    4. [ESPHome] Beta release
      maxpd @a200 last edited by maxpd
      @a200 lieferst du @Dutchman noch das Log? Danke dir.
        maxpd last edited by
        @Dutchman
        Ich hab meinen Servo, der bisher nur die Level Variable hat eingebunden.
        Das ist das esp script:
        esphome:
          platform: ESP8266
          board: d1_mini
        wifi:
          ssid: !secret wifi_ssid
          password: !secret wifi_password
          # Enable fallback hotspot (captive portal) in case wifi connection fails
          ap:
            ssid: "Little Wemos Fallback Hotspot"
            password: "************"
        captive_portal:
        # Enable logging
        logger:
        api:
          services:
            - service: control_servo
              variables:
                level: float
              then:
                - servo.write:
                    level: !lambda 'return level / 1000.0;'
        ota:
        output:
          - platform: esp8266_pwm
            pin: D3
            frequency: 50 Hz
        servo:
          - id: my_servo
            output: pwm_output
        Das ist das Debug Log hierzu.
        esphome.0
        2022-03-17 15:42:40.693	debug	Create_state called for : C45BBEDDA7E1.info._online with value : true
        esphome.0
        2022-03-17 15:42:40.661	debug	MODIFY to hasDeepSleep: ""
        esphome.0
        2022-03-17 15:42:40.660	debug	Create_state called for : C45BBEDDA7E1.info.hasDeepSleep with value : false
        esphome.0
        2022-03-17 15:42:40.660	debug	create id C45BBEDDA7E1.info.hasDeepSleep with value false and name hasDeepSleep
        esphome.0
        2022-03-17 15:42:40.598	debug	MODIFY to model: ""
        esphome.0
        2022-03-17 15:42:40.597	debug	Create_state called for : C45BBEDDA7E1.info.model with value : d1_mini
        esphome.0
        2022-03-17 15:42:40.597	debug	create id C45BBEDDA7E1.info.model with value d1_mini and name model
        esphome.0
        2022-03-17 15:42:40.573	debug	MODIFY to compilationTime: ""
        esphome.0
        2022-03-17 15:42:40.572	debug	Create_state called for : C45BBEDDA7E1.info.compilationTime with value : Mar 17 2022, 15:38:01
        esphome.0
        2022-03-17 15:42:40.572	debug	create id C45BBEDDA7E1.info.compilationTime with value Mar 17 2022, 15:38:01 and name compilationTime
        esphome.0
        2022-03-17 15:42:40.551	debug	MODIFY to esphomeVersion: ""
        esphome.0
        2022-03-17 15:42:40.551	debug	Create_state called for : C45BBEDDA7E1.info.esphomeVersion with value : 2022.3.0
        esphome.0
        2022-03-17 15:42:40.550	debug	create id C45BBEDDA7E1.info.esphomeVersion with value 2022.3.0 and name esphomeVersion
        esphome.0
        2022-03-17 15:42:40.475	info	ESPHome client little_wemos on ip 192.168.178.53 initialized
        esphome.0
        2022-03-17 15:42:40.474	debug	192.168.178.53 client log ListEntitiesDoneResponse
        esphome.0
        2022-03-17 15:42:40.472	debug	192.168.178.53 client data
        esphome.0
        2022-03-17 15:42:40.460	debug	MODIFY to macAddress: ""
        esphome.0
        2022-03-17 15:42:40.459	debug	Create_state called for : C45BBEDDA7E1.info.macAddress with value : C4:5B:BE:DD:A7:E1
        esphome.0
        2022-03-17 15:42:40.459	debug	create id C45BBEDDA7E1.info.macAddress with value C4:5B:BE:DD:A7:E1 and name macAddress
        esphome.0
        2022-03-17 15:42:40.436	debug	MODIFY to name: ""
        esphome.0
        2022-03-17 15:42:40.435	debug	Create_state called for : C45BBEDDA7E1.info.name with value : little_wemos
        esphome.0
        2022-03-17 15:42:40.434	debug	create id C45BBEDDA7E1.info.name with value little_wemos and name name
        esphome.0
        2022-03-17 15:42:40.430	debug	192.168.178.53 client log ListEntitiesServicesResponse
        esphome.0
        2022-03-17 15:42:40.426	debug	192.168.178.53 client data ) control_servo>�S� level
        esphome.0
        2022-03-17 15:42:40.406	debug	MODIFY to usesPassword: ""
        esphome.0
        2022-03-17 15:42:40.405	debug	Create_state called for : C45BBEDDA7E1.info.usesPassword with value : false
        esphome.0
