    4. IoBroker bootet nicht mehr
      Thomas Braun Most Active @Chrisbie last edited by
      @chrisbie
      Texte in CodeTags posten.
        @chrisbie
        Finger weg vom npm Upgrade!
          @chrisbie
          iobroker status
          sagt?
            Chrisbie @Thomas Braun last edited by
            internal/modules/cjs/loader.js:905
              throw err;
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                at internal/main/run_main_module.js:17:47 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
              @chrisbie
              iobroker stop
              iobroker fix
              iobroker update
              iobroker upgrade
              iobroker upgrade self
              iobroker start
                Chrisbie last edited by Chrisbie
                @thomas-braun sagte in IoBroker bootet nicht mehr:
                iobroker fix
                erhalte ich folgende Meldung:
                pi@RspIoBroker2:/opt/iobroker $ iobroker fix
                library: loaded
                Library version=2022-02-10
                ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                und bei iobroker update
                pi@RspIoBroker2:/opt/iobroker $ iobroker update
                  throw err;
                  requireStack: []
                  @chrisbie
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
                    vielen dank für die unterstüzung scheint, wieder einigermaßen zu laufen.
                      @chrisbie
                      iobroker update -u
                      zeigt?
                        Jetzt lief alles ein paar tage ohne Problem, aber seit heute habe ich ständig folgende Meldungen:
                        host.RspIoBroker2
                        		2022-03-18 20:51:32.821	error	Cannot download and install adapter "vis-materialdesign@0.3.14". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                        host.RspIoBroker2
                        		2022-03-18 20:51:32.724	info	iobroker npm-install: exit 12
                        host.RspIoBroker2
                        		2022-03-18 20:51:31.626	error	iobroker npm-install: host.RspIoBroker2 Unknown packetName vis-materialdesign. Please install packages from outside the repository using npm!
                        host.RspIoBroker2
                        		2022-03-18 20:51:28.676	info	iobroker install vis-materialdesign@0.3.14 using installedVersion
                        host.RspIoBroker2
                        		2022-03-18 20:51:28.675	warn	startInstance cannot find adapter "vis-materialdesign@0.3.14". Try to install it... 4 attempt
                        host.RspIoBroker2
                        		2022-03-18 20:51:28.579	info	iobroker npm-install: exit 12
                        host.RspIoBroker2
                        		2022-03-18 20:51:27.497	error	iobroker npm-install: host.RspIoBroker2 Unknown packetName vis-materialdesign. Please install packages from outside the repository using npm!
                        host.RspIoBroker2
                        		2022-03-18 20:51:25.253	info	stopInstance system.adapter.vis.0 (force=false, process=true)
                        host.RspIoBroker2
                        		2022-03-18 20:51:25.252	info	"system.adapter.vis.0" enabled
                        host.RspIoBroker2
                        		2022-03-18 20:51:25.196	info	stopInstance system.adapter.vis.0 (force=false, process=true)
                        host.RspIoBroker2
                        		2022-03-18 20:51:25.193	info	"system.adapter.vis.0" disabled
                        host.RspIoBroker2
                        		2022-03-18 20:51:24.414	info	iobroker install vis-materialdesign@0.3.14 using installedVersion
                        host.RspIoBroker2
                        		2022-03-18 20:51:24.414	warn	startInstance cannot find adapter "vis-materialdesign@0.3.14". Try to install it... 3 attempt
                        host.RspIoBroker2
                        		2022-03-18 20:51:24.301	info	iobroker npm-install: exit 12
                        host.RspIoBroker2
                        		2022-03-18 20:51:23.193	error	iobroker npm-install: host.RspIoBroker2 Unknown packetName vis-materialdesign. Please install packages from outside the repository using npm!
                        nach und alles wird extrem langsam.
                        nach einem Reboot, läuft es erst mal wieder. Aber was kann ich gengen die Meldung tun.
                        Aber weiter oben hat "Thomas Braun" ja empfolen die finder von einem Update zu lassen.
