┬ @iobroker/db-objects-file@1.2.7
                                            16 silly saveTree │ │ ├─┬ @iobroker/db-base@1.2.4
                                            16 silly saveTree │ │ │ ├── deep-clone@3.0.3
                                            16 silly saveTree │ │ │ ├─┬ fs-extra@9.1.0
                                            16 silly saveTree │ │ │ │ └── at-least-node@1.0.0
                                            16 silly saveTree │ │ │ ├─┬ node.extend@2.0.2
                                            16 silly saveTree │ │ │ │ └── is@3.3.0
                                            16 silly saveTree │ │ │ └── respjs@4.2.0
                                            16 silly saveTree │ │ ├─┬ @iobroker/db-objects-redis@1.2.7
                                            16 silly saveTree │ │ │ └─┬ ioredis@4.28.5
                                            16 silly saveTree │ │ │   ├── cluster-key-slot@1.1.0
                                            16 silly saveTree │ │ │   ├── denque@1.5.1
                                            16 silly saveTree │ │ │   ├── lodash.defaults@4.2.0
                                            16 silly saveTree │ │ │   ├── lodash.flatten@4.4.0
                                            16 silly saveTree │ │ │   ├── lodash.isarguments@3.1.0
                                            16 silly saveTree │ │ │   ├── p-map@2.1.0
                                            16 silly saveTree │ │ │   ├── redis-commands@1.7.0
                                            16 silly saveTree │ │ │   ├── redis-errors@1.2.0
                                            16 silly saveTree │ │ │   ├── redis-parser@3.0.0
                                            16 silly saveTree │ │ │   └── standard-as-callback@2.1.0
                                            16 silly saveTree │ │ ├── deep-clone@3.0.3
                                            16 silly saveTree │ │ ├── fs-extra@9.1.0
                                            16 silly saveTree │ │ └── node.extend@2.0.2
                                            16 silly saveTree │ ├─┬ @iobroker/db-objects-jsonl@1.2.7
                                            16 silly saveTree │ │ └─┬ @alcalzone/jsonl-db@1.3.0
                                            16 silly saveTree │ │   ├── alcalzone-shared@3.0.4
                                            16 silly saveTree │ │   └─┬ proper-lockfile@4.1.2
                                            16 silly saveTree │ │     └── retry@0.12.0
                                            16 silly saveTree │ ├── @iobroker/db-objects-redis@1.2.7
                                            16 silly saveTree │ ├─┬ @iobroker/db-states-file@1.2.7
                                            16 silly saveTree │ │ └── @iobroker/db-states-redis@1.2.7
                                            16 silly saveTree │ ├── @iobroker/db-states-jsonl@1.2.7
                                            16 silly saveTree │ ├── @iobroker/db-states-redis@1.2.7
                                            16 silly saveTree │ ├── @iobroker/plugin-base@1.2.1
                                            16 silly saveTree │ ├─┬ @iobroker/plugin-sentry@1.1.10
                                            16 silly saveTree │ │ ├─┬ @sentry/integrations@6.17.6
                                            16 silly saveTree │ │ │ ├── @sentry/types@6.17.6
                                            16 silly saveTree │ │ │ ├─┬ @sentry/utils@6.17.6
                                            16 silly saveTree │ │ │ │ └── tslib@1.14.1
                                            16 silly saveTree │ │ │ ├─┬ localforage@1.10.0
                                            16 silly saveTree │ │ │ │ └─┬ lie@3.1.1
                                            16 silly saveTree │ │ │ │   └── immediate@3.0.6
                                            16 silly saveTree │ │ │ └── tslib@1.14.1
                                            16 silly saveTree │ │ ├─┬ @sentry/node@6.17.6
                                            16 silly saveTree │ │ │ ├─┬ @sentry/core@6.17.6
                                            16 silly saveTree │ │ │ │ ├── @sentry/hub@6.17.6
                                            16 silly saveTree │ │ │ │ └── @sentry/minimal@6.17.6
                                            16 silly saveTree │ │ │ ├── @sentry/hub@6.17.6
                                            16 silly saveTree │ │ │ ├── @sentry/tracing@6.17.6
                                            16 silly saveTree │ │ │ ├── cookie@0.4.2
                                            16 silly saveTree │ │ │ └── lru_map@0.3.3
                                            16 silly saveTree │ │ └─┬ source-map-support@0.5.21
                                            16 silly saveTree │ │   ├── buffer-from@1.1.2
                                            16 silly saveTree │ │   └── source-map@0.6.1
                                            16 silly saveTree │ ├─┬ chokidar@3.5.3
                                            16 silly saveTree │ │ ├─┬ anymatch@3.1.2
                                            16 silly saveTree │ │ │ ├── normalize-path@3.0.0
                                            16 silly saveTree │ │ │ └── picomatch@2.3.1
                                            16 silly saveTree │ │ ├─┬ braces@3.0.2
