    4. [gelöst] SSD am Raspberry: nach kurzer Zeit nicht erreichbar
    • wendy2702
      wendy2702 @DGR last edited by
      @dgr /var/log
        Thomas Braun Most Active @DGR last edited by
        @dgr
        Du kannst auch mal in einer shell mit
        dmesg -wT
        schauen was da passiert.
          paul53 @DGR last edited by
          @dgr sagte: die SSD habe ich in den noch vorhandenen Adapter gesteckt:
          An USB 3 angeschlossen? Falls ja, probiere es mal an USB 2.
            DGR @wendy2702 last edited by
            @wendy2702
            Mar 27 12:04:42 raspi1 dhcpcd[830]: wlan0: adding route to 192.168.196.0/24
            Mar 27 12:04:42 raspi1 dhcpcd[830]: wlan0: adding default route via 192.168.196.13
            Mar 27 12:04:42 raspi1 avahi-daemon[399]: New relevant interface wlan0.IPv4 for mDNS.
            Mar 27 12:04:42 raspi1 avahi-daemon[399]: Registering new address record for 192.168.196.187 on wlan0.IPv4.
            Mar 27 12:04:42 raspi1 bthelper[703]: Changing power on succeeded
            Mar 27 12:04:42 raspi1 bthelper[703]: [#001#033[0;93m#002CHG#001#033[0m#002] Controller DC:A6:32:4F:8F:BC Powered: yes
            Mar 27 12:04:42 raspi1 systemd[1]: Stopping Network Time Synchronization...
            Mar 27 12:04:42 raspi1 systemd[1]: systemd-timesyncd.service: Succeeded.
            Mar 27 12:04:42 raspi1 systemd[1]: Stopped Network Time Synchronization.
            Mar 27 12:04:42 raspi1 systemd[1]: Starting Network Time Synchronization...
            Mar 27 12:04:42 raspi1 systemd[1]: Started Network Time Synchronization.
            Mar 27 12:04:42 raspi1 bash[732]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.admin.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.javascript.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.email.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.history.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.tr-064.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.ping.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.discovery.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.backitup.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.fullcalendar.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.deconz.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.wled.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.signal-cmb.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.web.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis-hqwidgets.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis-material-advanced.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis-plumb.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis-fancyswitch.0" for host "raspi1"
            Mar 27 12:04:42 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis-metro.0" for host "raspi1"
            Mar 27 12:04:43 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis-justgage.0" for host "raspi1"
            Mar 27 12:04:43 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis-jqui-mfd.0" for host "raspi1"
            Mar 27 12:04:43 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis-bars.0" for host "raspi1"
            Mar 27 12:04:43 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis-canvas-gauges.0" for host "raspi1"
            Mar 27 12:04:43 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis-colorpicker.0" for host "raspi1"
            Mar 27 12:04:43 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis-history.0" for host "raspi1"
            Mar 27 12:04:43 raspi1 bash[732]: host.raspi1 check instance "system.adapter.info.0" for host "raspi1"
            Mar 27 12:04:43 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis-lcars.0" for host "raspi1"
            Mar 27 12:04:43 raspi1 bash[732]: host.raspi1 check instance "system.adapter.vis-timeandweather.0" for host "raspi1"
            Mar 27 12:04:45 raspi1 bash[732]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
            Mar 27 12:04:45 raspi1 bash[732]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
            Mar 27 12:04:50 raspi1 bash[732]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
            Mar 27 12:04:50 raspi1 bash[732]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
            Mar 27 12:04:52 raspi1 kernel: [   31.720982] cam-dummy-reg: disabling
            Mar 27 12:04:52 raspi1 kernel: [   31.720996] vcc-sd: disabling
            Mar 27 12:04:52 raspi1 kernel: [   31.721002] cam1-reg: disabling
            Mar 27 12:04:52 raspi1 systemd-timesyncd[1077]: Timed out waiting for reply from 116.203.151.74:123 (0.debian.pool.ntp.org).
            Mar 27 12:04:52 raspi1 systemd-timesyncd[1077]: Initial synchronization to time server 129.70.132.33:123 (0.debian.pool.ntp.org).
            Mar 27 12:04:53 raspi1 systemd[1]: Created slice User Slice of UID 1000.
            Mar 27 12:04:53 raspi1 systemd[1]: Starting User Runtime Directory /run/user/1000...
            Mar 27 12:04:53 raspi1 systemd[1]: Finished User Runtime Directory /run/user/1000.
            Mar 27 12:04:53 raspi1 systemd[1]: Starting User Manager for UID 1000...
            nur ein Ausschnitt. keine Ahnung, ob da was Relevantes dabei ist.
              DGR @paul53 last edited by
              beides schon probiert
                DGR @Thomas Braun last edited by
                @thomas-braun said in SSD am Raspberry: System nach kurzer Zeit nicht erreichbar:
                dmesg -wT
                [Sun Mar 27 12:04:20 2022] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
                [Sun Mar 27 12:04:20 2022] Linux version 5.10.103-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1530 SMP PREEMPT Tue Mar 8 13:06:35 GMT 2022
                [Sun Mar 27 12:04:20 2022] random: fast init done
                [Sun Mar 27 12:04:20 2022] Machine model: Raspberry Pi 4 Model B Rev 1.1
                [Sun Mar 27 12:04:20 2022] efi: UEFI not found.
