Problem mit Admin und so
@marcus-hamburg sagte in Problem mit Admin und so:
nodesource.list.save.1
löschen.
sudo rm /etc/apt/sources.list.d/nodesource.list.save.1
iobroker stop iobroker fix iobroker update iobroker upgrade iobroker upgrade self iobroker start
@thomas-braun bei Upgrade kommt erneut ein Fehler
pi@raspberrypi:~ $ iob upgrade self Update js-controller from @3.3.22 to @4.0.21 NPM version: 8.3.1 npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call) npm ERR! code ENOTEMPTY npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/typescript npm ERR! dest /opt/iobroker/node_modules/.typescript-rKKYB1QG npm ERR! errno -39 npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/typescript' -> '/opt/iobroker/node_modules/.typescript-rKKYB1QG' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-03-16T16_24_42_511Z-debug-0.log host.raspberrypi Cannot install iobroker.js-controller@4.0.21: 217
Siehe oben. Verzeichnis umbenennen.
@thomas-braun Ich verzweifle an mich selbst.
pi@raspberrypi:~ $ sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn mv: der Aufruf von stat für '/opt/iobroker/node_modules/iobroker.javascript' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
sudo -u iobroker mv /opt/iobroker/node_modules/typescript /opt/iobroker/node_modules/.typescript-rKKYB1QG
@thomas-braun und noch immer
pi@raspberrypi:~ $ iob upgrade This upgrade of "tr-064" will introduce the following changes: ========================================================================== -> 4.2.15: fix crash case (Sentry IOBROKER-TR-064-35) ========================================================================== Would you like to upgrade tr-064 from @4.2.14 to @4.2.15 now? [(y)es, (n)o]: n No upgrade of "tr-064" desired. This upgrade of "simple-api" will introduce the following changes: ========================================================================== -> 2.6.2: Support of new flags for `getPlainValue`: `json` and `noStringify` ========================================================================== Would you like to upgrade simple-api from @2.6.1 to @2.6.2 now? [(y)es, (n)o]: y Update simple-api from @2.6.1 to @2.6.2 NPM version: 8.3.1 npm install iobroker.simple-api@2.6.2 --loglevel error --prefix "/opt/iobroker" (System call) npm ERR! code ENOTEMPTY npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/virtual-tsc npm ERR! dest /opt/iobroker/node_modules/.virtual-tsc-7cNzXXUj npm ERR! errno -39 npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/virtual-tsc' -> '/opt/iobroker/node_modules/.virtual-tsc-7cNzXXUj' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-03-16T17_38_14_891Z-debug-0.log host.raspberrypi Cannot install iobroker.simple-api@2.6.2: 217 pi@raspberrypi:~ $
Die Nummer ist immer gleich...
Die angebotenen Upgrades solltest du aber auch ausführen...
@thomas-braun Danke bin jetzt wieder weiter, einer der letzten Sachen:
Would you like to upgrade javascript from @5.2.13 to @5.2.21 now? [(y)es, (n)o]: y Update javascript from @5.2.13 to @5.2.21 NPM version: 8.3.1 Installing iobroker.javascript@5.2.21... (System call) host.raspberrypi Cannot install iobroker.javascript@5.2.21: 217
@thomas-braun ne nicht wirklich:
pi@raspberrypi:~ $ iob stop pi@raspberrypi:~ $ iob update -u Used repository: stable Adapter "javascript" : 5.2.21 , installed 5.2.13 [Updatable] pi@raspberrypi:~ $ iob upgrade This upgrade of "javascript" will at least introduce the following changes: ========================================================================== -> 5.2.21: Fixed build process -> 5.2.20: Fixed build process -> 5.2.19: Fix broken dependency -> 5.2.18: Fixed some german translations Fixed astro schedules -> 5.2.17: Fixed some german translations Fixed astro schedules -> 5.2.16: Fixed fonts -> 5.2.15: Added the monitoring of symlinks my mirroring Fix two crash cases reported by Sentry ========================================================================== Would you like to upgrade javascript from @5.2.13 to @5.2.21 now? [(y)es, (n)o]: y Update javascript from @5.2.13 to @5.2.21 NPM version: 8.3.1 Installing iobroker.javascript@5.2.21... (System call) host.raspberrypi Cannot install iobroker.javascript@5.2.21: 217
@thomas-braun sagte in Problem mit Admin und so:
Mehr kommt da nicht?
