    4. JavaScript
    5. HowTo: Zusatz-Programme fuer jarvis v3
      sigi234 Forum Testing Most Active @MCU last edited by sigi234
      @mcu sagte in HowTo: Zusatz-Programme fuer jarvis v3:
      Ändert sich etwas, wenn du den WeatherSelect neu auswählst?
      Nein
      javascript.0
      2022-03-23 14:22:24.402	error	at processImmediate (internal/timers.js:464:21)
      javascript.0
      2022-03-23 14:22:24.402	error	at Immediate._onImmediate (C:\Program Files\iobroker\Home\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:5909:56)
      javascript.0
      2022-03-23 14:22:24.402	error	at Object.stateChange (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\main.js:565:29)
      javascript.0
      2022-03-23 14:22:24.402	error	at Object.callback (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\lib\sandbox.js:1160:38)
      javascript.0
      2022-03-23 14:22:24.402	error	at Object.<anonymous> (script.js.Jarvis.DateWeather:138:5)
      javascript.0
      2022-03-23 14:22:24.402	error	at htmlSet (script.js.Jarvis.DateWeather:346:60)
      javascript.0
      2022-03-23 14:22:24.402	error	Error in callback: TypeError: Cannot read property 'start' of null
      javascript.0
      2022-03-23 14:21:25.905	error	at processTimers (internal/timers.js:500:7)
      javascript.0
      2022-03-23 14:21:25.905	error	at listOnTimeout (internal/timers.js:557:17)
      javascript.0
      2022-03-23 14:21:25.905	error	at Timeout._onTimeout (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\lib\sandbox.js:2218:34)
      javascript.0
      2022-03-23 14:21:25.904	error	at Object.<anonymous> (script.js.Jarvis.DateWeather:43:9)
      javascript.0
      2022-03-23 14:21:25.904	error	at htmlSet (script.js.Jarvis.DateWeather:346:60)
      javascript.0
      2022-03-23 14:21:25.903	error	Error in callback: TypeError: Cannot read property 'start' of null
        MCU @sigi234 last edited by
        @sigi234 Problem ist der dwd-Adapter:
        warning0 neu und nicht korrekt angelegt.
          MCU last edited by
          @sigi234 Beim Horoskop gibt es bzgl 5.5.0 keine Probleme bei mir:
          Vielleicht System neu starten? Upload?
            Jupp, bei mir auch nicht mehr.
              @sigi234
              DWD 2.8.2
              Nach Neustart vom System ist auch plötzlich die warning0 weg?
                Bei mir auch, aber nach Adapterneustart wieder da.
                Vielleicht kann sich @apollon77 das mal ansehen.
                host.MedionHome)
                2022-03-23 15:17:56.017	info	host.Medion(Home) instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                dwd.0
                2022-03-23 15:17:55.381	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                dwd.0
                2022-03-23 15:17:55.381	debug	Plugin sentry destroyed
                dwd.0
                2022-03-23 15:17:55.363	debug	Add warning "dwd.0.warning9":
                dwd.0
                2022-03-23 15:17:55.324	debug	Write warnings for 9: dwd.0.warning9 = undefined
                dwd.0
                2022-03-23 15:17:55.298	debug	Add warning "dwd.0.warning8":
                dwd.0
                2022-03-23 15:17:55.271	debug	Write warnings for 8: dwd.0.warning8 = undefined
                dwd.0
                2022-03-23 15:17:55.255	debug	Add warning "dwd.0.warning7":
                dwd.0
                2022-03-23 15:17:55.229	debug	Write warnings for 7: dwd.0.warning7 = undefined
                dwd.0
                2022-03-23 15:17:55.214	debug	Add warning "dwd.0.warning6":
                dwd.0
                2022-03-23 15:17:55.189	debug	Write warnings for 6: dwd.0.warning6 = undefined
                dwd.0
                2022-03-23 15:17:55.172	debug	Add warning "dwd.0.warning5":
                dwd.0
                2022-03-23 15:17:55.146	debug	Write warnings for 5: dwd.0.warning5 = undefined
                dwd.0
                2022-03-23 15:17:55.130	debug	Add warning "dwd.0.warning4":
                dwd.0
                2022-03-23 15:17:55.105	debug	Write warnings for 4: dwd.0.warning4 = undefined
                dwd.0
                2022-03-23 15:17:55.091	debug	Add warning "dwd.0.warning3":
                dwd.0
                2022-03-23 15:17:55.041	debug	Write warnings for 3: dwd.0.warning3 = undefined
                dwd.0
                2022-03-23 15:17:55.024	debug	Add warning "dwd.0.warning2":
                dwd.0
                2022-03-23 15:17:54.996	debug	Write warnings for 2: dwd.0.warning2 = undefined
                dwd.0
                2022-03-23 15:17:54.979	debug	Add warning "dwd.0.warning1":
                dwd.0
                2022-03-23 15:17:54.949	debug	Write warnings for 1: dwd.0.warning1 = undefined
                dwd.0
                2022-03-23 15:17:54.933	debug	Add warning "dwd.0.warning": 2022-03-23T22:00:00.000Z
                dwd.0
                2022-03-23 15:17:54.904	debug	Write warnings for 0: dwd.0.warning = {"regionName":"Kreis und Stadt Passau","type":5,"state":"Bayern","end":1648105200000,"start":1648072800000,"level":2,"description":"Es tritt leichter Frost zwischen 0 °C und -4 °C auf. In Tal- und Muldenlagen sinken die Temperaturen auf Werte bis -6 °C.","instruction":"","stateShort":"BY","altitudeStart":null,"altitudeEnd":null,"headline":"Amtliche WARNUNG vor FROST","event":"FROST"}
                dwd.0
                2022-03-23 15:17:54.804	debug	Sorted Warnings: [{"regionName":"Kreis und Stadt Passau","type":5,"state":"Bayern","end":1648105200000,"start":1648072800000,"level":2,"description":"Es tritt leichter Frost zwischen 0 °C und -4 °C auf. In Tal- und Muldenlagen sinken die Temperaturen auf Werte bis -6 °C.","instruction":"","stateShort":"BY","altitudeStart":null,"altitudeEnd":null,"headline":"Amtliche WARNUNG vor FROST","event":"FROST"}]
                dwd.0
                2022-03-23 15:17:54.803	debug	Find Warnings for Region: Kreis und Stadt Passau
                Edit:
                Jetzt wieder weg.
