    3. Off Topic
    4. Upgrade von Debian 10 'Buster' auf 11 'Bullseye'
      maxpd @Thomas Braun last edited by
      @thomas-braun Merci, deine Anleitung hat funktioniert!
      • SMS
        SMS last edited by
        Guten Morgen,
        leider komme ich aktuell nicht weiter und bitte euch um Hilfe.
        Pi4 8GB, Boot über USB
        Ausgangspunkt:
        2021-03-04-raspios-buster-armhf-lite
        Alles Neuere hat nicht funktioniert, warum auch immer. Aber nach versuch des updates ging der Pi nicht mehr. Grüne LED dauerhaft an.
        Was habe ich bis jetzt gemacht:
        sudo apt update -> sudo apt upgrade -> sudo reboot now -> sudo apt update -> Listen umgestellt -> sudo apt update -> sudo apt full-upgrade
        Nun hänge ich hier:
        411 upgraded, 89 newly installed, 8 to remove and 0 not upgraded.
        Need to get 0 B/355 MB of archives.
        After this operation, 294 MB of additional disk space will be used.
        Do you want to continue? [Y/n] y
        Reading changelogs... Done
        apt-listchanges: News
        apt (2.1.16) unstable; urgency=medium
          Automatically remove unused kernels on apt {dist,full}-upgrade. To revert
          to previous behavior, set APT::Get::AutomaticRemove::Kernels to false or
          pass --no-auto-remove to the command. apt-get remains unchanged.
          Packages files can now set the Phased-Update-Percentage field to restrict
          update rollout to a specified percentage of machines. Previously, this has
          only been available to users of Ubuntu's update-manager tool. See
          apt_preferences(5) for details and how to configure multiple systems to get
          the same updates. Phased updates are disabled in chroots for now to not
          break buildd-style setups.
         -- Julian Andres Klode <jak@debian.org>  Fri, 08 Jan 2021 22:01:50 +0100
        apt (1.9.11) experimental; urgency=medium
          apt(8) now waits for the lock indefinitely if connected to a tty, or
          for 120 seconds if not.
         -- Julian Andres Klode <jak@debian.org>  Wed, 26 Feb 2020 20:30:33 +0100
        apt (1.9.6) experimental; urgency=medium
          apt(8) no longer treats package names passed as regular expressions or fnmatch
          expressions, requiring the use of patterns (apt-patterns(5)) to perform complex
          searches. For ease of use, regular expressions starting with ^ or ending with
          $ continue to work.
          This fixes the problem where e.g. g++ could mean either "the package g++"
          or, if there is no g++ package, "all packages containing g". This change
          will propagate to apt-* after the release of Debian bullseye.
         -- Julian Andres Klode <jak@debian.org>  Wed, 15 Jan 2020 21:45:18 +0100
        apt (1.9.5) unstable; urgency=medium
          Credentials in apt_auth.conf(5) now only apply to https and tor+https
          sources to avoid them being leaked over plaintext (Closes: #945911). To
          opt-in to http, add http:// before the hostname. Note that this will transmit
          credentials in plain text, which you do not want on devices that could be
          operating in an untrusted network.
         -- Julian Andres Klode <juliank@ubuntu.com>  Mon, 02 Dec 2019 11:45:52 +0100
        Was soll ich tun?
        Danke!
        J M Thomas Braun 3 Replies Last reply Reply Quote 0
          Jan1 @SMS last edited by
          @sms
          Mein Rat wenn man so gefummelt hat, einfach Pi mit Bullseye neu aufsetzten und IOBroker Backup über den Adapter restoren. Zeitaufwand für einen der kein Plan hat, wohl 4 Stunden, mit Plan um die 2 😉
          Somit definitiv schneller als das Zerfummelte zu retten.
          Anleitung für ne wirklich saubere Installation des PI und das "Raspberry Pi OS Lite" verwenden.
            maxpd @SMS last edited by
            @sms ich glaube einmal Q drücken für quit. Dir wird nur das changelog angezeigt bevor es weitergeht. Oder?
              Thomas Braun Most Active @SMS last edited by
              @sms sagte in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
              Du installierst ein Buster, um dann auf Bullseye zu springen? Warum nicht direkt Bullseye?
              Aus der Anzeige des Changelogs kommst du glaube ich mit der Leertaste ans Ende. Oder mit Enter.
              J SMS 2 Replies Last reply Reply Quote 0
                Jan1 @Thomas Braun last edited by
                Deshalb auch der Link für die "gute" Anleitung.
