    • Knallochse
      Knallochse @Xsev last edited by
      @xsev du hast die falsche Baudrate eingestellt.
      Da muss bei esp32 115200 eingestellt werden
      Xsev 1 Reply Last reply Reply Quote 1
      • Xsev
        Xsev @Knallochse last edited by
        @knallochse Vielen Dank für den Tip!!!!
        @jomjol
        das Log sieht jetzt so aus
        ets Jul 29 2019 12:21:46
        rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
        configsip: 0, SPIWP:0xee
        clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
        mode:DIO, clock div:2
        load:0x3fff0030,len:4
        load:0x3fff0034,len:7248
        ho 0 tail 12 room 4
        load:0x40078000,len:13856
        load:0x40080400,len:4052
        entry 0x40080688
        I (31) boot: ESP-IDF 3.40100.200827 2nd stage bootloader
        I (31) boot: compile time 18:56:57
        I (31) boot: chip revision: 3
        I (35) boot_comm: chip revision: 3, min. bootloader chip revision: 0
        I (42) boot.esp32: SPI Speed      : 40MHz
        I (46) boot.esp32: SPI Mode       : DIO
        I (51) boot.esp32: SPI Flash Size : 4MB
        I (55) boot: Enabling RNG early entropy source...
        I (61) boot: Partition Table:
        I (64) boot: ## Label            Usage          Type ST Offset   Length
        I (72) boot:  0 nvs              WiFi data        01 02 00009000 00004000
        I (79) boot:  1 otadata          OTA data         01 00 0000d000 00002000
        I (87) boot:  2 phy_init         RF data          01 01 0000f000 00001000
        I (94) boot:  3 ota_0            OTA app          00 10 00010000 001db000
        I (102) boot:  4 ota_1            OTA app          00 11 001f0000 001db000
        I (109) boot: End of partition table
        I (113) boot_comm: chip revision: 3, min. application chip revision: 0
        I (121) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x51048 (331848) map
        I (273) esp_image: segment 1: paddr=0x00061070 vaddr=0x3ffb0000 size=0x0504c ( 20556) load
        I (283) esp_image: segment 2: paddr=0x000660c4 vaddr=0x40080000 size=0x00404 (  1028) load
        I (284) esp_image: segment 3: paddr=0x000664d0 vaddr=0x40080404 size=0x09b48 ( 39752) load
        I (310) esp_image: segment 4: paddr=0x00070020 vaddr=0x400d0020 size=0x122ec8 (1191624) map
        I (826) esp_image: segment 5: paddr=0x00192ef0 vaddr=0x40089f4c size=0x12c68 ( 76904) load
        I (881) boot: Loaded app from partition at offset 0x10000
        I (881) boot: Disabling RNG early entropy source...
        I (881) psram: This chip is ESP32-D0WD
        I (886) spiram: Found 16MBit SPI RAM device
        I (890) spiram: SPI RAM mode: flash 40m sram 40m
        I (896) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
        I (903) cpu_start: Pro cpu up.
        I (907) cpu_start: Application information:
        I (911) cpu_start: Project name:     esp32cam-server-only
        I (917) cpu_start: App version:      0.0.9.3
        I (922) cpu_start: Compile time:     Sep 25 2021 18:55:36
        I (928) cpu_start: ELF file SHA256:  49d2944a34ee25eb...
        I (934) cpu_start: ESP-IDF:          3.40100.200827
        I (940) cpu_start: Starting app cpu, entry point is 0x40081cf0
        I (0) cpu_start: App cpu up.
        I (1397) spiram: SPI SRAM memory test OK
        I (1397) heap_init: Initializing. RAM available for dynamic allocation:
        I (1398) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
        I (1404) heap_init: At 3FFC2A08 len 0001D5F8 (117 KiB): DRAM
        I (1410) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
        I (1416) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
        I (1423) heap_init: At 4009CBB4 len 0000344C (13 KiB): IRAM
        I (1429) cpu_start: Pro cpu start user code
        I (1434) spiram: Adding pool of 2048K of external SPI memory to heap allocator
        I (1459) spi_flash: detected chip: generic
        I (1460) spi_flash: flash io: dio
        I (1460) cpu_start: Starting scheduler on PRO CPU.
        I (0) cpu_start: Starting scheduler on APP CPU.
        I (1468) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations
        Do Reset Camera
        I (1478) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
        Init Camera
        I (3488) gpio: GPIO[5]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        I (3488) gpio: GPIO[18]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        I (3488) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        I (3498) gpio: GPIO[21]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        I (3508) gpio: GPIO[22]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        I (3518) gpio: GPIO[23]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        I (3528) gpio: GPIO[25]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        I (3538) gpio: GPIO[34]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        I (3548) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        I (3558) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        I (3568) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        I (3578) sccb: pin_sda 26 pin_scl 27
        I (3578) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
        I (3728) camera: Detected OV2640 camera
        I (3738) camera: Allocating 1 frame buffers (150 KB total)
        I (3748) camera: Allocating 150 KB frame buffer in OnBoard RAM
        I (4348) main: Using SDMMC peripheral
        Type: SDHC/SDXC
        Speed: 20 MHz
        I (4408) server_ota: Start CheckOTAUpdateCheck ...
