    • simatec
      simatec Developer Most Active @diwoma last edited by
      @diwoma Kannst du bitte mal die Version aus dem Dev-Branch testen?
      https://github.com/simatec/ioBroker.backitup/tarball/dev
      Hier muss jetzt keine eigene APP mehr erstellt werden.
      Einfach in der Auswahl von "Dropbox-API Typ" die Einstellung "Standard" wählen und den Anweisungen folgen.
      Wäre gut, wenn du mir dazu Feedback geben könntest
      • Negalein
        Negalein Global Moderator @simatec last edited by
        @simatec sagte in Test Adapter Backitup v2.3.x:
        Ich habe gerade Backitup die letzten Tage umgebaut, um die Änderungen in der Dropbox API supporten zu können.
        kein Upload in Dropbox
        [ERROR] [dropbox] - upload Dropbox: {"error_summary":"payload_too_large/","error":{".tag":"payload_too_large"},"code":409}
        Started iobroker ...
        [DEBUG] [iobroker] start with {"type":"creator","time":"23:00","debugging":true,"slaveBackup":"Single","everyXDays":"1","nameSuffix":"Standard","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"10.0.1.22","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/io_backup","dirMinimal":"sharename/backupDir","user":"Christian","pass":"****","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data/history/","nameSuffix":"Standard","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"10.0.1.22","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/io_backup","dirMinimal":"sharename/backupDir","user":"Christian","pass":"****","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"Standard","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"10.0.1.22","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/io_backup","dirMinimal":"sharename/backupDir","user":"Christian","pass":"****","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"host":"10.0.1.203","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"Standard","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":5000,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":4000,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        [DEBUG] [iobroker] - host.ioBroker 26151 states saved
        [DEBUG] [iobroker] - host.ioBroker 26199 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_03_27-16_06_39_Standard_backupiobroker.tar.gz
        [DEBUG] [iobroker] - done
        [DEBUG] [historyDB] - compress from historyDB started ...
        [DEBUG] [historyDB] - Packed 20MB so far...
        [DEBUG] [historyDB] - Packed 43MB so far...
        [DEBUG] [historyDB] - Packed 66MB so far...
        [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2022_03_27-16_07_10_Standard_backupiobroker.tar.gz
        [DEBUG] [historyDB] - done
        [DEBUG] [grafana] - Start Grafana Backup ...
        [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
        [DEBUG] [grafana] - Created dashboard directory
        [DEBUG] [grafana] - Created dashboards_manually_restore directory
        [DEBUG] [grafana] - Created datasource directory
        [DEBUG] [grafana] - start Grafana request ...
        [DEBUG] [grafana] - Grafana is available ... Status: 200
        [DEBUG] [grafana] - found Dashboard: allgemein
        [DEBUG] [grafana] - found Dashboard: wetterstation
        [DEBUG] [grafana] - found Dashboard: wetterstation-copy
        [DEBUG] [grafana] - found Dashboard: ender-3-v2
        [DEBUG] [grafana] - found Dashboard: new-dashboard-copy
        [DEBUG] [grafana] - found Dashboard: proxmox
        [DEBUG] [grafana] - found Dashboard: pv-statistik
        [DEBUG] [grafana] - found Dashboard: daddy
        [DEBUG] [grafana] - found Dashboard: wetterstation-v2
        [DEBUG] [grafana] - start Grafana backup compress ...
