    4. Test Adapter vodafone-speedtest v0.0.x GitHub/Latest
    • O
      oxident last edited by
      Gleiches Problem wie @JohGre
        JayBa last edited by
        hier auch das gleich Problem
          Thomas Braun Most Active @JayBa last edited by
          @jayba @oxident @JohGre
          https://github.com/peterbaumert/ioBroker.vofo-speedtest/issues/76
          jk-andersen created this issue in peterbaumert/ioBroker.vofo-speedtest
          closed Adapter not working suddenly #76
          • JohGre
            JohGre last edited by
            Bei mir funktioniert der Adapter seit gestern Nachmittag nicht mehr. Auch aus dem Log ist nicht wirklich was ersichtlich. Ist da was bekannt.
            2022-03-30 09:48:00.435 - debug: vofo-speedtest.0 (5218) Redis Objects: Use Redis connection: 10.0.0.227:9001
            2022-03-30 09:48:00.462 - debug: vofo-speedtest.0 (5218) Objects client ready ... initialize now
            2022-03-30 09:48:00.464 - debug: vofo-speedtest.0 (5218) Objects create System PubSub Client
            2022-03-30 09:48:00.465 - debug: vofo-speedtest.0 (5218) Objects create User PubSub Client
            2022-03-30 09:48:00.499 - debug: vofo-speedtest.0 (5218) Objects client initialize lua scripts
            2022-03-30 09:48:00.504 - debug: vofo-speedtest.0 (5218) Objects connected to redis: 10.0.0.227:9001
            2022-03-30 09:48:00.505 - silly: vofo-speedtest.0 (5218) redis psubscribe cfg.o.system.user.*
            2022-03-30 09:48:00.525 - silly: vofo-speedtest.0 (5218) redis psubscribe cfg.o.enum.*
            2022-03-30 09:48:00.527 - silly: vofo-speedtest.0 (5218) objectDB connected
            2022-03-30 09:48:00.528 - debug: vofo-speedtest.0 (5218) Redis States: Use Redis connection: 10.0.0.227:9000
            2022-03-30 09:48:00.543 - debug: vofo-speedtest.0 (5218) States create System PubSub Client
            2022-03-30 09:48:00.544 - debug: vofo-speedtest.0 (5218) States create User PubSub Client
            2022-03-30 09:48:00.570 - debug: vofo-speedtest.0 (5218) States connected to redis: 10.0.0.227:9000
            2022-03-30 09:48:00.571 - silly: vofo-speedtest.0 (5218) statesDB connected
            2022-03-30 09:48:00.664 - debug: vofo-speedtest.0 (5218) Plugin sentry Initialize Plugin (enabled=true)
            2022-03-30 09:48:00.941 - info: vofo-speedtest.0 (5218) starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.vofo-speedtest, node: v14.19.1, js-controller: 4.0.21
            2022-03-30 09:48:00.998 - silly: vofo-speedtest.0 (5218) States system redis pmessage system.adapter.vofo-speedtest.0.logLevel/system.adapter.vofo-speedtest.0.logLevel:{"val":"silly","ack":true,"ts":1648626480968,"q":0,"from":"system.adapter.vofo-speedtest.0","lc":1648626480968}
            2022-03-30 10:03:00.003 - warn: host.VM-Slave instance system.adapter.vofo-speedtest.0 already running with pid 5218
            dontobi Thomas Braun RK62 3 Replies Last reply Reply Quote 0
            • dontobi
              dontobi @JohGre last edited by
              @johgre Die Entwicklung des Adapters würde entweder eingestellt oder geschieht sehr schleppend. Schade.
              Aber daher habe ich mich vor einiger Zeit nach einer Alternative umgesehen. Ich bin dann auf den Docker Container SpeedFlux gestoßen. Jedoch gab es diesen nicht für ARM Geräte. Daher habe ich den Container so angepasst und unter SpeedFlux.rpi veröffentlicht. Vielleicht wäre das was für den ein oder anderen.
              https://github.com/dontobi/SpeedFlux.rpi
                Thomas Braun Most Active @JohGre last edited by
                @johgre
                Oder das Skript von @SKB verwenden.
                Findest du über die Suchfunktion:
                Kreyenborg
                als Suchbegriff.
