    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. [gelöst] web.0 läuft nicht
      Emi 0 @mickym last edited by
      @mickym
      ja, gibt es:
      mickym K 2 Replies Last reply Reply Quote 0
        Emi 0 @mickym last edited by wendy2702
        @mickym said in web.0 läuft nicht:
        iob logs
        micros02@smartmeter:~ $ iob logs
        2022-03-14 21:05:19.119  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:05:26.189  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:05:33.141  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:05:38.803  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:05:41.961  - info: host.smartmeter iobroker add flot --host smartmeter
        2022-03-14 21:05:44.988  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:05:51.288  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:05:57.392  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:06:03.280  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:06:04.494  - info: host.smartmeter iobroker host.smartmeter create instance flot
        2022-03-14 21:06:04.664  - info: host.smartmeter iobroker host.smartmeter object system.adapter.flot.upload created
        2022-03-14 21:06:05.011  - info: host.smartmeter iobroker host.smartmeter object system.adapter.flot.0 created
        2022-03-14 21:06:07.419  - info: host.smartmeter iobroker exit 0
        2022-03-14 21:06:08.079  - error: host.smartmeter startInstance system.adapter.flot.0 Adapter dependency not fulfilled on "smartmeter": required adapter "web" not found!
        2022-03-14 21:06:09.358  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:06:15.861  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:06:21.854  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:06:28.042  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:06:34.319  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:06:40.516  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:06:46.664  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:06:52.976  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:06:59.104  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:07:05.316  - info: smartmeter.0 (7330) Received 7 values, 2 updated
        2022-03-14 21:07:11.562  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:07:17.833  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:07:24.096  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:07:30.319  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:07:36.664  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:07:39.127  - info: host.smartmeter iobroker add vis --host smartmeter
        2022-03-14 21:07:42.890  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:07:49.309  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:07:55.399  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:08:01.424  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:08:01.454  - info: host.smartmeter iobroker host.smartmeter create instance vis
        2022-03-14 21:08:01.593  - info: host.smartmeter iobroker host.smartmeter object system.adapter.vis.upload created
        2022-03-14 21:08:01.665  - info: host.smartmeter iobroker host.smartmeter object vis.0 created
        2022-03-14 21:08:01.795  - info: host.smartmeter iobroker host.smartmeter object vis.0.control created
        2022-03-14 21:08:01.874  - info: host.smartmeter iobroker host.smartmeter object vis.0.control.instance created
        2022-03-14 21:08:01.954  - info: host.smartmeter iobroker host.smartmeter object vis.0.control.command created
        2022-03-14 21:08:02.043  - info: host.smartmeter iobroker host.smartmeter object vis.0.control.data created
        2022-03-14 21:08:02.214  - info: host.smartmeter iobroker host.smartmeter object system.adapter.vis.0 created
        2022-03-14 21:08:03.472  - info: host.smartmeter iobroker exit 0
        2022-03-14 21:08:05.426  - error: host.smartmeter startInstance system.adapter.vis.0 Adapter dependency not fulfilled on "smartmeter": required adapter "web" not found!
        2022-03-14 21:08:07.982  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:08:14.970  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:08:21.917  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:08:28.867  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:08:35.657  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:08:42.573  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:08:49.035  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:08:55.658  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:09:02.149  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:09:08.569  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:09:14.598  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:09:20.902  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:09:27.221  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:09:33.333  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:09:39.602  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:09:45.888  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:09:52.148  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:09:58.423  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:10:04.691  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:10:11.194  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:10:17.859  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:10:24.477  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:10:31.245  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:10:37.486  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:10:43.756  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:10:49.449  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:10:55.042  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:11:00.593  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:11:06.207  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:11:11.839  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:11:17.450  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:11:23.060  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:11:28.688  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:11:34.347  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:11:40.001  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:11:45.577  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:11:51.863  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:11:58.054  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:12:04.346  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:12:10.477  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:12:16.719  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:12:23.004  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:12:29.260  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:12:35.379  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:12:41.491  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:12:47.621  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:12:53.785  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:12:59.971  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:13:06.161  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:13:12.365  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:13:18.454  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:13:24.687  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:13:30.934  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:13:37.132  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:13:43.285  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:13:49.253  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:13:55.253  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:14:01.186  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:14:07.168  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:14:13.167  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:14:19.189  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:14:25.175  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:14:31.168  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:14:37.356  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:14:43.614  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:14:50.019  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:14:56.042  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:15:02.252  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:15:08.574  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:15:14.614  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:15:20.784  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:15:26.922  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:15:33.150  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:15:39.398  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:15:45.611  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:15:51.882  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:15:58.139  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:16:04.347  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:16:10.603  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:16:16.877  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:16:22.836  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:16:28.221  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:16:35.106  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:16:41.828  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:16:48.673  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:16:55.433  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:17:02.266  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:17:09.073  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:17:15.947  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:17:22.774  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:17:29.668  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:17:36.673  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:17:43.340  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:17:50.192  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:17:56.908  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:18:03.803  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:18:10.571  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:18:17.441  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:18:24.314  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:18:31.219  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:18:38.165  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:18:45.091  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:18:52.079  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:18:59.071  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:19:06.029  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:19:12.995  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:19:20.056  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:19:26.848  - info: smartmeter.0 (7330) Received 7 values, 2 updated
        2022-03-14 21:19:33.907  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:19:40.859  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:19:48.008  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:19:55.230  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:20:01.800  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:20:08.771  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:20:15.759  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:20:22.782  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:20:29.734  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:20:36.814  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:20:43.803  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:20:50.799  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:20:57.899  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:21:04.674  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:21:11.606  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:21:18.503  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:21:25.529  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:21:32.473  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:21:39.458  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:21:46.434  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:21:53.486  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:22:00.345  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:22:07.310  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:22:14.310  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:22:21.288  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:22:26.939  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:22:33.195  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:22:39.434  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:22:41.720  - info: host.smartmeter iobroker add web --host smartmeter
        2022-03-14 21:22:45.646  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:22:51.975  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:22:58.069  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:23:03.133  - info: host.smartmeter iobroker host.smartmeter create instance web
        2022-03-14 21:23:03.321  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.alive created
        2022-03-14 21:23:03.413  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.connected created
        2022-03-14 21:23:03.493  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.compactMode created
        2022-03-14 21:23:03.603  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.cpu created
        2022-03-14 21:23:03.951  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.cputime created
        2022-03-14 21:23:04.078  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.memHeapUsed created
        2022-03-14 21:23:04.175  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.memHeapTotal created
