    4. Test Adapter iobroker.uv-protect 0.3.x
    • JohGre
      JohGre last edited by
      Habe den Adapter anstatt openuv installiert, leider funktioniert er nur einmal gleich nach dem Starten, alle weiteren Aufrufe, die ja zeitgesteuert sind, werfen einen Fehler.
      2022-03-05 16:00:00.431 - debug: uv-protect.0 (209986) Redis Objects: Use Redis connection: 10.0.0.227:9001
      2022-03-05 16:00:00.463 - debug: uv-protect.0 (209986) Objects client ready ... initialize now
      2022-03-05 16:00:00.465 - debug: uv-protect.0 (209986) Objects create System PubSub Client
      2022-03-05 16:00:00.466 - debug: uv-protect.0 (209986) Objects create User PubSub Client
      2022-03-05 16:00:00.527 - debug: uv-protect.0 (209986) Objects client initialize lua scripts
      2022-03-05 16:00:00.532 - debug: uv-protect.0 (209986) Objects connected to redis: 10.0.0.227:9001
      2022-03-05 16:00:00.566 - debug: uv-protect.0 (209986) Redis States: Use Redis connection: 10.0.0.227:9000
      2022-03-05 16:00:00.586 - debug: uv-protect.0 (209986) States create System PubSub Client
      2022-03-05 16:00:00.587 - debug: uv-protect.0 (209986) States create User PubSub Client
      2022-03-05 16:00:00.625 - debug: uv-protect.0 (209986) States connected to redis: 10.0.0.227:9000
      2022-03-05 16:00:01.757 - info: uv-protect.0 (209986) starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v14.19.0, js-controller: 4.0.18
      2022-03-05 16:00:01.805 - debug: uv-protect.0 (209986) System language: en
      2022-03-05 16:00:01.805 - debug: uv-protect.0 (209986) System longitude: 13. System latitude: 48.
      2022-03-05 16:00:01.817 - debug: uv-protect.0 (209986) API Request started ...
      2022-03-05 16:00:32.248 - warn: uv-protect.0 (209986) Request error: Error: Request failed with status code 503
      2022-03-05 16:00:38.255 - info: uv-protect.0 (209986) Terminated (NO_ERROR): Without reason
      • FredF
        FredF Most Active Forum Testing @JohGre last edited by
        @johgre
        Und wo ist ein Fehler (error)?
        Die Instanz steht auf Log-Stufe debug - da kommen dann viele Meldungen. Besser umstellen auf info
        JohGre 1 Reply Last reply Reply Quote 0
        • JohGre
          JohGre @FredF last edited by
          @fredf vorletzte Zeile, im ioBroker log zwar ein warn, aber als response ein HTML Error und somit keine Daten
          • FredF
            @johgre Code 503 sagt laut suche, dass der Server nicht antwortet. API key eingetragen?
            • JohGre
              @fredf Ja, API Key ist eingetragen (und auch der richtige) und beim starten werden auch einmalig Daten geholt.
              2022-03-05 14:08:22.246 - debug: uv-protect.0 (207612) Redis Objects: Use Redis connection: 10.0.0.227:9001
              2022-03-05 14:08:22.272 - debug: uv-protect.0 (207612) Objects client ready ... initialize now
              2022-03-05 14:08:22.275 - debug: uv-protect.0 (207612) Objects create System PubSub Client
              2022-03-05 14:08:22.275 - debug: uv-protect.0 (207612) Objects create User PubSub Client
              2022-03-05 14:08:22.312 - debug: uv-protect.0 (207612) Objects client initialize lua scripts
              2022-03-05 14:08:22.316 - debug: uv-protect.0 (207612) Objects connected to redis: 10.0.0.227:9001
              2022-03-05 14:08:22.341 - debug: uv-protect.0 (207612) Redis States: Use Redis connection: 10.0.0.227:9000
              2022-03-05 14:08:22.356 - debug: uv-protect.0 (207612) States create System PubSub Client
              2022-03-05 14:08:22.357 - debug: uv-protect.0 (207612) States create User PubSub Client
              2022-03-05 14:08:22.379 - debug: uv-protect.0 (207612) States connected to redis: 10.0.0.227:9000
              2022-03-05 14:08:23.036 - info: uv-protect.0 (207612) starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v14.19.0, js-controller: 4.0.18
              2022-03-05 14:08:23.072 - debug: uv-protect.0 (207612) System language: en
              2022-03-05 14:08:23.072 - debug: uv-protect.0 (207612) System longitude: 13. System latitude: 48.
              2022-03-05 14:08:23.082 - debug: uv-protect.0 (207612) API Request started ...