                • SKB
                  SKB Developer Most Active last edited by SKB
                  ... oder direkt als Link 🙂
                  https://www.kreyenborg.koeln/speedtest-fuer-iobroker/
                  Gruß,
                  Stephan
                  • RK62
                    RK62 @JohGre last edited by
                    @johgre Ich hatte diesen Docker-Container mal getestet, der arbeitet recht zuverlässig und ist optisch auch nett aufgemacht: https://github.com/henrywhitaker3/Speedtest-Tracker
                    Mittlerweile habe ich den ookla-Speedtest in eine eigene Docker-Maschine gelegt, die dann regelmäßig ein Testergebnis für den ioBroker bereit stellt und dort dann visualisiert wird.
                    • JohGre
                      Danke an alle und @SKB für das Script werde es nun mal etwas testen
                        Thomas Braun Most Active @JohGre last edited by Thomas Braun
                        @johgre
                        Hier hab ich noch ein paar Ergänzungen zum Skript aufgeschrieben:
                        https://forum.iobroker.net/topic/48700/speedtest-skript-von-kreyenborg-koeln-für-kabel-gigabit
                        Da wird u. a. die speedtest binairy sauberer im System installiert.
                        JohGre 1 Reply Last reply Reply Quote 1
                        • JohGre
                          JohGre @Thomas Braun last edited by
                          @thomas-braun Super, danke für den Link und läuft schon. Ich musste aber noch in die sudoers.d von iobroker den Pfad zu speedtest eintragen damits dann wirklich lief.
                          sudo nano /etc/sudoers.d/iobroker
                          iobroker ALL=(ALL) NOPASSWD: /usr/bin/speedtest
                            @johgre sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                            Musste ich nicht. Warum auch?
                            echad@chet:~ $ which speedtest
                            /usr/bin/speedtest
                            echad@chet:~ $ ls -l /usr/bin/speedtest
                            -rwxr-xr-x 1 root root 2471896 Nov 17 23:26 /usr/bin/speedtest
                            echad@chet:~ $
                              Bongo last edited by
                              Habe ich nun auch installiert. Funktioniert! Danke.
                              Was ist der Unterschied zu den Datenpunkten download_Mb und download_Mb_calc?
                                mx-driver last edited by
                                Im Moment bekomme ich den Fehler:
                                instance system.adapter.vofo-speedtest.0 already running with pid 21677
                                Immer wenn er einen Speedtest machen sollte.
                                Hat das sonst noch jemand?
                                • Knallochse
                                  Knallochse last edited by
                                  Installation unter Node Version 18.15.0 nicht mehr möglich
                                  $ iobroker add vofo-speedtest auto --host buanet-iobroker1 --debug
                                  NPM version: 9.5.0
                                  Installing iobroker.vofo-speedtest@0.0.13... (System call)
                                  npm ERR! code 1
                                  npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-libcurl/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/.cache/node-gyp/18.15.0/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/18.15.0',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/18.15.0/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-libcurl',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Could not run curl-config, please make sure libcurl dev package is installed.
                                  npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2023-04-04T09_56_47_982Z-debug-0.log
                                  host.buanet-iobroker1 Cannot install iobroker.vofo-speedtest@0.0.13: 1
                                  ERROR: Process exited with code 25
                                  Github Issues dazu
                                  • wendy2702
                                    wendy2702 @Knallochse last edited by
                                    @knallochse sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                                    Mal hier gschaut: https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/2
                                      Thomas Braun Most Active @wendy2702 last edited by
                                      @wendy2702
                                      Du bist zu spät. Wurde schon gelöst:
                                      Kein Issue mit nodejs, da fehlen dev-packages.
                                      sudo apt update
                                      apt policy libcurl4-gnutls-dev libcurl4-nss-dev libcurl4-openssl-dev
                                      • wendy2702
                                        wendy2702 @Thomas Braun last edited by
                                        @thomas-braun Ups...
                                        OK.
                                          PatrickFro last edited by
                                          Moin,
                                          ich habe den Adapter gerade erst gefunden und installiert. So wie es scheint wird er ja nun doch weiterentwickelt, zumindest gab es einige Änderungen im letzten Monat.
                                          Ich verstehe die Ergebnisse jedoch noch nicht:
                                          9b7898b3-a51f-4574-92ba-4dd798486539-image.png im Vergleich zu baeddd3f-17c8-40c9-8d9c-148a2baf8fc2-image.png
                                          Schaue ich mir die Downloadraten an, sehe ich über die Webseite vom Speedtest 269 Mbit/s, über den Adapter eine Minute vor der Messung per Webseite 55,842 MB/s.