        I (4418) server_ota: SHA-256 for the partition table: : 9d4a2809ae90fb20709a8ca3dd3ac3462e1e73286bcd31b689060c91de06fa3a
        I (4478) server_ota: SHA-256 for bootloader: : ee8b22523ca2a6f08e0e01e2e6dd2ae40f0a13f93d5c02794b19cfca199b3e9e
        I (5118) server_ota: SHA-256 for current firmware: : dc1319e0f2d427d7bc8d303fa98e0456e09c555804634127bb0960ca1cb42b6a
        CheckOTAUpdate Partition: ESP_OK
        open config file /sdcard/wlan.ini in mode r
        file loaded
        WLan: XXXXXXX, XXXXXXXXXXXXXXX
        Hostename: Watermeter13
        I (5168) wifi:wifi driver task: 3ffd9cc4, prio:23, stack:6656, core=0
        I (5168) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
        I (5198) wifi:wifi firmware version: 3ea4c76
        I (5198) wifi:config NVS flash: enabled
        I (5198) wifi:config nano formating: disabled
        I (5198) wifi:Init dynamic tx buffer num: 32
        I (5208) wifi:Init data frame dynamic rx buffer num: 32
        I (5208) wifi:Init management frame dynamic rx buffer num: 32
        I (5218) wifi:Init management short buffer num: 32
        I (5218) wifi:Init static tx buffer num: 16
        I (5228) wifi:Init static rx buffer size: 1600
        I (5228) wifi:Init static rx buffer num: 10
        I (5228) wifi:Init dynamic rx buffer num: 32
        I (5328) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
        I (5328) wifi:mode : sta (94:b9:7e:ce:50:20)
        I (5338) BLINK: Blinken - start
        I (5338) wifi station: wifi_init_sta finished.
        I (5458) wifi:new:<3,0>, old:<1,0>, ap:<255,255>, sta:<3,0>, prof:1
        I (5458) wifi:state: init -> auth (b0)
        I (5468) wifi:state: auth -> assoc (0)
        I (5478) wifi:state: assoc -> run (10)
        I (5518) wifi:connected with Rocket, aid = 3, channel 3, BW20, bssid = e0:63:da:74:3e:f2
        I (5518) wifi:security: WPA2-PSK, phy: bgn, rssi: -78
        I (5528) wifi:pm start, type: 1
        I (5538) BLINK: Blinken - done
        I (5588) wifi:AP's beacon interval = 102400 us, DTIM period = 1
        I (6158) esp_netif_handlers: sta ip: 192.168.13.202, mask: 255.255.255.0, gw: 192.168.13.1
        I (6158) wifi station: got ip:192.168.13.202
        I (6158) BLINK: Blinken - start
        I (6158) wifi station: connected to ap SSID:Rocket password:XXXXXXXXXXX
        main: sleep for : 200ms
        I (8178) sntp: Time is not set yet. Connecting to WiFi and getting time over NTP.
        I (8178) sntp: Initializing SNTP
        I (8178) sntp: Waiting for system time to be set... (1/10)
        I (10178) sntp: Waiting for system time to be set... (2/10)
        I (12178) sntp: Waiting for system time to be set... (3/10)
        TimeZone set to CET-1CEST,M3.5.0,M10.5.0/3
        Logfile opened: /sdcard/log/message/log_2022-03-20.txt
        I (14188) sntp: The current date/time in Berlin is: Sun Mar 20 11:39:34 2022
        I (14188) sntp: The current date/time in Berlin is: 2022-03-20_11:39
        timeist 20220320-113934
        time 20220320-113934
        I (16168) BLINK: Blinken - done
        I (16218) server-main: Starting server on port: '80'
        I (16218) server-main: Registering URI handlers
        I (16218) server_tflite: server_part_camera - Registering URI handlers
        I (16218) server_ota: server_ota - Registering URI handlers
        I (16228) server_GPIO: start GpioHandler
        I (16228) server_GPIO: register GPIO Uri
        I (16238) server_GPIO: server_GPIO - Registering URI handlers
        vor reg server main
        vor dotautostart
        task_autodoFlow: start
        open config file /sdcard/config/config.ini in mode r
        [MakeImage]
        Start ReadParameter ([MakeImage]
        ;LogImageLocation = /log/source
        WaitBeforeTakingPicture = 5
        ;LogfileRetentionInDays = 15
        Brightness = -2
        ;Contrast = 0
        ;Saturation = 0
        ImageQuality = 5
        ImageSize = VGA
        FixedExposure = false
        [Alignment]
        Start ReadParameter ([Alignment])
        InitialRotate = 179
        InitialMirror = false
        SearchFieldX = 20
        SearchFieldY = 20
        AlignmentAlgo = Default
        FlipImageSize = false
        /config/ref0.jpg 103 271
        /config/ref1.jpg 442 142
        [Digits]
        Start ReadParameter ([Digits])
        Model = /config/dig1210s2q.tflite
        ;LogImageLocation = /log/digit
        ;LogfileRetentionInDays = 3
        ModelInputSize = 20 32
        main.dig1 294 126 30 54
        GetGENERAL - GENERAL main - roi dig1
        main.dig2 343 126 30 54
        GetGENERAL - GENERAL main - roi dig2
        main.dig3 391 126 30 54
        GetGENERAL - GENERAL main - roi dig3
        [Analog]
        Start ReadParameter ([Analog])
        Model = /config/ana0700s1lq.tflite
        ;LogImageLocation = /log/analog
        ModelInputSize = 32 32
        ExtendedResolution = true
        main.ana1 432 230 92 92
        GetGENERAL - GENERAL main - roi ana1
        main.ana2 379 332 92 92
        GetGENERAL - GENERAL main - roi ana2
        main.ana3 283 374 92 92
        GetGENERAL - GENERAL main - roi ana3
        main.ana4 155 328 92 92
        GetGENERAL - GENERAL main - roi ana4
        [PostProcessing]
        Start ReadParameter ([PostProcessing])