              2022-03-05 14:08:23.592 - debug: uv-protect.0 (207612) API Request successfully completed
              2022-03-05 14:08:23.592 - debug: uv-protect.0 (207612) {"result":{"uv":1.8666,"uv_time":"2022-03-05T13:08:23.511Z","uv_max":2.597,"uv_max_time":"2022-03-05T11:17:22.820Z","ozone":346.6,"ozone_time":"2022-03-05T12:04:38.489Z","safe_exposure_time":{"st1":89,"st2":107,"st3":143,"st4":179,"st5":286,"st6":536},"sun_info":{"sun_times":{"solarNoon":"2022-03-05T11:17:22.820Z","nadir":"2022-03-04T23:17:22.820Z","sunrise":"2022-03-05T05:39:49.203Z","sunset":"2022-03-05T16:54:56.436Z","sunriseEnd":"2022-03-05T05:43:03.240Z","sunsetStart":"2022-03-05T16:51:42.399Z","dawn":"2022-03-05T05:08:40.125Z","dusk":"2022-03-05T17:26:05.514Z","nauticalDawn":"2022-03-05T04:32:38.608Z","nauticalDusk":"2022-03-05T18:02:07.031Z","nightEnd":"2022-03-05T03:56:17.360Z","night":"2022-03-05T18:38:28.279Z","goldenHourEnd":"2022-03-05T06:21:47.708Z","goldenHour":"2022-03-05T16:12:57.931Z"},"sun_position":{"azimuth":0.571989127405678,"altitude":0.5310458359058243}}}}
              2022-03-05 14:08:23.837 - debug: uv-protect.0 (207612) API Request done
              2022-03-05 14:08:29.845 - info: uv-protect.0 (207612) Terminated (NO_ERROR): Without reason
              2022-03-05 15:00:00.413 - debug: uv-protect.0 (208702) Redis Objects: Use Redis connection: 10.0.0.227:9001
              2022-03-05 15:00:00.444 - debug: uv-protect.0 (208702) Objects client ready ... initialize now
              2022-03-05 15:00:00.446 - debug: uv-protect.0 (208702) Objects create System PubSub Client
              2022-03-05 15:00:00.447 - debug: uv-protect.0 (208702) Objects create User PubSub Client
              2022-03-05 15:00:00.490 - debug: uv-protect.0 (208702) Objects client initialize lua scripts
              2022-03-05 15:00:00.495 - debug: uv-protect.0 (208702) Objects connected to redis: 10.0.0.227:9001
              2022-03-05 15:00:00.528 - debug: uv-protect.0 (208702) Redis States: Use Redis connection: 10.0.0.227:9000
              2022-03-05 15:00:00.551 - debug: uv-protect.0 (208702) States create System PubSub Client
              2022-03-05 15:00:00.552 - debug: uv-protect.0 (208702) States create User PubSub Client
              2022-03-05 15:00:00.594 - debug: uv-protect.0 (208702) States connected to redis: 10.0.0.227:9000
              2022-03-05 15:00:01.506 - info: uv-protect.0 (208702) starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v14.19.0, js-controller: 4.0.18
              2022-03-05 15:00:01.563 - debug: uv-protect.0 (208702) System language: en
              2022-03-05 15:00:01.563 - debug: uv-protect.0 (208702) System longitude: 13. System latitude: 48.
              2022-03-05 15:00:01.572 - debug: uv-protect.0 (208702) API Request started ...
              2022-03-05 15:00:32.016 - warn: uv-protect.0 (208702) Request error: Error: Request failed with status code 503
              2022-03-05 15:00:38.025 - info: uv-protect.0 (208702) Terminated (NO_ERROR): Without reason
                ps1304 @simatec last edited by ps1304
                @simatec erstmal danke für den Adapter - habe ich neu installiert auf iobroker - bekomme für alle Datenpunkte Fehlermeldungen ala:
                Object uv-protect.0.sun_info.sun_position.altitude is invalid: Default value has to be type "number" but received type "string"
                System iobroker: 4.0.19node.js 16.14 / NPM 8.3.1 auf proxmox vm installiert
                Ist der Fehler bekannt?
