    5. Blockly für komplizierte Bedingung (Anfänger) (gelöst)
    • MaHott1980
      MaHott1980 @MaHott1980 last edited by
      @mahott1980 ```
      <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="eEyVHWnQ}Z}cpRx-0.Y^" x="138" y="-288">
      <mutation xmlns="http://www.w3.org/1999/xhtml" items="4"></mutation>
      <value name="OID0">
      <shadow type="field_oid" id=",Y,{Q|B}e?PxnX?ecNqI">
      <field name="oid">hm-rpc.0.IEQ0090247.1.STATE</field>
      <value name="OID1">
      <shadow type="field_oid" id="9zybvEs@h6CKG6|8yg3d">
      <field name="oid">hm-rpc.0.IEQ0523289.1.STATE</field>
      <value name="OID2">
      <shadow type="field_oid" id="~_,CkTU6ia5aB}bYI4co">
      <field name="oid">hm-rpc.0.IEQ0523298.1.STATE</field>
      <value name="OID3">
      <shadow type="field_oid" id="Wc;!]SW2ejzJ|Z+Dpc@"> <field name="oid">hm-rpc.0.IEQ0523303.1.STATE</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="yZos~Z3L=*$dz0t.rZHo"> <mutation else="1"></mutation> <value name="IF0"> <block type="logic_operation" id="w-whnICxoOKR2%vrKoB~" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_operation" id="[0:ogLWg/pN!d9Azq~{" inline="false">
      <block type="logic_operation" id="[}WJD[__J+^].|ElF(r5" inline="false">
      <block type="get_value" id="M%SQIZzKZIn{!Yqc.Sm"> <field name="ATTR">val</field> <field name="OID">hm-rpc.0.IEQ0090247.1.STATE</field> </block> </value> <value name="B"> <block type="get_value" id="pRY*In!5D^gsg!jl{6k7"> <field name="ATTR">val</field> <field name="OID">hm-rpc.0.IEQ0523289.1.STATE</field> </block> </value> </block> </value> <value name="B"> <block type="logic_operation" id="7ImAaTbV=MjXrSvPbpXH" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="get_value" id="(N%F^c#QO5Au6i[c1NzV"> <field name="ATTR">val</field> <field name="OID">hm-rpc.0.IEQ0523298.1.STATE</field> </block> </value> <value name="B"> <block type="get_value" id="XwbC]DB*T0G#[-ln+7H">
      <field name="OID">hm-rpc.0.IEQ0523303.1.STATE</field>
      <block type="logic_negate" id="9R$ITMunsx8R;2~*c~zw">
      <value name="BOOL">
      <block type="variables_get" id="Fz`cMWR,JmYeVI%G@SsA">
      <field name="VAR" id="Zw%u#sW?jv8%CiGB~ej3">Aktiviert</field>
      <block type="timeouts_settimeout" id="~oqtL(;ne1#.6yP1wjWA">
      <field name="DELAY">10</field>
      <block type="control" id="]MkGYm#]Q5%HhTp04d?4">
      <field name="OID">sonoff.0.Steckdose3.POWER</field>
      <block type="logic_boolean" id="YSHyA:rGWzEz=0?1~w0+">
      <block type="variables_set" id="|9G;KFzvZ[cW,jKx1wQJ">
      <block type="logic_boolean" id="^?k43,OFse)2m:Au(B(^">
      <statement name="ELSE">
      <block type="debug" id="WQ#phFmV9?C38Qa[!FF$">
      <value name="TEXT">
      <shadow type="text" id="QcpPlY9|I1_B$j8W:]$Z">
      <field name="TEXT">test1</field>
      <block type="timeouts_cleartimeout" id="Y%WMPojL:5W%)Tyv(mp:">
      MaHott1980 1 Reply Last reply Reply Quote 0
      • MaHott1980
        MaHott1980 @MaHott1980 last edited by MaHott1980
        code_text
        <block xmlns="https://developers.google.com/blockly/xml" type="schedule" id="qc%grAk|^t[Uqj-9C3?d" x="512" y="138">
          <field name="SCHEDULE">0 4 * * *</field>
            <block type="debug" id="=L-BX{3r.[VEQDc[wH:a">
              <value name="TEXT">
                <shadow type="text" id="2-HNJmbNYiXS#CE_wD!5">
                  <field name="TEXT">test2</field>
                <block type="variables_set" id="/WF-8D#Q$EgUSjCH-],2">
                    <block type="logic_boolean" id="cfWO4h,I%D%ma2S~u8mp">
        MaHott1980 paul53 2 Replies Last reply Reply Quote 0
        • MaHott1980
          code_text
            <value name="OID0">
            <value name="OID1">
            <value name="OID2">
            <value name="OID3">
              <shadow type="field_oid" id="Wc;!`]SW2ejzJ|Z+Dpc@">
                      <block type="logic_operation" id="[0:ogLWg/pN!d9A`zq~{" inline="false">
                              <block type="get_value" id="M%`SQIZzKZIn{!Yqc.Sm">
                              <block type="get_value" id="XwbC`]DB*T0G#[-ln+7H">
                        <value name="BOOL">
                  <block type="debug" id="Fiy:h@f,%|)40xF.C[Fg">
                    <value name="TEXT">
                      <shadow type="text" id="zNi4cgKQmW78fqmg?0J#">
            paul53 @MaHott1980 last edited by paul53
            @mahott1980
            Sind das etwa zwei verschiedene Skripte?
            Das Rücksetzen der Variablen Aktiviert muss im gleichen Skript erfolgen.
            • MaHott1980
              MaHott1980 @paul53 last edited by
              So also ohne die debug output??
              paul53 MaHott1980 2 Replies Last reply Reply Quote 0
                @mahott1980 sagte: So also ohne die debug output??
                Nein, Zeitplan außerhalb des Trigger-Blocks - so wie in meinen Bildern.
                • MaHott1980
                  @mahott1980
                  Ja aber so geht es nicht, und ich bekomme es nicht raus warum.😥
                    @mahott1980 sagte: so geht es nicht, und ich bekomme es nicht raus warum
                    Ändere die Uhrzeit zum Test auf 20:xx Uhr (kurz nach der aktuellen Zeit) und schau, ob die Logausgabe mit "test2" erfolgt.
                    • MaHott1980
                      MaHott1980 @paul53 last edited by MaHott1980
                      20:16:53.567 info javascript.0 (1172) Start javascript script.js.Louis_Zimmer.Louis_PC
                      20:16:53.570 info javascript.0 (1172) script.js.Louis_Zimmer.Louis_PC: registered 1 subscription and 1 schedule
                      20:18:00.018 info javascript.0 (1172) script.js.Louis_Zimmer.Louis_PC: test2
                      Würde sagen das es geht, nur das Steckdose auschalten nicht. Die Bleibt an.
                      Es ist doch zum Testen egal ob ich die Steckdose von Hand wieder anschalte oder?? Den das Aktivieren geht ja.
                        @mahott1980 sagte: nur das Steckdose auschalten nicht. Die Bleibt an.
                        Ich war nach Deinem ersten Beitrag der Meinung, dass die Steckdose manuell ausgeschaltet wird und nur einmal täglich automatisch einschalten soll.
                        Soll sie um 4:00 Uhr automatisch ausgeschaltet werden? Dann
                        • MaHott1980
                          Nein sie sollte immer wieder resettet werden sonst geht das bei Kindern in die Hose ; ))
                          • MaHott1980
                            Super jetzt geht es. Beim 1 mal nicht aber da war der Debug Mode Schuld laut Log. Mega Dank an Dich/Euch.
                            1699
