    3. Einsteigerfragen
    4. [erledigt] echarts geht nicht zu starten
      Emi 0 @Thomas Braun last edited by
      micros02@smartmeter:~ $ iobroker status
       Unable to increase LUA script timeout: Connection is closed.
       Cannot determine Set feature status: Connection is closed.
      Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
        Thomas Braun Most Active @Emi 0 last edited by
        @emi-0 sagte in echarts geht nicht zu starten:
        sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
          micros02@smartmeter:~ $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
          sudo: lsof: command not found
            @emi-0
            sudo apt update
            sudo apt install lsof
              hat etwas länger gedauert, weil PUTTY abgeschmiert war
              micros02@smartmeter:~ $ sudo apt update
              Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
              Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
              Get:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
              Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [264 kB]
              Fetched 13.5 MB in 51s (266 kB/s)
              Reading package lists... Done
              Building dependency tree... Done
              4 packages can be upgraded. Run 'apt list --upgradable' to see them.
              micros02@smartmeter:~ $ sudo apt install lsof
              The following NEW packages will be installed:
                lsof
              0 upgraded, 1 newly installed, 0 to remove and 4 not upgraded.
              Need to get 308 kB of archives.
              After this operation, 449 kB of additional disk space will be used.
              Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf lsof armhf 4.93.2+dfsg-1.1 [308 kB]
              Fetched 308 kB in 2s (183 kB/s)
              Selecting previously unselected package lsof.
              (Reading database ... 53331 files and directories currently installed.)
              Preparing to unpack .../lsof_4.93.2+dfsg-1.1_armhf.deb ...
              Unpacking lsof (4.93.2+dfsg-1.1) ...
              Setting up lsof (4.93.2+dfsg-1.1) ...
              Processing triggers for man-db (2.9.4-2) ...
              Was tue ich jetzt?
                @emi-0
                Jetzt nimmst du die 4 Updates auch noch mit:
                sudo apt full-upgrade
                sudo reboot
                Wenn es dann immer noch klemmt schauen wir je nach Meldung weiter.
                  ich habe irgendein Problem mit PUTTY wenn ich sudo reboot eingebe:
                  Thomas Braun da_Woody 2 Replies Last reply Reply Quote 0
                    @emi-0
                    Ich nutze kein Knetgummi (putty). Verbindung nochmal neuaufbauen? Bei den vier Updates dürfte auch openssl dabei gewesen sein.
                      habe ich jetzt schon 3x gemacht.
                      Gibt es etwas besseres als putty?
                        @emi-0
                        Ich verwende die PowerShell 7.2.2.
                          ok. Werde ich morgen ausprobieren.
                          Melde mich dann wieder.
                          Vielen Dank erstmal und schönen Abend
                          • da_Woody
                            da_Woody @Emi 0 last edited by
                            @emi-0 nu, wenn du das teil rebootest, verliert putty logischerweise die verbindung. du kannst danach mit rechtsklick in der titelleiste restart session nehmen.
                            da gibts einiges... bin vor kurzem wieder auf MobaXterm gestossen. mächtig, kann viel. sicher teilweise überpowert, aber man kann damit halt auch viel mehr anstellen.
                              Emi 0 @da_Woody last edited by
                              @da_woody
                              Inzwischen scheint echarts zu funktionieren.
                              Obwohl ich nichts mehr unternommen hatte.
                              Also ist das Problem beseitigt.
                              Danke an alle, die mit gewirkt haben.
                              1.5k
                              1869