                Komplettes Log zum Adapterstart:
                2022-03-13 15:42:50.792  - info: host.iobroker-master instance system.adapter.uv-protect.0 started with pid 50746
                2022-03-13 16:42:52.812  - warn: uv-protect.0 (50746) Object uv-protect.0.uv is invalid: Default value has to be type "number" but received type "string"
                2022-03-13 16:42:52.815  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                2022-03-13 16:42:52.835  - warn: uv-protect.0 (50746) Object uv-protect.0.uv_max is invalid: Default value has to be type "number" but received type "string"
                2022-03-13 16:42:52.835  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                2022-03-13 16:42:52.848  - warn: uv-protect.0 (50746) Object uv-protect.0.ozone is invalid: Default value has to be type "number" but received type "string"
                2022-03-13 16:42:52.849  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                2022-03-13 16:42:52.862  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st1 is invalid: Default value has to be type "number" but received type "string"
                2022-03-13 16:42:52.862  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                2022-03-13 16:42:52.872  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st2 is invalid: Default value has to be type "number" but received type "string"
                2022-03-13 16:42:52.873  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                2022-03-13 16:42:52.883  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st3 is invalid: Default value has to be type "number" but received type "string"
                2022-03-13 16:42:52.883  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                2022-03-13 16:42:52.931  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st4 is invalid: Default value has to be type "number" but received type "string"
                2022-03-13 16:42:52.932  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                2022-03-13 16:42:52.940  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st5 is invalid: Default value has to be type "number" but received type "string"
                2022-03-13 16:42:52.940  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                2022-03-13 16:42:52.948  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st6 is invalid: Default value has to be type "number" but received type "string"
                2022-03-13 16:42:52.948  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                2022-03-13 16:42:53.036  - warn: uv-protect.0 (50746) Object uv-protect.0.sun_info.sun_position.azimuth is invalid: Default value has to be type "number" but received type "string"
                2022-03-13 16:42:53.036  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                2022-03-13 16:42:53.043  - warn: uv-protect.0 (50746) Object uv-protect.0.sun_info.sun_position.altitude is invalid: Default value has to be type "number" but received type "string"
                2022-03-13 16:42:53.044  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                2022-03-13 16:42:53.102  - warn: uv-protect.0 (50746) Object uv-protect.0.uv_alert is invalid: Default value has to be type "boolean" but received type "string"
                2022-03-13 16:42:53.102  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                2022-03-13 16:42:53.110  - warn: uv-protect.0 (50746) Object uv-protect.0.uv_warn is invalid: Default value has to be type "boolean" but received type "string"
                2022-03-13 16:42:53.110  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
                2022-03-13 16:42:53.119  - info: uv-protect.0 (50746) starting. Version 0.3.4 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v16.14.0, js-controller: 4.0.19```
                • simatec
                  simatec Developer Most Active @ps1304 last edited by
                  @ps1304
                  Das sind nur Warnungen… Fixe ich in der nächsten Version
                  P Z 2 Replies Last reply Reply Quote 0
                    @simatec danke dir für die schnelle antwort und deinen adapter
                    • Z
                      zolpetol @simatec last edited by zolpetol
                      @simatec
                      Bei mir leider auch nur aktuelle Daten direkt nach dem Starten des Adapter, danach folgende Meldungen und keine Aktualisierung mehr:
                      APi-Key ist eingetragen
                      16:43h: zur Zeit funktioniert die Aktualisierung
                      19:19h. wieder vorbei Code 403 oder auch Code 500
                      simatec 2 Replies Last reply Reply Quote 0
                      • simatec
                        simatec Developer Most Active @zolpetol last edited by
                        @zolpetol Du hast nur eine gewisse Anzahl an API Abrufen innerhalb von 24 Stunden mit der freien Version.
                        Du solltest dementsprechend den Zeitintervall nicht so klein setzen
                        • simatec
                          @zolpetol Zitat auf der Page von OpenUV:
                          Need more than 50 daily requests? Check our Extended Plan for just $15 USD/month. Payments and billing processed by Stripe.
                          • Z
                            @simatec
                            Danke für die Info! Das Zeitintervall wurde gemäß dieser Info eingestellt:
                            • simatec
                              @zolpetol Dann sollte es nun funktionieren ...
                              • JohGre
                                @zolpetol sagte in Test Adapter iobroker.uv-protect 0.3.x:
                                @simatec
                                Hast du das Problem schon lösen können? Auch bei mir immer wieder ein 403 trotz neuem Key. Werd den Adapter wohl wieder deaktivieren
                                • simatec
                                  simatec Developer Most Active @JohGre last edited by
                                  @johgre Wie oft holst du die Daten?
                                  Mit der kostenlosen Version dieser API kannst du maximal 50 Anfragen pro Tag starten.
                                  Wenn du mehr abfragen hast, bekommst du diesen fehler.
                                  • JohGre
                                    JohGre @simatec last edited by
                                    @simatec Default-Einstellung des Adapters
                                    • simatec
                                      @johgre Dann ist die API sicher gerade nicht erreichbar ... Was aber nicht am Adapter liegt.
