    4. IoBroker bootet nicht mehr
      Thomas Braun Most Active @Chrisbie last edited by
      @chrisbie
      iobroker status
      sagt?
        Chrisbie @Thomas Braun last edited by
        internal/modules/cjs/loader.js:905
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
            at Function.Module._load (internal/modules/cjs/loader.js:746:27)
            at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
            at internal/main/run_main_module.js:17:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
          @chrisbie
          iobroker stop
          iobroker fix
          iobroker update
          iobroker upgrade
          iobroker upgrade self
          iobroker start
            Chrisbie last edited by Chrisbie
            @thomas-braun sagte in IoBroker bootet nicht mehr:
            iobroker fix
            erhalte ich folgende Meldung:
            pi@RspIoBroker2:/opt/iobroker $ iobroker fix
            library: loaded
            Library version=2022-02-10
            ioBroker is not installed in /opt/iobroker! Cannot fix anything...
            und bei iobroker update
            pi@RspIoBroker2:/opt/iobroker $ iobroker update
              throw err;
              requireStack: []
              @chrisbie
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
                vielen dank für die unterstüzung scheint, wieder einigermaßen zu laufen.
                  @chrisbie
                  iobroker update -u
                  zeigt?
                    Jetzt lief alles ein paar tage ohne Problem, aber seit heute habe ich ständig folgende Meldungen:
                    host.RspIoBroker2
                    		2022-03-18 20:51:32.821	error	Cannot download and install adapter "vis-materialdesign@0.3.14". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                    host.RspIoBroker2
                    		2022-03-18 20:51:32.724	info	iobroker npm-install: exit 12
                    host.RspIoBroker2
                    		2022-03-18 20:51:31.626	error	iobroker npm-install: host.RspIoBroker2 Unknown packetName vis-materialdesign. Please install packages from outside the repository using npm!
                    host.RspIoBroker2
                    		2022-03-18 20:51:28.676	info	iobroker install vis-materialdesign@0.3.14 using installedVersion
                    host.RspIoBroker2
                    		2022-03-18 20:51:28.675	warn	startInstance cannot find adapter "vis-materialdesign@0.3.14". Try to install it... 4 attempt
                    host.RspIoBroker2
                    		2022-03-18 20:51:28.579	info	iobroker npm-install: exit 12
                    host.RspIoBroker2
                    		2022-03-18 20:51:27.497	error	iobroker npm-install: host.RspIoBroker2 Unknown packetName vis-materialdesign. Please install packages from outside the repository using npm!
                    host.RspIoBroker2
                    		2022-03-18 20:51:25.253	info	stopInstance system.adapter.vis.0 (force=false, process=true)
                    host.RspIoBroker2
                    		2022-03-18 20:51:25.252	info	"system.adapter.vis.0" enabled
                    host.RspIoBroker2
                    		2022-03-18 20:51:25.196	info	stopInstance system.adapter.vis.0 (force=false, process=true)
                    host.RspIoBroker2
                    		2022-03-18 20:51:25.193	info	"system.adapter.vis.0" disabled
                    host.RspIoBroker2
                    		2022-03-18 20:51:24.414	info	iobroker install vis-materialdesign@0.3.14 using installedVersion
                    host.RspIoBroker2
                    		2022-03-18 20:51:24.414	warn	startInstance cannot find adapter "vis-materialdesign@0.3.14". Try to install it... 3 attempt
                    host.RspIoBroker2
                    		2022-03-18 20:51:24.301	info	iobroker npm-install: exit 12
                    host.RspIoBroker2
                    		2022-03-18 20:51:23.193	error	iobroker npm-install: host.RspIoBroker2 Unknown packetName vis-materialdesign. Please install packages from outside the repository using npm!
                    nach und alles wird extrem langsam.
                    nach einem Reboot, läuft es erst mal wieder. Aber was kann ich gengen die Meldung tun.
                    Aber weiter oben hat "Thomas Braun" ja empfolen die finder von einem Update zu lassen.
                      Thomas Braun Most Active @Chrisbie last edited by Thomas Braun
                      @chrisbie sagte in IoBroker bootet nicht mehr:
                      vis-materialdesign
                      vis-materialdesign
                      github:	0.5.76
                      latest:	0.5.9 for 9 months
                      stable:	-.-.-
                      Wo soll denn da eine 0.3.14 hergezaubert werden?
