    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      bob der 1. @Thomas Braun last edited by bob der 1.
      Habe genau das gleiche Problem mit den Adapter Versionen 0.0.10&0.0.12, Node Version v14.19.1
      bei
      cd /opt/iobroker/node_modules
      npm list canvas
      bekomme ich als Ausgabe
      iobroker.inst@3.0.0 /opt/iobroker
      ├── canvas@2.9.0
      ├─┬ iobroker.echarts@1.0.3
      │ └── canvas@2.8.0
      ├─┬ iobroker.iot@1.8.24
      │ └── canvas@2.9.0  deduped
      ├─┬ iobroker.mihome-vacuum@3.3.5 (github:iobroker-community-adapters/ioBroker.mi                                     home-vacuum#_____________)
      │ └── canvas@2.9.0
      └─┬ iobroker.parcel@0.0.10
      anschließend
      cd /opt/iobroker
      npm install canvas
      Ausgabe
      [.......[..................] / loadDep:simple-get: sill removeObsoleteDep removing nan@2.15.0 from the tree as its be
      > canvas@2.9.0 install /opt/iobroker/node_modules/canvas
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.0/canvas-v2.9.0-node-v83-linux-glibc-arm.tar.gz
      node-pre-gyp WARN Pre-built binaries not installable for canvas@2.9.0 and node@14.19.1 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
      node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.0/canvas-v2.9.0-node-v83-linux-glibc-arm.tar.gz
      make: Entering directory '/opt/iobroker/node_modules/canvas/build'
        SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
        COPY Release/canvas-postbuild.node
        CXX(target) Release/obj.target/canvas/src/backend/Backend.o
        CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
        CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
      ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
      ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
         E(ptr - data > imgdOffset, "image data overlaps with another structure");
      ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
       #define E(cond, msg) if(cond) return setErr(msg)
      ../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
         E(ptr - data + imgdSize > len, "not enough image data");
        CXX(target) Release/obj.target/canvas/src/Backends.o
        CXX(target) Release/obj.target/canvas/src/Canvas.o
        CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
        CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
        CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
        CXX(target) Release/obj.target/canvas/src/closure.o
        CXX(target) Release/obj.target/canvas/src/color.o
        CXX(target) Release/obj.target/canvas/src/Image.o
        CXX(target) Release/obj.target/canvas/src/ImageData.o
        CXX(target) Release/obj.target/canvas/src/init.o
        CXX(target) Release/obj.target/canvas/src/register_font.o
        SOLINK_MODULE(target) Release/obj.target/canvas.node
        COPY Release/canvas.node
      make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
      npm WARN http-cookie-agent@1.0.5 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
      + canvas@2.9.0
      updated 1 package in 95.966s
      70 packages are looking for funding
        run `npm fund` for details
      Adapter gelöscht,beide Versionen versucht ...nichts!
        skokarl last edited by
        wofür, oder wann wird bei Amazon der Token benötigt ?
        Was ist wenn man bei Amazon 2 Konten hat..... z.B. für Ehefrau?
        sorry, aber 617 Beiträge durchsichen ist echt übel .....
        G DJMarc75 2 Replies Last reply Reply Quote 0
          guergen @skokarl last edited by
          @skokarl Mal vorsichtig gesagt, zwei Instanzen anlegen....
          • DJMarc75
            DJMarc75 @skokarl last edited by
            @skokarl said in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
            eine Instanz des Adapters kann nur ein Konto, egal welcher Dienstleister, abarbeiten, also wie @guergen geschrieben hat dann dementsprechend viele Instanzen installieren.
              michaelxhoffmann last edited by michaelxhoffmann
              Hi, habe den Adapter heute installiert. Hätte da eine Frage zur DHL Benachrichtigung. Wie bekomme ich die SMS bzw. Mail? Wann erhalte ich die? Email und Passwort habe ich korrekt eingegeben, aber die PIN fehlt mir irgendwie. Die Instanz bleibt auch konsequent rot.Ich habe die DHL App auf meinem Iphone installiert, Dort funktioniert sie auch.
              Danke für Eure Hilfe
              Thomas Braun DJMarc75 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @michaelxhoffmann last edited by
                @michaelxhoffmann sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                Die kommt beim Versuch sich einzuloggen automatisch. Sollte Sie zumindest.
                • DJMarc75
                  DJMarc75 @michaelxhoffmann last edited by
                  @michaelxhoffmann said in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                  warte mal ne halbe Stunde und dann nochmal die Daten eingeben.
                  • Jabba_the_Hutt
                    Jabba_the_Hutt last edited by Jabba_the_Hutt
                    npm: 8.5.0
                    node.js: 16.14.2
                    Der Adapter lässt sich nicht installieren.
                    Fehler:
                    	Caught by controller[0]: was compiled against a different Node.js version using
                    Der rebuild verläuft dann auch in einem Error.
                    Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                    sigi234 T 2 Replies Last reply Reply Quote 0
                      sigi234 Forum Testing Most Active @Jabba_the_Hutt last edited by sigi234
                      @jabba_the_hutt
                      Steh ja eh da, FALSCHE Version von Node:
                      Empfohlene sind:
                      NODE.JS: V14.19.1
                      NPM: 6.14.16
                      https://forum.iobroker.net/topic/42952/der-kleine-iobroker-linux-werkzeugkasten
                      Jabba_the_Hutt 1 Reply Last reply Reply Quote 0
                        tombox @Jabba_the_Hutt last edited by
                        @jabba_the_hutt
                        Also node 16 ist kein problem aber npm 8 ist nocht nicht komplett getestet
                        cd /opt/iobroker
                        npm rebuild
                        npm install canvas
                        probiert?
