    4. Test Adapter BMW/Mini v2.0.0
      MSPtrs @bahnuhr last edited by MSPtrs
      @tombox @community
      habt ihr das selbe Problem mit den Adapter seit gestern Nachmittag?
      2022-03-17 14:24:08.931 - info: host.raspberrypimodbus "system.adapter.bmw.0" enabled
      2022-03-17 14:24:09.099 - info: host.raspberrypimodbus instance system.adapter.bmw.0 started with pid 27880
      2022-03-17 14:24:12.219 - info: bmw.0 (27880) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.bmw, node: v12.22.6, js-controller: 4.0.19
      2022-03-17 14:24:12.733 - error: bmw.0 (27880) Login failed
      2022-03-17 14:24:12.734 - error: bmw.0 (27880) Error: Request failed with status code 401
      2022-03-17 14:24:12.735 - error: bmw.0 (27880) {"error":"invalid_client","error_description":"Client authentication failed (e.g., login failure, unknown client, no client authentication included or unsupported authentication method)"}
      2022-03-17 14:24:12.736 - error: bmw.0 (27880) Please check username and password or too many logins in 5 minutes
      2022-03-17 14:24:12.737 - error: bmw.0 (27880) Start relogin in 5min
      2022-03-17 14:24:12.738 - error: bmw.0 (27880) undefined
      natürlich hab ich die Logindaten überprüft und den Adapter für über eine Stunde gestoppt.
      Hoffentlich bin ich nicht der einzige...
      EDIT: habs gelöst, der BMW Account hat das Passwort selbstständig geändert👍 🙄
      • bahnuhr
        bahnuhr Forum Testing Most Active @MSPtrs last edited by bahnuhr
        seit heute wieder folgendes im debug:
        bmw.0
        2022-03-24 19:09:09.180	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
        bmw.0
        2022-03-24 19:09:09.180	error	Error: Request failed with status code 400
        bmw.0
        2022-03-24 19:09:09.179	error	Login step 3 failed
        bmw.0
        2022-03-24 19:09:09.070	debug	{"redirect_to":"redirect_uri=com.bmw.connected://oauth?client_id=31c357a0-7a1d-4590-aa99-33b97244d048&response_type=code&scope=openid profile email offline_access smacc vehicle_data perseus dlm svds cesim vsapi remote_services fupo authenticate_user&state=cwU-gIE27j67poy2UcL3KQ&authorization=4VgjSefihLAANDVFMAAlMxAAIwMQ..*"}
        bmw.0
        2022-03-24 19:09:08.701	info	starting. Version 2.5.2 (non-npm: TA2k/ioBroker.bmw) in /opt/iobroker/node_modules/iobroker.bmw, node: v14.19.1, js-controller: 4.0.21
        Bitte bereinigen; oder Rückinfo was ich machen kann/soll.
        Danke.
          tombox @bahnuhr last edited by
          @bahnuhr Der login via app funktioniert ohne Probleme?
          • bahnuhr
            bahnuhr Forum Testing Most Active @tombox last edited by
            @tombox sagte in Test Adapter BMW v2.0.0:
            Jo,
            am Handy bin ich rein gekommen.
            Es steht aber da: aktualisiert vom Fahrzeug am 18.03.22 um 14:32
            Dies ist aber schon alt.
            Funktioniert bei BMW da was nicht ?
              @bahnuhr Auch ausloggen und einloggen geht noch.
              • bahnuhr
                @tombox
                Habe eben mal "aufleuchten" gedrückt.
                Jetzt steht da:
                aktualisiert vom Fahrzeug am 24.03.22 um 19:17
                Das scheint geklappt zu haben.
                jetzt probier ich mal ausloggen.....
                • bahnuhr
                  bahnuhr Forum Testing Most Active @bahnuhr last edited by bahnuhr
                  @bahnuhr sagte in Test Adapter BMW v2.0.0:
                  und ja, das hat auch geklappt.
                  Nachtrag:
                  Adapter bleibt gelb.
                  • bahnuhr
                    @tombox
                    Hat du schon eine Idee?
                    Adapter ist weiterhin gelb.
                    Kann ich irgendwas testen ?
                      tombox @bahnuhr last edited by tombox
                      @bahnuhr bitte die 2.5.3 ausprobieren. Irgendwie wurden die Cookies von BMW falsch konfiguriert und das fand die http library schlecht
                      bahnuhr 1 Reply Last reply Reply Quote 1
                      • bahnuhr
                        2.5.3. installaiert und die Instanz wurde sofort grün.
                        Danke schön für das schnelle reagieren und nachschauen.
                        Du kümmerst dich um deine Adapter (gibt ja auch andere).
                        nochmals Danke.
                        Läuft wieder.
                          Eufi @bahnuhr last edited by
                          Also bei mir funktioniert das Update nicht mehr. Passwort neu gesetzt, Adapter gelöscht und neu installiert.
                          Meldung: Please check username and password or too many logins in 5 minutes
                          Installiert ist die 2.5.3
                          Gibt es irgendwelche Tipps?
                          lobomau 1 Reply Last reply Reply Quote 0
                          • lobomau
                            lobomau @Eufi last edited by
                            @eufi das Offensichtlichste wäre es, den Adapter etwas länger nicht zu benutzen. 5min aus wirst du wahrscheinlich schon probiert haben, oder? Vielleicht mal einen Tag auslassen und nochmal testen?
