    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      tombox @ostseereiter last edited by
      @ostseereiter Nochmal installieren und schauen ob etwas im log steht
      ostseereiter 1 Reply Last reply Reply Quote 0
      • ostseereiter
        ostseereiter @tombox last edited by wendy2702
        @tombox wie gesagt die 10 läuft nun wieder auf die 12 und rot
        im Log finde ich nur das:
        	2022-03-17 14:39:42.325	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.debian
        2022-03-17 14:39:42.325	error	Caught by controller[0]: }
        host.debian
        2022-03-17 14:39:42.325	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
        host.debian
        2022-03-17 14:39:42.325	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
        host.debian
        2022-03-17 14:39:42.324	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
        host.debian
        2022-03-17 14:39:42.324	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
        host.debian
        2022-03-17 14:39:42.324	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
        host.debian
        2022-03-17 14:39:42.324	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
        host.debian
        2022-03-17 14:39:42.324	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
        host.debian
        2022-03-17 14:39:42.323	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
        host.debian
        2022-03-17 14:39:42.323	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
        host.debian
        2022-03-17 14:39:42.323	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
        host.debian
        2022-03-17 14:39:42.323	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
        host.debian
        2022-03-17 14:39:42.323	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        host.debian
        2022-03-17 14:39:42.322	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
        host.debian
        2022-03-17 14:39:42.322	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
        host.debian
        2022-03-17 14:39:42.321	error	Caught by controller[0]: was compiled against a different Node.js version using
        host.debian
        2022-03-17 14:39:42.321	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
        host.debian
        2022-03-17 14:39:42.321	error	Caught by controller[0]: ^
        host.debian
        2022-03-17 14:39:42.320	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
        host.debian
        2022-03-17 14:39:42.320	error	Caught by controller[0]: internal/modules/cjs/loader.js:1144
          Thomas Braun Most Active @ostseereiter last edited by Thomas Braun
          @ostseereiter
          Neubauen lassen. War glaube ich weiter oben schon mal Thema.
          Und/oder deine node-Installation aktualisieren.
          ostseereiter B 2 Replies Last reply Reply Quote 0
          • ostseereiter
            ostseereiter @Thomas Braun last edited by
            danke das war die Lösung:
            cd /opt/iobroker
            npm install canvas
              Gruter last edited by
              Hi, ich habe bei Amazon aktuell noch "Altdaten" unter Objekte.
              Unter parcel.0.amazon.sendungen01.detailedState
              habe ich noch ein Ordner mapTracking, in diesem sind Daten vom 02.03. angezeigt, diese gehören nicht zur aktuellen Bestellung.
              in der JSON gibt es aktuell auch keinen Eintrag zu mapTracking.
                bob der 1. @Thomas Braun last edited by bob der 1.
                Habe genau das gleiche Problem mit den Adapter Versionen 0.0.10&0.0.12, Node Version v14.19.1
                bei
                cd /opt/iobroker/node_modules
                npm list canvas
                bekomme ich als Ausgabe
                iobroker.inst@3.0.0 /opt/iobroker
                ├── canvas@2.9.0
                ├─┬ iobroker.echarts@1.0.3
                │ └── canvas@2.8.0
                ├─┬ iobroker.iot@1.8.24
                │ └── canvas@2.9.0  deduped
                ├─┬ iobroker.mihome-vacuum@3.3.5 (github:iobroker-community-adapters/ioBroker.mi                                     home-vacuum#_____________)
                │ └── canvas@2.9.0
                └─┬ iobroker.parcel@0.0.10
                anschließend
                cd /opt/iobroker
                npm install canvas
                Ausgabe
                [.......[..................] / loadDep:simple-get: sill removeObsoleteDep removing nan@2.15.0 from the tree as its be
                > canvas@2.9.0 install /opt/iobroker/node_modules/canvas
                > node-pre-gyp install --fallback-to-build
                node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.0/canvas-v2.9.0-node-v83-linux-glibc-arm.tar.gz
                node-pre-gyp WARN Pre-built binaries not installable for canvas@2.9.0 and node@14.19.1 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
                node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.0/canvas-v2.9.0-node-v83-linux-glibc-arm.tar.gz
                make: Entering directory '/opt/iobroker/node_modules/canvas/build'
                  SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
                  COPY Release/canvas-postbuild.node