                      Die Ausgabe zu
                      iobroker update -u
                      bist du auch Schuldig geblieben.
                        pi@RspIoBroker2:~ $ iobroker update -u
                        Used repository: Stable (default)
                        pi@RspIoBroker2:~ $
                        sollte da noch mehr sein?
                        Thomas Braun Gargano 2 Replies Last reply Reply Quote 0
                          @chrisbie
                          iobroker update -i
                          iobroker list adapters
                          iobroker list instances
                          • Gargano
                            Gargano @Chrisbie last edited by
                            @chrisbie was ist das denn für ein raspi? Wieviel RAM, free Ram, SD Card oder ssd?
                              pi@RspIoBroker2:~ $ iobroker update -i
                              Adapter    "admin"        : 5.3.1    , installed 5.3.1
                              Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
                              Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                              Adapter    "backitup"     : 2.3.3    , installed 2.3.3
                              Adapter    "cloud"        : 4.1.0    , installed 4.1.0
                              Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                              Adapter    "daswetter"    : 3.0.9    , installed 3.0.9
                              Adapter    "devices"      : 1.0.9    , installed 1.0.9
                              Adapter    "discovery"    : 2.7.5    , installed 2.7.5
                              Adapter    "divera247"    : 0.1.2    , installed 0.1.2
                              Adapter    "dwd"          : 2.7.7    , installed 2.7.7
                              Adapter    "flot"         : 1.10.7   , installed 1.10.7
                              Adapter    "history"      : 1.10.5   , installed 1.10.5
                              Adapter    "ical"         : 1.11.4   , installed 1.11.4
                              Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
                              Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
                              Adapter    "info"         : 1.9.8    , installed 1.9.8
                              Adapter    "iot"          : 1.8.24   , installed 1.8.24
                              Adapter    "javascript"   : 5.2.21   , installed 5.2.21
                              Controller "js-controller": 4.0.21   , installed 4.0.21
                              Adapter    "luftdaten"    : 2.1.3    , installed 2.1.3
                              Adapter    "mqtt"         : 2.4.1    , installed 2.4.1
                              Adapter    "nina"         : 0.0.25   , installed 0.0.25
                              Adapter    "samsung"      : 0.2.9    , installed 0.2.9
                              Adapter    "shelly"       : 5.3.2    , installed 5.3.2
                              Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
                              Adapter    "socketio"     : 4.1.4    , installed 4.1.4
                              Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
                              Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                              Adapter    "telegram"     : 1.11.1   , installed 1.11.1
                              Adapter    "text2command" : 2.1.1    , installed 2.1.1
                              Adapter    "tr-064"       : 4.2.15   , installed 4.2.15
                              Adapter    "trashschedule": 1.4.1    , installed 1.4.1
                              Adapter    "viessmannapi" : 2.0.9    , installed 2.0.9
                              Adapter    "vis"          : 1.4.5    , installed 1.4.5
                              Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                              Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                              Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
                              Adapter    "vis-metro"    : 1.1.2    , installed 1.1.2
                              Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                              Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
                              Adapter    "web"          : 4.2.0    , installed 4.2.0
                              Adapter    "ws"           : 1.2.0    , installed 1.2.0
                              Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
                                Chrisbie @Chrisbie last edited by Chrisbie
                                pi@RspIoBroker2:~ $ iobroker list instances
                                + system.adapter.admin.0                  : admin                 : RspIoBroker2                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.alexa2.0                 : alexa2                : RspIoBroker2                             -  enabled
                                  system.adapter.alias-manager.0          : alias-manager         : RspIoBroker2                             -  enabled
                                + system.adapter.backitup.0               : backitup              : RspIoBroker2                             -  enabled
                                + system.adapter.cloud.0                  : cloud                 : RspIoBroker2                             -  enabled
                                  system.adapter.coronavirus-statistics.0 : coronavirus-statistics: RspIoBroker2                             -  enabled
                                  system.adapter.daswetter.0              : daswetter             : RspIoBroker2                             -  enabled
                                  system.adapter.devices.0                : devices               : RspIoBroker2                             -  enabled
                                + system.adapter.discovery.0              : discovery             : RspIoBroker2                             -  enabled
                                + system.adapter.divera247.0              : divera247             : RspIoBroker2                             -  enabled
                                  system.adapter.dwd.0                    : dwd                   : RspIoBroker2                             -  enabled
                                  system.adapter.flot.0                   : flot                  : RspIoBroker2                             -  enabled
