    4. iobroker Benutzer Error in GUI!
    • Neues Video auf YouTube
      Mika 0 last edited by
      Dank euch innerhalb von Sekunden über Putty: 😉
      pi@iobroker:~ $ which node && node -v && which npm && npm -v && apt policy nodejs
      /usr/bin/node
      v14.19.1
      /usr/bin/npm
      6.14.16
      nodejs:
      Installed: 14.19.1-deb-1nodesource1
      Candidate: 14.19.1-deb-1nodesource1
      Version table:
      *** 14.19.1-deb-1nodesource1 500
      500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
      100 /var/lib/dpkg/status
      12.22.5~dfsg-2~11u1 500
      500 http://deb.debian.org/debian bullseye/main arm64 Packages
      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      pi@iobroker:~ $
      Hoffe das passt alles?
        Thomas Braun Most Active @Mika 0 last edited by
        @mika-0
        sudo ln -s /usr/bin/node /usr/bin/nodejs
        which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          Mika 0 last edited by Mika 0
          Tadaa:
          pi@iobroker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
          pi@iobroker:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.19.1
          v14.19.1
          6.14.16
          pi
          /home/pi
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
          Reading package lists... Done
          Building dependency tree... Done
          2 packages can be upgraded. Run 'apt list --upgradable' to see them.
          nodejs:
          Version table:
          pi@iobroker:~ $
          Also das habe ich gemacht und den Pi jetzt noch neu gestartet.
          Der Error ist weiterhin vorhanden.
            @mika-0
            Kannst du bitteText in CodeTags einbetten?
            iobroker update -i
            sagt?
              @thomas-braun sagte in iobroker Benutzer Error in GUI!:
              iobroker update -i
              Hallo Thomas. Aber ich habe deinen Befehl mal im Putty eingegeben und folgend das Ergebnis:
              pi@iobroker:~ $ iobroker update -i
              Used repository: stable
              Adapter    "admin"        : 5.3.1    , installed 5.3.1
              Adapter    "backitup"     : 2.3.3    , installed 2.3.3
              Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
              Adapter    "discovery"    : 2.7.5    , installed 2.7.5
              Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
              Adapter    "harmony"      : 1.2.2    , installed 1.2.2
              Adapter    "history"      : 1.10.5   , installed 1.10.5
              Adapter    "ical"         : 1.11.4   , installed 1.11.4
              Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
              Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
              Adapter    "javascript"   : 5.2.21   , installed 5.2.21
              Controller "js-controller": 4.0.21   , installed 4.0.21
              Adapter    "mihome-vacuum": 3.3.1    , installed 3.3.1
              Adapter    "net-tools"    : 0.1.7    , installed 0.1.7
              Adapter    "ping"         : 1.5.0    , installed 1.5.0
              Adapter    "s7"           : 1.3.10   , installed 1.3.10
              Adapter    "simple-api"   : 2.6.2    , installed 2.6.4
              Adapter    "smappee"      : 0.2.6    , installed 0.2.6
              Adapter    "socketio"     : 4.1.4    , installed 4.1.5
              Adapter    "tr-064"       : 4.2.15   , installed 4.2.15
              Adapter    "trashschedule": 1.4.1    , installed 1.4.1
              Adapter    "vis"          : 1.4.5    , installed 1.4.5
              Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
              Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
              Adapter    "vis-metro"    : 1.1.2    , installed 1.1.2
              Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
              Adapter    "web"          : 4.2.0    , installed 4.2.0
              Adapter    "ws"           : 1.2.0    , installed 1.2.0
              pi@iobroker:~ $
              Korrektur durchgeführt...
                @mika-0
                CodeTags:
                Text markieren, </> Icon anklicken, fertig.
                  @mika-0
                  Und was ist jetzt aktuell das Problem? Mit welchen Meldungen?
                    Mika 0 @Thomas Braun last edited by
                    Wenn ich auf Users im ioBroker drücke kommt immer noch Error.
                    Auszug vom Error:
                    Error: Minified React error #31; visit https://reactjs.org/docs/error-decoder.html?invariant=31&args[]=object%20with%20keys%20%7Ben%2C%20de%2C%20ru%2C%20pt%2C%20nl%2C%20fr%2C%20it%2C%20es%2C%20pl%2C%20zh-cn%7D for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
                        at Ec (6.501acaca.chunk.js:2:5595786)
                        at 6.501acaca.chunk.js:2:5600621
                        at Po (6.501acaca.chunk.js:2:5611663)
                        at Zi (6.501acaca.chunk.js:2:5657695)
                        at jl (6.501acaca.chunk.js:2:5643113)
                        at Sl (6.501acaca.chunk.js:2:5643041)
                        at Cl (6.501acaca.chunk.js:2:5642904)
                        at zl (6.501acaca.chunk.js:2:5639870)
                        at 6.501acaca.chunk.js:2:5589364
                        at t.unstable_runWithPriority (6.501acaca.chunk.js:2:5672574)
                        at Ga (6.501acaca.chunk.js:2:5589141)
                        at Ka (6.501acaca.chunk.js:2:5589309)
                        at Za (6.501acaca.chunk.js:2:5589244)
                        at pl (6.501acaca.chunk.js:2:5637247)
                        at Object.enqueueSetState (6.501acaca.chunk.js:2:5593262)
                        at s.m.setState (6.501acaca.chunk.js:2:5664084)
                        at :8081/static/js/9.a078e0d6.chunk.js:1:27236
                      @mika-0 sagte in iobroker Benutzer Error in GUI!:
                      Muss sich jemand mit Kenn vom Admin-GUI anschauen, denke ich.
                      Log ein Issue.
                        TT-Tom @Thomas Braun last edited by TT-Tom
                        @mika-0
                        Log ein Issue.
                        Es ist immer noch offen 1337
                        Mika wird warten müssen.
                          Mika 0 @TT-Tom last edited by
                          @tt-tom Danke der Info. Dann schließe ich erstmal das Thema.
                          • Elzershark
                            Elzershark last edited by Elzershark
                            Ganz oben auf den Schraubenschlüssel klicken. (Systemeinstellung)
                            Repositories
                            Dort die 2 anklicken (Beta) und speichern.
                            (Eventuell auf Experte einstellen (Oben der Kopf) und Version 5.3.4. installieren. ab 5.3.4. ist es gefixt)
                            Admin Adapter updaten.
                            Repositories wieder auf stable stellen. (1 anklicken)
                            Fertig
                            2088