        [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2022_03_27-16_07_46_Standard_backupiobroker.tar.gz
        [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
        [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
        [DEBUG] [grafana] - done
        [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
        [DEBUG] [javascripts] - found Script: Druckzeit
        [DEBUG] [javascripts] - found Script: Octoprint
        [DEBUG] [javascripts] - found Script: Restzeit
        [DEBUG] [javascripts] - found Script: Akku_Alarm_Tabelle
        [DEBUG] [javascripts] - found Script: Batteriestatus_Homematic_Kopieren
        [DEBUG] [javascripts] - found Script: Alexa-Telegram
        [DEBUG] [javascripts] - found Script: Alexa_Blacklist
        [DEBUG] [javascripts] - found Script: Alexa_Film_Lautstärke
        [DEBUG] [javascripts] - found Script: Alexa_Laura_Volume
        [DEBUG] [javascripts] - found Script: Alexa_Lautstärke_unter_20
        [DEBUG] [javascripts] - found Script: Alexa_Stimmen
        [DEBUG] [javascripts] - found Script: Alexa_gute_nacht
        [DEBUG] [javascripts] - found Script: Alexa_nervt
        [DEBUG] [javascripts] - found Script: Anwesenheit-Alexa
        [DEBUG] [javascripts] - found Script: Muellerinnerung
        [DEBUG] [javascripts] - found Script: Paketfach_Kopieren
        [DEBUG] [javascripts] - found Script: Doorbird_Bilder_BWM
        [DEBUG] [javascripts] - found Script: Doorbird_Bilder_Max
        [DEBUG] [javascripts] - found Script: Doorbird_Bilder_Nega
        [DEBUG] [javascripts] - found Script: Doorbird_Fullybrowser
        [DEBUG] [javascripts] - found Script: RFID-Keymatic
        [DEBUG] [javascripts] - found Script: RFID_true_false
        [DEBUG] [javascripts] - found Script: Ansage
        [DEBUG] [javascripts] - found Script: DP_Enigma_anlegen
        [DEBUG] [javascripts] - found Script: Enigma-Sender
        [DEBUG] [javascripts] - found Script: Enigma_Befehle
        [DEBUG] [javascripts] - found Script: Lautstärke
        [DEBUG] [javascripts] - found Script: 13thStreet
        [DEBUG] [javascripts] - found Script: ARD
        [DEBUG] [javascripts] - found Script: ATV
        [DEBUG] [javascripts] - found Script: ATV2
        [DEBUG] [javascripts] - found Script: BR
        [DEBUG] [javascripts] - found Script: Boomerang
        [DEBUG] [javascripts] - found Script: Discovery
        [DEBUG] [javascripts] - found Script: DisneyChannel
        [DEBUG] [javascripts] - found Script: DisneyJunior
        [DEBUG] [javascripts] - found Script: Fox
        [DEBUG] [javascripts] - found Script: Heimatkanal
        [DEBUG] [javascripts] - found Script: History
        [DEBUG] [javascripts] - found Script: Junior
        [DEBUG] [javascripts] - found Script: Kabel1
        [DEBUG] [javascripts] - found Script: Kabel1Doku
        [DEBUG] [javascripts] - found Script: KiKa
        [DEBUG] [javascripts] - found Script: Kinowelt
        [DEBUG] [javascripts] - found Script: LT1
        [DEBUG] [javascripts] - found Script: NatGeo
        [DEBUG] [javascripts] - found Script: NatGeoWild
        [DEBUG] [javascripts] - found Script: Nickelodeon
        [DEBUG] [javascripts] - found Script: ORF1
        [DEBUG] [javascripts] - found Script: ORF2
        [DEBUG] [javascripts] - found Script: Pro7
        [DEBUG] [javascripts] - found Script: Puls4