        Anzahl NUMBERS: 1 - DIGITS: 1, ANALOG: 1
        Number main, Anz DIG: 3, Anz ANA 4
        main.DecimalShift = 0
        PreValueUse = true
        PreValueAgeStartup = 720
        AllowNegativeRates = false
        main.MaxRateValue = 0.1
        ErrorMessage = true
        CheckDigitIncreaseConsistency = true
        ;[MQTT]
        Read Zeile Prevalue.ini: 2020-11-30_12-02-22
        42.013401
        TIME: 120, 10, 0, 1, 1073497820, 5
        Read: ;Uri = mqtt://IP-ADRESS:1883
        Read: ;MainTopic = wasserzaehler
        Read: ;ClientID = wasser
        Read: ;user = USERNAME
        Read: ;password = PASSWORD
        Read:
        Read: ;[GPIO]
        Read: ;MainTopicMQTT = wasserzaehler/GPIO
        Read: ;IO0 = input disabled 10 false false
        Read: ;IO1 = input disabled 10 false false
        Read: ;IO3 = input disabled 10 false false
        Read: ;IO4 = built-in-led disabled 10 false false
        Read: ;IO12 = input-pullup disabled 10 false false
        Read: ;IO13 = input-pullup disabled 10 false false
        Read:
        Read: [AutoTimer]
        Start ReadParameter ([AutoTimer]
        AutoStart = true
        Intervall = 4.85
        [Debug]
        Start ReadParameter ([Debug])
        Logfile = false
        [System]
        Start ReadParameter ([System])
        TimeZone = CET-1CEST,M3.5.0,M10.5.0/3
        ;TimeServer = undefined
        ;AutoAdjustSummertime = false
        ;Hostname = undefined
        SetupMode = true
        END OF FILE
        *************** Start GPIOHandler_Init *****************
        I (18088) server_GPIO: read GPIO config and init GPIO
        [MakeImage]
        Brightness = -2
        ;Contrast = 0
        ;Saturation = 0
        ImageQuality = 5
        ImageSize = VGA
        [Alignment]
        InitialRotate = 179
        SearchFieldX = 20
        SearchFieldY = 20
        [Digits]
        [Analog]
        [PostProcessing]
        PreValueUse = true
        ErrorMessage = true
        ;[MQTT]
        ;ClientID = wasser
        ;user = USERNAME
        ;[GPIO]
        [AutoTimer]
        AutoStart = true
        Intervall = 4.85
        [Debug]
        Logfile = false
        [System]
        SetupMode = true
        I (18248) server_GPIO: GPIO init comleted, handler is disabled
        Flashdauer: 5000
        Image loaded from memory: 0, 0, 0
        Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
        Core 0 register dump:
        PC      : 0x400ef308  PS      : 0x00060030  A0      : 0x8018c5ca  A1      : 0x3fff9fd0
        A2      : 0x00000780  A3      : 0x3ffc3c68  A4      : 0x00000280  A5      : 0x00000780
        A6      : 0x00000001  A7      : 0x000001e0  A8      : 0x00000000  A9      : 0x3f82c168
        A10     : 0x00000000  A11     : 0x3fffa388  A12     : 0x00003826  A13     : 0x00000001
        A14     : 0x3ffc35ac  A15     : 0x3fff9ef0  SAR     : 0x0000001e  EXCCAUSE: 0x0000001c
        EXCVADDR: 0x00000000  LBEG    : 0x4008bed5  LEND    : 0x4008bee5  LCOUNT  : 0xffffffff
        Backtrace: 0x400ef305:0x3fff9fd0 0x4018c5c7:0x3fffa040 0x4018c64e:0x3fffa080 0x40189d89:0x3fffa110 0x400f13a2:0x3fffa1c0
        Rebooting...
          jomjol @Xsev last edited by
          @xsev sagte in Wasserzähler - Version 2 - all-in-device:
          das Problem ist das PSRAM - da bist du wohl übers Ohr gehauen worden:
          [0;32mI (881) psram: This chip is ESP32-D0WD
          [0;32mI (886) spiram: Found 16MBit SPI RAM device
          Du hast nur einen 16MBit (=2 MByte) verbaut - da sollte eigentlich 64MBit stehen (=8 MByte, davon aber nur 4 MByte nutzbar.
          Reklamieren und neu bestellen - kommt wohl gerade häufig vor!
          Xsev 2 Replies Last reply Reply Quote 1
          • Xsev
            Xsev @jomjol last edited by
            @jomjol Ach schande ok, danke für die Info.
            • Xsev
              @jomjol Ich hatte noch einen alten ESP mit defekter Cam rumliegen, ich hab jetzt mal das alte Board genommen mit neuer Cam. Laut Log hat dieser ESP die 64Mbit aber der Fehler bleibt der selbe. Kurz vor Logende meldet er folgendes:
              14:04:37.130 -> 14:04:37.130 -> Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
              14:04:37.130 -> Core 0 register dump:
              14:04:37.130 -> PC      : 0x400ef308  PS      : 0x00060530  A0      : 0x8018c5ca  A1      : 0x3fff9fd0
              14:04:37.130 -> A2      : 0x00000780  A3      : 0x3ffc3c68  A4      : 0x00000280  A5      : 0x00000780
              14:04:37.130 -> A6      : 0x00000001  A7      : 0x000001e0  A8      : 0x00000000  A9      : 0x3f82c168
              14:04:37.130 -> A10     : 0x00000000  A11     : 0x3f92ddd8  A12     : 0x00004d80  A13     : 0x00000001
              14:04:37.130 -> A14     : 0x3ffc35ac  A15     : 0x3fff9ef0  SAR     : 0x0000001a  EXCCAUSE: 0x0000001c
              14:04:37.130 -> EXCVADDR: 0x00000000  LBEG    : 0x4008bed5  LEND    : 0x4008bee5  LCOUNT  : 0xffffffff
              14:04:37.130 ->
              14:04:37.130 -> ELF file SHA256: 49d2944a34ee25eb
              14:04:37.130 -> Backtrace: 0x400ef305:0x3fff9fd0 0x4018c5c7:0x3fffa040 0x4018c64e:0x3fffa080 0x40189d89:0x3fffa110 0x400f13a2:0x3fffa1c0
              Das ganze Log:
              14:04:15.068 -> Rebooting...
