    4. Test Adapter iobroker.uv-protect 0.3.x
    • simatec
      Ab sofort steht die Version 0.3.1 auf Github und auf npm zur Verfügung.
      Changelog
      0.3.1 (28.06.2021)
      • (simatec) Date / time formatted
      • JohGre
        JohGre last edited by
        Habe den Adapter anstatt openuv installiert, leider funktioniert er nur einmal gleich nach dem Starten, alle weiteren Aufrufe, die ja zeitgesteuert sind, werfen einen Fehler.
        2022-03-05 16:00:00.431 - debug: uv-protect.0 (209986) Redis Objects: Use Redis connection: 10.0.0.227:9001
        2022-03-05 16:00:00.463 - debug: uv-protect.0 (209986) Objects client ready ... initialize now
        2022-03-05 16:00:00.465 - debug: uv-protect.0 (209986) Objects create System PubSub Client
        2022-03-05 16:00:00.466 - debug: uv-protect.0 (209986) Objects create User PubSub Client
        2022-03-05 16:00:00.527 - debug: uv-protect.0 (209986) Objects client initialize lua scripts
        2022-03-05 16:00:00.532 - debug: uv-protect.0 (209986) Objects connected to redis: 10.0.0.227:9001
        2022-03-05 16:00:00.566 - debug: uv-protect.0 (209986) Redis States: Use Redis connection: 10.0.0.227:9000
        2022-03-05 16:00:00.586 - debug: uv-protect.0 (209986) States create System PubSub Client
        2022-03-05 16:00:00.587 - debug: uv-protect.0 (209986) States create User PubSub Client
        2022-03-05 16:00:00.625 - debug: uv-protect.0 (209986) States connected to redis: 10.0.0.227:9000
        2022-03-05 16:00:01.757 - info: uv-protect.0 (209986) starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v14.19.0, js-controller: 4.0.18
        2022-03-05 16:00:01.805 - debug: uv-protect.0 (209986) System language: en
        2022-03-05 16:00:01.805 - debug: uv-protect.0 (209986) System longitude: 13. System latitude: 48.
        2022-03-05 16:00:01.817 - debug: uv-protect.0 (209986) API Request started ...
        2022-03-05 16:00:32.248 - warn: uv-protect.0 (209986) Request error: Error: Request failed with status code 503
        2022-03-05 16:00:38.255 - info: uv-protect.0 (209986) Terminated (NO_ERROR): Without reason
        • FredF
          FredF Most Active Forum Testing @JohGre last edited by
          @johgre
          Und wo ist ein Fehler (error)?
          Die Instanz steht auf Log-Stufe debug - da kommen dann viele Meldungen. Besser umstellen auf info
          JohGre 1 Reply Last reply Reply Quote 0
          • JohGre
            JohGre @FredF last edited by
            @fredf vorletzte Zeile, im ioBroker log zwar ein warn, aber als response ein HTML Error und somit keine Daten
            • FredF
              @johgre Code 503 sagt laut suche, dass der Server nicht antwortet. API key eingetragen?
              • JohGre
                @fredf Ja, API Key ist eingetragen (und auch der richtige) und beim starten werden auch einmalig Daten geholt.
                2022-03-05 14:08:22.246 - debug: uv-protect.0 (207612) Redis Objects: Use Redis connection: 10.0.0.227:9001
                2022-03-05 14:08:22.272 - debug: uv-protect.0 (207612) Objects client ready ... initialize now
                2022-03-05 14:08:22.275 - debug: uv-protect.0 (207612) Objects create System PubSub Client
                2022-03-05 14:08:22.275 - debug: uv-protect.0 (207612) Objects create User PubSub Client
                2022-03-05 14:08:22.312 - debug: uv-protect.0 (207612) Objects client initialize lua scripts
                2022-03-05 14:08:22.316 - debug: uv-protect.0 (207612) Objects connected to redis: 10.0.0.227:9001
                2022-03-05 14:08:22.341 - debug: uv-protect.0 (207612) Redis States: Use Redis connection: 10.0.0.227:9000
                2022-03-05 14:08:22.356 - debug: uv-protect.0 (207612) States create System PubSub Client
                2022-03-05 14:08:22.357 - debug: uv-protect.0 (207612) States create User PubSub Client
                2022-03-05 14:08:22.379 - debug: uv-protect.0 (207612) States connected to redis: 10.0.0.227:9000
                2022-03-05 14:08:23.036 - info: uv-protect.0 (207612) starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v14.19.0, js-controller: 4.0.18
                2022-03-05 14:08:23.072 - debug: uv-protect.0 (207612) System language: en
                2022-03-05 14:08:23.072 - debug: uv-protect.0 (207612) System longitude: 13. System latitude: 48.
