    4. Fehler beim js-controller update
      headder9999 @Thomas Braun last edited by headder9999
      beim ersten update kommt gleich wieder ne npm fehlermeldung:
      user@iobroker-pi:~ $ iobroker upgrade
      Adapter "accuweather"    is not installed.
      Adapter "adb"            is not installed.
      Adapter "adguard"        is not installed.
      Invalid version of "js-controller". Installed "3.2.16", required ">=3.3.22
      Adapter "aio"            is not installed.
      Adapter "airconwithme"   is not installed.
      Adapter "airzone"        is not installed.
      This upgrade of "alarm" will at least introduce the following changes:
      -> 3.0.5:
      fixed pushover issue
      -> 3.0.4:
      changed burgle concept, added silent alarm at sharp inside, fixed little issues
      -> 2.2.1:
      added notification when warnings at beginning night rest
      -> 2.2.0:
      added telegram special parameters
      -> 2.1.2:
      fixed "colors" vulnerabilities
      -> 2.1.1:
      added countdown state for silent alarm
      -> 2.1.0:
      extend list states and speech output, added leave option
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade alarm from @2.0.2 to @3.0.5 now? [(y)es, (n)o]: y
      Update alarm from @2.0.2 to @3.0.5
      NPM version: 8.5.0
      npm install iobroker.alarm@3.0.5 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
      npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
      npm ERR!     /home/iobroker/.npm/_logs/2022-03-29T20_31_11_681Z-debug-0.log
      host.iobroker-pi Cannot install iobroker.alarm@3.0.5: 217
        Thomas Braun Most Active @headder9999 last edited by
        @headder9999 Alles?
          @headder9999
          sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
            @thomas-braun sagte in Fehler beim js-controller update:
            done
              @headder9999 Dann nochmal...
              iobroker upgrade
                Hi, da bin ich wieder...
                der letzte Befehl brachte nicht den gewünschten Erfolg:
                -> 3.0.5:
                -> 3.0.4:
                -> 2.2.1:
                -> 2.2.0:
                -> 2.1.2:
                -> 2.1.1:
                -> 2.1.0:
                NPM version: 8.5.0
                npm ERR! path /opt/iobroker/node_modules/typescript
                npm ERR! dest /opt/iobroker/node_modules/.typescript-rKKYB1QG
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/typescript' -> '/opt/iobroker/node_modules/.typescript-rKKYB1QG'
                npm ERR!     /home/iobroker/.npm/_logs/2022-03-31T16_51_56_784Z-debug-0.log
                  Thomas Braun Most Active @headder9999 last edited by Thomas Braun
                  @headder9999
                  Gleiche Nummer, anderes Modul...
                  Verzeichnis umbenennen.
                    so`?
                    sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.typescript-rKKYB1QG
                      @headder9999
                      Nein, der Quell-Ordner ist
                        nachdem ich noch ein Verzeichnis veschoben habe habe ich iobroker upgrade self ausprobiert und erhalte nun zur Abwechslung die folgende Ausgabe:
                        user@iobroker-pi:~ $ iobroker upgrade self
                        Update js-controller from @3.2.16 to @4.0.21
                        NPM version: 8.5.0
                        npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                        Server Objects 127.0.0.1:44292 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                        Server States 127.0.0.1:39272 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                        Server Objects 127.0.0.1:44292 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                        Server States 127.0.0.1:39274 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
                        Server Objects 127.0.0.1:44292 Error from InMemDB: Error: Unknown LUA script load
                        Server Objects 127.0.0.1:44292 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                        Starting node restart.js
                          headder9999 @headder9999 last edited by
                          @Thomas-Braun
                          Nun zeigt mit iobroker unter "hosts" an, dass js-controller nun die Version 4.0.21
                          Soweit so gut
                          aaaber wenn ich "admin" von 5.1.23 auf 5.3.1 update möchte sagt mir das System, dass der js-controller nur die Version 3.2.16
                          Ich verstehe die Welt nicht mehr....
                            @headder9999
                            iobroker stop
                            iobroker upload all
                            iobroker update
                            iobroker upgrade
                            Die Adapter hättest du vor dem js-controller aktualisieren sollen.
                              ...aber es scheint nun zu laufen. er updatet gerade die restlichen adapter.... sieht gut aus.
                              danke bis hier her!!
                                da bin ich wieder und wollte man wieder ein Update machen, um kein Update Muffel mehr zu sein.
                                Jedoch bekomme ich wieder einen Fehler, als ich den Admin updaten wollte. So kam ich wieder zu diesem Eintrag im Forum. Habe gleiches durchgespielt, aber ich bekomme nichts geupdatet.
                                Ich habe bereits iob update, iobroker upgrade -self probiert aber keine Chacne, immer die gleiche Meldung. Auch habe ich versucht den Host nach dortiger Anleitung zu updaten. Kein erfolg.
                                Habt ihr eine Idee?
                                  crunchip Forum Testing Most Active @headder9999 last edited by crunchip
                                  @headder9999 sagte in Fehler beim js-controller update:
                                  die aktuell nur du siehst😜
                                    headder9999 @crunchip last edited by
                                    @crunchip
                                    Oh...
                                    pi@iobroker-pi:~ $ iob upgrade
                                    This upgrade of "yamaha" will introduce the following changes:
                                    -> 0.5.3:
                                    Fix crash cases reported by Sentry
                                    -> 0.5.2:
                                    Would you like to upgrade yamaha from @0.5.1 to @0.5.3 now? [(y)es, (n)o]: y
                                    Update yamaha from @0.5.1 to @0.5.3
                                    NPM version: 8.19.3
                                    Installing iobroker.yamaha@0.5.3... (System call)
                                    host.iobroker-pi Cannot install iobroker.yamaha@0.5.3: 217
                                    Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                      @headder9999
                                      Ist oben angepinnt...
                                          was heißt oben angepinnt?
                                            5258