        2022-03-14 21:23:04.273  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.memRss created
        2022-03-14 21:23:04.364  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.uptime created
        2022-03-14 21:23:04.457  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:23:04.461  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.inputCount created
        2022-03-14 21:23:04.555  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.outputCount created
        2022-03-14 21:23:04.635  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.eventLoopLag created
        2022-03-14 21:23:04.724  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.sigKill created
        2022-03-14 21:23:04.797  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0.logLevel created
        2022-03-14 21:23:04.986  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.upload created
        2022-03-14 21:23:05.053  - info: host.smartmeter iobroker host.smartmeter object web.0 created
        2022-03-14 21:23:05.122  - info: host.smartmeter iobroker host.smartmeter object web.0.info created
        2022-03-14 21:23:05.193  - info: host.smartmeter iobroker host.smartmeter object web.0.info.connection created
        2022-03-14 21:23:05.240  - info: host.smartmeter iobroker host.smartmeter Set default value of web.0.info.connection:
        2022-03-14 21:23:05.383  - info: host.smartmeter iobroker host.smartmeter object system.adapter.web.0 created
        2022-03-14 21:23:06.681  - info: host.smartmeter iobroker exit 0
        2022-03-14 21:23:08.952  - info: host.smartmeter instance system.adapter.web.0 started with pid 7726
        2022-03-14 21:23:10.357  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:23:16.517  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:23:22.759  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:23:28.780  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:23:34.468  - info: web.0 (7726) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 21:23:35.369  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:23:36.914  - info: web.0 (7726) socket.io server listening on port 8082
        2022-03-14 21:23:36.991  - info: web.0 (7726) http server listening on port 8082
        2022-03-14 21:23:37.964  - warn: web.0 (7726) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
        2022-03-14 21:23:41.179  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:23:47.479  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:23:53.736  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:23:59.985  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:24:06.282  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:24:12.429  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:24:18.796  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:24:24.951  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:24:31.219  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:24:37.419  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:24:40.517  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
        2022-03-14 21:24:40.568  - info: web.0 (7726) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 21:24:40.580  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
        2022-03-14 21:24:40.627  - info: web.0 (7726) terminated http server on port 8082
        2022-03-14 21:24:40.646  - info: web.0 (7726) terminating
        2022-03-14 21:24:40.689  - info: web.0 (7726) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-03-14 21:24:41.542  - info: host.smartmeter instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-03-14 21:24:43.613  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:24:43.851  - info: host.smartmeter instance system.adapter.web.0 started with pid 7752
        2022-03-14 21:24:50.215  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:24:56.260  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:25:02.619  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:25:05.992  - info: web.0 (7752) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 21:25:07.017  - error: web.0 (7752) Please specify the email address and domains to use Let's Encrypt certificates! We reuse old certificates
        2022-03-14 21:25:08.476  - info: web.0 (7752) Secure socket.io server listening on port 8082
        2022-03-14 21:25:08.687  - info: web.0 (7752) https server listening on port 8082
        2022-03-14 21:25:08.819  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:25:09.529  - warn: web.0 (7752) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
        2022-03-14 21:25:15.095  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:25:21.439  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:25:27.689  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:25:33.998  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:25:40.288  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:25:46.504  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:25:52.858  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:25:59.004  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:26:05.278  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:26:11.499  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:26:17.628  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:26:23.881  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:26:30.159  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:26:36.465  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:26:42.458  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:26:48.496  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:26:54.591  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:27:00.613  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:27:06.811  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:27:13.031  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:27:18.974  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:27:24.979  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:27:31.166  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:27:37.169  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:27:43.309  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:27:49.398  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:27:55.523  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:28:01.584  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:28:07.665  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:28:13.694  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:28:19.747  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:28:25.824  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:28:31.859  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:28:37.779  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:28:43.685  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:28:49.708  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:28:56.899  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:29:02.639  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:29:08.496  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:29:14.177  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:29:20.145  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:29:25.917  - info: smartmeter.0 (7330) Received 7 values, 2 updated
        2022-03-14 21:29:31.815  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:29:37.312  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:29:42.919  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:29:48.207  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:29:53.702  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:29:59.151  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:30:04.508  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:30:09.934  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:30:15.437  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:30:20.888  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:30:28.041  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:30:35.164  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:30:40.993  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:30:46.873  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:30:52.806  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:30:58.853  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:31:05.115  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:31:10.997  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:31:16.976  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:31:23.009  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:31:29.087  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:31:35.188  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:31:41.237  - info: smartmeter.0 (7330) Received 7 values, 2 updated
        2022-03-14 21:31:47.319  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:31:53.500  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:31:59.449  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:32:05.514  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:32:11.625  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:32:17.655  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:32:23.697  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:32:29.741  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:32:35.824  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:32:41.917  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:32:47.947  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:32:54.035  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:33:00.134  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:33:06.339  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:33:12.355  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:33:18.559  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:33:24.810  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:33:31.095  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:33:37.347  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:33:43.489  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:33:49.689  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:33:55.935  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:34:02.162  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:34:08.501  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:34:14.631  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:34:20.855  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:34:27.274  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:34:33.370  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:34:39.133  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:34:44.765  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:34:50.423  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:34:55.986  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:35:01.554  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:35:07.073  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:35:12.883  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:35:18.414  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:35:24.019  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:35:29.692  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:35:35.349  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:35:40.924  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:35:46.684  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:35:52.643  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:35:59.128  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:36:05.537  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:36:11.897  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:36:18.351  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:36:24.759  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:36:31.069  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:36:37.459  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:36:43.780  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:36:50.220  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:36:56.681  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:37:03.076  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:37:09.453  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:37:15.693  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:37:22.076  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:37:28.504  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:37:35.345  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:37:41.669  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:37:48.211  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:37:54.777  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:37:57.099  - info: host.smartmeter stopInstance system.adapter.admin.0 (force=false, process=true)
        2022-03-14 21:37:57.431  - info: host.smartmeter stopInstance system.adapter.admin.0 send kill signal
        2022-03-14 21:37:57.313  - info: admin.0 (7316) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 21:37:57.551  - info: admin.0 (7316) terminating http server on port 8081
        2022-03-14 21:37:57.571  - info: admin.0 (7316) terminating
        2022-03-14 21:37:57.620  - info: admin.0 (7316) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-03-14 21:37:58.446  - info: host.smartmeter stopInstance system.adapter.admin.0 killing pid 7316
        2022-03-14 21:37:58.765  - info: host.smartmeter instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-03-14 21:37:59.397  - info: host.smartmeter stopInstance system.adapter.backitup.0 (force=false, process=true)
        2022-03-14 21:37:59.458  - info: host.smartmeter stopInstance system.adapter.backitup.0 send kill signal
        2022-03-14 21:37:59.438  - info: backitup.0 (7344) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 21:37:59.505  - info: backitup.0 (7344) cleaned everything up...