        [DEBUG] [javascripts] - found Script: RTL
        [DEBUG] [javascripts] - found Script: RTL2
        [DEBUG] [javascripts] - found Script: Romance
        [DEBUG] [javascripts] - found Script: SAT1
        [DEBUG] [javascripts] - found Script: Sat1Gold
        [DEBUG] [javascripts] - found Script: ServusTV
        [DEBUG] [javascripts] - found Script: Sky1
        [DEBUG] [javascripts] - found Script: SkyAction
        [DEBUG] [javascripts] - found Script: SkyAtlantic
        [DEBUG] [javascripts] - found Script: SkyBestOf
        [DEBUG] [javascripts] - found Script: SkyClassics
        [DEBUG] [javascripts] - found Script: SkyFamily
        [DEBUG] [javascripts] - found Script: SkyFun
        [DEBUG] [javascripts] - found Script: SkyKrimi
        [DEBUG] [javascripts] - found Script: SkyPremieren
        [DEBUG] [javascripts] - found Script: SkyPremieren24
        [DEBUG] [javascripts] - found Script: SkySerien
        [DEBUG] [javascripts] - found Script: SkySpecial
        [DEBUG] [javascripts] - found Script: SkyThriller
        [DEBUG] [javascripts] - found Script: SpiegelGeschichte
        [DEBUG] [javascripts] - found Script: SpiegelWissen
        [DEBUG] [javascripts] - found Script: SuperRTL
        [DEBUG] [javascripts] - found Script: SyFy
        [DEBUG] [javascripts] - found Script: TLC
        [DEBUG] [javascripts] - found Script: TNTComedy
        [DEBUG] [javascripts] - found Script: TNTFilm
        [DEBUG] [javascripts] - found Script: TNTSerie
        [DEBUG] [javascripts] - found Script: TV1
        [DEBUG] [javascripts] - found Script: Tele5
        [DEBUG] [javascripts] - found Script: Toggo
        [DEBUG] [javascripts] - found Script: VOX
        [DEBUG] [javascripts] - found Script: WeltDerWunder
        [DEBUG] [javascripts] - found Script: ZDF
        [DEBUG] [javascripts] - found Script: Alias-Rollo
        [DEBUG] [javascripts] - found Script: Fenster-Badezimmer
        [DEBUG] [javascripts] - found Script: Fenster-Kinderzimmer
        [DEBUG] [javascripts] - found Script: Fenster-Küche
        [DEBUG] [javascripts] - found Script: Fenster-Schlafzimmer
        [DEBUG] [javascripts] - found Script: Fenster-Wintergarten
        [DEBUG] [javascripts] - found Script: Fenster-Wintergartenschiebe
        [DEBUG] [javascripts] - found Script: Fenster-_&_Türstatus
        [DEBUG] [javascripts] - found Script: Fenster_Alexa_Kopieren
        [DEBUG] [javascripts] - found Script: Fenster_geschlossen
        [DEBUG] [javascripts] - found Script: Fensteransage
        [DEBUG] [javascripts] - found Script: Fensteransage-Abfrage
        [DEBUG] [javascripts] - found Script: Fensterauswertung
        [DEBUG] [javascripts] - found Script: Fensterzählen
        [DEBUG] [javascripts] - found Script: KiZi-Rollo-auf
        [DEBUG] [javascripts] - found Script: Küche-Rollo-auf
        [DEBUG] [javascripts] - found Script: Küche-offen
        [DEBUG] [javascripts] - found Script: Rollo-Synchron
        [DEBUG] [javascripts] - found Script: Rollo-Synchron-2
        [DEBUG] [javascripts] - found Script: Rollo-WiGa
        [DEBUG] [javascripts] - found Script: SZ-KiZi-auf
        [DEBUG] [javascripts] - found Script: SZ-Küche-auf
        [DEBUG] [javascripts] - found Script: SZ-Rollo-auf
        [DEBUG] [javascripts] - found Script: SZ-WiGa-auf
        [DEBUG] [javascripts] - found Script: Script-Neustart