              14:04:15.068 -> ets Jun  8 2016 00:22:57
              14:04:15.068 ->
              14:04:15.068 -> rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
              14:04:15.068 -> configsip: 0, SPIWP:0xee
              14:04:15.068 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
              14:04:15.068 -> mode:DIO, clock div:2
              14:04:15.068 -> load:0x3fff0030,len:4
              14:04:15.068 -> load:0x3fff0034,len:7248
              14:04:15.068 -> ho 0 tail 12 room 4
              14:04:15.068 -> load:0x40078000,len:13856
              14:04:15.068 -> load:0x40080400,len:4052
              14:04:15.068 -> entry 0x40080688
              14:04:15.068 -> I (31) boot: ESP-IDF 3.40100.200827 2nd stage bootloader
              14:04:15.068 -> I (31) boot: compile time 18:56:57
              14:04:15.068 -> I (31) boot: chip revision: 1
              14:04:15.068 -> I (34) boot_comm: chip revision: 1, min. bootloader chip revision: 0
              14:04:15.068 -> I (41) boot.esp32: SPI Speed      : 40MHz
              14:04:15.068 -> I (46) boot.esp32: SPI Mode       : DIO
              14:04:15.068 -> I (51) boot.esp32: SPI Flash Size : 4MB
              14:04:15.068 -> I (55) boot: Enabling RNG early entropy source...
              14:04:15.068 -> I (61) boot: Partition Table:
              14:04:15.068 -> I (64) boot: ## Label            Usage          Type ST Offset   Length
              14:04:15.068 -> I (71) boot:  0 nvs              WiFi data        01 02 00009000 00004000
              14:04:15.068 -> I (79) boot:  1 otadata          OTA data         01 00 0000d000 00002000
              14:04:15.068 -> I (86) boot:  2 phy_init         RF data          01 01 0000f000 00001000
              14:04:15.068 -> I (94) boot:  3 ota_0            OTA app          00 10 00010000 001db000
              14:04:15.068 -> I (101) boot:  4 ota_1            OTA app          00 11 001f0000 001db000
              14:04:15.068 -> I (109) boot: End of partition table
              14:04:15.068 -> I (113) boot_comm: chip revision: 1, min. application chip revision: 0
              14:04:15.068 -> I (120) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x51048 (331848) map
              14:04:15.224 -> I (273) esp_image: segment 1: paddr=0x00061070 vaddr=0x3ffb0000 size=0x0504c ( 20556) load
              14:04:15.224 -> I (283) esp_image: segment 2: paddr=0x000660c4 vaddr=0x40080000 size=0x00404 (  1028) load
              14:04:15.224 -> I (284) esp_image: segment 3: paddr=0x000664d0 vaddr=0x40080404 size=0x09b48 ( 39752) load
              14:04:15.224 -> I (310) esp_image: segment 4: paddr=0x00070020 vaddr=0x400d0020 size=0x122ec8 (1191624) map
              14:04:15.718 -> I (826) esp_image: segment 5: paddr=0x00192ef0 vaddr=0x40089f4c size=0x12c68 ( 76904) load
              14:04:16.357 -> I (880) boot: Loaded app from partition at offset 0x10000
              14:04:16.357 -> I (880) boot: Disabling RNG early entropy source...
              14:04:16.357 -> I (881) psram: This chip is ESP32-D0WD
              14:04:16.357 -> I (885) spiram: Found 64MBit SPI RAM device
              14:04:16.357 -> I (890) spiram: SPI RAM mode: flash 40m sram 40m
              14:04:16.357 -> I (895) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
              14:04:16.357 -> I (903) cpu_start: Pro cpu up.
              14:04:16.357 -> I (906) cpu_start: Application information:
              14:04:16.357 -> I (911) cpu_start: Project name:     esp32cam-server-only
              14:04:16.357 -> I (917) cpu_start: App version:      0.0.9.3
              14:04:16.357 -> I (922) cpu_start: Compile time:     Sep 25 2021 18:55:36
              14:04:16.357 -> I (928) cpu_start: ELF file SHA256:  49d2944a34ee25eb...
              14:04:16.357 -> I (934) cpu_start: ESP-IDF:          3.40100.200827
              14:04:16.357 -> I (940) cpu_start: Starting app cpu, entry point is 0x40081cf0
              14:04:16.357 -> I (931) cpu_start: App cpu up.
              14:04:16.841 -> I (1837) spiram: SPI SRAM memory test OK
              14:04:16.841 -> I (1838) heap_init: Initializing. RAM available for dynamic allocation:
              14:04:16.841 -> I (1838) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
              14:04:16.841 -> I (1844) heap_init: At 3FFC2A08 len 0001D5F8 (117 KiB): DRAM
              14:04:16.841 -> I (1851) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
              14:04:16.841 -> I (1857) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
              14:04:16.841 -> I (1864) heap_init: At 4009CBB4 len 0000344C (13 KiB): IRAM
              14:04:16.841 -> I (1870) cpu_start: Pro cpu start user code
              14:04:16.841 -> I (1875) spiram: Adding pool of 4096K of external SPI memory to heap allocator
              14:04:16.841 -> I (1900) spi_flash: detected chip: generic
              14:04:16.841 -> I (1901) spi_flash: flash io: dio
              14:04:16.841 -> I (1901) cpu_start: Starting scheduler on PRO CPU.
              14:04:16.841 -> I (0) cpu_start: Starting scheduler on APP CPU.