                M apollon77 2 Replies Last reply Reply Quote 0
                  MCU @sigi234 last edited by MCU
                  @sigi234 Lade mal die DateWeatherDWD v1.0.6.
                  https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/module/statehtml/dateweatherdwd/javascript-dateweatherdwd
                    Schaut Gut aus.
                    16:48:15.105	info	javascript.0 (4156) Stop script script.js.Jarvis.DateWeather1
                    16:48:38.683	info	javascript.0 (4156) Start javascript script.js.Jarvis.DateWeather1
                    16:48:38.705	info	javascript.0 (4156) script.js.Jarvis.DateWeather1: Script "script.js.Jarvis.DateWeather1" wurde für DateWeatherDWD v1.0.6 gestartet!
                    16:48:38.710	info	javascript.0 (4156) script.js.Jarvis.DateWeather1: registered 12 subscriptions and 1 schedule
                    16:48:42.707	info	javascript.0 (4156) script.js.Jarvis.DateWeather1: html neu erstellen
                    16:48:42.708	info	javascript.0 (4156) script.js.Jarvis.DateWeather1: DWD-Adapter ist installiert
                    16:48:42.709	info	javascript.0 (4156) script.js.Jarvis.DateWeather1: Warnung vorhanden
                      apollon77 @sigi234 last edited by
                      @sigi234 Bitte GitHub version versuchen. Ists da weg?
                        sigi234 Forum Testing Most Active @apollon77 last edited by sigi234
                        @apollon77 sagte in HowTo: Zusatz-Programme fuer jarvis v3:
                        Nein, warning0 wird nicht angelegt
                        dwd.0
                        2022-03-23 18:23:04.202	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        dwd.0
                        2022-03-23 18:23:04.201	debug	Plugin sentry destroyed
                        dwd.0
                        2022-03-23 18:23:04.186	debug	Add warning "dwd.0.warning9":
                        dwd.0
                        2022-03-23 18:23:04.136	debug	Write warnings for 9: dwd.0.warning9 = undefined
                        dwd.0
                        2022-03-23 18:23:04.119	debug	Add warning "dwd.0.warning8":
                        dwd.0
                        2022-03-23 18:23:04.089	debug	Write warnings for 8: dwd.0.warning8 = undefined
                        dwd.0
                        2022-03-23 18:23:04.072	debug	Add warning "dwd.0.warning7":
                        dwd.0
                        2022-03-23 18:23:04.042	debug	Write warnings for 7: dwd.0.warning7 = undefined
                        dwd.0
                        2022-03-23 18:23:04.025	debug	Add warning "dwd.0.warning6":
                        dwd.0
                        2022-03-23 18:23:03.993	debug	Write warnings for 6: dwd.0.warning6 = undefined
                        dwd.0
                        2022-03-23 18:23:03.975	debug	Add warning "dwd.0.warning5":
                        dwd.0
                        2022-03-23 18:23:03.942	debug	Write warnings for 5: dwd.0.warning5 = undefined
                        dwd.0
                        2022-03-23 18:23:03.924	debug	Add warning "dwd.0.warning4":
                        dwd.0
                        2022-03-23 18:23:03.804	debug	Write warnings for 4: dwd.0.warning4 = undefined
                        dwd.0
                        2022-03-23 18:23:03.788	debug	Add warning "dwd.0.warning3":
                        dwd.0
                        2022-03-23 18:23:03.759	debug	Write warnings for 3: dwd.0.warning3 = undefined
                        dwd.0
                        2022-03-23 18:23:03.741	debug	Add warning "dwd.0.warning2":
                        dwd.0
                        2022-03-23 18:23:03.711	debug	Write warnings for 2: dwd.0.warning2 = undefined
                        dwd.0
                        2022-03-23 18:23:03.696	debug	Add warning "dwd.0.warning1":
                        dwd.0
                        2022-03-23 18:23:03.669	debug	Write warnings for 1: dwd.0.warning1 = undefined
                        dwd.0
                        2022-03-23 18:23:03.653	debug	Add warning "dwd.0.warning": 2022-03-23T22:00:00.000Z
                        dwd.0
                        2022-03-23 18:23:03.524	debug	Write warnings for 0: dwd.0.warning = {"regionName":"Kreis und Stadt Passau","type":5,"state":"Bayern","end":1648105200000,"start":1648072800000,"level":2,"description":"Es tritt leichter Frost zwischen 0 °C und -4 °C auf. In Tal- und Muldenlagen sinken die Temperaturen auf Werte bis -6 °C.","instruction":"","stateShort":"BY","altitudeStart":null,"altitudeEnd":null,"headline":"Amtliche WARNUNG vor FROST","event":"FROST"}
