    4. [Anleitung] Selbstbau Wemos D1 mini und Helligkeitssensor BH1750
      smarthome2020 @OpenSourceNomad last edited by
      @opensourcenomad
      INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esp8266-lux.yaml...
      INFO Starting log output from esp8266-lux.local using esphome API
      INFO Successfully connected to esp8266-lux.local
      [21:47:09][I][app:102]: ESPHome version 2022.1.3 compiled on Mar 18 2022, 21:40:35
      [21:47:09][C][wifi:488]: WiFi:
      [21:47:09][C][wifi:350]:   Local MAC: Xxxx
      [21:47:09][C][wifi:351]:   SSID: xxxx]
      [21:47:09][C][wifi:352]:   IP Address: 192.168.xxx.xxx
      [21:47:09][C][wifi:354]:   BSSID: xxx]
      [21:47:09][C][wifi:355]:   Hostname: 'esp8266-lux'
      [21:47:09][C][wifi:357]:   Signal strength: -45 dB ▂▄▆█
      [21:47:09][C][wifi:361]:   Channel: 6
      [21:47:09][C][wifi:362]:   Subnet: 255.255.255.0
      [21:47:09][C][wifi:363]:   Gateway: 192.168.xxx.xxx
      [21:47:09][C][wifi:364]:   DNS1: 192.168.xxx.xxx
      [21:47:09][C][wifi:365]:   DNS2: 0.0.0.0
      [21:47:09][C][logger:233]: Logger:
      [21:47:09][C][logger:234]:   Level: DEBUG
      [21:47:09][C][logger:235]:   Log Baud Rate: 115200
      [21:47:09][C][logger:236]:   Hardware UART: UART0
      [21:47:09][C][i2c.arduino:037]: I2C Bus:
      [21:47:09][C][i2c.arduino:038]:   SDA Pin: GPIO4
      [21:47:09][C][i2c.arduino:039]:   SCL Pin: GPIO5
      [21:47:09][C][i2c.arduino:040]:   Frequency: 50000 Hz
      [21:47:09][C][i2c.arduino:043]:   Recovery: bus successfully recovered
      [21:47:09][I][i2c.arduino:053]: Results from i2c bus scan:
      [21:47:09][I][i2c.arduino:059]: Found i2c device at address 0x23
      [21:47:09][C][bh1750.sensor:027]: BH1750 'Lux'
      [21:47:09][C][bh1750.sensor:027]:   Device Class: 'illuminance'
      [21:47:09][C][bh1750.sensor:027]:   State Class: 'measurement'
      [21:47:09][C][bh1750.sensor:027]:   Unit of Measurement: 'lx'
      [21:47:09][C][bh1750.sensor:027]:   Accuracy Decimals: 1
      [21:47:09][C][bh1750.sensor:028]:   Address: 0x23
      [21:47:09][C][bh1750.sensor:048]:   Resolution: 0.5
      [21:47:09][C][bh1750.sensor:049]:   Update Interval: 60.0s
      [21:47:09][C][captive_portal:144]: Captive Portal:
      [21:47:09][C][ota:082]: Over-The-Air Updates:
      [21:47:09][C][ota:083]:   Address: esp8266-lux.local:8266
      [21:47:09][C][ota:086]:   Using Password.
      [21:47:09][C][api:134]: API Server:
      [21:47:09][C][api:135]:   Address: esp8266-lux.local:6053
      [21:47:09][C][api:139]:   Using noise encryption: NO
      [21:47:09][C][mdns:084]: mDNS:
      [21:47:09][C][mdns:085]:   Hostname: esp8266-lux
      Hier wäre vllt was, ist aber neu seit eben, habe ich heute Nachmittag noch nicht gesehen.
      esphome.0
      2022-03-18 21:41:30.992	error	ESPHome client 192.168.xxx.xxError: connect EISCONN 192.168.xxx.xx:6053 - Local (192.168.xxx.xx:41654)
      • OpenSourceNomad
        OpenSourceNomad Most Active @smarthome2020 last edited by OpenSourceNomad
        @smarthome2020 bräuchte ein log was ein paar Minuten läuft um zu sehen was "schief" läuft.
        Wenn er allerdings einmal (beim start) messen kann und danach nicht mehr riecht es nach einem fehlenden pull⬆⬇, in den logs sollte dann zumindest eine Zeile stehen das er nix bekommen hat oder i2c communication fehlgeschlagen hat etc.
          smarthome2020 @OpenSourceNomad last edited by smarthome2020
          @opensourcenomad
          Bei dem Sensor passiert im log über Minuten nichts , während bei einem anderen Sensor im Log neue Einträge hinzu kommen.
          Scheinbar ist der Wemos inaktiv nach dem Start?
          Nachtrag: nach ein paar Minuten kam noch :
          [22:16:50][I][ota:102]: Boot seems successful, resetting boot loop counter.