                          Thomas Braun Most Active @Chrisbie last edited by Thomas Braun
                          @chrisbie sagte in IoBroker bootet nicht mehr:
                          vis-materialdesign
                          vis-materialdesign
                          github:	0.5.76
                          latest:	0.5.9 for 9 months
                          stable:	-.-.-
                          Wo soll denn da eine 0.3.14 hergezaubert werden?
                          Die Ausgabe zu
                          iobroker update -u
                          bist du auch Schuldig geblieben.
                            pi@RspIoBroker2:~ $ iobroker update -u
                            Used repository: Stable (default)
                            pi@RspIoBroker2:~ $
                            sollte da noch mehr sein?
                            Thomas Braun Gargano 2 Replies Last reply Reply Quote 0
                              @chrisbie
                              iobroker update -i
                              iobroker list adapters
                              iobroker list instances
                              • Gargano
                                Gargano @Chrisbie last edited by
                                @chrisbie was ist das denn für ein raspi? Wieviel RAM, free Ram, SD Card oder ssd?
                                  pi@RspIoBroker2:~ $ iobroker update -i
                                  Adapter    "admin"        : 5.3.1    , installed 5.3.1
                                  Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
                                  Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                                  Adapter    "backitup"     : 2.3.3    , installed 2.3.3
                                  Adapter    "cloud"        : 4.1.0    , installed 4.1.0
                                  Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                  Adapter    "daswetter"    : 3.0.9    , installed 3.0.9
                                  Adapter    "devices"      : 1.0.9    , installed 1.0.9
                                  Adapter    "discovery"    : 2.7.5    , installed 2.7.5
                                  Adapter    "divera247"    : 0.1.2    , installed 0.1.2
                                  Adapter    "dwd"          : 2.7.7    , installed 2.7.7
                                  Adapter    "flot"         : 1.10.7   , installed 1.10.7
                                  Adapter    "history"      : 1.10.5   , installed 1.10.5
                                  Adapter    "ical"         : 1.11.4   , installed 1.11.4
                                  Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
                                  Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
                                  Adapter    "info"         : 1.9.8    , installed 1.9.8
                                  Adapter    "iot"          : 1.8.24   , installed 1.8.24
                                  Adapter    "javascript"   : 5.2.21   , installed 5.2.21
                                  Controller "js-controller": 4.0.21   , installed 4.0.21
                                  Adapter    "luftdaten"    : 2.1.3    , installed 2.1.3
                                  Adapter    "mqtt"         : 2.4.1    , installed 2.4.1
                                  Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                  Adapter    "samsung"      : 0.2.9    , installed 0.2.9
                                  Adapter    "shelly"       : 5.3.2    , installed 5.3.2
                                  Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
                                  Adapter    "socketio"     : 4.1.4    , installed 4.1.4
                                  Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
                                  Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                  Adapter    "telegram"     : 1.11.1   , installed 1.11.1
                                  Adapter    "text2command" : 2.1.1    , installed 2.1.1
                                  Adapter    "tr-064"       : 4.2.15   , installed 4.2.15
                                  Adapter    "trashschedule": 1.4.1    , installed 1.4.1
                                  Adapter    "viessmannapi" : 2.0.9    , installed 2.0.9
                                  Adapter    "vis"          : 1.4.5    , installed 1.4.5
                                  Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                  Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                                  Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
                                  Adapter    "vis-metro"    : 1.1.2    , installed 1.1.2
                                  Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                  Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
                                  Adapter    "web"          : 4.2.0    , installed 4.2.0
                                  Adapter    "ws"           : 1.2.0    , installed 1.2.0
                                  Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
                                    Chrisbie @Chrisbie last edited by Chrisbie
                                    pi@RspIoBroker2:~ $ iobroker list instances
                                    + system.adapter.admin.0                  : admin                 : RspIoBroker2                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.alexa2.0                 : alexa2                : RspIoBroker2                             -  enabled
                                      system.adapter.alias-manager.0          : alias-manager         : RspIoBroker2                             -  enabled
                                    + system.adapter.backitup.0               : backitup              : RspIoBroker2                             -  enabled
                                    + system.adapter.cloud.0                  : cloud                 : RspIoBroker2                             -  enabled
                                      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: RspIoBroker2                             -  enabled
                                      system.adapter.daswetter.0              : daswetter             : RspIoBroker2                             -  enabled
                                      system.adapter.devices.0                : devices               : RspIoBroker2                             -  enabled