                        dwd.0
                        2022-03-23 18:23:03.496	debug	Sorted Warnings: [{"regionName":"Kreis und Stadt Passau","type":5,"state":"Bayern","end":1648105200000,"start":1648072800000,"level":2,"description":"Es tritt leichter Frost zwischen 0 °C und -4 °C auf. In Tal- und Muldenlagen sinken die Temperaturen auf Werte bis -6 °C.","instruction":"","stateShort":"BY","altitudeStart":null,"altitudeEnd":null,"headline":"Amtliche WARNUNG vor FROST","event":"FROST"}]
                        dwd.0
                        2022-03-23 18:23:03.495	debug	Find Warnings for Region: Kreis und Stadt Passau
                          @sigi234 Soll ja auch nicht. warning = "warning0". So war es ja vorher auch.
                            apollon77 @MCU last edited by
                            @mcu Ja, Ich hab nicht aufgepasst ... kommt davon wenn man soviel an Adaptern rumfummelt die man selbst nicht geschrieben hat. Da kann man solche Kleinigkeiten übersehen 😞
                              MCU @apollon77 last edited by
                              @apollon77 Wir sind alle dankbar, dass du es kannst und machst. Da passieren auch mal Kleinigkeiten. Also DANKE.
                                Bloody last edited by
                                @MCU
                                Ich hatte bereits Combined, feed und short probiert, funktioniert bei keinem Wert.
                                  MCU @Bloody last edited by
                                  @bloody Falls es dir um die günstigste geht, ist im Adapter schon drin:
                                    MCU @Bloody last edited by MCU
                                    @bloody Also funktioniert bei mir mit dem feed-Wert. Du warst nicht gleichzeitig in der Bearbeitung von jarvis im FrontEnd?
                                    statelistSort('0','13c88101-c6bb-48b6-9347-5122a3ef3bbe','number',false);
                                    statelistSort('0','13c88101-c6bb-48b6-9347-5122a3ef3bbe','number',true);
                                    Habe die Doku nochmal angepasst:
                                    https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/system-effektprog./v3-systemprogramme/statelistsort
                                    evtl F5 drücken.
                                      Bloody @MCU last edited by
                                      @mcu
                                      Danke für die Rückmeldung.
                                      Das Problem war, dass ich zwar den feed Datenpunkt benutzt habe aber noch in den Datenpunkt Eigenschaften gerundet hatte ({"value":"val => parseFloat(val).toFixed(2)"}).
                                      Keine Ahnung, wieso ich das so gemacht hatte, weil es ja den DP short auch gibt. Gabs den schon immer? Naja egal, es geht jetzt.
                                      Hab es jetzt so gelöst.
                                      https://forum.iobroker.net/topic/49776/jarvis-v3-0-0-just-another-remarkable-vis/2364
                                      Dankeschön.
                                        Moin @MCU,
                                        hab doch noch ein Problem.
                                        Es steht nicht immer der billigste Preis oben. Erst wenn ich das Skript neustarte, passt es wieder.
                                        Aber da ist doch ein Trigger drin, falls sich ein Preis ändert, soll sich die Reihenfolge anpassen
                                        oder liege ich falsch?
                                          @bloody Das soll ja so. Soll der teuerste oben sein dann muss man false setzen.
                                            @mcu
                                            Kann leider gerade kein Screenshot machen, da es aktuell mit der Reihenfolge passt (von klein nach groß). Hätte ich vielleicht dazu sagen sollen... Bei mir ist es dann nicht von klein nach groß oder von groß nach klein sortiert, sondern die Preise sind durcheinander gewürfelt.
                                            Beispielsweise so:
                                            1.91
                                            1.95
                                            1.98
                                            1.89
                                            1.70
                                            81.1k
                                            javascript
                                            33
                                            889
                                            207151