        [DEBUG] [javascripts] - found Script: Test-Alias
        [DEBUG] [javascripts] - found Script: Türzählen
        [DEBUG] [javascripts] - found Script: WiGa-Rollo-auf
        [DEBUG] [javascripts] - found Script: Fritz-Onlinezeit
        [DEBUG] [javascripts] - found Script: Fritz_Daten
        [DEBUG] [javascripts] - found Script: Fritz_Tabelle
        [DEBUG] [javascripts] - found Script: Fritz_UPNP
        [DEBUG] [javascripts] - found Script: Gastzugang_QR
        [DEBUG] [javascripts] - found Script: Geraetesperre
        [DEBUG] [javascripts] - found Script: Netzwerkgeraete
        [DEBUG] [javascripts] - found Script: Fronius-Buz-1_10_Min
        [DEBUG] [javascripts] - found Script: Fronius-Buz-1_23_Uhr_59_Min
        [DEBUG] [javascripts] - found Script: Fronius-Buz-2_10_Min
        [DEBUG] [javascripts] - found Script: Fronius-Buz-2_23_Uhr_59_Min
        [DEBUG] [javascripts] - found Script: Fronius-Buz_Kopieren
        [DEBUG] [javascripts] - found Script: Fronius-Max_10_Min
        [DEBUG] [javascripts] - found Script: Fronius-Max_23_Uhr_59_Min
        [DEBUG] [javascripts] - found Script: Geschirrspueler_v0_1_Kopieren
        [DEBUG] [javascripts] - found Script: Trockner_v0_1
        [DEBUG] [javascripts] - found Script: Waschmaschine_v0_1
        [DEBUG] [javascripts] - found Script: Wassermelder_Aqua
        [DEBUG] [javascripts] - found Script: Fernbedienung-Keymatic
        [DEBUG] [javascripts] - found Script: Licht_zählen
        [DEBUG] [javascripts] - found Script: NMap-Tabelle
        [DEBUG] [javascripts] - found Script: Ping_Tabelle
        [DEBUG] [javascripts] - found Script: Web-Speedy-Tabelle
        [DEBUG] [javascripts] - found Script: BSZ
        [DEBUG] [javascripts] - found Script: Steckdosen_zählen
        [DEBUG] [javascripts] - found Script: Strom
        [DEBUG] [javascripts] - found Script: Strom_Geraete_Tabelle_Kopieren
        [DEBUG] [javascripts] - found Script: Strom_Tageswert
        [DEBUG] [javascripts] - found Script: TimerTarget
        [DEBUG] [javascripts] - found Script: Timer_Alexa
        [DEBUG] [javascripts] - found Script: Timer_Ziffern
        [DEBUG] [javascripts] - found Script: Zeituhr
        [DEBUG] [javascripts] - found Script: Adapter_Alive_Tabelle
        [DEBUG] [javascripts] - found Script: Adapter_Update_Info
        [DEBUG] [javascripts] - found Script: Adapterliste
        [DEBUG] [javascripts] - found Script: Alexa_Log
        [DEBUG] [javascripts] - found Script: CCU3-FW
        [DEBUG] [javascripts] - found Script: CCU3_CPU_Up_Temp
        [DEBUG] [javascripts] - found Script: CCU3_Servicemeld
        [DEBUG] [javascripts] - found Script: CCU_Ram_CPU
        [DEBUG] [javascripts] - found Script: DP_anlegen
        [DEBUG] [javascripts] - found Script: IOBroker-Versionen
        [DEBUG] [javascripts] - found Script: IOBroker_Log
        [DEBUG] [javascripts] - found Script: Objekte_anlegen_v0_1
        [DEBUG] [javascripts] - found Script: Objekte_erstellen
        [DEBUG] [javascripts] - found Script: Scriptliste
        [DEBUG] [javascripts] - found Script: Alexa_Temp_Enigma_Aqua
        [DEBUG] [javascripts] - found Script: Alexa_Temp_Enigma_KiZi
        [DEBUG] [javascripts] - found Script: Alexa_Temp_Enigma_WoZi
        [DEBUG] [javascripts] - found Script: Kinderzimmertemperatur
        [DEBUG] [javascripts] - found Script: Wohnzimmertemperatur