                                + system.adapter.history.0                : history               : RspIoBroker2                             -  enabled
                                  system.adapter.ical.0                   : ical                  : RspIoBroker2                             -  enabled
                                  system.adapter.ical.1                   : ical                  : RspIoBroker2                             -  enabled
                                  system.adapter.ical.2                   : ical                  : RspIoBroker2                             -  enabled
                                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : RspIoBroker2                             -  enabled
                                  system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : RspIoBroker2                             -  enabled
                                + system.adapter.influxdb.0               : influxdb              : RspIoBroker2                             -  enabled, port: 8086
                                + system.adapter.info.0                   : info                  : RspIoBroker2                             -  enabled
                                + system.adapter.iot.0                    : iot                   : RspIoBroker2                             -  enabled
                                + system.adapter.javascript.0             : javascript            : RspIoBroker2                             -  enabled
                                  system.adapter.luftdaten.0              : luftdaten             : RspIoBroker2                             -  enabled
                                + system.adapter.mqtt.0                   : mqtt                  : RspIoBroker2                             -  enabled, port: 8883, bind: 0.0.0.0
                                + system.adapter.nina.0                   : nina                  : RspIoBroker2                             -  enabled
                                + system.adapter.samsung.0                : samsung               : RspIoBroker2                             -  enabled
                                + system.adapter.shelly.0                 : shelly                : RspIoBroker2                             -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.simple-api.0             : simple-api            : RspIoBroker2                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                + system.adapter.sonoff.0                 : sonoff                : RspIoBroker2                             -  enabled, port: 1883, bind: 0.0.0.0
                                  system.adapter.sourceanalytix.0         : sourceanalytix        : RspIoBroker2                             - disabled
                                + system.adapter.tankerkoenig.0           : tankerkoenig          : RspIoBroker2                             -  enabled
                                + system.adapter.telegram.0               : telegram              : RspIoBroker2                             -  enabled, port: 8443, bind: 0.0.0.0
                                  system.adapter.text2command.0           : text2command          : RspIoBroker2                             - disabled
                                + system.adapter.tr-064.0                 : tr-064                : RspIoBroker2                             -  enabled
                                + system.adapter.tr-064.1                 : tr-064                : RspIoBroker2                             -  enabled
                                + system.adapter.trashschedule.0          : trashschedule         : RspIoBroker2                             -  enabled
                                  system.adapter.viessmannapi.0           : viessmannapi          : RspIoBroker2                             - disabled
                                  system.adapter.vis-bars.0               : vis-bars              : RspIoBroker2                             -  enabled
                                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : RspIoBroker2                             -  enabled
                                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : RspIoBroker2                             -  enabled
                                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : RspIoBroker2                             -  enabled
                                  system.adapter.vis-history.0            : vis-history           : RspIoBroker2                             -  enabled
                                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : RspIoBroker2                             -  enabled
                                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : RspIoBroker2                             -  enabled
                                  system.adapter.vis-metro.0              : vis-metro             : RspIoBroker2                             -  enabled
                                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : RspIoBroker2                             -  enabled
                                  system.adapter.vis-weather.0            : vis-weather           : RspIoBroker2                             -  enabled
                                  system.adapter.vis.0                    : vis                   : RspIoBroker2                             -  enabled
                                  system.adapter.web-speedy.0             : web-speedy            : RspIoBroker2                             - disabled
                                + system.adapter.web.0                    : web                   : RspIoBroker2                             -  enabled, port: 8082, bind: 192.168.178.200, run as: admin
                                + system.adapter.zigbee.0                 : zigbee                : RspIoBroker2                             -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2216870-if00
                                + instance is alive
                                pi@RspIoBroker2:~ $ iobroker list adapters
                                system.adapter.admin                   : admin          - v5.3.1
                                system.adapter.alexa2                  : alexa2         - v3.11.2
                                system.adapter.alias-manager           : alias-manager  - v1.2.4