                2022-03-05 14:08:23.082 - debug: uv-protect.0 (207612) API Request started ...
                2022-03-05 14:08:23.592 - debug: uv-protect.0 (207612) API Request successfully completed
                2022-03-05 14:08:23.592 - debug: uv-protect.0 (207612) {"result":{"uv":1.8666,"uv_time":"2022-03-05T13:08:23.511Z","uv_max":2.597,"uv_max_time":"2022-03-05T11:17:22.820Z","ozone":346.6,"ozone_time":"2022-03-05T12:04:38.489Z","safe_exposure_time":{"st1":89,"st2":107,"st3":143,"st4":179,"st5":286,"st6":536},"sun_info":{"sun_times":{"solarNoon":"2022-03-05T11:17:22.820Z","nadir":"2022-03-04T23:17:22.820Z","sunrise":"2022-03-05T05:39:49.203Z","sunset":"2022-03-05T16:54:56.436Z","sunriseEnd":"2022-03-05T05:43:03.240Z","sunsetStart":"2022-03-05T16:51:42.399Z","dawn":"2022-03-05T05:08:40.125Z","dusk":"2022-03-05T17:26:05.514Z","nauticalDawn":"2022-03-05T04:32:38.608Z","nauticalDusk":"2022-03-05T18:02:07.031Z","nightEnd":"2022-03-05T03:56:17.360Z","night":"2022-03-05T18:38:28.279Z","goldenHourEnd":"2022-03-05T06:21:47.708Z","goldenHour":"2022-03-05T16:12:57.931Z"},"sun_position":{"azimuth":0.571989127405678,"altitude":0.5310458359058243}}}}
                2022-03-05 14:08:23.837 - debug: uv-protect.0 (207612) API Request done
                2022-03-05 14:08:29.845 - info: uv-protect.0 (207612) Terminated (NO_ERROR): Without reason
                2022-03-05 15:00:00.413 - debug: uv-protect.0 (208702) Redis Objects: Use Redis connection: 10.0.0.227:9001
                2022-03-05 15:00:00.444 - debug: uv-protect.0 (208702) Objects client ready ... initialize now
                2022-03-05 15:00:00.446 - debug: uv-protect.0 (208702) Objects create System PubSub Client
                2022-03-05 15:00:00.447 - debug: uv-protect.0 (208702) Objects create User PubSub Client
                2022-03-05 15:00:00.490 - debug: uv-protect.0 (208702) Objects client initialize lua scripts
                2022-03-05 15:00:00.495 - debug: uv-protect.0 (208702) Objects connected to redis: 10.0.0.227:9001
                2022-03-05 15:00:00.528 - debug: uv-protect.0 (208702) Redis States: Use Redis connection: 10.0.0.227:9000
                2022-03-05 15:00:00.551 - debug: uv-protect.0 (208702) States create System PubSub Client
                2022-03-05 15:00:00.552 - debug: uv-protect.0 (208702) States create User PubSub Client
                2022-03-05 15:00:00.594 - debug: uv-protect.0 (208702) States connected to redis: 10.0.0.227:9000
                2022-03-05 15:00:01.506 - info: uv-protect.0 (208702) starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v14.19.0, js-controller: 4.0.18
                2022-03-05 15:00:01.563 - debug: uv-protect.0 (208702) System language: en
                2022-03-05 15:00:01.563 - debug: uv-protect.0 (208702) System longitude: 13. System latitude: 48.
                2022-03-05 15:00:01.572 - debug: uv-protect.0 (208702) API Request started ...
                2022-03-05 15:00:32.016 - warn: uv-protect.0 (208702) Request error: Error: Request failed with status code 503
                2022-03-05 15:00:38.025 - info: uv-protect.0 (208702) Terminated (NO_ERROR): Without reason
                  ps1304 @simatec last edited by ps1304
                  @simatec erstmal danke für den Adapter - habe ich neu installiert auf iobroker - bekomme für alle Datenpunkte Fehlermeldungen ala:
                  Object uv-protect.0.sun_info.sun_position.altitude is invalid: Default value has to be type "number" but received type "string"
                  System iobroker: 4.0.19node.js 16.14 / NPM 8.3.1 auf proxmox vm installiert
                  Ist der Fehler bekannt?
