    4. Fehler beim js-controller update
      headder9999 @Thomas Braun last edited by
      @thomas-braun sagte in Fehler beim js-controller update:
      sudo apt update
      yes
        Thomas Braun Most Active @headder9999 last edited by Thomas Braun
        @headder9999 Zeigen.
        Komplette Ein- und Ausgaben.
          jawoll 🙂
          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:3 http://phoscon.de/apt/deconz buster InRelease
          Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
          Reading package lists... Done
          Building dependency tree
          All packages are up to date.
            @headder9999
            iobroker update -i
            Komplette Ein- und Ausgabe bedeutet inkl. Eingabezeile / prompt.
              so?
              user@iobroker-pi:~ $ iobroker update -i
              Used repository: stable
              hash changed or no sources cached => force download of new sources
              update done
              Adapter    "admin"         : 5.3.1    , installed 5.1.23 [Updateable]
              Adapter    "alarm"         : 3.0.5    , installed 2.0.2 [Updateable]
              Adapter    "backitup"      : 2.3.3    , installed 2.1.13 [Updateable]
              Adapter    "discovery"     : 2.7.5    , installed 2.7.0 [Updateable]
              Adapter    "history"       : 1.10.5   , installed 1.9.13 [Updateable]
              Adapter    "info"          : 1.9.8    , installed 1.9.8
              Adapter    "iot"           : 1.8.24   , installed 1.8.22 [Updateable]
              Adapter    "javascript"    : 5.2.21   , installed 5.2.21
              Controller "js-controller" : 4.0.21   , installed 3.2.16 [Updateable]
              Adapter    "net-tools"     : 0.1.7    , installed 0.1.5 [Updateable]
              Adapter    "ping"          : 1.5.0    , installed 1.5.0
              Adapter    "plenticore"    : 2.2.0    , installed 2.2.0
              Adapter    "simple-api"    : 2.6.2    , installed 2.6.1 [Updateable]
              Adapter    "socketio"      : 4.1.4    , installed 3.1.4 [Updateable]
              Adapter    "tr-064"        : 4.2.15   , installed 4.2.14 [Updateable]
              Adapter    "web"           : 4.2.0    , installed 3.4.7 [Updateable]
                @headder9999
                Ja, so.
                Bist aber eher ein Update-Muffel...
                iobroker upgrade
                  headder9999 @Thomas Braun last edited by headder9999
                  beim ersten update kommt gleich wieder ne npm fehlermeldung:
                  user@iobroker-pi:~ $ iobroker upgrade
                  Adapter "accuweather"    is not installed.
                  Adapter "adb"            is not installed.
                  Adapter "adguard"        is not installed.
                  Invalid version of "js-controller". Installed "3.2.16", required ">=3.3.22
                  Adapter "aio"            is not installed.
                  Adapter "airconwithme"   is not installed.
                  Adapter "airzone"        is not installed.
                  This upgrade of "alarm" will at least introduce the following changes:
                  -> 3.0.5:
                  fixed pushover issue
                  -> 3.0.4:
                  changed burgle concept, added silent alarm at sharp inside, fixed little issues
                  -> 2.2.1:
                  added notification when warnings at beginning night rest
                  -> 2.2.0:
                  added telegram special parameters
                  -> 2.1.2:
                  fixed "colors" vulnerabilities
                  -> 2.1.1:
                  added countdown state for silent alarm
                  -> 2.1.0:
                  extend list states and speech output, added leave option
                  BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                  Would you like to upgrade alarm from @2.0.2 to @3.0.5 now? [(y)es, (n)o]: y
                  Update alarm from @2.0.2 to @3.0.5
                  NPM version: 8.5.0
                  npm install iobroker.alarm@3.0.5 --loglevel error --prefix "/opt/iobroker" (System call)
                  npm ERR! code ENOTEMPTY
                  npm ERR! syscall rename
                  npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                  npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                  npm ERR! errno -39
                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                  npm ERR!     /home/iobroker/.npm/_logs/2022-03-29T20_31_11_681Z-debug-0.log
                  host.iobroker-pi Cannot install iobroker.alarm@3.0.5: 217
                    @headder9999 Alles?
                      @headder9999
                      sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                        done
                          @headder9999 Dann nochmal...
                          iobroker upgrade
                            Hi, da bin ich wieder...
                            der letzte Befehl brachte nicht den gewünschten Erfolg:
                            -> 3.0.5:
                            -> 3.0.4:
                            -> 2.2.1:
                            -> 2.2.0:
                            -> 2.1.2:
                            -> 2.1.1:
                            -> 2.1.0:
                            NPM version: 8.5.0
                            npm ERR! path /opt/iobroker/node_modules/typescript
                            npm ERR! dest /opt/iobroker/node_modules/.typescript-rKKYB1QG
                            npm ERR! errno -39
                            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/typescript' -> '/opt/iobroker/node_modules/.typescript-rKKYB1QG'
                            npm ERR!     /home/iobroker/.npm/_logs/2022-03-31T16_51_56_784Z-debug-0.log
                              @headder9999
                              Gleiche Nummer, anderes Modul...
                              Verzeichnis umbenennen.
                                so`?
                                sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.typescript-rKKYB1QG
                                  @headder9999
                                  Nein, der Quell-Ordner ist
                                    nachdem ich noch ein Verzeichnis veschoben habe habe ich iobroker upgrade self ausprobiert und erhalte nun zur Abwechslung die folgende Ausgabe:
                                    user@iobroker-pi:~ $ iobroker upgrade self
                                    Update js-controller from @3.2.16 to @4.0.21
                                    NPM version: 8.5.0
                                    npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                    Server Objects 127.0.0.1:44292 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                                    Server States 127.0.0.1:39272 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                                    Server Objects 127.0.0.1:44292 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                                    Server States 127.0.0.1:39274 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
                                    Server Objects 127.0.0.1:44292 Error from InMemDB: Error: Unknown LUA script load
                                    Server Objects 127.0.0.1:44292 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                                    Starting node restart.js
                                      headder9999 @headder9999 last edited by
                                      @Thomas-Braun
                                      Nun zeigt mit iobroker unter "hosts" an, dass js-controller nun die Version 4.0.21
                                      Soweit so gut
                                      aaaber wenn ich "admin" von 5.1.23 auf 5.3.1 update möchte sagt mir das System, dass der js-controller nur die Version 3.2.16
                                      Ich verstehe die Welt nicht mehr....
                                        @headder9999
                                        iobroker stop
                                        iobroker upload all
                                        iobroker update
                                        iobroker upgrade
                                        Die Adapter hättest du vor dem js-controller aktualisieren sollen.
                                          ...aber es scheint nun zu laufen. er updatet gerade die restlichen adapter.... sieht gut aus.
                                          danke bis hier her!!
                                            da bin ich wieder und wollte man wieder ein Update machen, um kein Update Muffel mehr zu sein.
                                            Jedoch bekomme ich wieder einen Fehler, als ich den Admin updaten wollte. So kam ich wieder zu diesem Eintrag im Forum. Habe gleiches durchgespielt, aber ich bekomme nichts geupdatet.
                                            Ich habe bereits iob update, iobroker upgrade -self probiert aber keine Chacne, immer die gleiche Meldung. Auch habe ich versucht den Host nach dortiger Anleitung zu updaten. Kein erfolg.
                                            Habt ihr eine Idee?
                                            5258