                                system.adapter.backitup                : backitup       - v2.3.3
                                system.adapter.cloud                   : cloud          - v4.1.0
                                system.adapter.coronavirus-statistics  : coronavirus-statistics - v0.8.7
                                system.adapter.daswetter               : daswetter      - v3.0.9
                                system.adapter.devices                 : devices        - v1.0.9
                                system.adapter.discovery               : discovery      - v2.7.5
                                system.adapter.divera247               : divera247      - v0.1.2
                                system.adapter.dwd                     : dwd            - v2.7.7
                                system.adapter.flot                    : flot           - v1.10.7
                                system.adapter.history                 : history        - v1.10.5
                                system.adapter.ical                    : ical           - v1.11.4
                                system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
                                system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                                system.adapter.influxdb                : influxdb       - v2.6.3
                                system.adapter.info                    : info           - v1.9.8
                                system.adapter.iot                     : iot            - v1.8.24
                                system.adapter.javascript              : javascript     - v5.2.21
                                system.adapter.luftdaten               : luftdaten      - v2.1.3
                                system.adapter.mqtt                    : mqtt           - v2.4.1
                                system.adapter.mqtt-client             : mqtt-client    - v1.3.1
                                system.adapter.nina                    : nina           - v0.0.25
                                system.adapter.samsung                 : samsung        - v0.2.9
                                system.adapter.shelly                  : shelly         - v5.3.2
                                system.adapter.simple-api              : simple-api     - v2.6.2
                                system.adapter.socketio                : socketio       - v3.1.4
                                system.adapter.sonoff                  : sonoff         - v2.4.7
                                system.adapter.sourceanalytix          : sourceanalytix - v0.4.8
                                system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
                                system.adapter.telegram                : telegram       - v1.11.1
                                system.adapter.text2command            : text2command   - v2.1.1
                                system.adapter.tr-064                  : tr-064         - v4.2.15
                                system.adapter.trashschedule           : trashschedule  - v1.4.1
                                system.adapter.viessmannapi            : viessmannapi   - v2.0.9
                                system.adapter.vis                     : vis            - v1.4.5
                                system.adapter.vis-bars                : vis-bars       - v0.1.4
                                system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
                                system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
                                system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                                system.adapter.vis-history             : vis-history    - v1.0.0
                                system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.9
                                system.adapter.vis-materialdesign      : vis-materialdesign - v0.3.14
                                system.adapter.vis-metro               : vis-metro      - v1.1.2
                                system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                                system.adapter.vis-weather             : vis-weather    - v2.5.5
                                system.adapter.web                     : web            - v4.2.0
                                system.adapter.web-speedy              : web-speedy     - v0.2.0
                                system.adapter.zigbee                  : zigbee         - v1.6.16
                                  vis-materialdesign
                                  iobroker del vis-materialdesign
                                    so mal kucken ob es nun besser läuft.
                                    Was ich nicht verstehe, warum lief bis jetzt gut ein Jahr ohne Probleme und auf einmal hakt es an allen enden.
                                      Ich verstehe es immer noch nicht.
                                      Seit dem ich oben erwähntes problem hatte, läuft der IoBroker immer noch nicht rund.
                                      Alle adapter sind auf aktuellstem stand.
                                      Aber jetzt kann ich über die Web-Oberfläche die Adapterseite oder Instanzen seite nicht auf machen, da bekomme ich immer ein Time out und die "Cannot read setting" aber ich habe immer noch keine Ahnung woran es hängt.
                                      Gargano 1 Reply Last reply Reply Quote 0
                                      • Gargano
                                        @chrisbie Du hast meine Frage bezüglich Raspi RAM , free Ram, . SSD oder SDCard noch nicht beantwortet
                                          Chrisbie @Gargano last edited by
                                          @gargano
                                          Sorry, hatte ich wohl überlesen:
                                          es handelt sich um ein Raspberry 4 mit 8 GB RAM, Aktuell läuft alles über SD-Karte.
                                          Speicher Auslastung liegt bei 32%
                                            crunchip Forum Testing Most Active @Chrisbie last edited by
                                            @chrisbie ich gehe nochmal auf weiter oben ein
                                            Allerdings npm Update lief absolut schief,
                                            zeig mal
                                            which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                            1357