                                      Es ist ja auch nur eine reine Warnung und nix böses
                                      • Albert K
                                        Albert K @simatec last edited by
                                        @simatec
                                        Vielen Dank für den Adapter!!! 👍 👍 👍
                                        Hatte mit dem open-uv Adapter mehr und mehr Probleme (ständige Abstürze). Und meine Rollladen Steuerung zur Beschattung basiert auf dem berechneten lokalen UVI Wert.
                                        Jetzt klappt das wieder Super!
                                        viele Grüße
                                        • Jörg Knechten
                                          Jörg Knechten last edited by
                                          Hi der letzte Eintrag ist schon etwas her, aber ich versuche es einfach mal.
                                          Erstmal vielen Dank für die Arbeit, die in dem Adapter steckt. Für uns extrem hilfreich. da meine Frau Lupus hat und somit Sonne bzw. hohe UV-Strahlung meiden soll.
                                          Leider habe ich ein Problem. Die Werte aktualisieren sich bei mir nur, wenn ich den Adapter neu starte. Aktualisierung, wie empfohlen, alle 60 Min. Das Protokoll spuckt folgendes aus.
                                          host.vmiob
                                          2022-08-13 07:00:12.503	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                                          uv-protect.0
                                          2022-08-13 07:00:11.988	info	Terminated (NO_ERROR): Without reason
                                          uv-protect.0
                                          2022-08-13 07:00:05.984	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                          uv-protect.0
                                          2022-08-13 07:00:00.909	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                          host.vmiob
                                          2022-08-13 07:00:00.164	info	instance system.adapter.uv-protect.0 started with pid 21308
                                          host.vmiob
                                          2022-08-13 06:00:12.351	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                                          uv-protect.0
                                          2022-08-13 06:00:11.836	info	Terminated (NO_ERROR): Without reason
                                          uv-protect.0
                                          2022-08-13 06:00:05.832	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                          uv-protect.0
                                          2022-08-13 06:00:00.758	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                          host.vmiob
                                          2022-08-13 06:00:00.019	info	instance system.adapter.uv-protect.0 started with pid 21185
                                          host.vmiob
                                          2022-08-13 05:00:12.372	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                                          uv-protect.0
                                          2022-08-13 05:00:11.857	info	Terminated (NO_ERROR): Without reason
                                          uv-protect.0
                                          2022-08-13 05:00:05.853	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                          uv-protect.0
                                          2022-08-13 05:00:00.780	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                          host.vmiob
                                          2022-08-13 05:00:00.019	info	instance system.adapter.uv-protect.0 started with pid 21159
                                          mercedesme.0
                                          2022-08-13 04:58:46.419	info	Lost WebSocket connection. Reconnect WebSocket
                                          host.vmiob
                                          2022-08-13 04:00:12.354	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                                          uv-protect.0
                                          2022-08-13 04:00:11.840	info	Terminated (NO_ERROR): Without reason
                                          uv-protect.0
                                          2022-08-13 04:00:05.836	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                          uv-protect.0
                                          2022-08-13 04:00:00.762	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                          host.vmiob
                                          2022-08-13 04:00:00.019	info	instance system.adapter.uv-protect.0 started with pid 21131
                                          host.vmiob
                                          2022-08-13 03:00:12.382	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                                          uv-protect.0
                                          2022-08-13 03:00:11.867	info	Terminated (NO_ERROR): Without reason
                                          uv-protect.0
                                          2022-08-13 03:00:05.862	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                          uv-protect.0
                                          2022-08-13 03:00:00.786	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                          host.vmiob
                                          2022-08-13 03:00:00.018	info	instance system.adapter.uv-protect.0 started with pid 21090
                                          host.vmiob
                                          2022-08-13 02:00:12.353	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                                          uv-protect.0
                                          2022-08-13 02:00:11.840	info	Terminated (NO_ERROR): Without reason
                                          uv-protect.0
                                          2022-08-13 02:00:05.835	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                          uv-protect.0
                                          2022-08-13 02:00:00.761	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                          host.vmiob
                                          2022-08-13 02:00:00.021	info	instance system.adapter.uv-protect.0 started with pid 21051
                                          Das Problem scheint der Timout zu sein. Bin allerdings Newb bzgl. ioBroker.
                                          Vielen Dank im Voraus!
                                          • simatec
                                            simatec Developer Most Active @Jörg Knechten last edited by
                                            @jörg-knechten Hast du dir ein API-Key geholt und diesen im Adapter eingetragen?
                                            Geo-Daten werden vom System geholt ... dort müsst sie aber richtig eingetragen sein.
                                            Auch auf die Nachkommastellen achten, da die API von OpenUV diese so benötigt
                                            Beispiel:
                                            Längengrad: 13.376935
                                            Breitgrad: 52.516181
                                            Jörg Knechten 2 Replies Last reply Reply Quote 0
                                            41
                                            3611