              14:04:16.841 -> I (1909) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations
              14:04:16.841 -> Do Reset Camera
              14:04:16.841 -> I (1919) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
              14:04:18.823 -> Init Camera
              14:04:18.823 -> I (3929) gpio: GPIO[5]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
              14:04:18.958 -> I (3929) gpio: GPIO[18]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
              14:04:18.958 -> I (3929) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
              14:04:18.958 -> I (3939) gpio: GPIO[21]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
              14:04:18.958 -> I (3949) gpio: GPIO[22]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
              14:04:18.958 -> I (3959) gpio: GPIO[23]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
              14:04:18.958 -> I (3969) gpio: GPIO[25]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
              14:04:18.958 -> I (3979) gpio: GPIO[34]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
              14:04:18.958 -> I (3989) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
              14:04:18.958 -> I (3999) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
              14:04:18.958 -> I (4009) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
              14:04:18.958 -> I (4019) sccb: pin_sda 26 pin_scl 27
              14:04:18.958 ->
              14:04:18.958 -> I (4019) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
              14:04:19.098 -> I (4169) camera: Detected OV2640 camera
              14:04:19.098 -> I (4179) camera: Allocating 1 frame buffers (150 KB total)
              14:04:19.098 -> I (4189) camera: Allocating 150 KB frame buffer in OnBoard RAM
              14:04:19.694 -> I (4789) main: Using SDMMC peripheral
              14:04:19.788 -> Name: SN64G
              14:04:19.788 -> Type: SDHC/SDXC
              14:04:19.788 -> Speed: 20 MHz
              14:04:19.788 -> Size: 60906MB
              14:04:19.788 -> I (4849) server_ota: Start CheckOTAUpdateCheck ...
              14:04:19.788 -> Start CheckOTAUpdateCheck ...
              14:04:19.788 -> I (4859) server_ota: SHA-256 for the partition table: : 9d4a2809ae90fb20709a8ca3dd3ac3462e1e73286bcd31b689060c91de06fa3a
              14:04:19.835 -> I (4919) server_ota: SHA-256 for bootloader: : ee8b22523ca2a6f08e0e01e2e6dd2ae40f0a13f93d5c02794b19cfca199b3e9e
              14:04:20.491 -> I (5559) server_ota: SHA-256 for current firmware: : dc1319e0f2d427d7bc8d303fa98e0456e09c555804634127bb0960ca1cb42b6a
              14:04:20.491 -> CheckOTAUpdate Partition: ESP_OK
              14:04:20.538 -> open config file /sdcard/wlan.ini in mode r
              14:04:20.538 -> file loaded
              14:04:20.538 ->
              14:04:20.538 -> WLan: Rocket, XXXXXXXXXXXXX
              14:04:20.538 -> Hostename: Watermeter13
              14:04:20.538 -> I (5609) wifi:wifi driver task: 3ffd9cc4, prio:23, stack:6656, core=0
              14:04:20.538 -> I (5609) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
              14:04:20.538 -> I (5639) wifi:wifi firmware version: 3ea4c76
              14:04:20.585 -> I (5639) wifi:config NVS flash: enabled
              14:04:20.585 -> I (5639) wifi:config nano formating: disabled
              14:04:20.585 -> I (5639) wifi:Init dynamic tx buffer num: 32
              14:04:20.585 -> I (5649) wifi:Init data frame dynamic rx buffer num: 32
              14:04:20.585 -> I (5649) wifi:Init management frame dynamic rx buffer num: 32
              14:04:20.585 -> I (5659) wifi:Init management short buffer num: 32
              14:04:20.585 -> I (5659) wifi:Init static tx buffer num: 16
              14:04:20.585 -> I (5669) wifi:Init static rx buffer size: 1600
              14:04:20.585 -> I (5669) wifi:Init static rx buffer num: 10
              14:04:20.585 -> I (5669) wifi:Init dynamic rx buffer num: 32
              14:04:20.721 -> I (5769) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
              14:04:20.721 -> I (5769) wifi:mode : sta (9c:9c:1f:c9:24:34)
              14:04:20.721 -> I (5769) BLINK: Blinken - start
              14:04:20.721 -> I (5779) wifi station: wifi_init_sta finished.
              14:04:20.815 -> I (5899) wifi:new:<3,0>, old:<1,0>, ap:<255,255>, sta:<3,0>, prof:1
              14:04:20.815 -> I (5899) wifi:state: init -> auth (b0)
              14:04:20.815 -> I (5919) wifi:state: auth -> assoc (0)
              14:04:20.862 -> I (5929) wifi:state: assoc -> run (10)
              14:04:20.862 -> I (5959) wifi:connected with Rocket, aid = 2, channel 3, BW20, bssid = e0:63:da:74:3e:f2
              14:04:20.909 -> I (5959) wifi:security: WPA2-PSK, phy: bgn, rssi: -72
              14:04:20.909 -> I (5969) wifi:pm start, type: 1
              14:04:20.909 ->
              14:04:20.909 -> I (5979) BLINK: Blinken - done
              14:04:20.956 -> I (6019) wifi:AP's beacon interval = 102400 us, DTIM period = 1
              14:04:21.518 -> I (6599) esp_netif_handlers: sta ip: 192.168.13.206, mask: 255.255.255.0, gw: 192.168.13.1
              14:04:21.518 -> I (6599) wifi station: got ip:192.168.13.206
              14:04:21.518 -> I (6599) BLINK: Blinken - start
              14:04:21.518 -> I (6609) wifi station: connected to ap SSID:Rocket password:XXXXXXXXXXXXX
              14:04:21.518 -> main: sleep for : 200ms
              14:04:23.514 -> I (8619) sntp: Time is not set yet. Connecting to WiFi and getting time over NTP.