                                            16 silly saveTree │ │ │ └─┬ fill-range@7.0.1
                                            16 silly saveTree │ │ │   └─┬ to-regex-range@5.0.1
                                            16 silly saveTree │ │ │     └── is-number@7.0.0
                                            16 silly saveTree │ │ ├─┬ glob-parent@5.1.2
                                            16 silly saveTree │ │ │ └─┬ is-glob@4.0.3
                                            16 silly saveTree │ │ │   └── is-extglob@2.1.1
                                            16 silly saveTree │ │ ├─┬ is-binary-path@2.1.0
                                            16 silly saveTree │ │ │ └── binary-extensions@2.2.0
                                            16 silly saveTree │ │ ├── is-glob@4.0.3
                                            16 silly saveTree │ │ ├── normalize-path@3.0.0
                                            16 silly saveTree │ │ └── readdirp@3.6.0
                                            16 silly saveTree │ ├── ci-info@3.3.0
                                            16 silly saveTree │ ├── daemonize2@0.4.2
                                            16 silly saveTree │ ├─┬ decache@4.6.1
                                            16 silly saveTree │ │ └── callsite@1.0.0
                                            16 silly saveTree │ ├── deep-clone@3.0.3
                                            16 silly saveTree │ ├─┬ diskusage@1.1.3
                                            16 silly saveTree │ │ └── es6-promise@4.2.8
                                            16 silly saveTree │ ├─┬ event-stream@4.0.1
                                            16 silly saveTree │ │ ├── duplexer@0.1.2
                                            16 silly saveTree │ │ ├── from@0.1.7
                                            16 silly saveTree │ │ ├── map-stream@0.0.7
                                            16 silly saveTree │ │ ├─┬ pause-stream@0.0.11
                                            16 silly saveTree │ │ │ └── through@2.3.8
                                            16 silly saveTree │ │ ├── split@1.0.1
                                            16 silly saveTree │ │ ├── stream-combiner@0.2.2
                                            16 silly saveTree │ │ └── through@2.3.8
                                            16 silly saveTree │ ├── fs-extra@9.1.0
                                            16 silly saveTree │ ├─┬ greenlock-express@4.0.3
                                            16 silly saveTree │ │ ├─┬ @root/greenlock-express@4.0.4
                                            16 silly saveTree │ │ │ ├─┬ @root/greenlock@4.0.5
                                            16 silly saveTree │ │ │ │ ├─┬ @greenlock/manager@3.1.0
                                            16 silly saveTree │ │ │ │ │ └─┬ greenlock-manager-fs@3.1.1
                                            16 silly saveTree │ │ │ │ │   ├── @root/mkdirp@1.0.0
                                            16 silly saveTree │ │ │ │ │   └── safe-replace@1.1.0
                                            16 silly saveTree │ │ │ │ ├─┬ @root/acme@3.1.0
                                            16 silly saveTree │ │ │ │ │ ├─┬ @root/csr@0.8.1
                                            16 silly saveTree │ │ │ │ │ │ ├─┬ @root/asn1@1.0.0
                                            16 silly saveTree │ │ │ │ │ │ │ └── @root/encoding@1.0.1
                                            16 silly saveTree │ │ │ │ │ │ ├── @root/pem@1.0.4
                                            16 silly saveTree │ │ │ │ │ │ └── @root/x509@0.7.2
                                            16 silly saveTree │ │ │ │ │ ├── @root/encoding@1.0.1
                                            16 silly saveTree │ │ │ │ │ ├── @root/keypairs@0.10.3
                                            16 silly saveTree │ │ │ │ │ ├── @root/pem@1.0.4
                                            16 silly saveTree │ │ │ │ │ ├── @root/request@1.8.1
                                            16 silly saveTree │ │ │ │ │ └── @root/x509@0.7.2
                                            16 silly saveTree │ │ │ │ ├── @root/csr@0.8.1
                                            16 silly saveTree │ │ │ │ ├── @root/keypairs@0.10.3
                                            16 silly saveTree │ │ │ │ ├── @root/mkdirp@1.0.0
                                            16 silly saveTree │ │ │ │ ├── @root/request@1.8.1
                                            16 silly saveTree │ │ │ │ ├── acme-http-01-standalone@3.0.5
                                            16 silly saveTree │ │ │ │ ├── cert-info@1.5.1
                                            16 silly saveTree │ │ │ │ ├── greenlock-store-fs@3.2.2
                                            16 silly saveTree │ │ │ │ └── safe-replace@1.1.0
                                            16 silly saveTree │ │ │ └── redirect-https@1.3.1
                                            16 silly saveTree │ │ ├── @root/greenlock@4.0.5
                                            16 silly saveTree │ │ └── redirect-https@1.3.1
                                            16 silly saveTree │ ├─┬ greenlock@4.0.4
                                            16 silly saveTree │ │ └── @root/keypairs@0.9.0
