    4. Neu bei ioBroker und Vis (ein MAX! Projekt).
    • opossum
      opossum @BastiBpunkt last edited by
      Hallo, @bastibpunkt,
      schaue bitte im Chat.
      opossum 1 Reply Last reply Reply Quote 0
      • opossum
        opossum @opossum last edited by
        ich habe mein projekt offiziell zum Download gestellt. Bitte hier entlang
        @opossum
          patricke21 @opossum last edited by
          @opossum said in Neu bei ioBroker und Vis (ein MAX! Projekt).:
          Hallo, @nettino,
          im Spoiler siehst Du, welche Adapter bei mir installiert sind.
          Adapter    "admin"         : 5.2.3    , installed 5.2.3
          Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
          Adapter    "backitup"      : 2.2.3    , installed 2.2.3
          Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
          Adapter    "deconz"        : 1.3.19   , installed 1.3.19
          Adapter    "discovergy"    : 0.5.8    , installed 0.5.8
          Adapter    "discovery"     : 2.7.3    , installed 2.7.3
          Adapter    "dwd"           : 2.7.7    , installed 2.7.7
          Adapter    "fakeroku"      : 0.2.1    , installed 0.2.1
          Adapter    "fb-checkpresence": 1.1.13  , installed 1.1.13
          Adapter    "feiertage"     : 1.1.0    , installed 1.1.0
          Adapter    "flot"          : 1.10.7   , installed 1.10.7
          Adapter    "harmony"       : 1.2.2    , installed 1.2.2
          Adapter    "heatingcontrol": 2.7.2    , installed 2.7.2
          Adapter    "history"       : 1.9.14   , installed 1.9.14
          Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
          Adapter    "hm-rpc"        : 1.15.0   , installed 1.15.0
          Adapter    "ical"          : 1.11.4   , installed 1.11.4
          Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
          Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
          Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
          Adapter    "info"          : 1.9.8    , installed 1.9.8
          Adapter    "javascript"    : 5.2.13   , installed 5.2.13
          Controller "js-controller" : 3.3.22   , installed 3.3.22
          Adapter    "logparser"     : 1.1.0    , installed 1.1.0
          Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
          Adapter    "nut"           : 1.5.0    , installed 1.5.0
          Adapter    "ph803w"        : 1.0.1    , installed 1.0.1
          Adapter    "ping"          : 1.5.0    , installed 1.5.0
          Adapter    "pollenflug"    : 1.0.6    , installed 1.0.6
          Adapter    "proxmox"       : 1.3.4    , installed 1.3.4
          Adapter    "pushover"      : 2.0.5    , installed 2.0.5
          Adapter    "robonect"      : 0.1.4    , installed 0.1.4
          Adapter    "shelly"        : 4.0.7    , installed 4.0.8
          Adapter    "shuttercontrol": 1.4.10   , installed 1.4.10
          Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
          Adapter    "socketio"      : 3.1.5    , installed 3.1.5
          Adapter    "sql"           : 1.15.7   , installed 1.15.7
          Adapter    "systeminfo"    : 0.3.1    , installed 0.3.1
          Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
          Adapter    "tesla-motors"  : 1.0.9    , installed 1.0.9
          Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
          Adapter    "trashschedule" : 1.4.1    , installed 1.4.1
          Adapter    "unifi"         : 0.5.10   , installed 0.5.10
          Adapter    "upnp"          : 1.0.19   , installed 1.0.19
          Adapter    "vis"           : 1.4.5    , installed 1.4.5
          Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
          Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
          Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
          Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
          Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
          Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
          Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
          Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
          Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
          Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
          Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
          Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
          Adapter    "vw-connect"    : 0.0.48   , installed 0.0.48
          Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
          Adapter    "web"           : 3.4.16   , installed 3.4.16
          Adapter    "wled"          : 0.6.3    , installed 0.6.3
          @opossum
          Bitte entschuldige mein Anliegen. Ich nutze IoBroker seit nun 5 Tagen und verstehe zu 90% Nur Bahnhof.
          Die Suche nach den Adaptern VIS gibt mir eine große Anzahl an Suchergebnissen zurück. Jedoch finde ich keinen Adapter der nur VIS heißt.
          könntest du mir hier helfen. Ich würde auch gern deine Steuerung für meine Max!Cube Komponenten nutzen.