                  CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                  CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                  CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                  CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                  CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
                ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
                   E(ptr - data > imgdOffset, "image data overlaps with another structure");
                ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                 #define E(cond, msg) if(cond) return setErr(msg)
                ../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
                   E(ptr - data + imgdSize > len, "not enough image data");
                  CXX(target) Release/obj.target/canvas/src/Backends.o
                  CXX(target) Release/obj.target/canvas/src/Canvas.o
                  CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                  CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                  CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                  CXX(target) Release/obj.target/canvas/src/closure.o
                  CXX(target) Release/obj.target/canvas/src/color.o
                  CXX(target) Release/obj.target/canvas/src/Image.o
                  CXX(target) Release/obj.target/canvas/src/ImageData.o
                  CXX(target) Release/obj.target/canvas/src/init.o
                  CXX(target) Release/obj.target/canvas/src/register_font.o
                  SOLINK_MODULE(target) Release/obj.target/canvas.node
                  COPY Release/canvas.node
                make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
                npm WARN http-cookie-agent@1.0.5 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
                + canvas@2.9.0
                updated 1 package in 95.966s
                70 packages are looking for funding
                  run `npm fund` for details
                Adapter gelöscht,beide Versionen versucht ...nichts!
                  skokarl last edited by
                  wofür, oder wann wird bei Amazon der Token benötigt ?
                  Was ist wenn man bei Amazon 2 Konten hat..... z.B. für Ehefrau?
                  sorry, aber 617 Beiträge durchsichen ist echt übel .....
                  G DJMarc75 2 Replies Last reply Reply Quote 0
                    guergen @skokarl last edited by
                    @skokarl Mal vorsichtig gesagt, zwei Instanzen anlegen....
                    • DJMarc75
                      DJMarc75 @skokarl last edited by
                      @skokarl said in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                      eine Instanz des Adapters kann nur ein Konto, egal welcher Dienstleister, abarbeiten, also wie @guergen geschrieben hat dann dementsprechend viele Instanzen installieren.
                        michaelxhoffmann last edited by michaelxhoffmann
                        Hi, habe den Adapter heute installiert. Hätte da eine Frage zur DHL Benachrichtigung. Wie bekomme ich die SMS bzw. Mail? Wann erhalte ich die? Email und Passwort habe ich korrekt eingegeben, aber die PIN fehlt mir irgendwie. Die Instanz bleibt auch konsequent rot.Ich habe die DHL App auf meinem Iphone installiert, Dort funktioniert sie auch.
                        Danke für Eure Hilfe
                        Thomas Braun DJMarc75 2 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @michaelxhoffmann last edited by
                          @michaelxhoffmann sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                          Die kommt beim Versuch sich einzuloggen automatisch. Sollte Sie zumindest.
                          • DJMarc75
                            DJMarc75 @michaelxhoffmann last edited by
                            @michaelxhoffmann said in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                            warte mal ne halbe Stunde und dann nochmal die Daten eingeben.
                            • Jabba_the_Hutt
                              Jabba_the_Hutt last edited by Jabba_the_Hutt
                              npm: 8.5.0
                              node.js: 16.14.2
                              Der Adapter lässt sich nicht installieren.
                              Fehler:
                              Der rebuild verläuft dann auch in einem Error.
                              Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                              sigi234 T 2 Replies Last reply Reply Quote 0
                                sigi234 Forum Testing Most Active @Jabba_the_Hutt last edited by sigi234
                                @jabba_the_hutt
                                Steh ja eh da, FALSCHE Version von Node:
                                Empfohlene sind:
                                NODE.JS: V14.19.1
                                NPM: 6.14.16
                                https://forum.iobroker.net/topic/42952/der-kleine-iobroker-linux-werkzeugkasten
                                Jabba_the_Hutt 1 Reply Last reply Reply Quote 0
                                  tombox @Jabba_the_Hutt last edited by
                                  @jabba_the_hutt
                                  Also node 16 ist kein problem aber npm 8 ist nocht nicht komplett getestet
                                  cd /opt/iobroker
                                  npm rebuild
                                  npm install canvas
                                  probiert?