        2022-03-17 15:42:40.404	debug	create id C45BBEDDA7E1.info.usesPassword with value false and name usesPassword
        esphome.0
        2022-03-17 15:42:40.384	debug	192.168.178.53 client log DeviceInfoResponse
        esphome.0
        2022-03-17 15:42:40.380	debug	DeviceInfo little_wemos: {"192.168.178.53":{"ip":"192.168.178.53","mac":"C4:5B:BE:DD:A7:E1","deviceInfo":{"usesPassword":false,"name":"little_wemos","macAddress":"C4:5B:BE:DD:A7:E1","esphomeVersion":"2022.3.0","compilationTime":"Mar 17 2022, 15:38:01","model":"d1_mini","hasDeepSleep":false},"deviceName":"C45BBEDDA7E1","deviceInfoName":"little_wemos","passWord":""}}
        esphome.0
        2022-03-17 15:42:40.378	debug	DeviceData: {"usesPassword":false,"name":"little_wemos","macAddress":"C4:5B:BE:DD:A7:E1","esphomeVersion":"2022.3.0","compilationTime":"Mar 17 2022, 15:38:01","model":"d1_mini","hasDeepSleep":false}
        esphome.0
        2022-03-17 15:42:40.378	info	ESPHome Device info received for little_wemos
        esphome.0
        2022-03-17 15:42:40.375	debug	192.168.178.53 client data Klittle_wemosC4:5B:BE:DD:A7:E1"2022.3.0*Mar 17 2022, 15:38:012d1_mini
        esphome.0
        2022-03-17 15:42:40.359	info	ESPHome client 192.168.178.53 connected
        esphome.0
        2022-03-17 15:42:40.358	debug	192.168.178.53 client log ConnectResponse
        esphome.0
        2022-03-17 15:42:40.356	debug	192.168.178.53 client data
        esphome.0
        2022-03-17 15:42:40.341	debug	192.168.178.53 client log HelloResponse
        esphome.0
        2022-03-17 15:42:40.337	debug	192.168.178.53 client data 4 little_wemos (esphome v2022.3.0)"little_wemos
        esphome.0
        2022-03-17 15:42:40.323	debug	192.168.178.53 client log PingResponse
        esphome.0
        2022-03-17 15:42:40.320	debug	192.168.178.53 client data
        esphome.0
        2022-03-17 15:42:40.286	debug	espHomeDashboard_Process {"_events":{},"_eventsCount":0,"_maxListeners":100,"_closesNeeded":3,"_closesGot":0,"connected":false,"signalCode":null,"exitCode":null,"killed":false,"spawnfile":"npm","_handle":{"pid":16308},"spawnargs":["npm","run","-s","nopy","/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome","dashboard","/opt/iobroker/iobroker-data/esphome.0"],"pid":16308,"stdin":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":false,"sync":true,"needReadable":false,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null,"readable":false},"_events":{},"_eventsCount":1,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},"stdout":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},"stderr":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},"stdio":[{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":false,"sync":true,"needReadable":false,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null,"readable":false},"_events":{},"_eventsCount":1,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null},{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":null,"ended":false,"endEmitted":false,"reading":true,"sync":false,"needReadable":true,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":false,"decoder":null,"encoding":null},"_events":{},"_eventsCount":2,"_maxListeners":100,"_writableState":{"objectMode":false,"highWaterMark":16384,"finalCalled":false,"needDrain":false,"ending":false,"ended":false,"finished":false,"destroyed":false,"decodeStrings":false,"defaultEncoding":"utf8","length":0,"writing":false,"corked":0,"sync":true,"bufferProcessing":false,"writecb":null,"writelen":0,"afterWriteTickInfo":null,"buffered":[],"bufferedIndex":0,"allBuffers":true,"allNoop":true,"pendingcb":0,"prefinished":false,"errorEmitted":false,"emitClose":false,"autoDestroy":false,"errored":null,"closed":false,"writable":false,"closeEmitted":false},"allowHalfOpen":false,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null}]}
        esphome.0
        2022-03-17 15:42:40.272	info	Native Integration of ESPHome Dashboard enabled
        esphome.0
        2022-03-17 15:42:40.268	info	Auto Discovery startet, new devices (or IP changes) will be detected automatically
          maxpd @OpenSourceNomad last edited by
          @opensourcenomad hast du das schon umgesetzt? Das letzte Update des Adapters liegt noch vor 12.2021.