        [DEBUG] [javascripts] - found Script: Sidebar
        [DEBUG] [javascripts] - found Script: VIS-retour
        [DEBUG] [javascripts] - found Script: DP-anlegen
        [DEBUG] [javascripts] - found Script: GoogleWeather
        [DEBUG] [javascripts] - found Script: Material-Wetter
        [DEBUG] [javascripts] - found Script: Mondphasen
        [DEBUG] [javascripts] - found Script: Pegel-Ingling
        [DEBUG] [javascripts] - found Script: Pegel-Passau
        [DEBUG] [javascripts] - found Script: Pegel-Pramerdorf
        [DEBUG] [javascripts] - found Script: Pegel-Schaerding
        [DEBUG] [javascripts] - found Script: Regenvorschau
        [DEBUG] [javascripts] - found Script: Sonnenstand
        [DEBUG] [javascripts] - found Script: Sonnenstatus
        [DEBUG] [javascripts] - found Script: Temperaturvorhersage
        [DEBUG] [javascripts] - found Script: UWZ
        [DEBUG] [javascripts] - found Script: Wetter_2
        [DEBUG] [javascripts] - found Script: Wetter_3
        [DEBUG] [javascripts] - found Script: Wetter_Kopieren
        [DEBUG] [javascripts] - found Script: Wetter_to_FTP
        [DEBUG] [javascripts] - found Script: Wetterstation
        [DEBUG] [javascripts] - found Script: Wetterstatistik
        [DEBUG] [javascripts] - found Script: Wettertabelle
        [DEBUG] [javascripts] - found Script: Aquarium-Alarm
        [DEBUG] [javascripts] - found Script: Datum
        [DEBUG] [javascripts] - found Script: HP-Drucker
        [DEBUG] [javascripts] - found Script: Spritpreisrechner
        [DEBUG] [javascripts] - found Script: Volkszaehler
        [DEBUG] [javascripts] - found Script: Proxmox
        [DEBUG] [javascripts] - found Script: BSZ-PC
        [DEBUG] [javascripts] - found Script: BSZ-Aquarium
        [DEBUG] [javascripts] - found Script: BSZ-Serverschrank
        [DEBUG] [javascripts] - found Script: BSZ-Pelletsofen
        [DEBUG] [javascripts] - found Script: BSZ-3dDrucker
        [DEBUG] [javascripts] - found Script: BSZ-3dRaspi
        [DEBUG] [javascripts] - found Script: BSZ-3dLuefter
        [DEBUG] [javascripts] - found Script: Pihole
        [DEBUG] [javascripts] - found Script: Temp_min_max
        [DEBUG] [javascripts] - found Script: Alarm-Alexa
        [DEBUG] [javascripts] - found Script: Akku_Alarm_HM
        [DEBUG] [javascripts] - found Script: Akku_Alarm_HmIP
        [DEBUG] [javascripts] - found Script: Akku_Alarm_Xiaomi
        [DEBUG] [javascripts] - found Script: Doorbell_Alexa
        [DEBUG] [javascripts] - found Script: Doorbird-Telegram
        [DEBUG] [javascripts] - found Script: Alarm-Hue
        [DEBUG] [javascripts] - found Script: Klingelaufnahme_Syno
        [DEBUG] [javascripts] - found Script: Benachrichtigung_Telegram
        [DEBUG] [javascripts] - found Script: Hue_schneller
        [DEBUG] [javascripts] - found Script: Solarweb
        [DEBUG] [javascripts] - found Script: Solarweb_Test
        [DEBUG] [javascripts] - found Script: Slicerthumbnail
        [DEBUG] [javascripts] - found Script: Solarweb-Tabelle
        [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
        [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
        [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_03_27-16_07_51_Standard_backupiobroker.tar.gz
        [DEBUG] [javascripts] - done
        [DEBUG] [ftp] - FTP connected.