        2022-03-14 21:37:59.522  - info: backitup.0 (7344) terminating
        2022-03-14 21:37:59.559  - info: backitup.0 (7344) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-03-14 21:38:00.390  - info: host.smartmeter stopInstance system.adapter.discovery.0 (force=false, process=true)
        2022-03-14 21:38:00.480  - info: host.smartmeter stopInstance system.adapter.backitup.0 killing pid 7344
        2022-03-14 21:38:00.534  - info: discovery.0 (7337) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 21:38:00.625  - info: discovery.0 (7337) terminating
        2022-03-14 21:38:00.652  - info: discovery.0 (7337) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-03-14 21:38:00.722  - info: host.smartmeter stopInstance system.adapter.discovery.0 send kill signal
        2022-03-14 21:38:00.900  - info: host.smartmeter instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-03-14 21:38:01.170  - info: host.smartmeter instance system.adapter.admin.0 started with pid 7800
        2022-03-14 21:38:01.753  - info: host.smartmeter stopInstance system.adapter.discovery.0 killing pid 7337
        2022-03-14 21:38:01.856  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:38:02.069  - info: host.smartmeter instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-03-14 21:38:02.927  - info: host.smartmeter instance system.adapter.backitup.0 started with pid 7807
        2022-03-14 21:38:04.556  - info: host.smartmeter instance system.adapter.discovery.0 started with pid 7813
        2022-03-14 21:38:08.019  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:38:11.942  - info: host.smartmeter "system.adapter.vis.0" disabled
        2022-03-14 21:38:12.157  - info: host.smartmeter "system.adapter.vis.0" enabled
        2022-03-14 21:38:15.476  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:38:21.841  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:38:28.415  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:38:35.671  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:38:41.134  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:38:47.749  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:38:54.765  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:39:00.735  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:39:07.475  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:39:14.434  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:39:20.895  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:39:27.109  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:39:33.697  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:39:38.348  - info: vis.0 (7821) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 21:39:39.895  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:39:39.634  - error: vis.0 (7821) No license found for vis. Please get one on https://iobroker.net !
        2022-03-14 21:39:44.336  - info: vis.0 (7821) Terminated (NO_ERROR): Without reason
        2022-03-14 21:39:46.018  - info: host.smartmeter instance system.adapter.vis.0 terminated while should be started once
        2022-03-14 21:39:46.571  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:39:48.518  - info: discovery.0 (7813) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 21:39:51.444  - info: admin.0 (7800) starting. Version 5.3.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 21:39:53.004  - info: admin.0 (7800) requesting all states
        2022-03-14 21:39:53.204  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:39:53.030  - info: admin.0 (7800) requesting all objects
        2022-03-14 21:39:53.704  - info: backitup.0 (7807) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 21:39:55.825  - info: backitup.0 (7807) [iobroker] backup was activated at 02:40 every 1 day(s)
        2022-03-14 21:40:01.579  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:40:03.069  - info: admin.0 (7800) received all objects
        2022-03-14 21:40:07.252  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:40:11.862  - warn: admin.0 (7800) Cannot update rating: timeout of 15000ms exceeded
        2022-03-14 21:40:12.114  - info: admin.0 (7800) Request actual repository...
        2022-03-14 21:40:14.664  - info: admin.0 (7800) http server listening on port 8081
        2022-03-14 21:40:15.492  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:40:14.674  - info: admin.0 (7800) Use link "http://localhost:8081" to configure.
        2022-03-14 21:40:20.267  - info: host.smartmeter Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        2022-03-14 21:40:32.545  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:40:33.227  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:40:33.355  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:40:37.007  - info: admin.0 (7800) Repository received successfully.