                                    + system.adapter.discovery.0              : discovery             : RspIoBroker2                             -  enabled
                                    + system.adapter.divera247.0              : divera247             : RspIoBroker2                             -  enabled
                                      system.adapter.dwd.0                    : dwd                   : RspIoBroker2                             -  enabled
                                      system.adapter.flot.0                   : flot                  : RspIoBroker2                             -  enabled
                                    + system.adapter.history.0                : history               : RspIoBroker2                             -  enabled
                                      system.adapter.ical.0                   : ical                  : RspIoBroker2                             -  enabled
                                      system.adapter.ical.1                   : ical                  : RspIoBroker2                             -  enabled
                                      system.adapter.ical.2                   : ical                  : RspIoBroker2                             -  enabled
                                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : RspIoBroker2                             -  enabled
                                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : RspIoBroker2                             -  enabled
                                    + system.adapter.influxdb.0               : influxdb              : RspIoBroker2                             -  enabled, port: 8086
                                    + system.adapter.info.0                   : info                  : RspIoBroker2                             -  enabled
                                    + system.adapter.iot.0                    : iot                   : RspIoBroker2                             -  enabled
                                    + system.adapter.javascript.0             : javascript            : RspIoBroker2                             -  enabled
                                      system.adapter.luftdaten.0              : luftdaten             : RspIoBroker2                             -  enabled
                                    + system.adapter.mqtt.0                   : mqtt                  : RspIoBroker2                             -  enabled, port: 8883, bind: 0.0.0.0
                                    + system.adapter.nina.0                   : nina                  : RspIoBroker2                             -  enabled
                                    + system.adapter.samsung.0                : samsung               : RspIoBroker2                             -  enabled
                                    + system.adapter.shelly.0                 : shelly                : RspIoBroker2                             -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.simple-api.0             : simple-api            : RspIoBroker2                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                    + system.adapter.sonoff.0                 : sonoff                : RspIoBroker2                             -  enabled, port: 1883, bind: 0.0.0.0
                                      system.adapter.sourceanalytix.0         : sourceanalytix        : RspIoBroker2                             - disabled
                                    + system.adapter.tankerkoenig.0           : tankerkoenig          : RspIoBroker2                             -  enabled
                                    + system.adapter.telegram.0               : telegram              : RspIoBroker2                             -  enabled, port: 8443, bind: 0.0.0.0
                                      system.adapter.text2command.0           : text2command          : RspIoBroker2                             - disabled
                                    + system.adapter.tr-064.0                 : tr-064                : RspIoBroker2                             -  enabled
                                    + system.adapter.tr-064.1                 : tr-064                : RspIoBroker2                             -  enabled
                                    + system.adapter.trashschedule.0          : trashschedule         : RspIoBroker2                             -  enabled
                                      system.adapter.viessmannapi.0           : viessmannapi          : RspIoBroker2                             - disabled
                                      system.adapter.vis-bars.0               : vis-bars              : RspIoBroker2                             -  enabled
                                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : RspIoBroker2                             -  enabled
                                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : RspIoBroker2                             -  enabled
                                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : RspIoBroker2                             -  enabled
                                      system.adapter.vis-history.0            : vis-history           : RspIoBroker2                             -  enabled
                                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : RspIoBroker2                             -  enabled
                                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : RspIoBroker2                             -  enabled
                                      system.adapter.vis-metro.0              : vis-metro             : RspIoBroker2                             -  enabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : RspIoBroker2                             -  enabled
                                      system.adapter.vis-weather.0            : vis-weather           : RspIoBroker2                             -  enabled
                                      system.adapter.vis.0                    : vis                   : RspIoBroker2                             -  enabled
                                      system.adapter.web-speedy.0             : web-speedy            : RspIoBroker2                             - disabled
                                    + system.adapter.web.0                    : web                   : RspIoBroker2                             -  enabled, port: 8082, bind: 192.168.178.200, run as: admin