        [DEBUG] [ftp] - Send iobroker_2022_03_27-16_06_39_Standard_backupiobroker.tar.gz
        [DEBUG] [ftp] start with {"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false,"deleteBackupAfter":0}
        [DEBUG] [ftp] - Send historyDB_2022_03_27-16_07_10_Standard_backupiobroker.tar.gz
        [DEBUG] [ftp] - Send grafana_2022_03_27-16_07_46_Standard_backupiobroker.tar.gz
        [DEBUG] [ftp] - Send javascripts_2022_03_27-16_07_51_Standard_backupiobroker.tar.gz
        [DEBUG] [ftp] - done
        [DEBUG] [dropbox] start with {"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false,"deleteBackupAfter":0}
        [DEBUG] [dropbox] - Dropbox: Copy iobroker_2022_03_27-16_06_39_Standard_backupiobroker.tar.gz...
        [DEBUG] [dropbox] - Dropbox: Copy historyDB_2022_03_27-16_07_10_Standard_backupiobroker.tar.gz...
        [DEBUG] [dropbox] - Dropbox: Copy grafana_2022_03_27-16_07_46_Standard_backupiobroker.tar.gz...
        [DEBUG] [dropbox] - Dropbox: Copy javascripts_2022_03_27-16_07_51_Standard_backupiobroker.tar.gz...
        [DEBUG] [dropbox] - done
        [DEBUG] [clean] - done
        [DEBUG] [telegram] start with {"type":"creator","time":"23:00","debugging":true,"slaveBackup":"Single","everyXDays":"1","nameSuffix":"Standard","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"10.0.1.22","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/io_backup","dirMinimal":"sharename/backupDir","user":"Christian","pass":"****","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data/history/","nameSuffix":"Standard","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"10.0.1.22","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/io_backup","dirMinimal":"sharename/backupDir","user":"Christian","pass":"****","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"Standard","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"10.0.1.22","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/io_backup","dirMinimal":"sharename/backupDir","user":"Christian","pass":"****","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"host":"10.0.1.203","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"Standard","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":5000,"hostName":"Standard","ignoreErrors":false,"systemLang":"de","time":"27. Maerz 2022 um 16:09 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":4000,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
        [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0
        [DEBUG] [telegram] - done
        [DEBUG] [historyHTML] - new history html values created
        [DEBUG] [historyHTML] - done
        [DEBUG] [historyJSON] - new history json values created
        [DEBUG] [historyJSON] - done
        [DEBUG] [historyHTML] start with {"type":"creator","time":"23:00","debugging":true,"slaveBackup":"Single","everyXDays":"1","nameSuffix":"Standard","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"10.0.1.22","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/io_backup","dirMinimal":"sharename/backupDir","user":"Christian","pass":"****","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data/history/","nameSuffix":"Standard","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"10.0.1.22","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/io_backup","dirMinimal":"sharename/backupDir","user":"Christian","pass":"****","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"Standard","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"10.0.1.22","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/io_backup","dirMinimal":"sharename/backupDir","user":"Christian","pass":"****","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"host":"10.0.1.203","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"Standard","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","ignoreErrors":false,"systemLang":"de","time":"27. Maerz 2022 um 16:09 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":5000,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":4000,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
        [DEBUG] [historyJSON] start with {"type":"creator","time":"23:00","debugging":true,"slaveBackup":"Single","everyXDays":"1","nameSuffix":"Standard","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"10.0.1.22","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/io_backup","dirMinimal":"sharename/backupDir","user":"Christian","pass":"****","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data/history/","nameSuffix":"Standard","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"10.0.1.22","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/io_backup","dirMinimal":"sharename/backupDir","user":"Christian","pass":"****","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"Standard","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"www27.world4you.com","debugging":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","user":"ftp6257055_iobroker","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"10.0.1.22","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/io_backup","dirMinimal":"sharename/backupDir","user":"Christian","pass":"****","ignoreErrors":false},"dropbox":{"enabled":true,"type":"storage","source":null,"debugging":true,"deleteOldBackup":true,"accessToken":"****","dropboxAccessJson":"LGJM6Vmh4bcAAAAAAAAAAeEO7FkmrhK5uFwX-WdJ_FW6vczZMv7KTodaYMaKaEel","dropboxTokenType":"default","ownDir":true,"bkpType":"Minimal","dir":"/backupDir/minimal","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","ignoreErrors":false},"host":"10.0.1.203","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"Standard","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","ignoreErrors":false,"systemLang":"de","time":"27. Maerz 2022 um 16:09 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":5000,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":4000,"hostName":"Standard","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
        [EXIT] 0
        • simatec
          simatec Developer Most Active @Negalein last edited by
          @negalein Hast du die neue Verknüpfung erstellt?