                [Sun Mar 27 12:04:20 2022] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
                [Sun Mar 27 12:04:20 2022] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                [Sun Mar 27 12:04:20 2022] Zone ranges:
                [Sun Mar 27 12:04:20 2022]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
                [Sun Mar 27 12:04:20 2022]   DMA32    [mem 0x0000000040000000-0x00000000fbffffff]
                [Sun Mar 27 12:04:20 2022]   Normal   empty
                [Sun Mar 27 12:04:20 2022] Movable zone start for each node
                [Sun Mar 27 12:04:20 2022] Early memory node ranges
                [Sun Mar 27 12:04:20 2022]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
                [Sun Mar 27 12:04:20 2022]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                [Sun Mar 27 12:04:20 2022] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
                [Sun Mar 27 12:04:20 2022] On node 0 totalpages: 1012480
                [Sun Mar 27 12:04:20 2022]   DMA zone: 3788 pages used for memmap
                [Sun Mar 27 12:04:20 2022]   DMA zone: 0 pages reserved
                [Sun Mar 27 12:04:20 2022]   DMA zone: 242432 pages, LIFO batch:63
                [Sun Mar 27 12:04:20 2022]   DMA32 zone: 12032 pages used for memmap
                [Sun Mar 27 12:04:20 2022]   DMA32 zone: 770048 pages, LIFO batch:63
                [Sun Mar 27 12:04:20 2022] On node 0, zone DMA32: 256 pages in unavailable ranges
                [Sun Mar 27 12:04:20 2022] percpu: Embedded 32 pages/cpu s91416 r8192 d31464 u131072
                [Sun Mar 27 12:04:20 2022] pcpu-alloc: s91416 r8192 d31464 u131072 alloc=32*4096
                [Sun Mar 27 12:04:20 2022] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                [Sun Mar 27 12:04:20 2022] Detected PIPT I-cache on CPU0
                [Sun Mar 27 12:04:20 2022] CPU features: detected: Spectre-v2
                [Sun Mar 27 12:04:20 2022] CPU features: detected: Spectre-v4
                [Sun Mar 27 12:04:20 2022] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
                [Sun Mar 27 12:04:20 2022] Built 1 zonelists, mobility grouping on.  Total pages: 996660
                [Sun Mar 27 12:04:20 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:4F:8F:BA vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=4cacc907-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Sun Mar 27 12:04:20 2022] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
                [Sun Mar 27 12:04:20 2022] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
                [Sun Mar 27 12:04:20 2022] mem auto-init: stack:off, heap alloc:off, heap free:off
                [Sun Mar 27 12:04:20 2022] software IO TLB: mapped [mem 0x0000000037300000-0x000000003b300000] (64MB)
                [Sun Mar 27 12:04:20 2022] Memory: 3553680K/4049920K available (11136K kernel code, 1950K rwdata, 3988K rodata, 3712K init, 1253K bss, 168560K reserved, 327680K cma-reserved)
                [Sun Mar 27 12:04:20 2022] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                [Sun Mar 27 12:04:20 2022] ftrace: allocating 36803 entries in 144 pages
                [Sun Mar 27 12:04:20 2022] ftrace: allocated 144 pages with 2 groups
                [Sun Mar 27 12:04:20 2022] rcu: Preemptible hierarchical RCU implementation.
                [Sun Mar 27 12:04:20 2022] rcu:         RCU event tracing is enabled.
                [Sun Mar 27 12:04:20 2022] rcu:         RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
                [Sun Mar 27 12:04:20 2022]      Trampoline variant of Tasks RCU enabled.
                [Sun Mar 27 12:04:20 2022]      Rude variant of Tasks RCU enabled.
                [Sun Mar 27 12:04:20 2022]      Tracing variant of Tasks RCU enabled.
                [Sun Mar 27 12:04:20 2022] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
                [Sun Mar 27 12:04:20 2022] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
                [Sun Mar 27 12:04:20 2022] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
                [Sun Mar 27 12:04:20 2022] GIC: Using split EOI/Deactivate mode
                [Sun Mar 27 12:04:20 2022] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 10)
                [Sun Mar 27 12:04:20 2022] random: get_random_bytes called from start_kernel+0x3b0/0x570 with crng_init=1
                [Sun Mar 27 12:04:20 2022] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                [Sun Mar 27 12:04:20 2022] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                [Sun Mar 27 12:04:20 2022] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                [Sun Mar 27 12:04:20 2022] Console: colour dummy device 80x25
                [Sun Mar 27 12:04:20 2022] printk: console [tty1] enabled
                [Sun Mar 27 12:04:20 2022] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
                [Sun Mar 27 12:04:20 2022] pid_max: default: 32768 minimum: 301
                [Sun Mar 27 12:04:20 2022] LSM: Security Framework initializing
                [Sun Mar 27 12:04:20 2022] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
                [Sun Mar 27 12:04:20 2022] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
                [Sun Mar 27 12:04:20 2022] cgroup: Disabling memory control group subsystem
                [Sun Mar 27 12:04:20 2022] rcu: Hierarchical SRCU implementation.
                [Sun Mar 27 12:04:20 2022] EFI services will not be available.
                [Sun Mar 27 12:04:20 2022] smp: Bringing up secondary CPUs ...
                [Sun Mar 27 12:04:20 2022] Detected PIPT I-cache on CPU1
                [Sun Mar 27 12:04:20 2022] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
                [Sun Mar 27 12:04:20 2022] Detected PIPT I-cache on CPU2
                [Sun Mar 27 12:04:20 2022] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
                [Sun Mar 27 12:04:20 2022] Detected PIPT I-cache on CPU3
                [Sun Mar 27 12:04:20 2022] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
                [Sun Mar 27 12:04:20 2022] smp: Brought up 1 node, 4 CPUs
                [Sun Mar 27 12:04:20 2022] SMP: Total of 4 processors activated.