          Home Assistant Core 2021.12 or higher is required for ESPHome button entities to work.
          Und kommt das Template nicht in die configuration.yaml oder template.yaml im Home Assistant? Aber die gibt es im iobroker esphome Adapter nicht. Habe die Ordnerstruktur durchwühlt.
          • OpenSourceNomad
            OpenSourceNomad Most Active @maxpd last edited by OpenSourceNomad
            @maxpd said in [ESPHome] Beta release:
            Du kannst lokal die aktuellste Version (2022.03) mittels pip oder docker installieren.
            Allerdings wird dir das in diesem Fall wohl nicht weiterhelfen weil esphome für die buttons vom iobroker eine neuere Version verlangt.
            Nein.
              steimi last edited by
              einfach unter "Adapter -> eine bestimmte Version" die aktuelle Version 0.2.4 nochmal installieren. Dabei zieht er sich die aktuelle ESPhome-Version 2022.03
                maxpd @steimi last edited by
                @steimi Ja, lokal habe ich die 2022.03 im ESP.
                Hatte nur die Änderungsdaten der Files im ESPHome Adapter geprüft und die waren alle älter.
                also genau das was @OpenSourceNomad bestätigt hat.
                  bernd33-1 @a200 last edited by
                  @a200 said in [ESPHome] Beta release:
                  @johannes-bauerstatter Ein ESPHome Update innerhalb des USPHome-Adapters ist so einfach, dass es schon peinlich ist.
                  1. IoBroker unter Adapter "Expertenmodus" aktivieren.
                  2. Auf die Katze (installieren aus eigener URL) klicken.
                  3. Im Tab "VON NPM" den ESphome-Adapter auswählen.
                  Der Adapter wird reinstalliert, wobei die neuste Version von ESPHome gezogen und installiert wird. Alle Yamls und die Datenpunkte bleiben erhalten.
                  bei mir wird der ESP-Home Adapter nicht aufgelistet. Muss man noch was beachten?
                  Danke und Grüße, Bernd
                  aktuell habe ich die ESPHome version 2021.8.2 compiled on Mar 14 2022, 09:07:40
                  a200 1 Reply Last reply Reply Quote 0
                  • a200
                    a200 @bernd33-1 last edited by
                    @bernd33-1 Hast du dein Repository auf BETA umgestellt?
                      @a200 🤦‍♂️ Oh man, ja klar. Ich verwende ESPHome schon so selbstverständlich das ich garnicht mehr an Beta denke.
                      Ja klar, im Beta ist der Adapter da. Danke und schönen Sonntag noch, Bernd
                      • a200
                        @bernd33-1 sagte in [ESPHome] Beta release:
                        Freut mich zu hören. Über einen + würde ich mich freuen. LG
                          Beowolf @a200 last edited by Beowolf
                          Ich bekomme den Adapter nicht installiert.
                          Hier die Meldungen:
                          $ iobroker add esphome --host ioBroker-Master
                          NPM version: 6.14.16
                          Installing iobroker.esphome@0.2.4... (System call)
                          > iobroker.esphome@0.2.4 install /opt/iobroker/node_modules/iobroker.esphome> npip install
                          No python_modules directory; installing pip locally if needed.
                          Successfully completed pip check.