        2022-03-14 21:40:38.302  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:40:44.681  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:40:51.795  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:40:57.757  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:41:04.336  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:41:10.994  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:41:17.505  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:41:24.098  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:41:30.473  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:41:37.070  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:41:43.593  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:41:50.266  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:41:56.670  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:42:03.113  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:42:09.628  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:42:15.762  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:42:22.663  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:42:29.623  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:42:35.385  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:42:40.518  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:42:45.952  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:42:52.118  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:42:57.089  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:43:03.187  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:43:10.881  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:43:17.239  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:43:24.282  - info: smartmeter.0 (7330) Received 7 values, 2 updated
        2022-03-14 21:43:31.229  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:43:37.488  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:43:43.709  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:43:50.180  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:43:56.827  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:44:02.561  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:44:08.111  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:44:13.574  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:44:19.114  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:44:24.709  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:44:30.907  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:44:36.843  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:44:42.593  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:44:48.423  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:44:54.249  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:45:00.016  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:45:05.940  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:45:11.672  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:45:17.529  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:45:23.426  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:45:28.901  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:45:34.509  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:45:40.235  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:45:45.647  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:45:51.862  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:45:56.827  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:46:02.522  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:46:07.962  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:46:13.584  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:46:15.303  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
        2022-03-14 21:46:15.539  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
        2022-03-14 21:46:15.517  - info: web.0 (7752) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 21:46:15.656  - info: web.0 (7752) terminated https server on port 8082
        2022-03-14 21:46:15.683  - info: web.0 (7752) terminating
        2022-03-14 21:46:15.719  - info: web.0 (7752) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-03-14 21:46:16.671  - info: host.smartmeter instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-03-14 21:46:19.477  - info: host.smartmeter instance system.adapter.web.0 started with pid 7876
        2022-03-14 21:46:19.552  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:46:24.819  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:46:30.429  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:46:36.248  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:46:41.729  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:46:45.147  - info: web.0 (7876) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 21:46:46.099  - error: web.0 (7876) Please specify the email address and domains to use Let's Encrypt certificates! We reuse old certificates
        2022-03-14 21:46:47.446  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:46:47.967  - info: web.0 (7876) Secure socket.io server listening on port 8082
        2022-03-14 21:46:48.054  - info: web.0 (7876) https server listening on port 8082
        2022-03-14 21:46:49.007  - warn: web.0 (7876) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
        2022-03-14 21:46:52.908  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:46:58.517  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:47:01.415  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
        2022-03-14 21:47:01.503  - info: web.0 (7876) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 21:47:01.565  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
        2022-03-14 21:47:01.545  - info: web.0 (7876) terminated https server on port 8082
        2022-03-14 21:47:01.552  - info: web.0 (7876) terminating
        2022-03-14 21:47:01.611  - info: web.0 (7876) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-03-14 21:47:02.441  - info: host.smartmeter instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-03-14 21:47:04.384  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:47:04.708  - info: host.smartmeter instance system.adapter.web.0 started with pid 7893
        2022-03-14 21:47:10.470  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:47:16.099  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:47:22.189  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:47:28.078  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:47:33.607  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:47:34.857  - info: web.0 (7893) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 21:47:35.972  - error: web.0 (7893) Please specify the email address and domains to use Let's Encrypt certificates! We reuse old certificates
        2022-03-14 21:47:37.683  - info: web.0 (7893) Secure socket.io server listening on port 8082
        2022-03-14 21:47:37.766  - info: web.0 (7893) https server listening on port 8082
        2022-03-14 21:47:38.728  - warn: web.0 (7893) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
        2022-03-14 21:47:39.436  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:47:45.196  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:47:51.369  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:47:56.836  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:48:02.608  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:48:08.069  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:48:13.577  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:48:19.245  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:48:24.771  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:48:30.448  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:48:37.006  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:48:43.449  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:48:49.866  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:48:56.531  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:49:03.630  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:49:09.141  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:49:16.131  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:49:23.238  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:49:30.285  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:49:37.281  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:49:44.040  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:49:50.982  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:49:57.818  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:50:04.609  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:50:11.338  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:50:18.171  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:50:24.778  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:50:31.968  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:50:39.118  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:50:46.067  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:50:53.181  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:51:00.266  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:51:07.347  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:51:14.444  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:51:21.649  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:51:27.504  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:51:32.974  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:51:38.374  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:51:43.842  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:51:50.568  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:51:56.032  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:52:01.523  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:52:07.047  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:52:12.605  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:52:18.170  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:52:23.739  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:52:29.261  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:52:34.856  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:52:40.467  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:52:45.944  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:52:51.511  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:52:57.075  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:53:02.631  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:53:08.191  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:53:13.716  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:53:19.356  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:53:24.854  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:53:30.413  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:53:36.008  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:53:41.485  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:53:46.964  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:53:52.569  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:53:59.449  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:54:07.359  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:54:12.937  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:54:18.434  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:54:24.129  - info: smartmeter.0 (7330) Received 7 values, 2 updated
        2022-03-14 21:54:29.536  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:54:35.417  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:54:40.697  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:54:46.268  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:54:51.841  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:54:57.447  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:55:02.950  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:55:10.551  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:55:17.043  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:55:23.794  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:55:30.432  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:55:37.149  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:55:43.172  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:55:48.687  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:55:54.252  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:55:59.673  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:56:05.396  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:56:10.620  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:56:16.147  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:56:21.665  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:56:27.186  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:56:33.788  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:56:39.270  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:56:44.778  - info: smartmeter.0 (7330) Received 7 values, 2 updated
        2022-03-14 21:56:50.524  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:56:55.847  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:57:01.179  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:57:06.756  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:57:12.422  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:57:18.158  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:57:23.860  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:57:29.495  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:57:37.258  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:57:40.840  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:57:46.537  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
        2022-03-14 21:57:46.616  - info: web.0 (7893) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 21:57:46.734  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
        2022-03-14 21:57:46.684  - info: web.0 (7893) terminated https server on port 8082