                [Sun Mar 27 12:04:20 2022] CPU features: detected: 32-bit EL0 Support
                [Sun Mar 27 12:04:20 2022] CPU features: detected: CRC32 instructions
                [Sun Mar 27 12:04:20 2022] CPU features: detected: 32-bit EL1 Support
                [Sun Mar 27 12:04:20 2022] CPU: All CPU(s) started at EL2
                [Sun Mar 27 12:04:20 2022] alternatives: patching kernel code
                [Sun Mar 27 12:04:20 2022] devtmpfs: initialized
                [Sun Mar 27 12:04:20 2022] Enabled cp15_barrier support
                [Sun Mar 27 12:04:20 2022] Enabled setend support
                [Sun Mar 27 12:04:20 2022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
                [Sun Mar 27 12:04:20 2022] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                [Sun Mar 27 12:04:20 2022] pinctrl core: initialized pinctrl subsystem
                [Sun Mar 27 12:04:20 2022] DMI not present or invalid.
                [Sun Mar 27 12:04:20 2022] NET: Registered protocol family 16
                [Sun Mar 27 12:04:20 2022] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
                [Sun Mar 27 12:04:20 2022] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
                [Sun Mar 27 12:04:20 2022] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
                [Sun Mar 27 12:04:20 2022] audit: initializing netlink subsys (disabled)
                [Sun Mar 27 12:04:20 2022] audit: type=2000 audit(0.068:1): state=initialized audit_enabled=0 res=1
                [Sun Mar 27 12:04:20 2022] thermal_sys: Registered thermal governor 'step_wise'
                [Sun Mar 27 12:04:20 2022] cpuidle: using governor menu
                [Sun Mar 27 12:04:20 2022] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
                [Sun Mar 27 12:04:20 2022] ASID allocator initialised with 65536 entries
                [Sun Mar 27 12:04:20 2022] Serial: AMBA PL011 UART driver
                [Sun Mar 27 12:04:20 2022] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                [Sun Mar 27 12:04:20 2022] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-01-20T13:56:48, variant start
                [Sun Mar 27 12:04:20 2022] raspberrypi-firmware soc:firmware: Firmware hash is bd88f66f8952d34e4e0613a85c7a6d3da49e13e2
                [Sun Mar 27 12:04:20 2022] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                [Sun Mar 27 12:04:20 2022] vgaarb: loaded
                [Sun Mar 27 12:04:20 2022] SCSI subsystem initialized
                [Sun Mar 27 12:04:20 2022] usbcore: registered new interface driver usbfs
                [Sun Mar 27 12:04:20 2022] usbcore: registered new interface driver hub
                [Sun Mar 27 12:04:20 2022] usbcore: registered new device driver usb
                [Sun Mar 27 12:04:20 2022] usb_phy_generic phy: supply vcc not found, using dummy regulator
                [Sun Mar 27 12:04:20 2022] clocksource: Switched to clocksource arch_sys_counter
                [Sun Mar 27 12:04:21 2022] VFS: Disk quotas dquot_6.6.0
                [Sun Mar 27 12:04:21 2022] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
                [Sun Mar 27 12:04:21 2022] FS-Cache: Loaded
                [Sun Mar 27 12:04:21 2022] CacheFiles: Loaded
                [Sun Mar 27 12:04:21 2022] NET: Registered protocol family 2
                [Sun Mar 27 12:04:21 2022] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
                [Sun Mar 27 12:04:21 2022] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
                [Sun Mar 27 12:04:21 2022] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
                [Sun Mar 27 12:04:21 2022] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
                [Sun Mar 27 12:04:21 2022] TCP: Hash tables configured (established 32768 bind 32768)
                [Sun Mar 27 12:04:21 2022] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
                [Sun Mar 27 12:04:21 2022] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
                [Sun Mar 27 12:04:21 2022] NET: Registered protocol family 1
                [Sun Mar 27 12:04:21 2022] RPC: Registered named UNIX socket transport module.
                [Sun Mar 27 12:04:21 2022] RPC: Registered udp transport module.
                [Sun Mar 27 12:04:21 2022] RPC: Registered tcp transport module.
                [Sun Mar 27 12:04:21 2022] RPC: Registered tcp NFSv4.1 backchannel transport module.