                          Collecting esphome>=2021.8
                          Using cached esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
                          Collecting tornado>=3.2
                          Using cached tornado-6.1.tar.gz (497 kB)
                          Preparing metadata (setup.py): started
                          Preparing metadata (setup.py): finished with status 'done'
                          Collecting tzdata>=2021.1
                          Using cached tzdata-2022.1-py2.py3-none-any.whl (339 kB)
                          Collecting esphome-dashboard==20220209.0
                          Using cached esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
                          Collecting click==8.0.3
                          Using cached click-8.0.3-py3-none-any.whl (97 kB)
                          Collecting PyYAML==6.0
                          Using cached PyYAML-6.0.tar.gz (124 kB)
                          Installing build dependencies: started
                          Installing build dependencies: finished with status 'done'
                          Getting requirements to build wheel: started
                          Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started
                          Preparing metadata (pyproject.toml): finished with status 'done'
                          Collecting aioesphomeapi==10.8.2
                          Using cached aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
                          Collecting zeroconf==0.38.3
                          Using cached zeroconf-0.38.3-py3-none-any.whl (106 kB)
                          Collecting kconfiglib==13.7.1
                          Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                          Collecting esptool==3.2
                          Using cached esptool-3.2.tar.gz (206 kB)
                          Collecting colorama==0.4.4
                          Using cached colorama-0.4.4-py2.py3-none-any.whl (16 kB)
                          Collecting pyserial==3.5 Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
                          Collecting tzlocal==4.1
                          Using cached tzlocal-4.1-py3-none-any.whl (19 kB)
                          Collecting platformio==5.2.5
                          Using cached platformio-5.2.5.tar.gz (218 kB)
                          Collecting voluptuous==0.12.2
                          Using cached voluptuous-0.12.2.tar.gz (48 kB)
                          Collecting paho-mqtt==1.6.1
                          Using cached paho-mqtt-1.6.1.tar.gz (99 kB)
                          Collecting protobuf<4.0,>=3.12.2
                          Using cached protobuf-3.19.4-py2.py3-none-any.whl (162 kB)
                          Collecting noiseprotocol<1.0,>=0.3.1
                          Using cached noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                          Collecting importlib-metadata
                          Using cached importlib_metadata-4.11.3-py3-none-any.whl (18 kB)
                          Collecting bitstring>=3.1.6
                          Using cached bitstring-3.1.9-py3-none-any.whl (38 kB)
                          Collecting cryptography>=2.1.4
                          Using cached cryptography-36.0.2.tar.gz (572 kB)
                          Installing build dependencies: finished with status 'error'
                          host.ioBroker-Master Cannot install iobroker.esphome@0.2.4: 1
                          ERROR: Process exited with code 25
                          Wo habe ich da einen Fehler?
                            @beowolf welche python version ist drauf?
                              Beowolf @maxpd last edited by Beowolf
                              @maxpd
                              pi@ioBroker-Master:~ $ python --version
                              Python 2.7.16
                              pi@ioBroker-Master:~ $ python3 --version
                              Python 3.7.3
                              M Dutchman OpenSourceNomad Thomas Braun 4 Replies Last reply Reply Quote 0
                                maxpd @Beowolf last edited by
                                @beowolf
                                Ich würde dir ein Update empfehlen:
                                https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                Danach gehts.
                                • Dutchman
                                  Dutchman Developer Most Active Administrators @Beowolf last edited by
                                  @beowolf sagte in [ESPHome] Beta release:
                                  @maxpd
                                  Python 2.7.16
                                  Python 3.7.3
                                  python muss nach 3.7 verweisen , da dies für jedes System anders ist kan ich die Python Installation selber leider nicht Supporten
                                  • OpenSourceNomad
                                    OpenSourceNomad Most Active @Beowolf last edited by
                                    @beowolf said in [ESPHome] Beta release:
                                    Python 2.7.16
                                    Python 2 ist übrigens schon seit über 2 Jahren EOL. Wahrscheinlich gibt es so ziemliche keine (aktuelle) Software die nicht mit Python 3 kompatibel ist 💡
                                      Thomas Braun Most Active @Beowolf last edited by Thomas Braun
                                      @beowolf
                                      Debian? Bullseye?
                                      Dann würde ich empfehlen:
                                      sudo apt update
                                      sudo apt install python-is-python3
                                      sudo apt autoremove
                                        Beowolf @Thomas Braun last edited by Beowolf
                                        Hm.
                                        Ich habe jetzt alles neu aufgesetzt. Backup eingespielt usw.
                                        Es kommt immer noch diese Meldungen:
                                        pi@raspberrypi:~ $ cd /opt/iobroker
                                        pi@raspberrypi:/opt/iobroker $ npm i iobroker.esphome@latest
                                        > npip install
                                          Cache entry deserialization failed, entry ignored
                                          Using cached esphome-2022.3.0-py2.py3-none-any.whl (2.2 MB)
                                          Preparing metadata (setup.py) ... done
                                          Installing build dependencies ... done
                                          Getting requirements to build wheel ... done
                                          Preparing metadata (pyproject.toml) ... done
                                        Collecting esphome-dashboard==20220309.0
                                          Using cached esphome_dashboard-20220309.0-py3-none-any.whl (593 kB)
                                          Installing build dependencies ... error
                                          error: subprocess-exited-with-error
                                          × pip subprocess to install build dependencies did not run successfully.
