    4. Instanz Update-Anzeige passt nicht mehr
      mguenther last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 8GB
      Festplattenart: SSD
      Betriebssystem: Debian
      Node-Version: 14.19.0
      Nodejs-Version: 14.19.0
      NPM-Version: 6.14.16
      Installationsart: Skript
      Image genutzt: Ja
      irgendwie scheint es, dass die Anzeige über ein anstehendes update nicht mehr so ganz bei meinem System passt.
      Anbei eine Ausgabe von iob update:
      pi@raspberrypi:~ $ iob update
      Used repository: stable
      Adapter    "admin"        : 5.3.1    , installed 5.3.1
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.3.3    , installed 2.3.3
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "cloud"        : 4.1.0    , installed 4.1.0
      Adapter    "daswetter"    : 3.0.9    , installed 3.0.9
      Adapter    "deconz"       : 1.3.20   , installed 1.3.19 [Updatable]
      Adapter    "denon"        : 1.12.1   , installed 1.12.1
      Adapter    "devices"      : 1.0.9    , installed 1.0.9
      Adapter    "discovery"    : 2.7.5    , installed 2.7.5
      Adapter    "dwd"          : 2.7.7    , installed 2.7.7
      Adapter    "echarts"      : 1.0.3    , installed 1.0.3
      Adapter    "ekey"         : 1.1.0    , installed 1.1.0
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "flot"         : 1.10.7   , installed 1.10.7
      Adapter    "fullybrowser" : 2.0.10   , installed 2.0.10
      Adapter    "history"      : 1.10.5   , installed 1.10.5
      Adapter    "hm-rega"      : 3.0.35   , installed 3.0.35
      Adapter    "hm-rpc"       : 1.15.9   , installed 1.15.8 [Updatable]
      Adapter    "ical"         : 1.11.4   , installed 1.11.4
      Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
      Adapter    "icons-mfd-svg": 1.0.2    , installed 1.0.2
      Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
      Adapter    "info"         : 1.9.8    , installed 1.9.8
      Adapter    "iot"          : 1.8.24   , installed 1.8.24
      Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
      Adapter    "javascript"   : 5.2.21   , installed 5.2.21
      Controller "js-controller": 4.0.21   , installed 4.0.21
      Adapter    "lg-thinq"     : 0.0.4    , installed 0.0.4
      Adapter    "linux-control": 1.1.3    , installed 1.1.3
      Adapter    "logparser"    : 1.1.0    , installed 1.1.0
      Adapter    "modbus"       : 3.4.17   , installed 3.4.17
      Adapter    "mqtt"         : 2.4.1    , installed 2.4.1
      Adapter    "nut"          : 1.5.0    , installed 1.5.0
      Adapter    "odl"          : 1.1.4    , installed 1.1.4
      Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
      Adapter    "ping"         : 1.5.0    , installed 1.5.0
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "radar2"       : 2.0.3    , installed 2.0.3
      Adapter    "rpi2"         : 1.3.1    , installed 1.3.1
      Adapter    "rssfeed"      : 1.0.0    , installed 1.0.0
      Adapter    "shelly"       : 5.3.2    , installed 5.3.2
      Adapter    "shuttercontrol": 1.4.10  , installed 1.4.10
      Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
      Adapter    "socketio"     : 3.1.5    , installed 4.1.0
      Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
      Adapter    "sprinklecontrol": 0.2.7  , installed 0.2.7
      Adapter    "sql"          : 1.16.1   , installed 1.16.1
      Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
      Adapter    "trashschedule": 1.4.1    , installed 1.4.1
      Adapter    "unifi"        : 0.5.10   , installed 0.5.10
      Adapter    "vis"          : 1.4.5    , installed 1.4.5
      Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
      Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "vis-metro"    : 1.1.2    , installed 1.1.2
      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
      Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
      Adapter    "vw-connect"   : 0.0.48   , installed 0.0.48
      Adapter    "weatherunderground": 3.3.1, installed 3.3.1
      Adapter    "web"          : 3.4.16   , installed 3.4.16
      Adapter    "wled"         : 0.6.3    , installed 0.6.3
      Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
      anbei noch die Screenshots, die Menüleiste sieht so aus:
      Das würde ja noch mit der obigen Ausgae übereinstimmen, wenn ich nicht schon vor einiger Zeit über die grafische Oberfläche die deconz-Instanz gelöscht hätte. Ist dann die Anzeige für ein deconz-Update überflüssig?
      Dann ist mir aufgefallen, dass mir beim HM-RPC gar kein Update angezeigt wird.
      Mein System läuft, aber das passt irgendwie nicht zusammen...
      Was kann ich machen?
      M Thomas Braun 2 Replies Last reply Reply Quote 0
        mguenther @mguenther last edited by
        als Ergänzung - die Info Seite zeigt mir gar nix an...
          Thomas Braun Most Active @mguenther last edited by
          @mguenther sagte in Instanz Update-Anzeige passt nicht mehr:
          Dann ist nur eine Instanz gelöscht, der Adapter ist noch da.
          Das Terminal lügt nicht. Die GUI/der Browser schon.
          Cache löschen, Seite neu laden.
            mguenther @Thomas Braun last edited by
            @thomas-braun sagte in Instanz Update-Anzeige passt nicht mehr:
            also, wenn ich zB. die letzte Instanz "lösche", wäre es dann nicht sinnvoll, auch den Adapter zu löschen?
            So ist es ziemlich verwirrend. Wenn ich einen Adapter gar nicht installiert habe, dann wird mir ja auch kein update angezeigt... egal.
            Terminal hatte ich schon verstanden und auch als Master angesehen - finde nur die grafische Umsetzung "unpassend"... Der HM-RPC kam dann irgendwann auch unter dem Reiter Adapter als Updatefähig...
              Das musst DU wissen und machen. Ein Adapter liefert nur den Rahmen für daraus hergeleitete Instanzen.
                Dann frage ich nochmal als Laie anders - wie lösche ich denn den deconz Adapter, so dass er mir zum Update auch nicht mehr angezeigt wird? Bei Bedarf würde ich aber ihn dann weiterhin gerne unter dem Reiter Adapter finden wollen (um ihn ggf. wieder zu installieren).
                Da unten rechts?
                  @mguenther
                  iobroker del deconz
                    danke - war ja ganz einfach 🙂