                              Eufi @lobomau last edited by
                              @lobomau
                              Der war ne Woche aus bis ich es wieder probiert habe jetzt…
                              • lobomau
                                lobomau @Eufi last edited by lobomau
                                @eufi da der Adapter bei mir störungsfrei läuft, müssen wir den Fehler bei dir suchen.
                                Wir können ja einmal die installierten Versionen/Einstellungen vergleichen. Ich habe:
                                • BMW Adapter: 2.5.3
                                • js-controller: 4.0.23
                                • Nodejs: 14.19.1
                                • npm: 6.14.16
                                • Adapter Update interval: 1 min
                                Zu guter Letzt könnte man über die BMW Handy-App neues Passwort vergeben und/oder BMW-Adapter neu installieren.
                                  @lobomau
                                  Sorry für die späte Antwort. Bei mir war leider die letzten Tage leider Stress angesagt...
                                  BMW Adapter: 2.5.3
                                  js-controller: 4.0.15
                                  Nodejs: 14.19.1
                                  npm: 6.14.16
                                  Adapter Update interval: 5 min
                                  Ich versuche mal den js-controller heute upzudaten.
                                  Meinst du es kann daran liegen?
                                    Eufi @Eufi last edited by
                                    @lobomau
                                    Ich habe jetzt noch einmal ein neues Passwort vergeben und jetzt geht es wieder.... ganz dubiose Sache.
                                    Sorry für die Mühe, die ich gemacht habe.
                                    lobomau 1 Reply Last reply Reply Quote 1
                                    • lobomau
                                      Ich glaube der Server/Api hat heute ein Problem. Die Werte über den Adapter kommen sauber rein in ioBroker. Es gibt aber den Fehler im log und ich komme grad nicht per Handy-App auf den BMW:
                                      bmw.0
                                      2022-05-18 14:54:53.649	error	Error: Request failed with status code 500
                                      bmw.0
                                      2022-05-18 14:54:53.648	error	getvehicles v2 failed
                                      bmw.0
                                      2022-05-18 14:54:29.280	error	Error: Request failed with status code 500
                                      bmw.0
                                      2022-05-18 14:54:29.280	error	getvehicles v2 failed
                                      bmw.0
                                      2022-05-18 14:54:24.462	error	Error: Request failed with status code 500
                                      bmw.0
                                      2022-05-18 14:54:24.461	error	getvehicles v2 failed
                                      bmw.0
                                      2022-05-18 14:53:59.191	error	Error: Request failed with status code 500
                                      bmw.0
                                      2022-05-18 14:53:59.190	error	getvehicles v2 failed
                                      bmw.0
                                      2022-05-18 14:53:53.616	error	Error: Request failed with status code 500
                                      bmw.0
                                      2022-05-18 14:53:53.616	error	getvehicles v2 failed
                                      bmw.0
                                      2022-05-18 14:53:21.173	error	Error: Request failed with status code 500
                                      bmw.0
                                      2022-05-18 14:53:21.172	error	getvehicles v2 failed
                                      • bahnuhr
                                        bahnuhr Forum Testing Most Active @lobomau last edited by
                                        @lobomau sagte in Test Adapter BMW v2.0.0:
                                        bei mir das gleiche.
                                        Fehler im log und komme auch nicht auf die app im Handy
                                        • bahnuhr
                                          bahnuhr Forum Testing Most Active last edited by bahnuhr
                                          Fehler hat sich geändert.
                                          Bis 20:07 kam code 500.
                                          jetzt kommt code 429 (to many requests)
                                          bmw.0
                                          2022-05-18 20:26:40.319	error	Error: Request failed with status code 429
                                          bmw.0
                                          2022-05-18 20:26:40.318	error	getvehicles v2 failed
                                          bmw.0
                                          2022-05-18 20:26:40.266	error	Error: Request failed with status code 429
                                          bmw.0
                                          2022-05-18 20:26:40.265	error	getvehicles v2 failed
                                          bmw.0
                                          2022-05-18 20:16:40.387	error	Error: Request failed with status code 429
                                          bmw.0
                                          2022-05-18 20:16:40.386	error	getvehicles v2 failed
                                          bmw.0
                                          2022-05-18 20:16:40.292	error	Error: Request failed with status code 429
                                          bmw.0
                                          2022-05-18 20:16:40.291	error	getvehicles v2 failed
                                          bmw.0
                                          2022-05-18 20:07:40.462	error	Error: Request failed with status code 500
                                          bmw.0
                                          2022-05-18 20:07:40.462	error	getvehicles v2 failed
                                          bmw.0
                                          2022-05-18 20:07:10.363	error	Error: Request failed with status code 500
                                          bmw.0
                                          2022-05-18 20:07:10.362	error	getvehicles v2 failed
                                          bmw.0
                                          2022-05-18 19:57:41.123	error	Error: Request failed with status code 500
                                          bmw.0
                                          2022-05-18 19:57:41.123	error	getvehicles v2 failed
                                          bmw.0
                                          2022-05-18 19:57:10.472	error	Error: Request failed with status code 500
                                          bmw.0
                                          2022-05-18 19:57:10.471	error	getvehicles v2 failed
                                          Liegt hier irgendwo ein Adapter Fehler vor.
                                          Oder liegt es wieder an BMW?
                                          • lobomau
                                            lobomau @bahnuhr last edited by
                                            @bahnuhr da waren die grad am "fertig machen" 🙂 Seit 20:38 Uhr kommen keine errors mehr im log 👍
                                            674
                                            149905
