    4. [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren
    • lobomau
      lobomau @lobomau last edited by lobomau
      @lobomau leider habe ich doch Probleme mit InfluxDB2.x
      Wenn ich bestimmte Graphen aufrufe (flot oder echart) bekomme ich Warnungen, Fehler und der influxdb-container geht an seine CPU Grenze. Kann jemand damit etwas anfangen?
      influxdb.0
      2022-01-11 13:10:06.456	warn	Error in query "from(bucket: "Speicher") |> range(start: 2021-01-11T00:09:54.319Z, stop: 2022-01-11T00:09:54.319Z) |> filter(fn: (r) => r["_measurement"] == "proxmox.0.node_proxmox.cpu") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> sort(columns: ["_time"], desc: true) |> group() |> limit(n: 1)": RequestTimedOutError: Request timed out
      influxdb.0
      2022-01-11 13:09:57.449	warn	Error in query "from(bucket: "Speicher") |> range(start: 2021-01-11T00:09:43.437Z, stop: 2022-01-11T00:09:43.437Z) |> filter(fn: (r) => r["_measurement"] == "linkeddevices.0.Leistung_PV-4000W.power") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> sort(columns: ["_time"], desc: true) |> group() |> limit(n: 1)": RequestTimedOutError: Request timed out
      influxdb.0
      2022-01-11 13:21:53.792	error	Error: read ECONNRESET
      influxdb.0
      2022-01-11 13:21:52.952	error	RequestTimedOutError: Request timed out
      influxdb.0
      2022-01-11 13:21:39.892	error	RequestTimedOutError: Request timed out
      influxdb.0
      2022-01-11 13:21:26.878	error	getHistory: Error: 3 Error happened while processing 3 queries
      influxdb.0
      2022-01-11 13:21:26.462	error	getHistory: Error: 3 Error happened while processing 3 queries
      influxdb.0
      2022-01-11 13:21:25.166	error	getHistory: Error: 3 Error happened while processing 3 queries
      influxdb.0
      2022-01-11 13:21:19.879	error	Error during ping: RequestTimedOutError: Request timed out. Attempting reconnect.
      influxdb.0
      2022-01-11 13:21:17.204	error	getHistory: Error: 3 Error happened while processing 3 queries
      influxdb.0
      2022-01-11 13:21:15.474	error	getHistory: Error: 3 Error happened while processing 3 queries
      influxdb.0
      2022-01-11 13:21:13.517	error	getHistory: Error: 3 Error happened while processing 3 queries
      influxdb.0
      2022-01-11 13:21:10.540	error	getHistory: Error: 3 Error happened while processing 3 queries
      influxdb.0
      2022-01-11 13:21:10.051	error	getHistory: Error: 3 Error happened while processing 3 queries
        ftd @lobomau last edited by
        @lobomau Kannst du die gleiche Abfrage mal in der Influx GUI starten? Wie lange dauert die?
        lobomau 1 Reply Last reply Reply Quote 0
        • lobomau
          lobomau @ftd last edited by
          @ftd werde ich gleich mal testen. Im Augenblick geht gar nix mehr. Influx nimmt was es kriegen kann an CPU. Ist seit paar Stunden so, komme grad nach Hause...
          top - 17:57:26 up 39 days,  3:27,  3 users,  load average: 156.61, 149.68, 142.3
          Tasks: 400 total,   1 running, 399 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.4 us, 25.4 sy,  0.0 ni,  0.0 id, 74.1 wa,  0.0 hi,  0.1 si,  0.0 st
          MiB Mem :   7813.9 total,    298.7 free,   6960.1 used,    555.1 buff/cache
          MiB Swap:   7168.0 total,   4583.1 free,   2584.9 used.    510.3 avail Mem
              PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
          3778649 100998    20   0 5575048   1.9g  23268 S 100.3  24.5 130:41.03 influxd
          3783114 root      20   0   10700   4432   3480 R   0.7   0.1   0:00.38 top
          3842149 101000    20   0  758568  56352  10836 S   0.7   0.7  28:54.91 io.syno+
          1233138 100108    20   0 3392572 377880   9380 S   0.3   4.7  57:21.34 java
          3181972 101000    20   0  951068  34604   8768 S   0.3   0.4   7:17.51 io.back+
                1 root      20   0  164588   8896   6480 S   0.0   0.1   0:42.85 systemd
                2 root      20   0       0      0      0 S   0.0   0.0   0:03.13 kthreadd
                3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
                4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par+
                6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker+
                9 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_perc+
               10 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tas+
               11 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tas+
               12 root      20   0       0      0      0 S   0.0   0.0  12:03.82 ksoftir+
            Thomas Braun Most Active @lobomau last edited by
            @lobomau sagte in [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren:
            Das kannst du dir fast rahmen lassen. Selten so eine hohe Load gesehen.