              14:04:23.561 -> I (8619) sntp: Initializing SNTP
              14:04:23.561 -> I (8619) sntp: Waiting for system time to be set... (1/10)
              14:04:25.525 -> I (10619) sntp: Waiting for system time to be set... (2/10)
              14:04:27.593 -> TimeZone set to CET-1CEST,M3.5.0,M10.5.0/3
              14:04:27.593 -> Logfile opened: /sdcard/log/message/log_2022-03-20.txt
              14:04:27.593 -> I (12629) sntp: The current date/time in Berlin is: Sun Mar 20 14:04:29 2022
              14:04:27.593 -> I (12629) sntp: The current date/time in Berlin is: 2022-03-20_14:04
              14:04:27.593 -> timeist 20220320-140429
              14:04:27.593 -> time 20220320-140429
              14:04:27.593 -> main: sleep for : 200ms
              14:04:29.619 -> I (14659) server-main: Starting server on port: '80'
              14:04:29.619 -> I (14659) server-main: Registering URI handlers
              14:04:29.619 -> I (14659) server_tflite: server_part_camera - Registering URI handlers
              14:04:29.619 -> I (14659) server_ota: server_ota - Registering URI handlers
              14:04:29.619 -> I (14669) server_GPIO: start GpioHandler
              14:04:29.619 -> I (14669) server_GPIO: register GPIO Uri
              14:04:29.619 -> I (14679) server_GPIO: server_GPIO - Registering URI handlers
              14:04:29.619 -> vor reg server main
              14:04:29.619 -> vor dotautostart
              14:04:29.619 -> task_autodoFlow: start
              14:04:29.619 -> open config file /sdcard/config/config.ini in mode r
              14:04:29.619 -> [MakeImage]
              14:04:29.619 -> Start ReadParameter ([MakeImage]
              14:04:29.619 -> )
              14:04:29.619 -> ;LogImageLocation = /log/source
              14:04:29.619 -> WaitBeforeTakingPicture = 5
              14:04:29.619 -> ;LogfileRetentionInDays = 15
              14:04:29.619 -> Brightness = -2
              14:04:29.619 -> ;Contrast = 0
              14:04:29.619 -> ;Saturation = 0
              14:04:29.619 -> ImageQuality = 5
              14:04:29.619 -> ImageSize = VGA
              14:04:29.619 -> FixedExposure = false
              14:04:29.619 ->
              14:04:29.619 -> [Alignment]
              14:04:31.563 -> Start ReadParameter ([Alignment])
              14:04:31.563 -> InitialRotate = 179
              14:04:31.563 -> InitialMirror = false
              14:04:31.563 -> SearchFieldX = 20
              14:04:31.563 -> SearchFieldY = 20
              14:04:31.563 -> AlignmentAlgo = Default
              14:04:31.563 -> FlipImageSize = false
              14:04:31.563 -> /config/ref0.jpg 103 271
              14:04:31.563 -> /config/ref1.jpg 442 142
              14:04:31.563 ->
              14:04:31.563 -> [Digits]
              14:04:31.563 -> Start ReadParameter ([Digits])
              14:04:31.563 -> Model = /config/dig1210s2q.tflite
              14:04:31.563 -> ;LogImageLocation = /log/digit
              14:04:31.563 -> ;LogfileRetentionInDays = 3
              14:04:31.563 -> ModelInputSize = 20 32
              14:04:31.563 -> main.dig1 294 126 30 54
              14:04:31.563 -> GetGENERAL - GENERAL main - roi dig1
              14:04:31.563 -> main.dig2 343 126 30 54
              14:04:31.563 -> GetGENERAL - GENERAL main - roi dig2
              14:04:31.563 -> main.dig3 391 126 30 54
              14:04:31.563 -> GetGENERAL - GENERAL main - roi dig3
              14:04:31.563 ->
              14:04:31.563 -> [Analog]
              14:04:31.563 -> Start ReadParameter ([Analog])
              14:04:31.563 -> Model = /config/ana0700s1lq.tflite
              14:04:31.563 -> ;LogImageLocation = /log/analog
              14:04:31.563 -> ModelInputSize = 32 32
              14:04:31.563 -> ExtendedResolution = true
              14:04:31.563 -> main.ana1 432 230 92 92
              14:04:31.563 -> GetGENERAL - GENERAL main - roi ana1
              14:04:31.563 -> main.ana2 379 332 92 92
              14:04:31.563 -> GetGENERAL - GENERAL main - roi ana2
              14:04:31.563 -> main.ana3 283 374 92 92
              14:04:31.563 -> GetGENERAL - GENERAL main - roi ana3
              14:04:31.563 -> main.ana4 155 328 92 92
              14:04:31.563 -> GetGENERAL - GENERAL main - roi ana4
              14:04:31.563 ->
              14:04:31.563 -> [PostProcessing]
              14:04:31.563 -> Start ReadParameter ([PostProcessing])
              14:04:31.563 -> Anzahl NUMBERS: 1 - DIGITS: 1, ANALOG: 1
              14:04:31.563 -> Number main, Anz DIG: 3, Anz ANA 4
              14:04:31.563 -> main.DecimalShift = 0
              14:04:31.563 -> PreValueUse = true
              14:04:31.563 -> PreValueAgeStartup = 720
              14:04:31.563 -> AllowNegativeRates = false
              14:04:31.563 -> main.MaxRateValue = 0.1
              14:04:31.563 -> ErrorMessage = true
              14:04:31.563 -> CheckDigitIncreaseConsistency = true
              14:04:31.563 ->
              14:04:31.563 -> ;[MQTT]
              14:04:31.563 -> Read Zeile Prevalue.ini: 2020-11-30_12-02-22