                        • DJMarc75
                          DJMarc75 last edited by DJMarc75
                          @tombox
                          Frage:
                          Kann man in der Konfig die einzelnen Dienstleister mit eine Checkbox zum de- oder aktivieren versehen ?
                          So muss man nicht jedesmal, wenn man einen Dienst an- oder ausschalten möchte die Zugangsdaten löschen oder neu eingeben.
                          • Rene R
                            Rene R last edited by
                            Hallo Liebe CSSler,
                            Ich bräuchte eure Hilfe....
                            Ich habe vor in dem CSS ( HTML ) beim Header wo Amazon Bestell Status steht davor und daneben ein kleines Amazon Logo hinzufügen.
                            und wäre es möglich die Gelieferten Bestellungen zu verstecken?
                            Ich habe es versucht über den VIS OWL das hinzubekommen aber klappt irgendwie nicht weil ich nur geringen platz haben höhe und breite 200px
                            hier den CSS CODE:
                            <style type="text/css">
                            #{wid} .tg {
                             border-collapse:collapse;border-color:#9ABAD9;border-spacing:0;
                            #{wid} .tg td{
                             background-color:;border-color:#9ABAD9;border-style:solid;border-width:0px;color:white;
                             font-family:Comic Sans MS, sans-serif;font-size:10pxpx;overflow:hidden;padding:10px 5px;word-break:normal;
                            #{wid} .tg th{
                             background-color:#409cff;border-color:#9ABAD9;border-style:solid;border-width:0px;color:#fff;
                             font-family:Comic Sans MS, sans-serif;font-size:10px;font-weight:normal;overflow:hidden;padding:10px 5px;word-break:normal;
                            #{wid} .tg .tg-vn85{
                             border-color:ffcc67;text-align:left;vertical-align:top
                            #{wid} .tg-sort-header::-moz-selection{
                             background:0 0}
                            #{wid} .tg-sort-header::selection{
                             background:0 0}.tg-sort-header{
                             cursor:pointer
                            #{wid} .tg-sort-header:after{
                             content:'';float:right;margin-top:7px;border-width:0 5px 5px;border-style:solid;
                             border-color:#404040 transparent;visibility:hidden
                            #{wid} .tg-sort-header:hover:after{
                             visibility:visible}
                            #{wid} .tg-sort-asc:after,.tg-sort-asc:hover:after,.tg-sort-desc:after{
                             visibility:visible;opacity:.4
                            #{wid} .tg-sort-desc:after{
                            border-bottom:none;border-width:5px 5px 0
                            }</style>
                            <table id="tg-noEOi" class="tg">
                            <thead>
                             <tr>
                            <th class="tg-vn85">Amazon Bestell Status</th>
                             </tr>
                            </thead>
                            <tbody>
                             <tr>
                             <td class="tg-vn85">{parcel.0.amazon.sendungen01.status}</td>
                             </tr>
                             <tr>
                             <td class="tg-vn85">{parcel.0.amazon.sendungen02.status}</td>
                             </tr>
                             <tr>
                             <td class="tg-vn85">{parcel.0.amazon.sendungen03.status}</td>
                             </tr>
                             <tr>
                             <td class="tg-vn85">{parcel.0.amazon.sendungen04.status}</td>
                             </tr>
                            </tbody>
                            </table>
                            Wäre super wenn einer von euch mir helfen könnte.
                            Liebe Grüße
                            Rene
                            P.S der Adapter ist super
                            • Jabba_the_Hutt
                              Jabba_the_Hutt @sigi234 last edited by
                              @sigi234
                              Ist mir schon klar, dass für NICHT Betatester andere Versionen vorgesehen sind.
                                Buchi @Rene R last edited by
                                @rene-r sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                Hallo Liebe CSSler,
                                Warum sollte das mit owl nicht gehen? Alles einstellbar 🙂
                                Rene R 1 Reply Last reply Reply Quote 0
                                • Jabba_the_Hutt
                                  Jabba_the_Hutt @tombox last edited by
                                  @tombox
                                  Ja, habe ich versucht. Hilft leider auch nichts.
                                  • Rene R
                                    Rene R @Buchi last edited by
                                    @buchi
                                    Ja schon aber das einstellen und VIS ist neuland für mich und css erst recht bräuchte da echt hilfe beim coden.
                                    B 1 Reply Last reply Reply Quote -1
                                      @buchi
                                      Dann solltest einfach mal im Thread fragen. Bisher wurde noch jedem geholfen 😉
                                      Rene R Chaot 2 Replies Last reply Reply Quote 0
                                      • Rene R
                                        @buchi
                                        okay habe ich
                                        danke euch
                                        • Stephan Schleich
                                          Stephan Schleich @tombox last edited by
                                          @tombox bei 17track ist es so wenn man die Verfolgungen löscht oder archiviert kann man mehr wie die 40 Stück machen, kann man die funktion noch zur verfügung stellen?
                                          • Chaot
                                            Chaot @Buchi last edited by
                                            @buchi
                                            Ist ja lustig.
                                            Wenn ich eine Paketnummer in der DHL App tracke dann wird mir die auch im Adapter angezeigt. Also auch manuelle Pakete (Lieferung an Firma oder so) werden mit übernommen.
                                            17track amazon briefe dhl dpd gls ups
                                            122
                                            1534
                                            525948