              Rushmed Most Active @Segway last edited by
              @segway sagte in [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren:
              Die neue native Syntax für eine neue Datenbank/Bucket in Influx 2.1 ist Flux. InfluxQL wird in 2.1 nicht mehr unterstützt.
              Im Prinzip hast du Recht aber würde die Hoffnung noch nicht aufgeben.
              Angeblich soll der Zugriff auch per InfluxQL klappen nur leider ist die Doku von Influx echt grauselig !
              Ich tüftle grad wie man das evtl hinbekommt
              Für mich ist das Umstellen aller Dashboards und auch das neu Anlegen echt mühselig. Gibts hier schon etwas Neues
              • Uli977
                Uli977 last edited by
                ich möchte InfluxDB in einem ProxmoxCT installieren, bekomme aber folgende Meldung bei der Influxdb installation.
                apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8))
                Kann mir da jemand helfen, was zu tun ist?
                Viele Grüße!
                wendy2702 FredF 2 Replies Last reply Reply Quote 0
                • wendy2702
                  wendy2702 @Uli977 last edited by
                  @uli977 sagte in [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren:
                  Welches OS und nach welchem Befehl genau bzw. an welcher Stelle der Anleitung?
                  Uli977 1 Reply Last reply Reply Quote 0
                  • Uli977
                    Uli977 @wendy2702 last edited by
                    @wendy2702
                    Ubuntu 21.04
                    Nach Eingabe dieses Befehls
                    wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                    • wendy2702
                      wendy2702 @Uli977 last edited by wendy2702
                      Keine Ahnung woher du den hast.
                      Der steht weder auf Seite 1 dieser Anleitung noch in der offiziellen Influx Anleitung.
                      Das hier aus der Offiziellen Anleitung:
                      wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
                      export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
                      echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
                      sudo apt-get update && sudo apt-get install influxdb2
                      Ist das was auf Seite 1 beschrieben steht
                      Uli977 3 Replies Last reply Reply Quote 0
                      • Uli977
                        @wendy2702
                        Hatte dies von der Seite verdrahtet.info
                        Danke, so wie von dir beschrieben geht es!
                        Danke! Danke!
                        • FredF
                          FredF Most Active Forum Testing @Uli977 last edited by
                          @uli977 Dieses Problem hatte ich gestern auch... Anscheinend kommt diese Fehlermeldung durch Debian 11. Mit Debian 10 hat es dann geklappt...
                          • wendy2702
                            wendy2702 @FredF last edited by
                            @fredf Sag bitte nicht du hast wegen der "Meldung" ein totes/sterbendes Pferd installiert?
                            • FredF
                              FredF Most Active Forum Testing @wendy2702 last edited by FredF
                              @wendy2702 Um zu sehen ob es daran liegt schon, habe aber noch keine Lösung nach mehreren erfolglosen gefunden...
                              Edit: Könnte es daran liegen, das ich noch auf proxmox 6 bin?
                              • Uli977
                                Uli977 @wendy2702 last edited by Uli977
                                @wendy2702
                                Gibt es noch ne Anleitung wie man die DB dann einrichtet und wie ich mit dem ioBroker dran komme?
                                Influxdb läuft in einem eigenen Container im proxmox und hat auch eine eigene IP..
                                • wendy2702
                                  @uli977 https://github.com/ioBroker/ioBroker.influxdb
                                  • wendy2702
                                    @fredf Liegt am verwendeten OS im Container.
                                    • Uli977
                                      @wendy2702
                                      irgendwie komme ich nicht mittels eingabe "influx" in das UI....
                                      • wendy2702
                                        @uli977 Hat sich glaube ich zu Influx 2.x geändert:
                                        https://docs.influxdata.com/influxdb/v2.1/reference/cli/influx/
                                        • FredF
                                          @wendy2702
                                          influx setup
                                          • Uli977
                                            Danke Euch InfluxDB läuft und hat Verbindung mit dem ioBroker.....
                                            Ich mach mal weiter und schaue wie es dann so klappt im Grafana.
                                            131
                                            32614