                • SMS
                  SMS @Thomas Braun last edited by
                  @thomas-braun wie geschrieben, wenn ich das Neuste installiere und den Pi neu starte, leuchtet die grüne LED dauerhaft und es geht gar nichts mehr.
                  Vielleicht lag es am USB (ich benutze jetzt einen Anderen), aber aktuell komme ich so weiter ...
                    Was für ein USB?
                    Was veranstaltet ihr da eigentlich immer bei den Installationen?
                    SMS 1 Reply Last reply Reply Quote 0
                    • SMS
                      USB 2.0 (werde es mit einem aneren PI nochmal versuchen direkt auf bullseye)
                      keine Ahnung. Eigentlich funktioniert ja alles automatisch ...
                      J Thomas Braun 2 Replies Last reply Reply Quote 0
                        @sms
                        Für die Installation ist aber kein USB vorgesehen und da ist schon das erste ? 😉
                        Halte Dich an die Anleitung und es läuft.
                          Wenn man das wie vorgesehen machen würde... Ja.
                          • SMS
                            SMS @Jan1 last edited by
                            @jan1
                            leider gehen bei mir die Speicherkarten kaputt, was ich auch nicht verstehe. Daher bin ich auf USB umgestiegen.
                              Jan1 @SMS last edited by Jan1
                              @sms
                              Ich hatte sehr lange den IOBroker auf nem Pi und nie ein Defekt der Karte. Wenn ich nicht irre, steht in der Anleitung auch wie man das auf USB bekommt.
                              Übrigens sind USB Sticks anfälliger als SD Karten, deshalb ist das auch nicht wirklich ne Lösung. Es sei man hängt ne SSD an USB 😉
                                maxpd @Jan1 last edited by
                                @jan1 ich habe eine SSD am USB2 und habe letzte Woche die Anleitung hier erfolgreich durchlaufen.
                                • OpenSourceNomad
                                  OpenSourceNomad Most Active last edited by
                                  @sms said in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
                                  Nein! Doch! Ohhh!
                                  RaspberryOS + ioBroker = SD Karten Killer 💥
                                    Jan1 @OpenSourceNomad last edited by
                                    @opensourcenomad
                                    Zwei Jahr mit Pi auf SD Karte und keine defekt SD, folglich sind solch pauschale Aussagen doch etwas haarsträubend, selbst wenn die über den Link dann noch erklärt werden 😉
                                    • OpenSourceNomad
                                      OpenSourceNomad Most Active @Jan1 last edited by OpenSourceNomad
                                      @jan1 said in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
                                      Wer es nicht schafft den Link zu öffnen den sollen sich aber auch die Nackenhaare zu Berge stellen und alle seine Flash Speicher einen frühzeitigen Tot durch write ampflication sterben! 🤣
                                      Soll schon Leute gegeben haben die haben SD Karten zwei Jahre nicht benutzt und dann waren die Daten futsch, auch eine besondere Eigenheit von Flash Speicher (Stichwort: data retention) 💡
                                        Thomas Braun Most Active last edited by
                                        Am besten benutzen wir wieder wie die alten Sumerer Tontäfelchen. Die kann man auch nach Jahrtausenden noch lesen.
                                        • wendy2702
                                          wendy2702 last edited by
                                          In Stein meißeln soll auch relativ lange halten....
                                          Wenn denn die Daten nicht zu häufig überschrieben werden 😉
                                          • OpenSourceNomad
                                            Wenn es lange halten muss (die Menschheit überleben?) dann am ehesten noch Microfilm schön verpackt und im Bergwerk verklappt. 🛡
                                            Für alle anderen reicht im privaten Bereich Wahrscheinlich noch die gute alte Festplatte, die hält Daten auch Dauerhaft ohne Bestromung im Gegensatz zu Flashspeichern welche auf das auffrischen von Daten/neu schreiben (das macht der Controller automatisch) angewiesen ist. Das liegt an der technischen Beschaffenheit von Flash Speicher, ohne Strom gibt es über die Dauer einen Verlust elektrischer Ladung die zu Datenverlust oder bei minderwertigen/simplen Flash (meist noname SD/USB) auch gleich zur Komplettbeschädigung führen kann.
                                            Manch einer wundert sich, wenn er einen uralt USB Stick aus der Sofaritze taucht, dass dieser gar nicht mehr beschreibar ist (grid lock) und teilweise korrupte Daten enthält 💡
                                            1.0k
                                            309
                                            82614
