    4. [erledigt] Backup Fehler
      hm_krause @apollon77 last edited by
      @apollon77
      pi@iobroker:~ $ free -m
                    gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
      Speicher:       7812        3082         647           0        4082        4693
      Swap:             99           1          98
      pi@iobroker:~ $ top
      top - 17:08:56 up  2:44,  1 user,  load average: 1,45, 1,16, 1,16
      Tasks: 173 total,   3 running, 170 sleeping,   0 stopped,   0 zombie
      %CPU(s): 26,2 us,  3,6 sy,  0,0 ni, 69,9 id,  0,0 wa,  0,0 hi,  0,3 si,  0,0 st
      MiB Spch:   7812,0 total,    451,4 free,   3275,7 used,   4084,9 buff/cache
      MiB Swap:    100,0 total,     98,7 free,      1,3 used.   4500,5 avail Spch
          PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
         7065 iobroker  20   0 1858920   1,0g  35412 R  87,7  13,2 114:52.91 iobroker.js-con
        16670 iobroker  20   0  662596  69940  29424 R  11,9   0,9   0:02.09 node
         8035 iobroker  20   0  934068  79012  35420 S   3,6   1,0   1:29.85 io.tr-064.0
        10538 iobroker  20   0  957780 108868  31660 S   3,0   1,4   5:03.46 io.zigbee.0
         7093 iobroker  20   0 1233196 372344  35684 S   2,6   4,7   3:33.51 io.admin.0
         8528 iobroker  20   0 1377640 536396  35668 S   2,6   6,7  16:37.12 io.javascript.0
        12193 iobroker  20   0 1102200 254640  30656 S   1,3   3,2   4:32.46 io.web.0
        15321 iobroker  20   0 1008648 149564  30180 S   1,3   1,9   0:56.23 io.influxdb.0
         8546 iobroker  20   0  942320  83736  30036 S   1,0   1,0   1:16.32 io.mqtt.1
        12575 root      20   0       0      0      0 I   0,7   0,0   0:03.18 kworker/u8:1-ext4-rsv-conversion
           12 root      20   0       0      0      0 S   0,3   0,0   0:02.76 ksoftirqd/0
           90 root     -51   0       0      0      0 S   0,3   0,0   0:20.79 irq/51-mmc0
         8539 iobroker  20   0  664520  67952  30052 S   0,3   0,8   0:17.42 io.mqtt.0
        10147 iobroker  20   0  675720  83352  34888 S   0,3   1,0   1:19.42 io.upnp.0
        10181 iobroker  20   0  742020  87568  30040 S   0,3   1,1   3:02.73 io.sourceanalyt
        11595 iobroker  20   0  661816  66412  34744 S   0,3   0,8   0:11.96 io.shuttercontr
        15780 root      20   0       0      0      0 I   0,3   0,0   0:03.53 kworker/1:1-events_power_efficient
        16607 iobroker  20   0  733696  67384  30548 S   0,3   0,8   0:02.69 io.vis.0
        16681 pi        20   0   10080   3560   2816 R   0,3   0,0   0:00.03 top
            1 root      20   0  166100  10164   7184 S   0,0   0,1   0:05.64 systemd
            2 root      20   0       0      0      0 S   0,0   0,0   0:00.03 kthreadd
            3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
            4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
            6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/0:0H-events_highpri
            8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
            9 root      20   0       0      0      0 S   0,0   0,0   0:00.00 rcu_tasks_kthre
           10 root      20   0       0      0      0 S   0,0   0,0   0:00.00 rcu_tasks_rude_
           11 root      20   0       0      0      0 S   0,0   0,0   0:00.00 rcu_tasks_trace
           13 root      20   0       0      0      0 I   0,0   0,0   0:09.92 rcu_preempt
           14 root      rt   0       0      0      0 S   0,0   0,0   0:00.01 migration/0
           15 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
           16 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
           17 root      rt   0       0      0      0 S   0,0   0,0   0:00.00 migration/1
           18 root      20   0       0      0      0 S   0,0   0,0   0:00.40 ksoftirqd/1
           20 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/1:0H-kblockd
           21 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/2
           22 root      rt   0       0      0      0 S   0,0   0,0   0:00.01 migration/2
      Mal versucht ob Backup tut wenn du ioBroker stoppst? Also manuelles "iob backup" kommando ohne Backitup?
      ....werde ich machen..
        @apollon77
        ...wird nix
        pi@iobroker:/ $ sudo systemctl stop iobroker
        pi@iobroker:/ $ iobroker backup
        No connection to databases possible ...
        pi@iobroker:/ $ cd /opt/iobroker
        pi@iobroker:/opt/iobroker $ iobroker backup
          hm_krause last edited by
          ....und jetzt ????
          pi@iobroker:/ $ sudo systemctl start iobroker
          pi@iobroker:/ $ sudo systemctl status iobroker
          ● iobroker.service - ioBroker Server
               Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
               Active: active (running) since Sun 2022-03-20 17:47:32 CET; 10s ago
                 Docs: http://iobroker.net
             Main PID: 18644 (iobroker.js-con)
                Tasks: 11 (limit: 8986)
                  CPU: 14.866s
               CGroup: /system.slice/iobroker.service
                       └─18644 iobroker.js-controller
          Mär 20 17:47:32 iobroker systemd[1]: Started ioBroker Server.