                                            16 silly saveTree │ ├─┬ jsonwebtoken@8.5.1
                                            16 silly saveTree │ │ ├─┬ jws@3.2.2
                                            16 silly saveTree │ │ │ └── jwa@1.4.1
                                            16 silly saveTree │ │ ├── lodash.includes@4.3.0
                                            16 silly saveTree │ │ ├── lodash.isboolean@3.0.3
                                            16 silly saveTree │ │ ├── lodash.isinteger@4.0.4
                                            16 silly saveTree │ │ ├── lodash.isnumber@3.0.3
                                            16 silly saveTree │ │ ├── lodash.isplainobject@4.0.6
                                            16 silly saveTree │ │ ├── lodash.isstring@4.0.1
                                            16 silly saveTree │ │ ├── lodash.once@4.1.1
                                            16 silly saveTree │ │ └── semver@5.7.1
                                            16 silly saveTree │ ├─┬ jszip@3.7.1
                                            16 silly saveTree │ │ ├── lie@3.3.0
                                            16 silly saveTree │ │ ├── pako@1.0.11
                                            16 silly saveTree │ │ ├─┬ readable-stream@2.3.7
                                            16 silly saveTree │ │ │ ├── isarray@1.0.0
                                            16 silly saveTree │ │ │ └── safe-buffer@5.1.2
                                            16 silly saveTree │ │ └── set-immediate-shim@1.0.1
                                            16 silly saveTree │ ├─┬ le-acme-core@2.1.4
                                            16 silly saveTree │ │ └─┬ rsa-compat@1.9.4
                                            16 silly saveTree │ │   ├─┬ keypairs@1.2.14
                                            16 silly saveTree │ │   │ ├── eckles@1.4.1
                                            16 silly saveTree │ │   │ └── rasha@1.2.5
                                            16 silly saveTree │ │   ├── node-forge@0.7.6
                                            16 silly saveTree │ │   └── ursa-optional@0.9.10
                                            16 silly saveTree │ ├── le-challenge-fs@2.0.9
                                            16 silly saveTree │ ├── le-sni-auto@2.1.9
                                            16 silly saveTree │ ├─┬ loadavg-windows@1.1.1
                                            16 silly saveTree │ │ └── weak-daemon@1.0.3
                                            16 silly saveTree │ ├── mime@2.6.0
                                            16 silly saveTree │ ├── ncp@2.0.0
                                            16 silly saveTree │ ├── node-forge@0.10.0
                                            16 silly saveTree │ ├── node.extend@2.0.2
                                            16 silly saveTree │ ├── pidusage@2.0.21
                                            16 silly saveTree │ ├── promisify-child-process@4.1.1
                                            16 silly saveTree │ ├─┬ prompt@1.2.1
                                            16 silly saveTree │ │ ├── async@0.9.2
                                            16 silly saveTree │ │ ├── colors@1.4.0
                                            16 silly saveTree │ │ ├─┬ read@1.0.7
                                            16 silly saveTree │ │ │ └── mute-stream@0.0.8
                                            16 silly saveTree │ │ ├── revalidator@0.1.8
                                            16 silly saveTree │ │ └─┬ winston@2.4.5
                                            16 silly saveTree │ │   ├── async@1.0.0
                                            16 silly saveTree │ │   ├── colors@1.0.3
                                            16 silly saveTree │ │   ├── cycle@1.0.3
                                            16 silly saveTree │ │   ├── eyes@0.1.8
                                            16 silly saveTree │ │   └── stack-trace@0.0.10
                                            16 silly saveTree │ ├── readline-sync@1.4.10
                                            16 silly saveTree │ ├─┬ tar@6.1.11
                                            16 silly saveTree │ │ ├── chownr@2.0.0
                                            16 silly saveTree │ │ ├─┬ fs-minipass@2.1.0
                                            16 silly saveTree │ │ │ └── minipass@3.1.6
                                            16 silly saveTree │ │ ├── minipass@3.1.6
                                            16 silly saveTree │ │ ├── minizlib@2.1.2
                                            16 silly saveTree │ │ └── mkdirp@1.0.4
                                            16 silly saveTree │ ├─┬ winston-daily-rotate-file@4.6.0
                                            16 silly saveTree │ │ ├─┬ file-stream-rotator@0.6.1
                                            16 silly saveTree │ │ │ └── moment@2.29.1
                                            16 silly saveTree │ │ ├── object-hash@2.2.0
                                            16 silly saveTree │ │ ├── triple-beam@1.3.0
                                            16 silly saveTree │ │ └─┬ winston-transport@4.5.0
                                            16 silly saveTree │ │   ├─┬ logform@2.3.2