                                          │ exit code: 1
                                          ╰─> [122 lines of output]
                                              Collecting setuptools>=40.6.0
                                                Using cached setuptools-60.10.0-py3-none-any.whl (1.1 MB)
                                              Collecting wheel
                                                Using cached wheel-0.37.1-py2.py3-none-any.whl (35 kB)
                                              Collecting cffi>=1.12
                                                Using cached cffi-1.15.0.tar.gz (484 kB)
                                              Collecting setuptools-rust>=0.11.4
                                                Using cached setuptools_rust-1.1.2-py3-none-any.whl (21 kB)
                                              Collecting pycparser
                                                Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
                                              Collecting typing-extensions>=3.7.4.3
                                                Using cached typing_extensions-4.1.1-py3-none-any.whl (26 kB)
                                              Collecting semantic-version<3,>=2.8.2
                                                Using cached semantic_version-2.9.0-py2.py3-none-any.whl (15 kB)
                                              Building wheels for collected packages: cffi
                                                Building wheel for cffi (setup.py): started
                                                Building wheel for cffi (setup.py): finished with status 'error'
                                                × python setup.py bdist_wheel did not run successfully.
                                                │ exit code: 1
                                                ╰─> [36 lines of output]
                                                    running bdist_wheel
                                                    running build
                                                    running build_py
                                                    creating build
                                                    creating build/lib.linux-armv7l-3.9
                                                    creating build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/lock.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/vengine_gen.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/error.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/model.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/__init__.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/ffiplatform.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/api.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/cparser.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/commontypes.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/verifier.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/pkgconfig.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/recompiler.py -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/_cffi_include.h -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/parse_c_type.h -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/_embedding.h -> build/lib.linux-armv7l-3.9/cffi
                                                    copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-3.9/cffi
                                                    running build_ext
                                                    building '_cffi_backend' extension
                                                    creating build/temp.linux-armv7l-3.9
                                                    creating build/temp.linux-armv7l-3.9/c
                                                    arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.9/c/_cffi_backend.o
                                                    c/_cffi_backend.c:2:10: fatal error: Python.h: Datei oder Verzeichnis nicht gefunden
                                                        2 | #include <Python.h>
                                                    compilation terminated.
                                                    error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
                                                    [end of output]
                                                note: This error originates from a subprocess, and is likely not a problem with pip.
                                                ERROR: Failed building wheel for cffi
                                                Running setup.py clean for cffi
                                              Failed to build cffi
                                              Installing collected packages: wheel, typing-extensions, setuptools, semantic-version, pycparser, setuptools-rust, cffi
                                                Running setup.py install for cffi: started
                                                Running setup.py install for cffi: finished with status 'error'
                                                × Running setup.py install for cffi did not run successfully.
                                                │ exit code: 1
                                                ╰─> [38 lines of output]
                                                    running install
                                                    /opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.9/site-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
                                                      warnings.warn(
                                                    running build
                                                    running build_py
                                                    creating build
                                                    running build_ext
                                                    [end of output]
                                              error: legacy-install-failure
                                              × Encountered error while trying to install package.
                                              ╰─> cffi
                                              note: This is an issue with the package mentioned above, not pip.
                                              hint: See above for output from the failure.
                                              [end of output]
                                        │ exit code: 1
                                        ╰─> See above for output.
                                        npm ERR! code ELIFECYCLE
                                        npm ERR! errno 1
                                        npm ERR! iobroker.esphome@0.2.4 install: `npip install`
                                        npm ERR! Exit status 1
                                        npm ERR!
                                        npm ERR! Failed at the iobroker.esphome@0.2.4 install script.
                                        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-03-21T16_38_52_555Z-debug.log
                                        Wo mache ich etwas falsch?
                                          Wie ist denn python jetzt installiert?
                                          python --version
                                          python3 --version
                                          apt policy python3-pip
                                          apt policy python3-cffi
                                            pi@raspberrypi:/opt/iobroker $ python --version
                                            Python 3.9.2
                                            pi@raspberrypi:/opt/iobroker $ python3 --version
                                            Python 3.9.2
                                            pi@raspberrypi:/opt/iobroker $ apt policy python3-pip
                                            python3-pip:
                                              Installiert:           (keine)
                                              Installationskandidat: 20.3.4-4+rpt1
                                              Versionstabelle:
                                                 20.3.4-4+rpt1 500
                                                    500 http://archive.raspberrypi.org/debian bullseye/main armhf Packages
                                                 20.3.4-4 500
                                                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                            pi@raspberrypi:/opt/iobroker $ apt policy python3-cffi
                                            python3-cffi:
                                              Installationskandidat: 1.14.5-1
                                              Versionstabelle:
                                                 1.14.5-1 500
                                            1.2k
                                            591
                                            152339