              14:04:31.563 -> 42.013401
              14:04:31.563 -> TIME: 120, 10, 0, 1, 1, 5
              14:04:31.563 -> Read: ;Uri = mqtt://IP-ADRESS:1883
              14:04:31.563 -> Read: ;MainTopic = wasserzaehler
              14:04:31.563 -> Read: ;ClientID = wasser
              14:04:31.563 -> Read: ;user = USERNAME
              14:04:31.563 -> Read: ;password = PASSWORD
              14:04:31.563 -> Read: ;[GPIO]
              14:04:31.563 -> Read: ;MainTopicMQTT = wasserzaehler/GPIO
              14:04:31.563 -> Read: ;IO0 = input disabled 10 false false
              14:04:31.563 -> Read: ;IO1 = input disabled 10 false false
              14:04:31.563 -> Read: ;IO3 = input disabled 10 false false
              14:04:31.563 -> Read: ;IO4 = built-in-led disabled 10 false false
              14:04:31.563 -> Read: ;IO12 = input-pullup disabled 10 false false
              14:04:31.563 -> Read: ;IO13 = input-pullup disabled 10 false false
              14:04:31.563 -> Read: [AutoTimer]
              14:04:31.563 -> Start ReadParameter ([AutoTimer]
              14:04:31.563 -> )
              14:04:31.563 -> AutoStart = true
              14:04:31.563 -> Intervall = 4.85
              14:04:31.563 ->
              14:04:31.563 -> [Debug]
              14:04:31.563 -> Start ReadParameter ([Debug])
              14:04:31.563 -> Logfile = false
              14:04:31.563 -> LogfileRetentionInDays = 3
              14:04:31.563 ->
              14:04:31.563 -> [System]
              14:04:31.563 -> Start ReadParameter ([System])
              14:04:31.563 -> TimeZone = CET-1CEST,M3.5.0,M10.5.0/3
              14:04:31.563 -> TimeZone set to CET-1CEST,M3.5.0,M10.5.0/3
              14:04:31.563 -> ;TimeServer = undefined
              14:04:31.563 -> ;AutoAdjustSummertime = false
              14:04:31.563 -> ;Hostname = undefined
              14:04:31.563 -> SetupMode = true
              14:04:31.563 -> END OF FILE
              14:04:31.563 -> *************** Start GPIOHandler_Init *****************
              14:04:31.563 -> I (16519) server_GPIO: read GPIO config and init GPIO
              14:04:31.563 -> open config file /sdcard/config/config.ini in mode r
              14:04:31.563 -> [MakeImage]
              14:04:31.563 -> ;LogImageLocation = /log/source
              14:04:31.563 -> WaitBeforeTakingPicture = 5
              14:04:31.563 -> ;LogfileRetentionInDays = 15
              14:04:31.563 -> Brightness = -2
              14:04:31.563 -> ;Contrast = 0
              14:04:31.563 -> ;Saturation = 0
              14:04:31.563 -> ImageQuality = 5
              14:04:31.563 -> ImageSize = VGA
              14:04:31.563 -> FixedExposure = false
              14:04:31.563 ->
              14:04:31.563 -> [Alignment]
              14:04:31.563 ->
              14:04:31.563 ->
              14:04:31.563 -> I (16609) BLINK: Blinken - done
              14:04:31.563 ->
              14:04:31.563 ->
              14:04:31.563 -> ;Uri = mqtt://IP-ADRESS:1883
              14:04:31.563 -> ;MainTopic = wasserzaehler
              14:04:31.563 -> ;ClientID = wasser
              14:04:31.563 -> ;user = USERNAME
              14:04:31.563 -> ;password = PASSWORD
              14:04:31.563 ->
              14:04:31.563 -> ;[GPIO]
              14:04:31.563 -> ;MainTopicMQTT = wasserzaehler/GPIO
              14:04:31.563 -> ;IO0 = input disabled 10 false false
              14:04:31.563 -> ;IO1 = input disabled 10 false false
              14:04:31.563 -> ;IO3 = input disabled 10 false false
              14:04:31.563 -> ;IO4 = built-in-led disabled 10 false false
              14:04:31.610 -> ;IO12 = input-pullup disabled 10 false false
              14:04:31.610 -> ;IO13 = input-pullup disabled 10 false false
              14:04:31.610 ->
              14:04:31.610 -> [AutoTimer]
              14:04:31.610 -> AutoStart = true
              14:04:31.610 -> Intervall = 4.85
              14:04:31.610 ->
              14:04:31.610 -> [Debug]
              14:04:31.610 -> Logfile = false
              14:04:31.610 -> LogfileRetentionInDays = 3
              14:04:31.610 ->
              14:04:31.610 -> [System]
              14:04:31.610 -> TimeZone = CET-1CEST,M3.5.0,M10.5.0/3
              14:04:31.610 -> ;TimeServer = undefined
              14:04:31.610 -> ;AutoAdjustSummertime = false
              14:04:31.610 -> ;Hostname = undefined
              14:04:31.610 -> SetupMode = true
              14:04:31.610 -> I (16689) server_GPIO: GPIO init comleted, handler is disabled
              14:04:31.610 -> Flashdauer: 5000
              14:04:37.130 -> Image loaded from memory: 0, 0, 0
              14:04:37.130 ->
              14:04:37.130 ->
              14:04:37.130 -> Rebooting...
              14:04:37.130 -> ets Jun  8 2016 00:22:57
                martinschm @Xsev last edited by
                ich habe gerade in meinen history Daten gesehen, das bei mir die 4 an der dritten Stelle wohl nicht richtig erkannt wird. Lauter raw Werte die ein N dort anzeigen. Mittlerweile ist der Zähler bei der 5 und dann der 6 angekommen.