                                            16 silly saveTree │ │   │ ├── fecha@4.2.1
                                            16 silly saveTree │ │   │ └── safe-stable-stringify@1.1.1
                                            16 silly saveTree │ ├─┬ winston-seq-updated@1.0.4
                                            16 silly saveTree │ │ └── seq-logging@0.4.6
                                            16 silly saveTree │ ├─┬ winston-syslog@2.5.0
                                            16 silly saveTree │ │ ├── glossy@0.1.7
                                            16 silly saveTree │ │ └── unix-dgram@2.0.4
                                            16 silly saveTree │ ├─┬ winston@3.5.1
                                            16 silly saveTree │ │ ├─┬ @dabh/diagnostics@2.0.2
                                            16 silly saveTree │ │ │ ├─┬ colorspace@1.1.4
                                            16 silly saveTree │ │ │ │ ├─┬ color@3.2.1
                                            16 silly saveTree │ │ │ │ │ ├─┬ color-convert@1.9.3
                                            16 silly saveTree │ │ │ │ │ │ └── color-name@1.1.3
                                            16 silly saveTree │ │ │ │ │ └─┬ color-string@1.9.0
                                            16 silly saveTree │ │ │ │ │   └─┬ simple-swizzle@0.2.2
                                            16 silly saveTree │ │ │ │ │     └── is-arrayish@0.3.2
                                            16 silly saveTree │ │ │ │ └── text-hex@1.0.0
                                            16 silly saveTree │ │ │ ├── enabled@2.0.0
                                            16 silly saveTree │ │ │ └── kuler@2.0.0
                                            16 silly saveTree │ │ ├── async@3.2.3
                                            16 silly saveTree │ │ ├─┬ one-time@1.0.0
                                            16 silly saveTree │ │ │ └── fn.name@1.1.0
                                            16 silly saveTree │ │ ├── readable-stream@3.6.0
                                            16 silly saveTree │ │ └── safe-stable-stringify@2.3.1
                                            16 silly saveTree │ └─┬ yargs@16.2.0
                                            16 silly saveTree │   ├─┬ cliui@7.0.4
                                            16 silly saveTree │   │ ├─┬ string-width@4.2.3
                                            16 silly saveTree │   │ │ ├── emoji-regex@8.0.0
                                            16 silly saveTree │   │ │ ├── is-fullwidth-code-point@3.0.0
                                            16 silly saveTree │   │ │ └─┬ strip-ansi@6.0.1
                                            16 silly saveTree │   │ │   └── ansi-regex@5.0.1
                                            16 silly saveTree │   │ ├── strip-ansi@6.0.1
                                            16 silly saveTree │   │ └─┬ wrap-ansi@7.0.0
                                            16 silly saveTree │   │   ├─┬ ansi-styles@4.3.0
                                            16 silly saveTree │   │   │ └─┬ color-convert@2.0.1
                                            16 silly saveTree │   │   │   └── color-name@1.1.4
                                            16 silly saveTree │   │   └── strip-ansi@6.0.1
                                            16 silly saveTree │   ├── escalade@3.1.1
                                            16 silly saveTree │   ├── get-caller-file@2.0.5
                                            16 silly saveTree │   ├── require-directory@2.1.1
                                            16 silly saveTree │   ├─┬ string-width@4.2.3
                                            16 silly saveTree │   │ ├── is-fullwidth-code-point@3.0.0
                                            16 silly saveTree │   │ └─┬ strip-ansi@6.0.1
                                            16 silly saveTree │   │   └── ansi-regex@5.0.1
                                            16 silly saveTree │   ├── y18n@5.0.8
                                            16 silly saveTree │   └── yargs-parser@20.2.9
                                            16 silly saveTree ├─┬ iobroker.radar2@2.0.3
                                            16 silly saveTree │ ├─┬ @abandonware/noble@1.9.2-15
                                            16 silly saveTree │ │ ├─┬ @abandonware/bluetooth-hci-socket@0.5.3-8
                                            16 silly saveTree │ │ │ ├─┬ @mapbox/node-pre-gyp@1.0.8
                                            16 silly saveTree │ │ │ │ ├── detect-libc@1.0.3
                                            16 silly saveTree │ │ │ │ ├─┬ make-dir@3.1.0
                                            16 silly saveTree │ │ │ │ │ └── semver@6.3.0
                                            16 silly saveTree │ │ │ │ ├─┬ nopt@5.0.0
                                            16 silly saveTree │ │ │ │ │ └── abbrev@1.1.1
                                            16 silly saveTree │ │ │ │ ├─┬ npmlog@5.0.1
                                            16 silly saveTree │ │ │ │ │ ├─┬ are-we-there-yet@2.0.0
                                            16 silly saveTree │ │ │ │ │ │ └─┬ readable-stream@3.6.0
                                            16 silly saveTree │ │ │ │ │ │   └── string_decoder@1.3.0
