    4. Raspi Permission denied
    • Damrak2022
      Damrak2022 @liv-in-sky last edited by Damrak2022
      @liv-in-sky Ich wollte gerade über Instanzen die Vis aufrufen, bekomme da aber eine leere Seite angezeigt, wo steht: File edit.html not found: {}
      Was tun?
      Diese Fehler stehen im Log
      host.raspberrypi
      2022-03-28 08:19:05.368	error	Cannot download and install adapter "vis@1.4.12". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
      host.raspberrypi
      2022-03-28 08:19:03.342	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.12: 6
      vis.0
      2022-03-28 08:18:57.795	error	Not exists
      vis.0
      2022-03-28 08:18:57.794	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:463:21)
      vis.0
      2022-03-28 08:18:57.792	error	unhandled promise rejection: Not exists
      vis.0
      2022-03-28 08:18:57.791	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.raspberrypi
      2022-03-28 08:18:20.122	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.12: 6
      vis.0
      2022-03-28 08:18:16.632	error	Not exists
      vis.0
      2022-03-28 08:18:16.631	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:463:21)
      vis.0
      2022-03-28 08:18:16.629	error	unhandled promise rejection: Not exists
      vis.0
      2022-03-28 08:18:16.628	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.raspberrypi
      2022-03-28 08:17:33.303	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.12: 6
      vis.0
      2022-03-28 08:17:29.341	error	Not exists
      vis.0
      2022-03-28 08:17:29.340	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:463:21)
      vis.0
      2022-03-28 08:17:29.338	error	unhandled promise rejection: Not exists
      vis.0
      2022-03-28 08:17:29.337	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.raspberrypi
      2022-03-28 08:16:52.412	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.12: 6
      vis.0
      2022-03-28 08:16:43.538	error	Not exists
      vis.0
      2022-03-28 08:16:43.537	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:463:21)
      vis.0
      2022-03-28 08:16:43.531	error	unhandled promise rejection: Not exists
      vis.0
      2022-03-28 08:16:43.530	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        liv-in-sky @Damrak2022 last edited by
        @damrak2022
        evtl vis nochmal uploaden
        • Damrak2022
          Damrak2022 last edited by Damrak2022
          @liv-in-sky Da tut sich garnichts.
          Wenn ich in die Instanzeinstellungen der Vis gehe sehe ich das hier
          Bin mal 15 Minuten weg
            @damrak2022
            in der iobroker console (iterm) mal folgendes eingeben
            iobroker upload vis
            • Damrak2022
              @liv-in-sky Inn bekomme ich folgende Meldung:
              pi@raspberrypi:~ $ iobroker upload vis
              INFO: Directory "for vis.admin" was not found! Nothing was uploaded or deleted.
              Cannot find io-package.json for "vis"
              INFO: Directory "for vis" was not found! Nothing was uploaded or deleted.
              pi@raspberrypi:~ $ upload vis
              -bash: upload: command not found
              pi@raspberrypi:~ $
              Dann habe ich noch das versucht:
              pi@raspberrypi:~ $ cd /opt/iobroker
              pi@raspberrypi:/opt/iobroker $ iobroker stop vis
              The adapter "vis.0" was stopped.
              pi@raspberrypi:/opt/iobroker $ iobroker upload vis
                @damrak2022 probier es mit
                iob del vis.0
                iob add vis
                haselchen Damrak2022 2 Replies Last reply Reply Quote 0
                • haselchen
                  haselchen Most Active @crunchip last edited by haselchen
                  Irrtum , deswegen gelöscht
                    wir arbeiten gerade daran ........
                    • Damrak2022
                      Damrak2022 @crunchip last edited by
                      @crunchip So mit Hilfe von @liv-in-sky geht wieder alles. Das eine Problem as ich hatte war das mir die Vis nicht angezeigt wurde. Zum Glück ist jetzt alles wieder vorhanden. Danke an alle!
                        crunchip Forum Testing Most Active @Damrak2022 last edited by
                        @damrak2022 und woran lag es nun bzw was habt ihr gemacht?
                          @damrak2022
                          Wie gelöst?
                          • Damrak2022
                            Damrak2022 @sigi234 last edited by
                            @sigi234 das kann @liv-in-sky besser beantworten. Es hatte wohl etwas mit einer falschen repositiry zu tun. Da hat ersann einiges umgestellt und dann konnte auch die vis neu installiert werden.
                            • Latzi
                              Latzi last edited by
                              @liv-in-sky
                              ich habe exakt das gleiche Problem (nur kein Raspi sondern VM unter proxmox):
                              latzi@ioBroker:/opt/iobroker$ iobroker upload vis
                              Ich hab zuvor den Server getauscht und ein Backup eingespielt, bis auf vis funktioniert soweit mal alles.
                              Kannst du mir hier bitte weiterhelfen?
                                liv-in-sky @Latzi last edited by
                                @latzi
                                Soweit ich mich erinnere habe ich die repo Einstellungen wieder gerade biegen müssen
                                Siehe hier
                                https://forum.iobroker.net/post/784483
                                Weiss aber nicht, ob das auch dein Problem ist
                                  babl @Damrak2022 last edited by babl
                                  gelöscht
                                    This post is deleted!
                                    liv-in-sky Glasfaser 2 Replies Last reply Reply Quote 0
                                      liv-in-sky @babl last edited by
                                        babl @liv-in-sky last edited by babl
                                        Thomas Braun liv-in-sky 3 Replies Last reply Reply Quote 0
                                          Thomas Braun Most Active @babl last edited by Thomas Braun
                                            liv-in-sky @babl last edited by liv-in-sky
                                            1.3k
                                            59
                                            5639