                Kann ich irgendwie mit anderen Trainingswerten ein Test laufen lassen ob er damit die 4 richtig erkannt hätte?
                ciao
                Martin
                  toki1973 @martinschm last edited by
                  Kann mir das jemand erklären?
                    JoergH @toki1973 last edited by
                    @toki1973 Was ist denn unklar? Der Zähler wird korrekt abgelesen, aber zuvor hatte er wohl mal einen höheren falschen Wert und da er nicht rückwärts zählen darf laut Deinen Einstellungen ("allow negative rates - false"), übermittelt er weiter den zuvor fälschlicherweise ermittelten, hohen Wert. Warum der mal so falsch ermittelt wurde? Keine Ahnung. Ich habe von 4 Zählern mit 3 en dauernd Probleme mit der Erkennung. Ich denke ohne eigenes Training mit den Bildern der eigenen Schrift wird es vermutlich nicht besser werden bei mir.
                      mameier1234 @JoergH last edited by
                      @joergh Ich denke mal die Hauptfrage ist, warum da ein Sprung zwischendurch von 390 auf 411 stattfand, obwohl das MaxRateValue auf 0,9 steht...
                      Das passiert bei mir auch leider immer wieder mal.. Bisher ohne Erklärung..
                      Xsev 1 Reply Last reply Reply Quote 0
                      • Xsev
                        Xsev @mameier1234 last edited by
                        @jomjol
                        Kannst du vielleicht bei Gelegenheit bitte nochmal über das Log schauen. Trotz anderem ESP (mit 64Mbit Psram) und jetzt auch neuer 32GB SD Karte, selbes Problem. Ich komm aus dem Dauerreboot einfach nicht raus.
                        14:04:37.130 ->
                        Das ganze Log:
                        14:04:15.068 ->
                        14:04:18.958 ->
                        14:04:20.538 ->
                        14:04:20.909 ->
                        14:04:29.619 -> )
                        14:04:29.619 ->
                        14:04:31.563 ->
                        14:04:31.563 ->
                        14:04:31.563 ->
                        14:04:31.563 ->
                        14:04:31.563 -> )
                        14:04:31.563 ->
                        14:04:31.563 ->
                        14:04:31.563 ->
                        14:04:31.563 ->
                        14:04:31.563 ->
                        14:04:31.563 ->
                        14:04:31.563 ->
                        14:04:31.563 ->
                        14:04:31.610 ->
                        14:04:31.610 ->
                        14:04:31.610 ->
                        14:04:37.130 ->
                        14:04:37.130 ->
                          The Problem I see is here:
                          This tells, that the image from the camera could not be loaded. Can you check the connection to your camera (flex band).
                            BorderCounter @jomjol last edited by
                            mein Problem: Die vollen Kubikmeter (6) wird nicht erkannt. Raw Value: 0082N.075 (00826.075)- Alter Stand war 0082N.981 (00825.981). Durch den Sprung der vollen Kubikmeter von 825 auf 826 und die Tatsache, dass die 1-Kubikmeterstelle nicht richtig erkannt wird, ist die "neue Menge" kleiner als die "alte Menge". Wie gehe ich am besten damit um?
                            Ich habe Versuchsweise das Feld für die Stelle zu vergrößern, schafft aber keine Abhilfe.
                              JoergH @BorderCounter last edited by
                              @bordercounter Das Fenster um die Ziffer 6 sieht zu groß aus. Das würde ich mal exakt anpassen, dann erkennt er die Ziffer vielleicht besser...
                                BorderCounter @JoergH last edited by
                                @joergh Ich habe das Feld schon größer gemacht. als es exakt gepasst hat, war der fehler der selbe 😞
                                • Xsev
                                  Xsev @BorderCounter last edited by
                                  @bordercounter Du kannst mal mit einem anderen Erkennungsfile testen, ich hab mit den älteren Versionen teilweise bessere Ergebnisse erzielt. Da sollten 2-3 auf der SD Karte sein, evtl. gibt's die auch als Download auf Git...
                                    markushi last edited by markushi
                                    bin zufällig auch über dieses absolut geniale Projekt gestoßen und habs mal provisorisch installiert um meinen analogen Stromzähler auszulesen:
                                    Funktioniert 1a und was mich echt überrascht hat, ist die hohe Erkennungsqualität der Software! Aktuell logge ich so jede Stunde den Stand in meine Postgres Datenbank:
                                    Problem für mich bei dem Ganzen: Ich habe keine 3D-Drucker! Und irgendwie finde ich keinen Shop, wo ich mir ein gedrucktes Gehäuse für das Modul bestellen könnte?!? Habt ihr einen Tipp für mich? Wollte mir deswegen ungern einen 3D-Drucker anschaffen....
                                    Danke!
                                    Gruß - Markus
                                    ERLEDIGT ---> hab jetzt bei einem Online Druckdienst Gehäuse bestellt ✌
                                    • BananaJoe
                                      BananaJoe Most Active @markushi last edited by
                                      @markushi aus Pappe oder Bastelholz / Bastelkunststoffplatten aus dem Baumarkt.
                                      Kannst du mit dem Teppichmesser zuschneiden und kleben.
                                      Musst nur schauen woran du es hängen oder festklemmen kannst
                                        Kann ich eigentlich was machen, um die Erkennung zu verbessern? Mir scheint es so, als ob die "6" Probleme macht:
                                        Das wurde auch in anderen Posts hier erwähnt, dass es mit der Zahl wohl Probleme gibt!? Hat jemand einen Tipp für mich?
                                        • Xsev
                                          Xsev @Xsev last edited by
                                          @markushi Probier mal folgendes:
                                            markushi @Xsev last edited by
                                            @xsev Was genau ist das Erkennungsfile? Sind das die dig... Files im config Verzeichnis?
                                            238
                                            3411
                                            2015756