          Ich bedanke mich für deine Hilfe und verbleibe
          mit freundlichen Grüßen
          patricke21
          C mickym 2 Replies Last reply Reply Quote 0
            Cino @patricke21 last edited by
            • mickym
              mickym Most Active @patricke21 last edited by mickym
              @patricke21
              Du wirst trotzdem noch Dein originales Webinterface brauchen, da Du mit dem Adapter die Zeitprofile nicht ändern kannst. Ich hoffe Dir ist das klar.
                patricke21 @mickym last edited by
                @mickym said in Neu bei ioBroker und Vis (ein MAX! Projekt).:
                @patricke21
                Es geht mir hautsächlich darum, dass ich die Heizung weiterhin über das Internet regeln kann, wenn MAX! diese Funktion 2023 aufkündigt.
                Die Zeit Profile habe ich die letzten 6 Jahre nicht geändert. Die sind gut optimiert 😉 .
                • mickym
                  @patricke21 Nun gerade wenn Du die Heizung über das Internet steuern willst, musst Du Dir aber um einen Remote Zugriff Gedanken machen und im Übrigen sag ich ja nur, dass Du die App nicht wegschmeißen sollst, falls Du doch mal was ändern musst. Der Adapter gibt Dir soweit ich weiß keinen Zugriff auf die Zeitprofile - deshalb habe ich mein fhem System immer noch laufen. 😉
                    Cino last edited by
                    Die Zeitprofile kriegt er mit Heating Control auch hin.
                    • mickym
                      mickym Most Active @Cino last edited by mickym
                      @cino Na wenn Du meinst - Heating Control kann nur digital auf und zu machen (bzw. ab und anschalten) - das wird nie an eine interne Hardwaresteuerung der Thermostaten heranreichen. Aber ich will hier keine Diskussion aufmachen. Jeder soll machen, wie er meint. Soweit ich in Erinnerung habe, wird ja nicht die Temperatur im Zeitprofil angesteuert, sondern auch die Temperatur über den Adapter gesteuert.
                        Cino @mickym last edited by
                        @mickym Heatingcontrol gibt eine Soll Temperatur vor. Die Regelung macht das Thermostat selber. Genau so wie die Max App.
                        • mickym
                          @cino sagte in Neu bei ioBroker und Vis (ein MAX! Projekt).:
                          Na dann ist ja gut, wenn es sich so verhält. 🙂
                          • U
                            uk68 last edited by
                            Wow, das sieht mal Super aus, ich bin hier neu und bin fleißig am Basteln! kann man sowas als Vorlage speichern?
                            Die Widgets von Vis für Thermostate sind da ja nicht so Tool.
                            würde mich über deine Freuen 😉
                              Snert @opossum last edited by
                              Ich baue die Widgets einzeln, in der Hauptansicht kommt dann das Basic View in Widget zum Einsatz. Hat den Vorteil, dass ich bei Änderungen in einer Ansicht nur die eine View pflegen muss. Diese Thermostatview ist also 9 mal auf der Grundansicht eingebaut.
                              Kannst du mir das evtl. genauer erläutern?
                              Ich habe mir jetzt eine neue View "Thermostat_Vorlage" erstellt und in dieser habe ich jetzt 1x alles so aufgebaut (inkl. der Datenpunkte für ein Thermostat) wie es gerne hätte.
                              Auf meiner View "Thermostat_Übersicht" kann ich 1x ohne Probleme die "Thermostat_Vorlage" über das Widget "View in Widget" einfügen. Sobal ich ein weiteres Widget mit dem Vorlagenview hinzufüge, verschwindet das andere.
                              Ebenso die Frage: Wie kann ich innerhalb der "View in Widget" die Datenpunkte anpassen, ohne damit auch die Vorlage zu ändern?
                              Vielen Dank
                                Fast Eddy @uk68 last edited by
                                Hallo Opossum,
                                hätte auch Interesse an deinem Projekt, könntest du mir das zur Verfügung stellen ?
                                Fast Eddy
                                vis
                                60
                                125
                                31021