          pi@iobroker:/ $ iob list instances
           Objects database error: connect ECONNREFUSED 0.0.0.0:9001
          pi@iobroker:/ $
            ...wird schlimmer:
             Cannot read system.config: undefined (OK when migrating or restoring)
            /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                    throw e;
            Error: Connection is closed.
                at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                at Redis.scan (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                at ScanStream._read (/opt/iobroker/node_modules/ioredis/built/ScanStream.js:36:41)
                at ScanStream.Readable.read (internal/streams/readable.js:465:10)
                at resume_ (internal/streams/readable.js:963:12)
                at processTicksAndRejections (internal/process/task_queues.js:82:21)
            Emitted 'error' event on ScanStream instance at:
                at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                at processTicksAndRejections (internal/process/task_queues.js:95:5)
            • simatec
              simatec Developer Most Active @hm_krause last edited by
              @hm_krause
              Warum hantierst du da mit sudo?
              Hier mal die Standard Befehle, um iobroker zu steuern
              iob stop
              iob start
              iob restart
                apollon77 @hm_krause last edited by
                @hm_krause naja mal langsam ... alles gut. Dein System hat sehr viele Daten ... wo auchimmer die herkommen (das hattest Du noch nicht gesagt).
                Also tweaken wir mal bissl:
                In /opt/iobroker/iobroker-data liegen eine states.jsonl und eine objects.jsonl ... WIe groß sind die?
                in /opt/iobroker/iobroker-data/iobroker.json in den Abschnitten zu "states" und "object" gibts jeweils ein "connectTimeout" ... schreib da mal 60000 als Wert rein.
                Gehts dann wieder?
                  crunchip Forum Testing Most Active @apollon77 last edited by
                  @apollon77 sagte in Backitup Fehler:
                  aber gezeigt
                  https://forum.iobroker.net/post/780181
                  zumindest sind die Adapter überschaubar und schon mal kein ble dabei, (OT: das war mit der alten Adminoberfläche sehr hilfreich, sofort seine Werte zu sehen)
                    apollon77 @hm_krause last edited by apollon77
                    @hm_krause nee ... weil da sieht man nicht wo diese massen an objekten und states herkommen 😞
                    Mirr fällt aber ausser Admin auf die Admin4 "alte ui" umzuschalten gerade keine idee ein weil da wurde das im Admin angezeigt
                    Wobei an sich wäre mqtt mit den zwei Instanzen ein Kandidat, je nachdem wie "gross" die Struktur ist ... Also wenn ioBroker noch startet mal da reinschauen. Auch bitte schauen ob da was komisch ist. Die neuesten mqtt Versionen (weis snicht ob Du Beta oder Stable nutzt) legen Folder strukturen an... das könnte ggf paar Objekte adden - aber du hattest ja auch sehr viele States
                      Habe ein altes Backup eingespielt, alles aktualisiert und jetzt hier nur noch
                      "Objekte: 67196, Zustände: 56335", passt so.
                      Danke für Eure Hilfe 👍
                        @hm_krause Naja Aber ich sag mal so: Ohne zu wissen wo die Objektmassen herkommen ist das für mich keine Echhte Lösung weil es dir morgen wieder passieren kann.
                        Eine frage: Welche mqtt Version nutzt du? Beta oder Stable?
                        Kannst Du jetzt wo alles wieder an ist ggf mal schauen ob es wieder mehr Objekte werden/geworden sind? Zeigt dir Admin oben rechts an unter "Objekte"
                          @apollon77
                          mqtt und alles andere ist "Stable"
                          Objekte: 67668, Zustände: 56711
                          crunchip apollon77 2 Replies Last reply Reply Quote 0
                            crunchip Forum Testing Most Active @hm_krause last edited by crunchip
                            @hm_krause also Tendenz steigend.
                            Vllt werden auch durch den radar2 neu gefundene Geräte angelegt,(wechselnte mac adressen), seh mal den durch
                            Wobei das auch nicht so viele sein dürften.
                            Am einfachsten ist es wirklich die alte Admin Oberfläche zu aktivieren, so das man im Verzeichnis die einzelne Anzahl erkennt, woher es kommt.
                              @hm_krause Finde raus was da dazukommt, sonst endest Du bald wieder dort.
                                hm_krause @crunchip last edited by
                                @crunchip
                                "Am einfachsten ist es wirklich die alte Admin Oberfläche zu aktivieren"
                                Wie mache ich das richtig?
                                  @hm_krause Öffne Admin Instanzkonfiguration ... da ist ein Haken wie "alte Oberflächet/UI" oder so ... Falls Admin nicht mehr geht das es dann such ich den CLI Kommando raus
                                  • wendy2702
                                    wendy2702 @apollon77 last edited by
                                    @apollon77 sagte in [erledigt] Backitup Fehler:
                                    iobroker set admin.0 --react false
                                    wenn ich mich richtig erinnere
                                      apollon77 @wendy2702 last edited by
                                      @wendy2702 Ja das "war einmal" :-))
                                      iobroker set admin.0 --material true
                                      ist "neu richtig"
                                      wendy2702 H 2 Replies Last reply Reply Quote 0
                                      • wendy2702
                                        @apollon77 OK.
                                        Die untiefen der CLI Befehle
                                          @apollon77
                                          ...vorher iob stop?
                                            hm_krause @hm_krause last edited by
                                            ...hilft das weiter?
                                            2615