                [Sun Mar 27 12:04:21 2022] PCI: CLS 0 bytes, default 64
                [Sun Mar 27 12:04:21 2022] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
                [Sun Mar 27 12:04:21 2022] kvm [1]: IPA Size Limit: 44 bits
                [Sun Mar 27 12:04:21 2022] kvm [1]: vgic interrupt IRQ9
                [Sun Mar 27 12:04:21 2022] kvm [1]: Hyp mode initialized successfully
                [Sun Mar 27 12:04:21 2022] Initialise system trusted keyrings
                [Sun Mar 27 12:04:21 2022] workingset: timestamp_bits=46 max_order=20 bucket_order=0
                [Sun Mar 27 12:04:21 2022] zbud: loaded
                [Sun Mar 27 12:04:21 2022] FS-Cache: Netfs 'nfs' registered for caching
                [Sun Mar 27 12:04:21 2022] NFS: Registering the id_resolver key type
                [Sun Mar 27 12:04:21 2022] Key type id_resolver registered
                [Sun Mar 27 12:04:21 2022] Key type id_legacy registered
                [Sun Mar 27 12:04:21 2022] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                [Sun Mar 27 12:04:21 2022] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                [Sun Mar 27 12:04:21 2022] Key type asymmetric registered
                [Sun Mar 27 12:04:21 2022] Asymmetric key parser 'x509' registered
                [Sun Mar 27 12:04:21 2022] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                [Sun Mar 27 12:04:21 2022] io scheduler mq-deadline registered
                [Sun Mar 27 12:04:21 2022] io scheduler kyber registered
                [Sun Mar 27 12:04:21 2022] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                [Sun Mar 27 12:04:21 2022] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                [Sun Mar 27 12:04:21 2022] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                [Sun Mar 27 12:04:21 2022] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                [Sun Mar 27 12:04:21 2022] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                [Sun Mar 27 12:04:21 2022] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                [Sun Mar 27 12:04:21 2022] pci_bus 0000:00: root bus resource [bus 00-ff]
                [Sun Mar 27 12:04:21 2022] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                [Sun Mar 27 12:04:21 2022] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                [Sun Mar 27 12:04:21 2022] pci 0000:00:00.0: PME# supported from D0 D3hot
                [Sun Mar 27 12:04:21 2022] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
                [Sun Mar 27 12:04:21 2022] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                [Sun Mar 27 12:04:21 2022] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                [Sun Mar 27 12:04:21 2022] pci 0000:01:00.0: PME# supported from D0 D3cold
                [Sun Mar 27 12:04:21 2022] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
                [Sun Mar 27 12:04:21 2022] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                [Sun Mar 27 12:04:21 2022] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                [Sun Mar 27 12:04:21 2022] pci 0000:00:00.0: PCI bridge to [bus 01]
                [Sun Mar 27 12:04:21 2022] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                [Sun Mar 27 12:04:21 2022] iproc-rng200 fe104000.rng: hwrng registered
                [Sun Mar 27 12:04:21 2022] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
                [Sun Mar 27 12:04:21 2022] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                [Sun Mar 27 12:04:21 2022] cacheinfo: Unable to detect cache hierarchy for CPU 0
                [Sun Mar 27 12:04:21 2022] brd: module loaded
                [Sun Mar 27 12:04:21 2022] loop: module loaded
                [Sun Mar 27 12:04:21 2022] Loading iSCSI transport class v2.0-870.
                [Sun Mar 27 12:04:21 2022] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                [Sun Mar 27 12:04:21 2022] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                [Sun Mar 27 12:04:21 2022] usbcore: registered new interface driver r8152
                [Sun Mar 27 12:04:21 2022] usbcore: registered new interface driver lan78xx
                [Sun Mar 27 12:04:21 2022] usbcore: registered new interface driver smsc95xx
                [Sun Mar 27 12:04:21 2022] pci 0000:00:00.0: enabling device (0000 -> 0002)
                [Sun Mar 27 12:04:21 2022] xhci_hcd 0000:01:00.0: enabling device (0000 -> 0002)
                [Sun Mar 27 12:04:21 2022] xhci_hcd 0000:01:00.0: xHCI Host Controller
                [Sun Mar 27 12:04:21 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                [Sun Mar 27 12:04:21 2022] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00000e0000000890
                [Sun Mar 27 12:04:21 2022] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
                [Sun Mar 27 12:04:21 2022] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                [Sun Mar 27 12:04:21 2022] usb usb1: Product: xHCI Host Controller
                [Sun Mar 27 12:04:21 2022] usb usb1: Manufacturer: Linux 5.10.103-v8+ xhci-hcd
                [Sun Mar 27 12:04:21 2022] usb usb1: SerialNumber: 0000:01:00.0
                [Sun Mar 27 12:04:21 2022] hub 1-0:1.0: USB hub found
                [Sun Mar 27 12:04:21 2022] hub 1-0:1.0: 1 port detected
                [Sun Mar 27 12:04:21 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                [Sun Mar 27 12:04:21 2022] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                [Sun Mar 27 12:04:21 2022] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
                [Sun Mar 27 12:04:21 2022] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                [Sun Mar 27 12:04:21 2022] usb usb2: Product: xHCI Host Controller
                [Sun Mar 27 12:04:21 2022] usb usb2: Manufacturer: Linux 5.10.103-v8+ xhci-hcd
                [Sun Mar 27 12:04:21 2022] usb usb2: SerialNumber: 0000:01:00.0
                [Sun Mar 27 12:04:21 2022] hub 2-0:1.0: USB hub found
                [Sun Mar 27 12:04:21 2022] hub 2-0:1.0: 4 ports detected
                [Sun Mar 27 12:04:21 2022] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                [Sun Mar 27 12:04:21 2022] dwc_otg: FIQ enabled
                [Sun Mar 27 12:04:21 2022] dwc_otg: NAK holdoff enabled
                [Sun Mar 27 12:04:21 2022] dwc_otg: FIQ split-transaction FSM enabled
                [Sun Mar 27 12:04:21 2022] Module dwc_common_port init
                [Sun Mar 27 12:04:21 2022] usbcore: registered new interface driver uas
                [Sun Mar 27 12:04:21 2022] usbcore: registered new interface driver usb-storage
                [Sun Mar 27 12:04:21 2022] mousedev: PS/2 mouse device common for all mice