          • Negalein
            Ja
            simatec 3 Replies Last reply Reply Quote 0
            • simatec
              @negalein OK, ich schaue mal, ob man an der Dateigröße etwas ändern kann.
              Denke es liegt an der Größe des Backups
              • simatec
                @negalein Kannst du mir mal bitte den Inhalt der App "Backitup by ioBroker" zeigen?
                • Negalein
                  wo finde ich das?
                  • simatec
                    @negalein In deiner Dropbox ... Den direkten Inhalt des Ordners
                    • Negalein
                      Ah, das meintest du
                      • simatec
                        @negalein Wie groß ist dein aktuelles iobroker Backup
                        • Negalein
                          440 MB
                          • simatec
                            @negalein Wow ... was hast da denn alles drin.
                            Also meine erste Recherche hat ergeben, dass Dropbox wohl keine Dateien größer 150 MB zulässt
                            • Negalein
                              mehrere große Views, einige Adapter, usw. 😉
                              Ok, dann werd ich auf Lokal und FTP setzen.
                              • simatec
                                @negalein Warte mal ... Ich versuche das zu umgehen
                                • simatec
                                  Ab sofort steht die Version 2.4.0 auf Github und in kürze auch im latest zur Verfügung.
                                  Changelog
                                  2.4.0 (2022-03-28)
                                  • (simatec) Default History path added
                                  • (simatec) dependencies updated
                                  • (simatec) Dropbox default APP added
                                  • (simatec) Bugfix Info Messages
                                  • (simatec) Info Message for Script-Backup added
                                  • (simatec) Signal-cmb added
                                  • (simatec) many small Bugfixes
                                  • (simatec) Documentation updated
                                  amg_666 M 2 Replies Last reply Reply Quote 0
                                  • amg_666
                                    amg_666 @simatec last edited by
                                    @simatec Läuft bei mir (iob auf Master Slave mit je einer Backup-Instanz, Sicherung auf NAS per FTP), keine Fehlermeldungen oder so.👍
                                      MCU @simatec last edited by MCU
                                      @simatec Zurzeit wird bei der Extra-Sicherung von jarvis nur dessen Sicherungsdateien gesichert. In den Sicherungsdateien sind aber nicht immer alle DPs enthalten, da sie nur erstellt werden, wenn sich was in den DPS ändert.
                                      Sinnvoller wäre es in der Einzelsicherung von jarvis auch die DPs von jarvis zu haben, damit man bei einer Rücksicherung von jarvis nur die Extra-Sicherung nutzen kann.
                                      https://github.com/Zefau/ioBroker.jarvis/issues/1658
                                      mcuiobroker created this issue in Zefau/ioBroker.jarvis
                                      closed backitup-Sicherung anpassen #1658
                                      • simatec
                                        simatec Developer Most Active @MCU last edited by
                                        @mcu
                                        Mache mal bitte ein Issue mit allen relevanten DP‘s auf.
                                          @simatec https://github.com/simatec/ioBroker.backitup/issues/655
                                          mcuiobroker created this issue in simatec/ioBroker.backitup
                                          closed Adjust Detail-Backup from jarvis #655
                                          • simatec
                                            @mcu danke dir
                                            170
                                            2780
                                            2380158