                                            16 silly saveTree │ │ │ │ │ └─┬ gauge@3.0.2
                                            16 silly saveTree │ │ │ │ │   ├── color-support@1.1.3
                                            16 silly saveTree │ │ │ │ │   ├─┬ string-width@4.2.3
                                            16 silly saveTree │ │ │ │ │   │ ├── is-fullwidth-code-point@3.0.0
                                            16 silly saveTree │ │ │ │ │   │ └─┬ strip-ansi@6.0.1
                                            16 silly saveTree │ │ │ │ │   │   └── ansi-regex@5.0.1
                                            16 silly saveTree │ │ │ │ │   └── strip-ansi@6.0.1
                                            16 silly saveTree │ │ │ │ └─┬ rimraf@3.0.2
                                            16 silly saveTree │ │ │ │   └─┬ glob@7.2.0
                                            16 silly saveTree │ │ │ │     ├── fs.realpath@1.0.0
                                            16 silly saveTree │ │ │ │     ├── inflight@1.0.6
                                            16 silly saveTree │ │ │ │     └── path-is-absolute@1.0.1
                                            16 silly saveTree │ │ │ ├─┬ debug@4.3.3
                                            16 silly saveTree │ │ │ └─┬ usb@1.9.2
                                            16 silly saveTree │ │ │   ├── node-addon-api@4.3.0
                                            16 silly saveTree │ │ │   └── node-gyp-build@4.3.0
                                            16 silly saveTree │ │ ├─┬ debug@4.3.3
                                            16 silly saveTree │ │ │ └── ms@2.1.2
                                            16 silly saveTree │ │ └── node-addon-api@3.2.1
                                            16 silly saveTree │ ├── axios@0.21.4
                                            16 silly saveTree │ ├─┬ net-ping@1.2.3
                                            16 silly saveTree │ │ └─┬ raw-socket@1.7.0
                                            16 silly saveTree │ │   └── nan@2.14.2
                                            16 silly saveTree │ ├── node-arp@1.0.6
                                            16 silly saveTree │ ├─┬ node-ble@1.7.0
                                            16 silly saveTree │ │ └─┬ dbus-next@0.10.2
                                            16 silly saveTree │ │   ├── @nornagon/put@0.0.8
                                            16 silly saveTree │ │   ├─┬ event-stream@3.3.4
                                            16 silly saveTree │ │   │ ├── map-stream@0.1.0
                                            16 silly saveTree │ │   │ ├── split@0.3.3
                                            16 silly saveTree │ │   │ └── stream-combiner@0.0.4
                                            16 silly saveTree │ │   ├── hexy@0.2.11
                                            16 silly saveTree │ │   ├── jsbi@2.0.5
                                            16 silly saveTree │ │   ├── long@4.0.0
                                            16 silly saveTree │ │   ├─┬ usocket@0.3.0
                                            16 silly saveTree │ │   │ └─┬ node-gyp@7.1.2
                                            16 silly saveTree │ │   │   ├── env-paths@2.2.1
                                            16 silly saveTree │ │   │   └─┬ which@2.0.2
                                            16 silly saveTree │ │   │     └── isexe@2.0.0
                                            16 silly saveTree │ │   └─┬ xml2js@0.4.23
                                            16 silly saveTree │ │     ├── sax@1.2.4
                                            16 silly saveTree │ │     └── xmlbuilder@11.0.1
                                            16 silly saveTree │ ├─┬ ping@0.4.1
                                            16 silly saveTree │ │ ├── q@1.5.1
                                            16 silly saveTree │ │ └── underscore@1.13.2
                                            16 silly saveTree │ └── xml2js@0.4.23
                                            16 silly saveTree ├─┬ iobroker.rpi2@1.3.1
                                            16 silly saveTree │ ├─┬ node-dht-sensor@0.4.3
                                            16 silly saveTree │ │ └── node-addon-api@1.7.2
                                            16 silly saveTree │ ├─┬ rpi-gpio-buttons@2.0.1
                                            16 silly saveTree │ │ ├── button-events@1.0.2
                                            16 silly saveTree │ │ └─┬ rpi-gpio@2.1.7
                                            16 silly saveTree │ │   ├─┬ async-retry@1.3.3
                                            16 silly saveTree │ │   │ └── retry@0.13.1
                                            16 silly saveTree │ │   ├─┬ debug@3.2.7
                                            16 silly saveTree │ │   └── epoll@2.0.10
                                            16 silly saveTree │ ├── rpi-gpio@2.1.7
                                            16 silly saveTree │ └── sync-exec@0.6.2
                                            16 silly saveTree └─┬ iobroker.zigbee@1.6.16
                                            16 silly saveTree   ├── typescript@4.5.5
                                            16 silly saveTree   ├─┬ zigbee-herdsman-converters@14.0.422