                  Komplettes Log zum Adapterstart:
                  2022-03-13 15:42:50.792  - info: host.iobroker-master instance system.adapter.uv-protect.0 started with pid 50746
                  2022-03-13 16:42:52.812  - warn: uv-protect.0 (50746) Object uv-protect.0.uv is invalid: Default value has to be type "number" but received type "string"
                  2022-03-13 16:42:52.815  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                  2022-03-13 16:42:52.835  - warn: uv-protect.0 (50746) Object uv-protect.0.uv_max is invalid: Default value has to be type "number" but received type "string"
                  2022-03-13 16:42:52.835  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                  2022-03-13 16:42:52.848  - warn: uv-protect.0 (50746) Object uv-protect.0.ozone is invalid: Default value has to be type "number" but received type "string"
                  2022-03-13 16:42:52.849  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                  2022-03-13 16:42:52.862  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st1 is invalid: Default value has to be type "number" but received type "string"
                  2022-03-13 16:42:52.862  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                  2022-03-13 16:42:52.872  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st2 is invalid: Default value has to be type "number" but received type "string"
                  2022-03-13 16:42:52.873  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                  2022-03-13 16:42:52.883  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st3 is invalid: Default value has to be type "number" but received type "string"
                  2022-03-13 16:42:52.883  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                  2022-03-13 16:42:52.931  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st4 is invalid: Default value has to be type "number" but received type "string"
                  2022-03-13 16:42:52.932  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                  2022-03-13 16:42:52.940  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st5 is invalid: Default value has to be type "number" but received type "string"
                  2022-03-13 16:42:52.940  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                  2022-03-13 16:42:52.948  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st6 is invalid: Default value has to be type "number" but received type "string"
                  2022-03-13 16:42:52.948  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                  2022-03-13 16:42:53.036  - warn: uv-protect.0 (50746) Object uv-protect.0.sun_info.sun_position.azimuth is invalid: Default value has to be type "number" but received type "string"
                  2022-03-13 16:42:53.036  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                  2022-03-13 16:42:53.043  - warn: uv-protect.0 (50746) Object uv-protect.0.sun_info.sun_position.altitude is invalid: Default value has to be type "number" but received type "string"
                  2022-03-13 16:42:53.044  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                  2022-03-13 16:42:53.102  - warn: uv-protect.0 (50746) Object uv-protect.0.uv_alert is invalid: Default value has to be type "boolean" but received type "string"
                  2022-03-13 16:42:53.102  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                  2022-03-13 16:42:53.110  - warn: uv-protect.0 (50746) Object uv-protect.0.uv_warn is invalid: Default value has to be type "boolean" but received type "string"
                  2022-03-13 16:42:53.110  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                  2022-03-13 16:42:53.119  - info: uv-protect.0 (50746) starting. Version 0.3.4 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v16.14.0, js-controller: 4.0.19```
                  • simatec
                    simatec Developer Most Active @ps1304 last edited by
                    @ps1304
                    Das sind nur Warnungen… Fixe ich in der nächsten Version
                    P Z 2 Replies Last reply Reply Quote 0
                      @simatec danke dir für die schnelle antwort und deinen adapter
                      • Z
                        zolpetol @simatec last edited by zolpetol
                        @simatec
                        Bei mir leider auch nur aktuelle Daten direkt nach dem Starten des Adapter, danach folgende Meldungen und keine Aktualisierung mehr:
                        APi-Key ist eingetragen
                        16:43h: zur Zeit funktioniert die Aktualisierung
                        19:19h. wieder vorbei Code 403 oder auch Code 500
                        simatec 2 Replies Last reply Reply Quote 0
                        • simatec
                          simatec Developer Most Active @zolpetol last edited by
                          @zolpetol Du hast nur eine gewisse Anzahl an API Abrufen innerhalb von 24 Stunden mit der freien Version.
                          Du solltest dementsprechend den Zeitintervall nicht so klein setzen
                          • simatec
                            @zolpetol Zitat auf der Page von OpenUV:
                            Need more than 50 daily requests? Check our Extended Plan for just $15 USD/month. Payments and billing processed by Stripe.
                            • Z
                              @simatec
                              Danke für die Info! Das Zeitintervall wurde gemäß dieser Info eingestellt:
                              • simatec
                                @zolpetol Dann sollte es nun funktionieren ...
                                • JohGre
                                  @zolpetol sagte in Test Adapter iobroker.uv-protect 0.3.x:
                                  @simatec
                                  Hast du das Problem schon lösen können? Auch bei mir immer wieder ein 403 trotz neuem Key. Werd den Adapter wohl wieder deaktivieren
                                  • simatec
                                    simatec Developer Most Active @JohGre last edited by
                                    @johgre Wie oft holst du die Daten?
                                    Mit der kostenlosen Version dieser API kannst du maximal 50 Anfragen pro Tag starten.