        2022-03-14 21:57:46.691  - info: web.0 (7893) terminating
        2022-03-14 21:57:46.740  - info: web.0 (7893) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-03-14 21:57:46.868  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:57:47.575  - info: host.smartmeter instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-03-14 21:57:49.946  - info: host.smartmeter instance system.adapter.web.0 started with pid 7925
        2022-03-14 21:57:52.137  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:57:58.100  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:58:03.589  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:58:09.437  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:58:15.227  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:58:15.339  - info: web.0 (7925) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 21:58:17.156  - info: web.0 (7925) socket.io server listening on port 8082
        2022-03-14 21:58:17.238  - info: web.0 (7925) http server listening on port 8082
        2022-03-14 21:58:18.192  - warn: web.0 (7925) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
        2022-03-14 21:58:20.885  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:58:26.501  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:58:32.213  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:58:37.838  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:58:43.588  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:58:49.456  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:58:54.783  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:59:00.582  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:59:06.096  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:59:11.711  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:59:17.382  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:59:22.991  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:59:28.710  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:59:34.337  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:59:39.952  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:59:45.813  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:59:51.401  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 21:59:57.057  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:00:02.580  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:00:09.407  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:00:14.758  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:00:22.784  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:00:29.397  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:00:34.806  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:00:40.359  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:00:46.921  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:00:53.696  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:00:59.063  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:01:04.505  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:01:10.152  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:01:15.776  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:01:21.408  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:01:27.052  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:01:32.781  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:01:38.382  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:01:46.301  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:01:51.648  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:01:58.318  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:02:06.242  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:02:08.296  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
        2022-03-14 22:02:08.378  - info: web.0 (7925) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 22:02:08.475  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
        2022-03-14 22:02:08.439  - info: web.0 (7925) terminated http server on port 8082
        2022-03-14 22:02:08.459  - info: web.0 (7925) terminating
        2022-03-14 22:02:08.511  - info: web.0 (7925) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-03-14 22:02:09.324  - info: host.smartmeter instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-03-14 22:02:11.688  - info: host.smartmeter instance system.adapter.web.0 started with pid 7965
        2022-03-14 22:02:11.742  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:02:19.589  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:02:24.969  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:02:31.547  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:02:33.867  - info: web.0 (7965) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 22:02:36.189  - info: web.0 (7965) socket.io server listening on port 8082
        2022-03-14 22:02:36.285  - info: web.0 (7965) http server listening on port 8082
        2022-03-14 22:02:37.228  - warn: web.0 (7965) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
        2022-03-14 22:02:39.368  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:02:47.410  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:02:52.270  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
        2022-03-14 22:02:52.358  - info: web.0 (7965) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 22:02:52.371  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
        2022-03-14 22:02:52.418  - info: web.0 (7965) terminated http server on port 8082
        2022-03-14 22:02:52.446  - info: web.0 (7965) terminating
        2022-03-14 22:02:52.487  - info: web.0 (7965) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-03-14 22:02:53.117  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:02:53.392  - info: host.smartmeter stopInstance system.adapter.web.0 killing pid 7965
        2022-03-14 22:02:53.584  - info: host.smartmeter instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-03-14 22:02:55.512  - info: host.smartmeter instance system.adapter.web.0 started with pid 7980
        2022-03-14 22:02:58.549  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:03:04.290  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:03:09.661  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:03:15.119  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:03:17.686  - info: web.0 (7980) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 22:03:19.731  - info: web.0 (7980) socket.io server listening on port 8082
        2022-03-14 22:03:19.813  - info: web.0 (7980) http server listening on port 8082
        2022-03-14 22:03:20.854  - warn: web.0 (7980) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
        2022-03-14 22:03:20.975  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:03:26.435  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:03:31.987  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:03:37.609  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:03:43.310  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:03:49.165  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:03:55.087  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:04:00.598  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:04:06.514  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:04:12.361  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:04:18.193  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:04:24.231  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:04:29.679  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:04:37.173  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:04:44.334  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:04:51.503  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:04:58.722  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:05:05.941  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:05:13.046  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:05:19.930  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:05:27.168  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:05:34.357  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:05:40.919  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:05:46.538  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:05:52.159  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:05:57.772  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:06:03.377  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:06:09.099  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:06:14.568  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:06:20.299  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:06:25.798  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:06:33.208  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:06:39.974  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:06:46.773  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:06:53.525  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:07:00.254  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:07:07.024  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:07:13.838  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:07:20.601  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:07:27.389  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:07:34.214  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:07:40.926  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:07:47.712  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:07:54.523  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:08:01.299  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:08:08.067  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:08:14.905  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:08:21.679  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:08:28.489  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:08:35.953  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:08:43.304  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:08:50.869  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:08:58.192  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:09:05.561  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:09:13.156  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:09:20.509  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:09:28.094  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:09:35.487  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:09:43.098  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:09:50.466  - info: smartmeter.0 (7330) Received 7 values, 2 updated
        2022-03-14 22:09:58.109  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:10:05.504  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:10:13.098  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:10:20.361  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:10:27.821  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:10:35.299  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:10:42.320  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:10:49.459  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:10:56.534  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:11:04.130  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:11:11.429  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:11:18.923  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:11:26.404  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:11:33.865  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:11:41.371  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:11:48.831  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:11:56.274  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:12:03.689  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:12:11.202  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:12:18.640  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:12:24.533  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:12:30.390  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:12:36.331  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:12:42.319  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:12:48.337  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:12:54.189  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:12:59.971  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:13:05.990  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:13:11.927  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:13:18.053  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:13:23.969  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:13:29.923  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:13:35.994  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:13:41.901  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:13:48.135  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:13:54.247  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:14:00.325  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:14:06.519  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:14:12.737  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:14:18.965  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:14:25.147  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:14:31.369  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:14:37.615  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:14:43.860  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:14:50.231  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:14:56.279  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:15:02.526  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:15:08.776  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:15:14.989  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:15:21.229  - info: smartmeter.0 (7330) Received 7 values, 3 updated
        2022-03-14 22:15:23.703  - info: host.smartmeter received SIGTERM
        2022-03-14 22:15:23.794  - info: backitup.0 (7807) cleaned everything up...