                                            16 silly saveTree   │ ├── buffer-crc32@0.2.13
                                            16 silly saveTree   │ ├─┬ https-proxy-agent@5.0.0
                                            16 silly saveTree   │ │ ├─┬ agent-base@6.0.2
                                            16 silly saveTree   │ │ │ └─┬ debug@4.3.3
                                            16 silly saveTree   │ ├─┬ tar-stream@2.2.0
                                            16 silly saveTree   │ │ │ │ ├── base64-js@1.5.1
                                            16 silly saveTree   │ │ │   ├─┬ string_decoder@1.3.0
                                            16 silly saveTree   │ │ │   │ └── safe-buffer@5.2.1
                                            16 silly saveTree   │ │ ├─┬ end-of-stream@1.4.4
                                            16 silly saveTree   │ │ │ └─┬ once@1.4.0
                                            16 silly saveTree   │ │ │   └── wrappy@1.0.2
                                            16 silly saveTree   │ │ ├── inherits@2.0.4
                                            16 silly saveTree   │ └─┬ zigbee-herdsman@0.14.14
                                            16 silly saveTree   │   ├── debounce@1.2.1
                                            16 silly saveTree   │   ├─┬ debug@4.3.3
                                            16 silly saveTree   │   ├── fast-deep-equal@3.1.3
                                            16 silly saveTree   │   ├── mixin-deep@2.0.1
                                            16 silly saveTree   │   ├─┬ mz@2.7.0
                                            16 silly saveTree   │   │ ├── any-promise@1.3.0
                                            16 silly saveTree   │   │ ├── object-assign@4.1.1
                                            16 silly saveTree   │   │ └─┬ thenify-all@1.6.0
                                            16 silly saveTree   │   │   └── thenify@3.3.1
                                            16 silly saveTree   │   ├─┬ serialport@9.2.8
                                            16 silly saveTree   │   │ ├─┬ @serialport/binding-mock@9.2.4
                                            16 silly saveTree   │   │ │ └── @serialport/binding-abstract@9.2.3
                                            16 silly saveTree   │   │ ├─┬ @serialport/bindings@9.2.8
                                            16 silly saveTree   │   │ │ ├─┬ @serialport/parser-readline@9.2.4
                                            16 silly saveTree   │   │ │ │ └── @serialport/parser-delimiter@9.2.4
                                            16 silly saveTree   │   │ │ ├─┬ bindings@1.5.0
                                            16 silly saveTree   │   │ │ │ └── file-uri-to-path@1.0.0
                                            16 silly saveTree   │   │ │ ├── nan@2.15.0
                                            16 silly saveTree   │   │ │ └─┬ prebuild-install@7.0.1
                                            16 silly saveTree   │   │ │   ├── detect-libc@2.0.0
                                            16 silly saveTree   │   │ │   ├── expand-template@2.0.3
                                            16 silly saveTree   │   │ │   ├── github-from-package@0.0.0
                                            16 silly saveTree   │   │ │   ├── minimist@1.2.5
                                            16 silly saveTree   │   │ │   ├── mkdirp-classic@0.5.3
                                            16 silly saveTree   │   │ │   ├── napi-build-utils@1.0.2
                                            16 silly saveTree   │   │ │   ├─┬ node-abi@3.8.0
                                            16 silly saveTree   │   │ │   │ └─┬ semver@7.3.5
                                            16 silly saveTree   │   │ │   │   └─┬ lru-cache@6.0.0
                                            16 silly saveTree   │   │ │   │     └── yallist@4.0.0
                                            16 silly saveTree   │   │ │   ├─┬ npmlog@4.1.2
                                            16 silly saveTree   │   │ │   │ ├─┬ are-we-there-yet@1.1.7
                                            16 silly saveTree   │   │ │   │ │ ├── delegates@1.0.0
                                            16 silly saveTree   │   │ │   │ │ └─┬ readable-stream@2.3.7
                                            16 silly saveTree   │   │ │   │ │   ├── core-util-is@1.0.3
                                            16 silly saveTree   │   │ │   │ │   ├── inherits@2.0.4
                                            16 silly saveTree   │   │ │   │ │   ├── isarray@1.0.0
                                            16 silly saveTree   │   │ │   │ │   ├── process-nextick-args@2.0.1
                                            16 silly saveTree   │   │ │   │ │   ├── safe-buffer@5.1.2
                                            16 silly saveTree   │   │ │   │ │   ├── string_decoder@1.1.1
                                            16 silly saveTree   │   │ │   │ │   └── util-deprecate@1.0.2
                                            16 silly saveTree   │   │ │   │ ├── console-control-strings@1.1.0
                                            16 silly saveTree   │   │ │   │ ├─┬ gauge@2.7.4
                                            16 silly saveTree   │   │ │   │ │ ├── aproba@1.2.0