                [Sun Mar 27 12:04:21 2022] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                [Sun Mar 27 12:04:21 2022] sdhci: Secure Digital Host Controller Interface driver
                [Sun Mar 27 12:04:21 2022] sdhci: Copyright(c) Pierre Ossman
                [Sun Mar 27 12:04:21 2022] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                [Sun Mar 27 12:04:21 2022] sdhci-pltfm: SDHCI platform and OF driver helper
                [Sun Mar 27 12:04:21 2022] ledtrig-cpu: registered to indicate activity on CPUs
                [Sun Mar 27 12:04:21 2022] hid: raw HID events driver (C) Jiri Kosina
                [Sun Mar 27 12:04:21 2022] usbcore: registered new interface driver usbhid
                [Sun Mar 27 12:04:21 2022] usbhid: USB HID core driver
                [Sun Mar 27 12:04:21 2022] ashmem: initialized
                [Sun Mar 27 12:04:21 2022] Initializing XFRM netlink socket
                [Sun Mar 27 12:04:21 2022] NET: Registered protocol family 17
                [Sun Mar 27 12:04:21 2022] Key type dns_resolver registered
                [Sun Mar 27 12:04:21 2022] registered taskstats version 1
                [Sun Mar 27 12:04:21 2022] Loading compiled-in X.509 certificates
                [Sun Mar 27 12:04:21 2022] Key type ._fscrypt registered
                [Sun Mar 27 12:04:21 2022] Key type .fscrypt registered
                [Sun Mar 27 12:04:21 2022] Key type fscrypt-provisioning registered
                [Sun Mar 27 12:04:21 2022] uart-pl011 fe201000.serial: there is not valid maps for state default
                [Sun Mar 27 12:04:21 2022] uart-pl011 fe201000.serial: cts_event_workaround enabled
                [Sun Mar 27 12:04:21 2022] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 23, base_baud = 0) is a PL011 rev2
                [Sun Mar 27 12:04:21 2022] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                [Sun Mar 27 12:04:21 2022] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                [Sun Mar 27 12:04:21 2022] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                [Sun Mar 27 12:04:21 2022] of_cfs_init
                [Sun Mar 27 12:04:21 2022] of_cfs_init: OK
                [Sun Mar 27 12:04:21 2022] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                [Sun Mar 27 12:04:21 2022] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                [Sun Mar 27 12:04:21 2022] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                [Sun Mar 27 12:04:21 2022] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
                [Sun Mar 27 12:04:21 2022] Waiting for root device PARTUUID=4cacc907-02...
                [Sun Mar 27 12:04:21 2022] mmc1: new high speed SDIO card at address 0001
                [Sun Mar 27 12:04:21 2022] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                [Sun Mar 27 12:04:21 2022] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                [Sun Mar 27 12:04:21 2022] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                [Sun Mar 27 12:04:21 2022] usb 1-1: Product: USB2.0 Hub
                [Sun Mar 27 12:04:21 2022] hub 1-1:1.0: USB hub found
                [Sun Mar 27 12:04:21 2022] hub 1-1:1.0: 4 ports detected
                [Sun Mar 27 12:04:22 2022] usb 1-1.2: new high-speed USB device number 3 using xhci_hcd
                [Sun Mar 27 12:04:22 2022] usb 1-1.2: New USB device found, idVendor=1908, idProduct=0226, bcdDevice= 1.11
                [Sun Mar 27 12:04:22 2022] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                [Sun Mar 27 12:04:22 2022] usb-storage 1-1.2:1.0: USB Mass Storage device detected
                [Sun Mar 27 12:04:22 2022] scsi host0: usb-storage 1-1.2:1.0
                [Sun Mar 27 12:04:22 2022] usb 1-1.3: new high-speed USB device number 4 using xhci_hcd
                [Sun Mar 27 12:04:22 2022] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=9210, bcdDevice=21.00
                [Sun Mar 27 12:04:22 2022] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                [Sun Mar 27 12:04:22 2022] usb 1-1.3: Product: RTL9210B-CG
                [Sun Mar 27 12:04:22 2022] usb 1-1.3: Manufacturer: Realtek
                [Sun Mar 27 12:04:22 2022] usb 1-1.3: SerialNumber: 012345678931
                [Sun Mar 27 12:04:22 2022] usb-storage 1-1.3:1.0: USB Mass Storage device detected
                [Sun Mar 27 12:04:22 2022] scsi host1: usb-storage 1-1.3:1.0
                [Sun Mar 27 12:04:22 2022] usb 1-1.4: new full-speed USB device number 5 using xhci_hcd
                [Sun Mar 27 12:04:23 2022] usb 1-1.4: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
                [Sun Mar 27 12:04:23 2022] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                [Sun Mar 27 12:04:23 2022] usb 1-1.4: Product: ConBee II
                [Sun Mar 27 12:04:23 2022] usb 1-1.4: Manufacturer: dresden elektronik ingenieurtechnik GmbH
                [Sun Mar 27 12:04:23 2022] usb 1-1.4: SerialNumber: DE2130518
                [Sun Mar 27 12:04:23 2022] scsi 0:0:0:0: Direct-Access     Generic  Mass-Storage     1.11 PQ: 0 ANSI: 2
                [Sun Mar 27 12:04:23 2022] scsi 1:0:0:0: Direct-Access     Realtek  RTL9210B NVME    1.00 PQ: 0 ANSI: 6
                [Sun Mar 27 12:04:23 2022] sd 1:0:0:0: [sdb] 250069680 512-byte logical blocks: (128 GB/119 GiB)
                [Sun Mar 27 12:04:23 2022] sd 1:0:0:0: [sdb] Write Protect is off
                [Sun Mar 27 12:04:23 2022] sd 1:0:0:0: [sdb] Mode Sense: 37 00 00 08
                [Sun Mar 27 12:04:23 2022] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
                [Sun Mar 27 12:04:23 2022]  sdb: sdb1 sdb2
                [Sun Mar 27 12:04:23 2022] sd 1:0:0:0: [sdb] Attached SCSI disk
                [Sun Mar 27 12:04:24 2022] sd 0:0:0:0: [sda] 124735488 512-byte logical blocks: (63.9 GB/59.5 GiB)
                [Sun Mar 27 12:04:24 2022] sd 0:0:0:0: [sda] Write Protect is off
                [Sun Mar 27 12:04:24 2022] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
                [Sun Mar 27 12:04:24 2022] sd 0:0:0:0: [sda] No Caching mode page found
                [Sun Mar 27 12:04:24 2022] sd 0:0:0:0: [sda] Assuming drive cache: write through
                [Sun Mar 27 12:04:24 2022]  sda: sda1
                [Sun Mar 27 12:04:24 2022] sd 0:0:0:0: [sda] Attached SCSI removable disk
                [Sun Mar 27 12:04:24 2022] EXT4-fs (sdb2): INFO: recovery required on readonly filesystem
                [Sun Mar 27 12:04:24 2022] EXT4-fs (sdb2): write access will be enabled during recovery
                [Sun Mar 27 12:04:24 2022] EXT4-fs (sdb2): recovery complete
                [Sun Mar 27 12:04:24 2022] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null)
                [Sun Mar 27 12:04:24 2022] VFS: Mounted root (ext4 filesystem) readonly on device 8:18.