        2022-03-14 22:15:23.843  - info: web.0 (7980) terminated http server on port 8082
        2022-03-14 22:15:23.826  - info: host.smartmeter stopInstance system.adapter.admin.0 (force=false, process=true)
        2022-03-14 22:15:23.829  - info: host.smartmeter stopInstance system.adapter.history.0 (force=false, process=true)
        2022-03-14 22:15:23.885  - info: host.smartmeter stopInstance system.adapter.smartmeter.0 (force=false, process=true)
        2022-03-14 22:15:23.889  - info: host.smartmeter stopInstance system.adapter.discovery.0 (force=false, process=true)
        2022-03-14 22:15:23.892  - info: host.smartmeter stopInstance system.adapter.backitup.0 (force=false, process=true)
        2022-03-14 22:15:23.947  - info: host.smartmeter stopInstance system.adapter.flot.0 (force=false, process=false)
        2022-03-14 22:15:23.950  - info: host.smartmeter stopInstance system.adapter.vis.0 (force=false, process=false)
        2022-03-14 22:15:23.952  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
        2022-03-14 22:15:23.874  - info: admin.0 (7800) terminating http server on port 8081
        2022-03-14 22:15:24.360  - info: admin.0 (7800) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 22:15:24.382  - info: smartmeter.0 (7330) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 22:15:24.407  - info: discovery.0 (7813) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 22:15:24.434  - info: backitup.0 (7807) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 22:15:24.431  - info: web.0 (7980) Got terminate signal TERMINATE_YOURSELF
        2022-03-14 22:15:24.610  - info: smartmeter.0 (7330) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-14 22:15:24.596  - info: backitup.0 (7807) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-14 22:15:24.625  - info: web.0 (7980) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-14 22:15:24.635  - info: discovery.0 (7813) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-14 22:15:24.739  - info: admin.0 (7800) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-14 22:15:24.975  - info: host.smartmeter stopInstance system.adapter.admin.0 send kill signal
        2022-03-14 22:15:24.984  - info: host.smartmeter stopInstance system.adapter.smartmeter.0 send kill signal
        2022-03-14 22:15:24.987  - info: host.smartmeter stopInstance system.adapter.discovery.0 send kill signal
        2022-03-14 22:15:24.989  - info: host.smartmeter stopInstance system.adapter.backitup.0 send kill signal
        2022-03-14 22:15:24.992  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
        2022-03-14 22:15:26.037  - info: host.smartmeter stopInstance system.adapter.admin.0 killing pid 7800
        2022-03-14 22:15:26.063  - info: host.smartmeter stopInstance system.adapter.smartmeter.0 killing pid 7330
        2022-03-14 22:15:26.074  - info: host.smartmeter stopInstance system.adapter.discovery.0 killing pid 7813
        2022-03-14 22:15:26.093  - info: host.smartmeter stopInstance system.adapter.backitup.0 killing pid 7807
        2022-03-14 22:15:26.256  - info: host.smartmeter stopInstance system.adapter.web.0 killing pid 7980
        2022-03-14 22:15:27.487  - warn: host.smartmeter instance system.adapter.smartmeter.0 terminated due to SIGTERM
        2022-03-14 22:15:27.494  - info: host.smartmeter instance system.adapter.smartmeter.0 terminated with code null ()
        2022-03-14 22:15:27.639  - warn: host.smartmeter instance system.adapter.admin.0 terminated due to SIGTERM
        2022-03-14 22:15:27.642  - info: host.smartmeter instance system.adapter.admin.0 terminated with code null ()
        2022-03-14 22:15:27.657  - warn: host.smartmeter instance system.adapter.backitup.0 terminated due to SIGTERM
        2022-03-14 22:15:27.660  - info: host.smartmeter instance system.adapter.backitup.0 terminated with code null ()
        2022-03-14 22:15:27.673  - warn: host.smartmeter instance system.adapter.discovery.0 terminated due to SIGTERM
        2022-03-14 22:15:27.676  - info: host.smartmeter instance system.adapter.discovery.0 terminated with code null ()
        2022-03-14 22:15:27.679  - warn: host.smartmeter instance system.adapter.web.0 terminated due to SIGTERM
        2022-03-14 22:15:27.682  - info: host.smartmeter instance system.adapter.web.0 terminated with code null ()
        2022-03-14 22:15:28.643  - info: history.0 (7323) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-03-14 22:15:29.728  - info: host.smartmeter instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2022-03-14 22:15:29.732  - info: host.smartmeter All instances are stopped.
        2022-03-14 22:15:29.962  - info: host.smartmeter terminated
        2022-03-14 22:15:44.610  - info: host.smartmeter iobroker.js-controller version 4.0.21 js-controller starting
        2022-03-14 22:15:44.709  - info: host.smartmeter Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2022-03-14 22:15:44.716  - info: host.smartmeter hostname: smartmeter, node: v12.22.5
        2022-03-14 22:15:44.723  - info: host.smartmeter ip addresses: 192.168.178.191 2001:16b8:220a:5a00:13a1:9f6c:3f10:875b fe80::3214:b3be:5fb:d542
        2022-03-14 22:15:55.235  - info: host.smartmeter connected to Objects and States
        2022-03-14 22:15:55.647  - info: host.smartmeter added notifications configuration of host
        2022-03-14 22:15:58.737  - info: host.smartmeter 8 instances found
        2022-03-14 22:15:58.942  - info: host.smartmeter starting 7 instances
        2022-03-14 22:15:59.542  - info: host.smartmeter instance system.adapter.admin.0 started with pid 8037
        2022-03-14 22:16:03.304  - info: host.smartmeter instance system.adapter.history.0 started with pid 8044
        2022-03-14 22:16:07.455  - info: host.smartmeter instance system.adapter.smartmeter.0 started with pid 8052
        2022-03-14 22:16:11.796  - info: host.smartmeter instance system.adapter.discovery.0 started with pid 8059
        2022-03-14 22:16:15.790  - info: host.smartmeter instance system.adapter.backitup.0 started with pid 8066
        2022-03-14 22:16:20.274  - info: host.smartmeter instance system.adapter.web.0 started with pid 8073
        2022-03-14 22:16:47.359  - info: host.smartmeter received SIGTERM