                                          Wenn ich die verschiedenen Werte richtig zuordnete, müsste ich bei MB/s x 8,25 rechnen um auf Mbit/s zu kommen. Das aber ergäbe 470 Mbit/s. Wo ist hier mein Denkfehler?
                                          • wollerosekaufe
                                            wollerosekaufe last edited by wollerosekaufe
                                            verstehe es auch nicht so ganz.
                                            auf npm ist version 1.0.1, aber nur dependencies aktualisiert und kein release.
                                            haben wir noch chancen dass der adapter gefixt wird? @Bluefox @peterbaumert 🙂
                                            anyway, der adapter läuft bei mir nicht. habe ebenso das problem von @PatrickFro mit VIEL zu niedrigen DL rates.
                                            dazu klappt der UL test erst gar nicht, der adapter stoppt einfach "ohne fehlermeldung", vofo-speedtest.0.Results.upload_MB etc. bleibt alles leer.
                                            host.iobroker
                                            	2023-11-17 22:57:39.204	info	instance system.adapter.vofo-speedtest.0 terminated with code 0 (NO_ERROR)
                                            vofo-speedtest.0
                                            	2023-11-17 22:57:38.631	info	Terminated (NO_ERROR): Without reason
                                            vofo-speedtest.0
                                            	2023-11-17 22:57:38.577	info	cleaned everything up...
                                            vofo-speedtest.0
                                            	2023-11-17 22:57:38.576	info	starting cleanup...
                                            vofo-speedtest.0
                                            	2023-11-17 22:57:38.563	info	Vofo-Speedtest finished with 184.013mbit download speed and 0mbit upload speed.
                                            vofo-speedtest.0
                                            	2023-11-17 22:57:04.317	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.vofo-speedtest, node: v18.18.2, js-controller: 5.0.16
                                            host.iobroker
                                            	2023-11-17 22:57:00.080	info	instance system.adapter.vofo-speedtest.0 started with pid 509363
                                            mit CURL ist das ganze noch schlimmer, da crasht der adapter mit UNCAUGHT_EXCEPTION:
                                            host.iobroker
                                            	2023-11-17 23:01:44.523	error	instance system.adapter.vofo-speedtest.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                            vofo-speedtest.0
                                            	2023-11-17 23:01:43.944	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            vofo-speedtest.0
                                            	2023-11-17 23:01:43.941	info	terminating
                                            vofo-speedtest.0
                                            	2023-11-17 23:01:43.938	info	cleaned everything up...
                                            vofo-speedtest.0
                                            	2023-11-17 23:01:43.937	info	starting cleanup...
                                            vofo-speedtest.0
                                            	2023-11-17 23:01:43.799	error	Curl handle is closed.
                                            vofo-speedtest.0
                                            	2023-11-17 23:01:43.798	error	Error: Curl handle is closed. at Curl.close (/opt/iobroker/node_modules/node-libcurl/dist/Curl.js:588:21) at VofoSpeedtest.stopDownloadTest (/opt/iobroker/node_modules/iobroker.vofo-speedtest/main.js:824:29) at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.vofo-speedtest/main.js:540:39) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
                                            vofo-speedtest.0
                                            	2023-11-17 23:01:43.787	error	uncaught exception: Curl handle is closed.
                                            vofo-speedtest.0
                                            	2023-11-17 23:00:03.861	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.vofo-speedtest, node: v18.18.2, js-controller: 5.0.16
                                            host.iobroker
                                            	2023-11-17 23:00:00.125	info	instance system.adapter.vofo-speedtest.0 started with pid 509581
                                            iobroker läuft auf buanet/docker mit libcurl4-openssl-dev package
                                            btw: bei mir wird die config nicht richtig aktualisiert, daher meldet npm permanent die alte version. alle anderen dateien werden sauber von 1.0.1 geladen, code auf dem iobroker entspricht den neuen github files - das update klappt also. adapter mehrmals de- und neu installiert, hilft nichts. hab die config nun manuell angepasst damit die update-meldung nicht nervt.
                                            31.7k
                                            79.8k
                                            vodafone speedtest
                                            42
                                            202
                                            25307