                [Sun Mar 27 12:04:24 2022] devtmpfs: mounted
                [Sun Mar 27 12:04:24 2022] Freeing unused kernel memory: 3712K
                [Sun Mar 27 12:04:24 2022] Run /sbin/init as init process
                [Sun Mar 27 12:04:24 2022]   with arguments:
                [Sun Mar 27 12:04:24 2022]     /sbin/init
                [Sun Mar 27 12:04:24 2022]   with environment:
                [Sun Mar 27 12:04:24 2022]     HOME=/
                [Sun Mar 27 12:04:24 2022]     TERM=linux
                [Sun Mar 27 12:04:24 2022] systemd[1]: System time before build time, advancing clock.
                [Sun Mar 27 12:04:24 2022] NET: Registered protocol family 10
                [Sun Mar 27 12:04:24 2022] Segment Routing with IPv6
                [Sun Mar 27 12:04:24 2022] systemd[1]: systemd 247.3-6 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
                [Sun Mar 27 12:04:24 2022] systemd[1]: Detected architecture arm64.
                [Sun Mar 27 12:04:24 2022] systemd[1]: Set hostname to <raspi1>.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Queued start job for default target Graphical Interface.
                [Sun Mar 27 12:04:25 2022] random: systemd: uninitialized urandom read (16 bytes read)
                [Sun Mar 27 12:04:25 2022] systemd[1]: Created slice system-getty.slice.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Created slice system-modprobe.slice.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Created slice system-systemd\x2dfsck.slice.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Created slice User and Session Slice.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Reached target Local Encrypted Volumes.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Reached target Paths.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Reached target Slices.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Reached target Swap.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Listening on Syslog Socket.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Listening on fsck to fsckd communication Socket.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Listening on initctl Compatibility Named Pipe.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Listening on Journal Audit Socket.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Listening on Journal Socket (/dev/log).
                [Sun Mar 27 12:04:25 2022] systemd[1]: Listening on Journal Socket.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Listening on udev Control Socket.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Listening on udev Kernel Socket.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Mounting POSIX Message Queue File System...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Mounting RPC Pipe File System...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Mounting Kernel Debug File System...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Mounting Kernel Trace File System...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Starting Restore / save the current clock...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Starting Set the console keyboard layout...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Starting Create list of static device nodes for the current kernel...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Starting Load Kernel Module configfs...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Starting Load Kernel Module drm...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Starting Load Kernel Module fuse...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Starting File System Check on Root Device...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Starting Journal Service...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Starting Load Kernel Modules...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Starting Coldplug All udev Devices...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Mounted POSIX Message Queue File System.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Mounted RPC Pipe File System.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Mounted Kernel Debug File System.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Mounted Kernel Trace File System.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Finished Create list of static device nodes for the current kernel.
                [Sun Mar 27 12:04:25 2022] systemd[1]: modprobe@configfs.service: Succeeded.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Finished Load Kernel Module configfs.
                [Sun Mar 27 12:04:25 2022] fuse: init (API version 7.32)
                [Sun Mar 27 12:04:25 2022] systemd[1]: Mounting Kernel Configuration File System...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Started File System Check Daemon to report status.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Finished Restore / save the current clock.
                [Sun Mar 27 12:04:25 2022] systemd[1]: modprobe@fuse.service: Succeeded.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Finished Load Kernel Module fuse.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Finished Load Kernel Modules.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Mounted Kernel Configuration File System.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Mounting FUSE Control File System...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Starting Apply Kernel Variables...
                [Sun Mar 27 12:04:25 2022] systemd[1]: modprobe@drm.service: Succeeded.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Finished Load Kernel Module drm.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Mounted FUSE Control File System.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Finished Apply Kernel Variables.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Finished File System Check on Root Device.
                [Sun Mar 27 12:04:25 2022] systemd[1]: Starting Remount Root and Kernel File Systems...
                [Sun Mar 27 12:04:25 2022] systemd[1]: Started Journal Service.
                [Sun Mar 27 12:04:26 2022] EXT4-fs (sdb2): re-mounted. Opts: commit=600
                [Sun Mar 27 12:04:26 2022] systemd-journald[137]: Received client request to flush runtime journal.
                [Sun Mar 27 12:04:26 2022] systemd-journald[137]: File /var/log/journal/5c6a97b0f1e7404d8d3154e6725860ba/system.journal corrupted or uncleanly shut down, renaming and replacing.