                                    Wenn du mehr abfragen hast, bekommst du diesen fehler.
                                    • JohGre
                                      JohGre @simatec last edited by
                                      @simatec Default-Einstellung des Adapters
                                      • simatec
                                        @johgre Dann ist die API sicher gerade nicht erreichbar ... Was aber nicht am Adapter liegt.
                                        Es ist ja auch nur eine reine Warnung und nix böses
                                        • Albert K
                                          Albert K @simatec last edited by
                                          @simatec
                                          Vielen Dank für den Adapter!!! 👍 👍 👍
                                          Hatte mit dem open-uv Adapter mehr und mehr Probleme (ständige Abstürze). Und meine Rollladen Steuerung zur Beschattung basiert auf dem berechneten lokalen UVI Wert.
                                          Jetzt klappt das wieder Super!
                                          viele Grüße
                                          • Jörg Knechten
                                            Jörg Knechten last edited by
                                            Hi der letzte Eintrag ist schon etwas her, aber ich versuche es einfach mal.
                                            Erstmal vielen Dank für die Arbeit, die in dem Adapter steckt. Für uns extrem hilfreich. da meine Frau Lupus hat und somit Sonne bzw. hohe UV-Strahlung meiden soll.
                                            Leider habe ich ein Problem. Die Werte aktualisieren sich bei mir nur, wenn ich den Adapter neu starte. Aktualisierung, wie empfohlen, alle 60 Min. Das Protokoll spuckt folgendes aus.
                                            host.vmiob
                                            2022-08-13 07:00:12.503	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                                            uv-protect.0
                                            2022-08-13 07:00:11.988	info	Terminated (NO_ERROR): Without reason
                                            uv-protect.0
                                            2022-08-13 07:00:05.984	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                            uv-protect.0
                                            2022-08-13 07:00:00.909	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                            host.vmiob
                                            2022-08-13 07:00:00.164	info	instance system.adapter.uv-protect.0 started with pid 21308
                                            host.vmiob
                                            2022-08-13 06:00:12.351	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                                            uv-protect.0
                                            2022-08-13 06:00:11.836	info	Terminated (NO_ERROR): Without reason
                                            uv-protect.0
                                            2022-08-13 06:00:05.832	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                            uv-protect.0
                                            2022-08-13 06:00:00.758	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                            host.vmiob
                                            2022-08-13 06:00:00.019	info	instance system.adapter.uv-protect.0 started with pid 21185
                                            host.vmiob
                                            2022-08-13 05:00:12.372	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                                            uv-protect.0
                                            2022-08-13 05:00:11.857	info	Terminated (NO_ERROR): Without reason
                                            uv-protect.0
                                            2022-08-13 05:00:05.853	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                            uv-protect.0
                                            2022-08-13 05:00:00.780	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                            host.vmiob
                                            2022-08-13 05:00:00.019	info	instance system.adapter.uv-protect.0 started with pid 21159
                                            mercedesme.0
                                            2022-08-13 04:58:46.419	info	Lost WebSocket connection. Reconnect WebSocket
                                            host.vmiob
                                            2022-08-13 04:00:12.354	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                                            uv-protect.0
                                            2022-08-13 04:00:11.840	info	Terminated (NO_ERROR): Without reason
                                            uv-protect.0
                                            2022-08-13 04:00:05.836	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                            uv-protect.0
                                            2022-08-13 04:00:00.762	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                            host.vmiob
                                            2022-08-13 04:00:00.019	info	instance system.adapter.uv-protect.0 started with pid 21131
                                            host.vmiob
                                            2022-08-13 03:00:12.382	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                                            uv-protect.0
                                            2022-08-13 03:00:11.867	info	Terminated (NO_ERROR): Without reason
                                            uv-protect.0
                                            2022-08-13 03:00:05.862	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                            uv-protect.0
                                            2022-08-13 03:00:00.786	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                            host.vmiob
                                            2022-08-13 03:00:00.018	info	instance system.adapter.uv-protect.0 started with pid 21090
                                            host.vmiob
                                            2022-08-13 02:00:12.353	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                                            uv-protect.0
                                            2022-08-13 02:00:11.840	info	Terminated (NO_ERROR): Without reason
                                            uv-protect.0
                                            2022-08-13 02:00:05.835	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                            uv-protect.0
                                            2022-08-13 02:00:00.761	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                            host.vmiob
                                            2022-08-13 02:00:00.021	info	instance system.adapter.uv-protect.0 started with pid 21051
                                            Das Problem scheint der Timout zu sein. Bin allerdings Newb bzgl. ioBroker.
                                            Vielen Dank im Voraus!
                                            41
                                            3250