                                  • DJMarc75
                                    DJMarc75 last edited by DJMarc75
                                    @tombox
                                    Frage:
                                    Kann man in der Konfig die einzelnen Dienstleister mit eine Checkbox zum de- oder aktivieren versehen ?
                                    So muss man nicht jedesmal, wenn man einen Dienst an- oder ausschalten möchte die Zugangsdaten löschen oder neu eingeben.
                                    • Rene R
                                      Rene R last edited by
                                      Hallo Liebe CSSler,
                                      Ich bräuchte eure Hilfe....
                                      Ich habe vor in dem CSS ( HTML ) beim Header wo Amazon Bestell Status steht davor und daneben ein kleines Amazon Logo hinzufügen.
                                      und wäre es möglich die Gelieferten Bestellungen zu verstecken?
                                      Ich habe es versucht über den VIS OWL das hinzubekommen aber klappt irgendwie nicht weil ich nur geringen platz haben höhe und breite 200px
                                      hier den CSS CODE:
                                      <style type="text/css">
                                      #{wid} .tg {
                                       border-collapse:collapse;border-color:#9ABAD9;border-spacing:0;
                                      #{wid} .tg td{
                                       background-color:;border-color:#9ABAD9;border-style:solid;border-width:0px;color:white;
                                       font-family:Comic Sans MS, sans-serif;font-size:10pxpx;overflow:hidden;padding:10px 5px;word-break:normal;
                                      #{wid} .tg th{
                                       background-color:#409cff;border-color:#9ABAD9;border-style:solid;border-width:0px;color:#fff;
                                       font-family:Comic Sans MS, sans-serif;font-size:10px;font-weight:normal;overflow:hidden;padding:10px 5px;word-break:normal;
                                      #{wid} .tg .tg-vn85{
                                       border-color:ffcc67;text-align:left;vertical-align:top
                                      #{wid} .tg-sort-header::-moz-selection{
                                       background:0 0}
                                      #{wid} .tg-sort-header::selection{
                                       background:0 0}.tg-sort-header{
                                       cursor:pointer
                                      #{wid} .tg-sort-header:after{
                                       content:'';float:right;margin-top:7px;border-width:0 5px 5px;border-style:solid;
                                       border-color:#404040 transparent;visibility:hidden
                                      #{wid} .tg-sort-header:hover:after{
                                       visibility:visible}
                                      #{wid} .tg-sort-asc:after,.tg-sort-asc:hover:after,.tg-sort-desc:after{
                                       visibility:visible;opacity:.4
                                      #{wid} .tg-sort-desc:after{
                                      border-bottom:none;border-width:5px 5px 0
                                      }</style>
                                      <table id="tg-noEOi" class="tg">
                                      <thead>
                                       <tr>
                                      <th class="tg-vn85">Amazon Bestell Status</th>
                                       </tr>
                                      </thead>
                                      <tbody>
                                       <tr>
                                       <td class="tg-vn85">{parcel.0.amazon.sendungen01.status}</td>
                                       </tr>
                                       <tr>
                                       <td class="tg-vn85">{parcel.0.amazon.sendungen02.status}</td>
                                       </tr>
                                       <tr>
                                       <td class="tg-vn85">{parcel.0.amazon.sendungen03.status}</td>
                                       </tr>
                                       <tr>
                                       <td class="tg-vn85">{parcel.0.amazon.sendungen04.status}</td>
                                       </tr>
                                      </tbody>
                                      </table>
                                      Wäre super wenn einer von euch mir helfen könnte.
                                      Liebe Grüße
                                      Rene
                                      P.S der Adapter ist super
                                      • Jabba_the_Hutt
                                        Jabba_the_Hutt @sigi234 last edited by
                                        @sigi234
                                        Ist mir schon klar, dass für NICHT Betatester andere Versionen vorgesehen sind.
                                          Buchi @Rene R last edited by
                                          @rene-r sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                          Hallo Liebe CSSler,
                                          Warum sollte das mit owl nicht gehen? Alles einstellbar 🙂
                                          Rene R 1 Reply Last reply Reply Quote 0
                                          • Jabba_the_Hutt
                                            Jabba_the_Hutt @tombox last edited by
                                            @tombox
                                            Ja, habe ich versucht. Hilft leider auch nichts.
                                            17track amazon briefe dhl dpd gls ups
                                            122
                                            1534
                                            525950