                                    + system.adapter.zigbee.0                 : zigbee                : RspIoBroker2                             -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2216870-if00
                                    + instance is alive
                                    pi@RspIoBroker2:~ $ iobroker list adapters
                                    system.adapter.admin                   : admin          - v5.3.1
                                    system.adapter.alexa2                  : alexa2         - v3.11.2
                                    system.adapter.alias-manager           : alias-manager  - v1.2.4
                                    system.adapter.backitup                : backitup       - v2.3.3
                                    system.adapter.cloud                   : cloud          - v4.1.0
                                    system.adapter.coronavirus-statistics  : coronavirus-statistics - v0.8.7
                                    system.adapter.daswetter               : daswetter      - v3.0.9
                                    system.adapter.devices                 : devices        - v1.0.9
                                    system.adapter.discovery               : discovery      - v2.7.5
                                    system.adapter.divera247               : divera247      - v0.1.2
                                    system.adapter.dwd                     : dwd            - v2.7.7
                                    system.adapter.flot                    : flot           - v1.10.7
                                    system.adapter.history                 : history        - v1.10.5
                                    system.adapter.ical                    : ical           - v1.11.4
                                    system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
                                    system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                                    system.adapter.influxdb                : influxdb       - v2.6.3
                                    system.adapter.info                    : info           - v1.9.8
                                    system.adapter.iot                     : iot            - v1.8.24
                                    system.adapter.javascript              : javascript     - v5.2.21
                                    system.adapter.luftdaten               : luftdaten      - v2.1.3
                                    system.adapter.mqtt                    : mqtt           - v2.4.1
                                    system.adapter.mqtt-client             : mqtt-client    - v1.3.1
                                    system.adapter.nina                    : nina           - v0.0.25
                                    system.adapter.samsung                 : samsung        - v0.2.9
                                    system.adapter.shelly                  : shelly         - v5.3.2
                                    system.adapter.simple-api              : simple-api     - v2.6.2
                                    system.adapter.socketio                : socketio       - v3.1.4
                                    system.adapter.sonoff                  : sonoff         - v2.4.7
                                    system.adapter.sourceanalytix          : sourceanalytix - v0.4.8
                                    system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
                                    system.adapter.telegram                : telegram       - v1.11.1
                                    system.adapter.text2command            : text2command   - v2.1.1
                                    system.adapter.tr-064                  : tr-064         - v4.2.15
                                    system.adapter.trashschedule           : trashschedule  - v1.4.1
                                    system.adapter.viessmannapi            : viessmannapi   - v2.0.9
                                    system.adapter.vis                     : vis            - v1.4.5
                                    system.adapter.vis-bars                : vis-bars       - v0.1.4
                                    system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
                                    system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
                                    system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                                    system.adapter.vis-history             : vis-history    - v1.0.0
                                    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.9
                                    system.adapter.vis-materialdesign      : vis-materialdesign - v0.3.14
                                    system.adapter.vis-metro               : vis-metro      - v1.1.2
                                    system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                                    system.adapter.vis-weather             : vis-weather    - v2.5.5
                                    system.adapter.web                     : web            - v4.2.0
                                    system.adapter.web-speedy              : web-speedy     - v0.2.0
                                    system.adapter.zigbee                  : zigbee         - v1.6.16
                                      vis-materialdesign
                                      iobroker del vis-materialdesign
                                        so mal kucken ob es nun besser läuft.
                                        Was ich nicht verstehe, warum lief bis jetzt gut ein Jahr ohne Probleme und auf einmal hakt es an allen enden.
                                          Ich verstehe es immer noch nicht.
                                          Seit dem ich oben erwähntes problem hatte, läuft der IoBroker immer noch nicht rund.
                                          Alle adapter sind auf aktuellstem stand.
                                          Aber jetzt kann ich über die Web-Oberfläche die Adapterseite oder Instanzen seite nicht auf machen, da bekomme ich immer ein Time out und die "Cannot read setting" aber ich habe immer noch keine Ahnung woran es hängt.
                                          Gargano 1 Reply Last reply Reply Quote 0
                                          • Gargano
                                            @chrisbie Du hast meine Frage bezüglich Raspi RAM , free Ram, . SSD oder SDCard noch nicht beantwortet
                                            1357