                                            16 silly saveTree   │   │ │   │ │ ├── has-unicode@2.0.1
                                            16 silly saveTree   │   │ │   │ │ ├── signal-exit@3.0.7
                                            16 silly saveTree   │   │ │   │ │ ├─┬ string-width@1.0.2
                                            16 silly saveTree   │   │ │   │ │ │ ├── code-point-at@1.1.0
                                            16 silly saveTree   │   │ │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
                                            16 silly saveTree   │   │ │   │ │ │ │ └── number-is-nan@1.0.1
                                            16 silly saveTree   │   │ │   │ │ │ └─┬ strip-ansi@3.0.1
                                            16 silly saveTree   │   │ │   │ │ │   └── ansi-regex@2.1.1
                                            16 silly saveTree   │   │ │   │ │ ├── strip-ansi@3.0.1
                                            16 silly saveTree   │   │ │   │ │ └── wide-align@1.1.5
                                            16 silly saveTree   │   │ │   │ └── set-blocking@2.0.0
                                            16 silly saveTree   │   │ │   ├─┬ pump@3.0.0
                                            16 silly saveTree   │   │ │   │ ├─┬ end-of-stream@1.4.4
                                            16 silly saveTree   │   │ │   │ │ └─┬ once@1.4.0
                                            16 silly saveTree   │   │ │   │ │   └── wrappy@1.0.2
                                            16 silly saveTree   │   │ │   │ └── once@1.4.0
                                            16 silly saveTree   │   │ │   ├─┬ rc@1.2.8
                                            16 silly saveTree   │   │ │   │ ├── deep-extend@0.6.0
                                            16 silly saveTree   │   │ │   │ ├── ini@1.3.8
                                            16 silly saveTree   │   │ │   │ └── strip-json-comments@2.0.1
                                            16 silly saveTree   │   │ │   ├─┬ simple-get@4.0.1
                                            16 silly saveTree   │   │ │   │ ├─┬ decompress-response@6.0.0
                                            16 silly saveTree   │   │ │   │ │ └── mimic-response@3.1.0
                                            16 silly saveTree   │   │ │   │ └── simple-concat@1.0.1
                                            16 silly saveTree   │   │ │   ├─┬ tar-fs@2.1.1
                                            16 silly saveTree   │   │ │   │ ├── chownr@1.1.4
                                            16 silly saveTree   │   │ │   │ └─┬ tar-stream@2.2.0
                                            16 silly saveTree   │   │ │   │   ├─┬ bl@4.1.0
                                            16 silly saveTree   │   │ │   │   │ ├─┬ buffer@5.7.1
                                            16 silly saveTree   │   │ │   │   │ │ ├── base64-js@1.5.1
                                            16 silly saveTree   │   │ │   │   │ │ └── ieee754@1.2.1
                                            16 silly saveTree   │   │ │   │   │ └── readable-stream@3.6.0
                                            16 silly saveTree   │   │ │   │   ├── fs-constants@1.0.0
                                            16 silly saveTree   │   │ │   │   └── readable-stream@3.6.0
                                            16 silly saveTree   │   │ │   └── tunnel-agent@0.6.0
                                            16 silly saveTree   │   │ ├── @serialport/parser-byte-length@9.2.4
                                            16 silly saveTree   │   │ ├── @serialport/parser-cctalk@9.2.4
                                            16 silly saveTree   │   │ ├── @serialport/parser-delimiter@9.2.4
                                            16 silly saveTree   │   │ ├── @serialport/parser-inter-byte-timeout@9.2.4
                                            16 silly saveTree   │   │ ├── @serialport/parser-readline@9.2.4
                                            16 silly saveTree   │   │ ├── @serialport/parser-ready@9.2.4
                                            16 silly saveTree   │   │ ├── @serialport/parser-regex@9.2.4
                                            16 silly saveTree   │   │ └── @serialport/stream@9.2.4
                                            16 silly saveTree   │   └── slip@1.0.2
                                            16 silly saveTree   └─┬ zigbee-herdsman@0.14.16
                                            16 silly saveTree     ├── debounce@1.2.1
                                            16 silly saveTree     ├─┬ debug@4.3.3
                                            16 silly saveTree     │ └── ms@2.1.2
                                            16 silly saveTree     ├── fast-deep-equal@3.1.3
                                            16 silly saveTree     ├── mixin-deep@2.0.1
                                            16 silly saveTree     ├─┬ mz@2.7.0
                                            16 silly saveTree     │ ├── any-promise@1.3.0
                                            16 silly saveTree     │ ├── object-assign@4.1.1
                                            16 silly saveTree     │ └─┬ thenify-all@1.6.0
                                            16 silly saveTree     │   └── thenify@3.3.1
                                            16 silly saveTree     ├─┬ serialport@9.2.8