                [Sun Mar 27 12:04:27 2022] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                [Sun Mar 27 12:04:27 2022] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                [Sun Mar 27 12:04:27 2022] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                [Sun Mar 27 12:04:27 2022] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                [Sun Mar 27 12:04:27 2022] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                [Sun Mar 27 12:04:27 2022] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                [Sun Mar 27 12:04:27 2022] [vc_sm_connected_init]: start
                [Sun Mar 27 12:04:27 2022] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                [Sun Mar 27 12:04:27 2022] bcm2835_audio bcm2835_audio: card created with 8 channels
                [Sun Mar 27 12:04:27 2022] [vc_sm_connected_init]: installed successfully
                [Sun Mar 27 12:04:27 2022] mc: Linux media interface: v0.10
                [Sun Mar 27 12:04:27 2022] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
                [Sun Mar 27 12:04:27 2022] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
                [Sun Mar 27 12:04:27 2022] videodev: Linux video capture interface: v2.00
                [Sun Mar 27 12:04:27 2022] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                [Sun Mar 27 12:04:27 2022] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                [Sun Mar 27 12:04:27 2022] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                [Sun Mar 27 12:04:27 2022] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                [Sun Mar 27 12:04:27 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                [Sun Mar 27 12:04:27 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                [Sun Mar 27 12:04:27 2022] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                [Sun Mar 27 12:04:27 2022] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                [Sun Mar 27 12:04:27 2022] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                [Sun Mar 27 12:04:27 2022] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                [Sun Mar 27 12:04:27 2022] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                [Sun Mar 27 12:04:27 2022] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                [Sun Mar 27 12:04:27 2022] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                [Sun Mar 27 12:04:27 2022] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                [Sun Mar 27 12:04:27 2022] random: crng init done
                [Sun Mar 27 12:04:27 2022] random: 7 urandom warning(s) missed due to ratelimiting
                [Sun Mar 27 12:04:27 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                [Sun Mar 27 12:04:27 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                [Sun Mar 27 12:04:27 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                [Sun Mar 27 12:04:27 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                [Sun Mar 27 12:04:27 2022] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
                [Sun Mar 27 12:04:27 2022] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
                [Sun Mar 27 12:04:27 2022] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
                [Sun Mar 27 12:04:27 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
                [Sun Mar 27 12:04:27 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
                [Sun Mar 27 12:04:27 2022] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
                [Sun Mar 27 12:04:27 2022] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                [Sun Mar 27 12:04:27 2022] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
                [Sun Mar 27 12:04:27 2022] Registered IR keymap rc-cec
                [Sun Mar 27 12:04:27 2022] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
                [Sun Mar 27 12:04:27 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
                [Sun Mar 27 12:04:27 2022] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                [Sun Mar 27 12:04:27 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input1
                [Sun Mar 27 12:04:27 2022] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
                [Sun Mar 27 12:04:27 2022] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                [Sun Mar 27 12:04:27 2022] usbcore: registered new interface driver cdc_acm
                [Sun Mar 27 12:04:27 2022] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                [Sun Mar 27 12:04:27 2022] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                [Sun Mar 27 12:04:27 2022] sd 0:0:0:0: Attached scsi generic sg0 type 0
                [Sun Mar 27 12:04:27 2022] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
                [Sun Mar 27 12:04:27 2022] sd 1:0:0:0: Attached scsi generic sg1 type 0
                [Sun Mar 27 12:04:27 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input2
                [Sun Mar 27 12:04:27 2022] brcmfmac: F1 signature read @0x18000000=0x15264345
                [Sun Mar 27 12:04:27 2022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                [Sun Mar 27 12:04:27 2022] usbcore: registered new interface driver brcmfmac
                [Sun Mar 27 12:04:27 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input3
                [Sun Mar 27 12:04:27 2022] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
                [Sun Mar 27 12:04:28 2022] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
                [Sun Mar 27 12:04:28 2022] Registered IR keymap rc-cec
                [Sun Mar 27 12:04:28 2022] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
                [Sun Mar 27 12:04:28 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input4
                [Sun Mar 27 12:04:28 2022] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
                [Sun Mar 27 12:04:28 2022] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
                [Sun Mar 27 12:04:28 2022] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input5
                [Sun Mar 27 12:04:28 2022] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
                [Sun Mar 27 12:04:28 2022] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
                [Sun Mar 27 12:04:28 2022] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
                [Sun Mar 27 12:04:28 2022] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
                [Sun Mar 27 12:04:28 2022] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
                [Sun Mar 27 12:04:28 2022] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
                [Sun Mar 27 12:04:28 2022] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
                [Sun Mar 27 12:04:28 2022] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                [Sun Mar 27 12:04:28 2022] vc4-drm gpu: [drm] Cannot find any crtc or sizes
                [Sun Mar 27 12:04:29 2022] uart-pl011 fe201000.serial: no DMA platform data
                [Sun Mar 27 12:04:29 2022] 8021q: 802.1Q VLAN Support v1.8
                [Sun Mar 27 12:04:29 2022] Adding 102396k swap on /var/swap.  Priority:-2 extents:2 across:110588k FS
                [Sun Mar 27 12:04:30 2022] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                [Sun Mar 27 12:04:30 2022] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                [Sun Mar 27 12:04:30 2022] bcmgenet fd580000.ethernet eth0: Link is Down
                [Sun Mar 27 12:04:32 2022] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
                [Sun Mar 27 12:04:32 2022] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                [Sun Mar 27 12:04:34 2022] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                [Sun Mar 27 12:04:35 2022] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                [Sun Mar 27 12:04:36 2022] Bluetooth: Core ver 2.22
                [Sun Mar 27 12:04:36 2022] NET: Registered protocol family 31
                [Sun Mar 27 12:04:36 2022] Bluetooth: HCI device and connection manager initialized
                [Sun Mar 27 12:04:36 2022] Bluetooth: HCI socket layer initialized
                [Sun Mar 27 12:04:36 2022] Bluetooth: L2CAP socket layer initialized
                [Sun Mar 27 12:04:36 2022] Bluetooth: SCO socket layer initialized
                [Sun Mar 27 12:04:36 2022] Bluetooth: HCI UART driver ver 2.3
                [Sun Mar 27 12:04:36 2022] Bluetooth: HCI UART protocol H4 registered
                [Sun Mar 27 12:04:36 2022] Bluetooth: HCI UART protocol Three-wire (H5) registered
                [Sun Mar 27 12:04:36 2022] Bluetooth: HCI UART protocol Broadcom registered
                [Sun Mar 27 12:04:36 2022] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                [Sun Mar 27 12:04:36 2022] Bluetooth: BNEP filters: protocol multicast
                [Sun Mar 27 12:04:36 2022] Bluetooth: BNEP socket layer initialized
                [Sun Mar 27 12:04:36 2022] NET: Registered protocol family 38
                [Sun Mar 27 12:04:51 2022] cam-dummy-reg: disabling
                [Sun Mar 27 12:04:51 2022] vcc-sd: disabling
                [Sun Mar 27 12:04:51 2022] cam1-reg: disabling
                  DGR @DGR last edited by
                  @dgr noch ein Hinweis: es steckt noch eine SD-Karte (64GB für Datensicherung) mit drin. Habe es aber auch schon ohne probiert.