          • OpenSourceNomad
            @smarthome2020 said in [Anleitung] Selbstbau Wemos D1 mini und Helligkeitssensor BH1750:
            Schalt mal die logger component auf verbose 🔍
              @opensourcenomad
              Neben dem log von eben kommt dann ergänzend nur :
              [22:25:23][V][mdns:086]:   Services:
              [22:25:23][V][mdns:088]:   - _esphomelib, _tcp, 6053
              [22:25:23][V][mdns:090]:     TXT: version = 2022.1.3
              [22:25:23][V][mdns:090]:     TXT: mac = bcff4d191c18
              [22:25:23][V][mdns:090]:     TXT: platform = ESP8266
              [22:25:23][V][mdns:090]:     TXT: board = d1_mini
              [22:26:12][D][api:098]: Accepted 192.168.xxx.xx
              [22:26:12][V][api.connection:763]: Hello from client: 'raspberrypi (192.168.xxx.xx)'
              [22:26:12][D][api.connection:779]: raspberrypi (192.168.xxx.xx): Connected successfully
              Im Hauptlog des ioBroker kommt aber immer wieder:
              ESPHome client 192.168.xxx.xx Error: connect EISCONN 192.168.xxx.xx:6053 - Local (192.168.xxx.xx:48714)
              • OpenSourceNomad
                und minütlich kommt nix bezüglich der bh1750 component? Zur not noch very_verbose versuchen.
                  @opensourcenomad
                  [22:43:28][VV][scheduler:185]: Running interval '' with interval=60000 last_execution=6490 (now=66490)
                  [22:43:33][D][api:098]: Accepted 192.168.xxx.x
                  [22:43:33][VV][api.service:337]: on_ping_request: PingRequest {}
                  [22:43:33][VV][api.service:043]: send_ping_response: PingResponse {}
                  [22:43:33][VV][api.service:301]: on_hello_request: HelloRequest {
                    client_info: 'raspberrypi'
                  [22:43:33][V][api.connection:763]: Hello from client: 'raspberrypi (192.168.xxx.x)'
                  [22:43:33][VV][api.service:013]: send_hello_response: HelloResponse {
                    api_version_major: 1
                    api_version_minor: 6
                    server_info: 'esp8266-lux (esphome v2022.1.3)'
                  [22:43:33][VV][api.service:310]: on_connect_request: ConnectRequest {
                    password: 'xxx'
                  [22:43:33][D][api.connection:779]: raspberrypi (192.168.xxx.x): Connected successfully
                  [22:43:33][VV][api.service:019]: send_connect_response: ConnectResponse {
                    invalid_password: NO
                  [22:43:33][VV][api.service:355]: on_device_info_request: DeviceInfoRequest {}
                  [22:43:33][VV][api.service:049]: send_device_info_response: DeviceInfoResponse {
                    uses_password: YES
                    mac_address: 'Xxx'
                    esphome_version: '2022.1.3'
                    compilation_time: 'Mar 18 2022, 22:41:21'
                    model: 'd1_mini'
                    has_deep_sleep: NO
                    project_name: ''
                    project_version: ''
                    webserver_port: 0
                  [22:43:33][VV][api.service:364]: on_list_entities_request: ListEntitiesRequest {}
                  [22:43:33][VV][api.service:132]: send_list_entities_sensor_response: ListEntitiesSensorResponse {
                    object_id: 'lux'
                    key: 914478924
                    unique_id: 'esp8266-luxsensorlux'
                    icon: ''
                    unit_of_measurement: 'lx'
                    accuracy_decimals: 1
                    force_update: NO
                    device_class: 'illuminance'
                    state_class: STATE_CLASS_MEASUREMENT
                    legacy_last_reset_type: LAST_RESET_NONE
                    disabled_by_default: NO
                    entity_category: ENTITY_CATEGORY_NONE
                  [22:43:33][VV][api.service:373]: on_subscribe_states_request: SubscribeStatesRequest {}
                  [22:43:33][VV][api.service:055]: send_list_entities_done_response: ListEntitiesDoneResponse {}
                  [22:43:33][VV][api.service:140]: send_sensor_state_response: SensorStateResponse {
                    key: 914478924
                    state: 12.9167
                    missing_state: NO
                  [22:43:36][VV][api.service:337]: on_ping_request: PingRequest {}
                  [22:43:36][VV][api.service:043]: send_ping_response: PingResponse {}
                  [22:43:48][VV][api.service:337]: on_ping_request: PingRequest {}
                  [22:43:48][VV][api.service:043]: send_ping_response: PingResponse {}
                  Und :
                  d1_mini
                  [22:50:04][VV][api.service:337]: on_ping_request: PingRequest {}
                  [22:50:04][VV][api.service:043]: send_ping_response: PingResponse {}
                  [22:50:09][VV][scheduler:185]: Running interval 'update' with interval=60000 last_execution=407236 (now=467236)
                  [22:50:09][VV][i2c.arduino:124]: 0x23 TX 21
                  [22:50:09][VV][i2c.arduino:148]: TX failed: not acknowledged
                  [22:50:13][VV][api.service:337]: on_ping_request: PingRequest {}
                  [22:50:13][VV][api.service:043]: send_ping_response: PingResponse {}
                  [22:50:19][VV][api.service:337]: on_ping_request: PingRequest {}
                  [22:50:19][VV][api.service:043]: send_ping_response: PingResponse {}
                  [22:50:28][VV][scheduler:185]: Running interval '' with interval=60000 last_execution=426490 (now=486492)
                  [22:50:29][VV][api.service:337]: on_ping_request: PingRequest {}
                  [22:50:29][VV][api.service:043]: send_ping_response: PingResponse {}
                  [22:50:34][VV][api.service:337]: on_ping_request: PingRequest {}
                  [22:50:34][VV][api.service:043]: send_ping_response: PingResponse {}
                  [22:50:44][VV][api.service:337]: on_ping_request: PingRequest {}
                  [22:50:44][VV][api.service:043]: send_ping_response: PingResponse {}
                  [22:50:49][VV][api.service:337]: on_ping_request: PingRequest {}
                  [22:50:49][VV][api.service:043]: send_ping_response: PingResponse {}
                    @opensourcenomad sagte in [Anleitung] Selbstbau Wemos D1 mini und Helligkeitssensor BH1750:
                    Die neuste esphome version (2022.03) hat übrigens eine interessante Änderung bezüglich des bh1750:
                    Wie sehe ich, welche Version aufgespielt ist? Habe eben alle esphome Geräte aktualisiert… finde nur nirgends was von 2022.03..