        2022-03-14 22:16:47.571  - info: host.smartmeter stopInstance system.adapter.admin.0 (force=false, process=true)
        2022-03-14 22:16:47.577  - info: host.smartmeter stopInstance system.adapter.history.0 (force=false, process=true)
        2022-03-14 22:16:47.591  - info: host.smartmeter stopInstance system.adapter.smartmeter.0 (force=false, process=true)
        2022-03-14 22:16:47.596  - info: host.smartmeter stopInstance system.adapter.discovery.0 (force=false, process=true)
        2022-03-14 22:16:47.602  - info: host.smartmeter stopInstance system.adapter.backitup.0 (force=false, process=true)
        2022-03-14 22:16:47.607  - info: host.smartmeter stopInstance system.adapter.web.0 (force=false, process=true)
        2022-03-14 22:16:47.612  - info: host.smartmeter stopInstance system.adapter.vis.0 (force=false, process=true)
        2022-03-14 22:16:49.094  - warn: host.smartmeter instance system.adapter.admin.0 terminated due to SIGTERM
        2022-03-14 22:16:49.106  - info: host.smartmeter instance system.adapter.admin.0 terminated with code null ()
        2022-03-14 22:16:49.124  - warn: host.smartmeter instance system.adapter.history.0 terminated due to SIGTERM
        2022-03-14 22:16:49.128  - info: host.smartmeter instance system.adapter.history.0 terminated with code null ()
        2022-03-14 22:16:49.146  - warn: host.smartmeter instance system.adapter.smartmeter.0 terminated due to SIGTERM
        2022-03-14 22:16:49.150  - info: host.smartmeter instance system.adapter.smartmeter.0 terminated with code null ()
        2022-03-14 22:16:49.167  - warn: host.smartmeter instance system.adapter.discovery.0 terminated due to SIGTERM
        2022-03-14 22:16:49.172  - info: host.smartmeter instance system.adapter.discovery.0 terminated with code null ()
        2022-03-14 22:16:49.188  - warn: host.smartmeter instance system.adapter.backitup.0 terminated due to SIGTERM
        2022-03-14 22:16:49.203  - info: host.smartmeter instance system.adapter.backitup.0 terminated with code null ()
        2022-03-14 22:16:49.209  - warn: host.smartmeter instance system.adapter.web.0 terminated due to SIGTERM
        2022-03-14 22:16:49.221  - info: host.smartmeter instance system.adapter.web.0 terminated with code null ()
        2022-03-14 22:16:49.228  - info: host.smartmeter instance system.adapter.vis.0 terminated while should be started once
        2022-03-14 22:16:49.305  - info: host.smartmeter stopInstance system.adapter.admin.0 send kill signal
        2022-03-14 22:16:49.309  - info: host.smartmeter stopInstance system.adapter.smartmeter.0 send kill signal
        2022-03-14 22:16:49.313  - info: host.smartmeter stopInstance system.adapter.discovery.0 send kill signal
        2022-03-14 22:16:49.317  - info: host.smartmeter stopInstance system.adapter.backitup.0 send kill signal
        2022-03-14 22:16:49.321  - info: host.smartmeter stopInstance system.adapter.web.0 send kill signal
        2022-03-14 22:17:03.022  - info: host.smartmeter force terminating
        2022-03-14 22:17:31.119  - info: host.smartmeter iobroker.js-controller version 4.0.21 js-controller starting
        2022-03-14 22:17:31.310  - info: host.smartmeter Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2022-03-14 22:17:31.327  - info: host.smartmeter hostname: smartmeter, node: v12.22.5
        2022-03-14 22:17:31.344  - info: host.smartmeter ip addresses: 192.168.178.191 2001:16b8:220a:5a00:13a1:9f6c:3f10:875b fe80::3214:b3be:5fb:d542
        2022-03-14 22:17:52.589  - info: host.smartmeter connected to Objects and States
        2022-03-14 22:17:53.573  - info: host.smartmeter added notifications configuration of host
        2022-03-14 22:17:57.297  - info: host.smartmeter 8 instances found
        2022-03-14 22:17:57.488  - info: host.smartmeter starting 7 instances
        2022-03-14 22:17:58.451  - info: host.smartmeter instance system.adapter.admin.0 started with pid 8144
        2022-03-14 22:18:02.544  - info: host.smartmeter instance system.adapter.history.0 started with pid 8151
        2022-03-14 22:18:05.986  - info: host.smartmeter instance system.adapter.smartmeter.0 started with pid 8158
        2022-03-14 22:18:10.146  - info: host.smartmeter instance system.adapter.discovery.0 started with pid 8165
        2022-03-14 22:18:14.425  - info: host.smartmeter instance system.adapter.backitup.0 started with pid 8172
        2022-03-14 22:18:18.647  - info: host.smartmeter instance system.adapter.web.0 started with pid 8179
        2022-03-14 22:20:00.094  - info: history.0 (8151) starting. Version 1.10.5 in /opt/iobroker/node_modules/iobroker.history, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 22:20:03.502  - info: history.0 (8151) enabled logging of 0_userdata.0.example_state (Count=1), Alias=false
        2022-03-14 22:20:03.609  - info: history.0 (8151) enabled logging of smartmeter.0.1-0:16_7_0__255.value (Count=2), Alias=false
        2022-03-14 22:20:10.634  - info: admin.0 (8144) starting. Version 5.3.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 22:20:12.673  - info: admin.0 (8144) requesting all states
        2022-03-14 22:20:12.724  - info: admin.0 (8144) requesting all objects
        2022-03-14 22:20:24.026  - info: vis.0 (8186) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 22:20:24.712  - info: discovery.0 (8165) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 22:20:24.919  - info: admin.0 (8144) received all objects
        2022-03-14 22:20:25.310  - error: vis.0 (8186) No license found for vis. Please get one on https://iobroker.net !
        2022-03-14 22:20:31.854  - info: vis.0 (8186) Terminated (NO_ERROR): Without reason
        2022-03-14 22:20:35.340  - info: host.smartmeter instance system.adapter.vis.0 terminated while should be started once
        2022-03-14 22:20:35.867  - warn: admin.0 (8144) Cannot update rating: timeout of 15000ms exceeded
        2022-03-14 22:20:36.088  - info: admin.0 (8144) Request actual repository...
        2022-03-14 22:20:36.757  - info: admin.0 (8144) http server listening on port 8081
        2022-03-14 22:20:37.041  - info: backitup.0 (8172) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 22:20:36.778  - info: admin.0 (8144) Use link "http://localhost:8081" to configure.