                    @dgr
                    Ich würde ja den Desktopbetrieb und das WLAN ausschalten.
                    blkid
                    sagt?
                      blkid
                      /dev/sdb1: LABEL_FATBOOT="boot" LABEL="boot" UUID="F914-FF4D" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="4cacc907-01"
                      /dev/sdb2: LABEL="rootfs" UUID="1943b829-a99b-45b8-9fe5-7136dbea4c4a" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="4cacc907-02"
                      /dev/sda1: LABEL_FATBOOT="STICK" UUID="A71C-E230" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="4f91c42d-01"
                      Desktopbetrieb ? Es ist Bullseye light. Was müßte ich da ändern ?
                        @dgr
                        WLAN abschalten über sudo raspi-config ? Wenn ja, wo dort ?
                          Thomas Braun Most Active @DGR last edited by Thomas Braun
                          @dgr
                          Da läuft ein Recovery auf dem root-Dateisystem.
                          Da ist vermutlich was größeres defekt. Installier es neu.
                          Nix kopieren, klonen oder sonst was auftauen, Neuinstallation.
                            ich habe auf die SSD jetzt mit "Raspberry pi Imager" Bullseye light geflasht (incl. SSH, WLAN deaktiviert).
                            Danach an den Raspberry gesteckt, den gestartet, aber nichts passiert. Die SSD wird nicht angesprochen (keine LED aktiv)
                            Keine LED am LAN-Eingang. Im Router ist demzufolge auch nichts zu sehen.
                              Formatiert war die SSD mit FAT32
                                Thomas Braun Most Active last edited by
                                @dgr sagte in SSD am Raspberry: System nach kurzer Zeit nicht erreichbar:
                                Das spielt keine Rolle, beim flash wird das Dateisystem aus dem Image draufgebügelt.
                                D 3 Replies Last reply Reply Quote 0
                                  @thomas-braun nach scheinbar endlos langer Zeit erscheint der Raspberry im Router, allerdings mit einer DHCP-Adresse und nicht der, die ich beim Flashen vorgegeben habe. Ping funktioniert, aber kein SSH.
                                    ich habe mal den USB-Port gewechselt (von USB 2.0 auf USB 3.0). Jetzt komme ich mit Putty drauf. Den USB-Port am Raspberry hatte ich aber vorher schon mal probiert ohne Erfolg.
                                    Gleich ein Fehler:
                                    sudo apt-get update && sudo apt-get upgrade -y
                                    sudo: unable to execute /usr/bin/apt-get: Input/output error
                                      die Fehler sind typisch für das, was ich vorher schon hatte, wenn iobroker nicht mehr lief und Putty noch aktiv war, aber keine Kommandos mehr nahm.
                                        @dgr
                                        Vielleicht ist die SSD durch...
                                          @thomas-braun es sieht ganz so aus. Ich wollte statt Schnellformatierung mal richtig formatieren, aber "Windows konnte die Formatierung nicht abschließen".
                                          Ich schicke das Teil zurück.
                                            @thomas-braun nach neuer SSD (allerdings gleicher Typ) passiert das Gleiche.
                                            1. SSD formatiert
                                            2. mit Raspberry Pi Imager das Image 2022-01-28-raspios-bullseye-arm64-lite eingespielt
                                            3. SSD in Raspberry
                                            4. Putty: sudo apt-get update && sudo apt-get dist-upgrade -y
                                            sudo reboot
                                            -bash: /usr/bin/sudo: Input/output error
                                            Ich denke, es ist eher unwahrscheinlich, dass es an der SSD liegt.
                                            6. Ausschalten/Einschalten
                                            7.
                                             sudo lsblk
                                            NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
                                            sda      8:0    0 119.2G  0 disk
                                            ├─sda1   8:1    0   256M  0 part /boot
                                            └─sda2   8:2    0   119G  0 part /
                                            sdb      8:16   1  59.5G  0 disk
                                            └─sdb1   8:17   1  59.5G  0 part
                                            Dazu ein Hinweis: es steckt noch ein USB-Stick mit einer SD-Karte 64 GB mit drin
                                            2422