                    • OpenSourceNomad
                      Wie vermutet hackt es an der Kommunikation. Eventuell mal pull up am gpio aktivieren?
                      Z.b. im Dashboard footer
                        Dieter_P @smarthome2020 last edited by
                        @smarthome2020
                        Bei mir hat sich der BH1750 nach einigen Messungen/Ergebnissen immer wieder verabschiedet (Der I2C Teilnehmer wurde nicht mehr gefunden). Die Lösung war eine Pufferung der 5V Versorgungsspannung direkt am BH1750 mit einem kleinen Elko (100uF).
                          klassisch Most Active last edited by klassisch
                          Erfahrungsbericht:
                          Betreibe 2 BH1750 Sensoren seit Jahren. Einer sitzt unter einem Dachfenster und schaut unter 25° Dachneigung nach Norden. Der andere scheut durch ein Giebelfenster (also 90° Neigung) nach Osten.
                          SW ist noch alt und selbstgefrickelt. Müßte man heute so nicht mehr machen, aber läuft stabil.
                          Ale meine ESPs D1 Mini bekommen vom Start weg jeweils einen 1000µF Kondensators an den 3.3V und 5V. Nicht optimiert, wahrscheinlich überdimensioniert, aber eben stabil.
                          Nett sind dann die Jahresansichten. Ansonsten habe ich wenige praktische Anwendungen.
                          Für meine Lichtsteuerung in den Zimmern nutze ich aqara Zigbee Helligkeitssensoren an das Fenster geklebt.
                          Hier noch eine Mehrjahresansicht, seit Aufzeichnung mit ioBroker. Die CCU.io Daten konnte ich leider nicht konvertieren.
                            smarthome2020 @Dieter_P last edited by
                            @dieter_p
                            Ich hab den Sensor an den 3,3V angeklemmt. Meinst du, dass das zu wenig ist und die Ursache sein könnte?
                            Ansonsten muss ich einen Kondensator besorgen. Bisher lief alles ohne Kondensatoren/Widerständen stabil.
                            OpenSourceNomad D 2 Replies Last reply Reply Quote 0
                            • OpenSourceNomad
                              Immer 5V wenn der Sensor (breakoutboard) das kann.
                                @opensourcenomad
                                Auf 5V angekoppelt ist der Sensor gar nicht erreichbar.
                                Geht nur auf 3,3V.
                                Ich muss nachher mal einen anderen BH1750 nutzen bzw. ein anderes Board. Nicht, dass Hardware daran schuld ist.
                                  smarthome2020 @smarthome2020 last edited by smarthome2020
                                  @smarthome2020 sagte in [Anleitung] Selbstbau Wemos D1 mini und Helligkeitssensor BH1750:
                                  @opensourcenomad
                                  Geht nur auf 3,3V.
                                  --> es scheint an der Hardware zu liegen. Hab an einem anderen ESP mal einen BH1750 angeschlossen und da geht es einwandfrei.
                                    Dieter_P @smarthome2020 last edited by Dieter_P
                                    @dieter_p
                                    Es gibt verschiedene Versionen. Ich nutze diese:
                                    Die ist mit 5V Versorgungsspannung spezifiziert und auf 3,3V lief er gar nicht bei mir. Der I2C Bus ist zugegeben recht lang bei mir, wofür er im Ursprung nie gedacht war. Aber lokal die 5V gepuffert lässt ihn problemlos betreiben.
                                    Da Du von 3,3V und D1 Mini sprichst, klingt dass eher nach einem Problem durch diese D1 Mini Kopien mit sehr billigem/schwachen Spannungsregler 5V -> 3,3V. Hierdurch gibt es oft Probleme, da der Spannungsregler gerade für den Betrieb des D1 Mini reicht, aber nicht noch zur Versorgung weiterer Sensoren. Evtl. hilft ein Pufferkondensator aber ein besserer D1 Mini ist auch eine sehr gute Sache.
                                    123
                                    34766