                                            16 silly saveTree     │ │ └── @serialport/binding-abstract@9.2.3
                                            16 silly saveTree     │ │   ├── detect-libc@2.0.0
                                            16 silly saveTree     │ │   ├─┬ node-abi@3.8.0
                                            16 silly saveTree     │ │   │ └─┬ semver@7.3.5
                                            16 silly saveTree     │ │   │   └─┬ lru-cache@6.0.0
                                            16 silly saveTree     │ │   │     └── yallist@4.0.0
                                            16 silly saveTree     │ │   │ │   ├── core-util-is@1.0.3
                                            16 silly saveTree     │ │   │ │   ├── inherits@2.0.4
                                            16 silly saveTree     │ │   │ │   ├── string_decoder@1.1.1
                                            16 silly saveTree     │ │   │ │   └── util-deprecate@1.0.2
                                            16 silly saveTree     │ │   ├─┬ simple-get@4.0.1
                                            16 silly saveTree     │ │   │ ├─┬ decompress-response@6.0.0
                                            16 silly saveTree     │ │   │ │ └── mimic-response@3.1.0
                                            16 silly saveTree     │ │   │ └── simple-concat@1.0.1
                                            16 silly saveTree     │ │   ├─┬ tar-fs@2.1.1
                                            16 silly saveTree     │ │   │ ├── chownr@1.1.4
                                            16 silly saveTree     │ │   │ └─┬ tar-stream@2.2.0
                                            16 silly saveTree     │ │   │   ├─┬ bl@4.1.0
                                            16 silly saveTree     │ │   │   │ ├─┬ buffer@5.7.1
                                            16 silly saveTree     │ │   │   │ │ ├── base64-js@1.5.1
                                            16 silly saveTree     │ │   │   │ │ └── ieee754@1.2.1
                                            16 silly saveTree     │ │   │   ├── fs-constants@1.0.0
                                            16 silly saveTree     │ │   │   └── readable-stream@3.6.0
                                            16 silly saveTree     │ │   └── tunnel-agent@0.6.0
                                            16 silly saveTree     │ └── @serialport/stream@9.2.4
                                            16 silly saveTree     └── slip@1.0.2
                                            17 verbose stack SyntaxError: Unexpected token  in JSON at position 966657 while parsing near '...6GgiGOvl7CY/KNh8rxS�'�&�&�'�&�&�'�...'
                                            17 verbose stack     at JSON.parse (<anonymous>)
                                            17 verbose stack     at parseJson (/usr/lib/node_modules/npm/node_modules/json-parse-better-errors/index.js:7:17)
                                            17 verbose stack     at module.exports (/usr/lib/node_modules/npm/lib/utils/parse-json.js:4:10)
                                            17 verbose stack     at parsePkgLock (/usr/lib/node_modules/npm/lib/install/read-shrinkwrap.js:67:12)
                                            17 verbose stack     at /usr/lib/node_modules/npm/lib/install/read-shrinkwrap.js:27:22
                                            17 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
                                            17 verbose stack     at Holder$2._callFunction (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:1:1), <anonymous>:14:44)
                                            17 verbose stack     at Holder$2.checkFulfillment (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:1:1), <anonymous>:29:30)
                                            17 verbose stack     at Promise.eval (eval at thenCallback (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:1:1), <anonymous>:6:20)
                                            17 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:571:21)
                                            17 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
                                            17 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:699:18)
                                            17 verbose stack     at Promise._fulfill (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:643:18)
                                            17 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:587:21)
                                            18 verbose cwd /opt/iobroker
                                            19 verbose Linux 5.10.103-v7+
                                            20 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller@4.0.21" "--loglevel" "error" "--unsafe-perm" "--prefix" "/opt/iobroker"
                                            21 verbose node v14.19.0
                                            22 verbose npm  v6.14.16
                                            23 error Unexpected token  in JSON at position 966657 while parsing near '...6GgiGOvl7CY/KNh8rxS�'�&�&�'�&�&�'�...'
                                            24 verbose exit [ 1, true ]
                                            501
                                            138674