        2022-03-14 22:20:38.703  - info: backitup.0 (8172) [iobroker] backup was activated at 02:40 every 1 day(s)
        2022-03-14 22:20:44.538  - info: host.smartmeter Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        2022-03-14 22:20:46.934  - info: smartmeter.0 (8158) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 22:20:57.091  - info: web.0 (8179) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 4.0.21
        2022-03-14 22:20:59.132  - info: smartmeter.0 (8158) Received 7 values, 7 updated
        2022-03-14 22:20:59.202  - info: smartmeter.0 (8158) Received 7 values, 6 updated
        2022-03-14 22:21:01.009  - info: admin.0 (8144) Repository received successfully.
        2022-03-14 22:21:02.354  - info: web.0 (8179) socket.io server listening on port 8082
        2022-03-14 22:21:02.479  - info: web.0 (8179) http server listening on port 8082
        2022-03-14 22:21:03.457  - warn: web.0 (8179) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
        2022-03-14 22:21:03.810  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:21:07.939  - error: admin.0 (8144) error
        2022-03-14 22:21:10.473  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:21:17.032  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:21:23.510  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:21:29.547  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:21:36.075  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:21:50.985  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:21:51.025  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:21:56.413  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:22:04.160  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:22:09.494  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:22:16.212  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:22:22.962  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:22:29.691  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:22:36.115  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:22:42.737  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:22:49.576  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:22:56.128  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:23:02.653  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:23:09.280  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:23:15.960  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:23:22.637  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:23:29.342  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:23:35.808  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:23:42.587  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:23:49.255  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:23:56.520  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:24:02.780  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:24:09.375  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:24:18.263  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        2022-03-14 22:24:22.919  - info: smartmeter.0 (8158) Received 7 values, 3 updated
        micros02@smartmeter:~ $
        • mickym
          mickym Most Active @Emi 0 last edited by
          @emi-0 Ja das ist der Mist, mit dem HTTPS und den Zertifikaten - den Du angehakt hattest.
          Lösche doch einfach die Web Instanz und installiere diese neu und ändere nichts an den Einstellungen.
          Wenn Du noch auf den Admin kommst.
          Wenn nicht dann löschst Du die instanz:
          iob del web.0
          dann installierst Du die Instanz neu:
          iob add web: 0
          • wendy2702
            wendy2702 last edited by
            Wie sehen deine Socket.io Einstellungen aus?
              Emi 0 @mickym last edited by
              @mickym said in web.0 läuft nicht:
              iob add web: 0
              Geht nicht, immer noch gelbes Dreieck aber nur 1 Warnung:
              2022-03-14 22:40:12.910  - info: web.0 (8379) http server listening on port 8082
              2022-03-14 22:40:13.655  - info: smartmeter.0 (8158) Received 7 values, 3 updated
              2022-03-14 22:40:13.908  - warn: web.0 (8379) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
              2022-03-14 22:40:18.969  - info: smartmeter.0 (8158) Received 7 values, 3 updated
                Emi 0 @wendy2702 last edited by
                @wendy2702
                wo finde ich die?
                • wendy2702
                  wendy2702 @Emi 0 last edited by
                  @emi-0 Unter Instanzen den Socket.io auswählen und dann auf den Schraubenschlüssel
                    @wendy2702
                    gibt es bei mir nicht:
                      paul53 @Emi 0 last edited by
                      @emi-0 sagte: gibt es bei mir nicht:
                      Muss es auch nicht. Der Web-Adapter hat seine eigene socket.io.
                        Emi 0 @paul53 last edited by
                        wie komme da ran?
                          @emi-0 sagte: wie komme da ran?
                          Gar nicht, ist auch nicht nötig.
                            was kann ich jetzt tun?
                            • wendy2702
                              Du musst da nicht dran kommen. Wäre nur interessant gewesen wenn er installiert wäre.
                              Was kommt bei
                              iob list instances
                              und hast du schon ein
                              iob upload all
                              Probiert?
                              • mickym
                                Meines Erachtens liegt der ganze Mist an dem HTTPS anhaken und den Zertifikaten. Am Besten den Adapter nicht nur die Instanz komplett löschen - auch schauen, dass die Objekte weg sind und dann neu installieren.
                                  paul53 @Emi 0 last edited by paul53
                                  @emi-0 sagte: was kann ich jetzt tun?
                                  Bei so hartnäckiger Verweigerung würde ich
                                  • Instanz web.0 löschen
                                  • Adapter web löschen
                                  • ioBroker neu starten
                                  • Adapter web installieren oder Adapter flot installieren (web sollte automatisch mit installiert werden)
                                  • wendy2702
                                    Mal hier lesen:
                                    https://github.com/ioBroker/ioBroker.web/issues/184
                                    Wenn alles funktioniert ist das mehr oder weniger „kosmetisch“ und in 4.1.3 gelöst
                                    raintonr created this issue in ioBroker/ioBroker.web
                                    closed After upgrading to 3.4.16 'not connected' warning triangle shown by each instance. #184
                                      @wendy2702
                                      micros02@smartmeter:~ $ iob list instances
                                      + system.adapter.admin.0                  : admin                 : smartmeter                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.backitup.0               : backitup              : smartmeter                               -  enabled
                                      + system.adapter.discovery.0              : discovery             : smartmeter                               -  enabled
                                      + system.adapter.history.0                : history               : smartmeter                               -  enabled
                                      + system.adapter.smartmeter.0             : smartmeter            : smartmeter                               -  enabled
                                      + system.adapter.web.0                    : web                   : smartmeter                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                      paul53 wendy2702 2 Replies Last reply Reply Quote 0
                                        @emi-0
                                        Sieht so aus, als ob web.0 läuft. Installiere mal den Adapter flot.
                                        • wendy2702
                                          @emi-0 sagte in web.0 läuft nicht:
                                          @wendy2702
                                          + instance is alive
                                          Dann passt wohl der verlinkte GitHub Eintrag da du genau diese Version mit dem Fehler verwendest, kein VIS oder ähnliches installiert ist
                                          info: web.0 (7752) starting. Version 3.4.16
                                            nein läuft nicht:
                                            Ich werde morgen Deine Vorschläge durchführen.
                                            Dank erstmal ...
                                            1679