zum Error 217 hab ich nichts gefunden
@homoran OK. Werde mal für heute Schluss machen, grundsätzlich bin sehr froh über diese tolle schnell Hilfe. Mein System ist wieder Schick und die 217 bekommt bestimmt noch jemand gelöst. Danke Danke Danke.
@homoran sagte in Problem mit Admin und so:
Ich schon...
Hatte damals mit dem nodeJS-Setup zu tun.
das einzige was ich fand ging in die Richtung bei node-red
Irgendwas mit User Zuordnung -
https://forum.iobroker.net/topic/49058/installation-javascript-npm-modul-in-js-adapter
Kann natürlich sein, das die Versionen aus 'stable' noch nicht mit aktuellen node/npm-Installationen parat kommen.
@Marcus-Hamburg Geh mal mit nodeJS auf die Version 14 inkl. npm@6 runter.
ich hatte das selbe Problem.
Gelöst habe ich es, indem ich den erweiterten Modus eingeschaltet habe. Im Log kam dann immer die Meldung, daß irgendein Verzeichnis nicht leer sei. Das Verzeichnis habe ich dann mittels rm -rf gelöscht. Nach dem dritten Verzeichnis habe ich mittels
find /opt/iobroker/node_modules -name .\*-\* >out
mir alle potentiellen Problemverzeichnisse gesucht. In der Datei sind noch ein paar Verzeichnisse, die nicht gelöscht werden sollten. Das Namensschema ist ungefähr .admin-PkhUgfdt - also .Adapername-Zufallsstring
Alle anderen Verzeichnisse habe ich raus gelöscht und dann mittels
while read a
do
rm -rf ${a}
done <out
die ganzen Verzeichnisse gelöscht.Das geht sicherlich eleganter mit dem richtigen regulären Ausdruck und dem find exec …
Jedenfalls habe ich mit diesem Ansatz die Installationblockade beseitigen können.
Vielleicht hilft es bei der Fehlersuch.
Hearp
Eleganter geht es so:
https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
Hallo Forum!
ein Jahr später läuft mein iobroker eigentlich ganz, wenn ich nicht doch ein recht schwachen PI und nun hab ich einen neuen bestellt. In diesem Zusammenhang stellte ich fest, dass seit auf den Tag genau kein Automatisches Update durchgeführt wurde. Manuell über das Terminal kam folgende Ausgabe.
pi@raspberrypi:/opt/iobroker $ ./iobroker backup host.raspberrypi 11971 states saved host.raspberrypi 17365 objects saved <--- Last few GCs ---> [15135:0x54a8cf0] 43648 ms: Mark-sweep 303.8 (328.3) -> 202.6 (219.8) MB, 405.4 / 0.1 ms (average mu = 0.914, current mu = 0.905) external memory pressure scavenge might not succeed [15135:0x54a8cf0] 47162 ms: Mark-sweep (reduce) 305.4 (320.6) -> 305.3 (311.6) MB, 824.0 / 0.1 ms (+ 75.1 ms in 30 steps since start of marking, biggest step 5.5 ms, walltime since start of marking 1150 ms) (average mu = 0.831, current mu = 0.744) all <--- JS stacktrace ---> FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory ./iobroker: Zeile 10: 15134 Abgebrochen sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
Updates werden grundsätzlich nicht automatisch ausgeführt. Die musst du selber anstoßen.
iob stop iob fix iob diag
sagt? Insbesondere die vollständige Ausgabe des letzten Befehls interessiert.
