    4. TESTER: Neuer Adapter Webuntis
      SigiMOE @elektrickser.de last edited by
      @elektrickser-de Wäre super wenn Du mir es dann zur Verfügung stellen könntest
        jwedenig Most Active @SigiMOE last edited by
        Hi!
        Ich schaffe es leider in beide meiner Schulen meiner Kinder mich nicht einzuloggen mit dem Adapter, Hier das Log:
        Wer eine Idee?
        host.raspberrypi
        2022-03-30 12:42:27.830	error	instance system.adapter.webuntis.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
        webuntis.0
        2022-03-30 12:42:27.116	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
        webuntis.0
        2022-03-30 12:42:27.056	error	adapter disabled
        host.raspberrypi
        2022-03-30 12:41:57.638	info	"system.adapter.webuntis.0" disabled
        host.raspberrypi
        2022-03-30 12:41:54.661	info	Restart adapter system.adapter.webuntis.0 because enabled
        host.raspberrypi
        2022-03-30 12:41:54.660	error	instance system.adapter.webuntis.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        webuntis.0
        2022-03-30 12:41:53.981	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        webuntis.0
        2022-03-30 12:41:53.980	info	terminating
        webuntis.0
        2022-03-30 12:41:53.968	error	Server didn't returned any result.
        webuntis.0
        2022-03-30 12:41:53.967	error	Error: Server didn't returned any result. at WebUntis._request (/opt/iobroker/node_modules/webuntis/index.js:643:42) at processTicksAndRejections (internal/process/task_queues.js:97:5) at async WebUntis.getOwnTimetableForToday (/opt/iobroker/node_modules/webuntis/index.js:300:16)
        webuntis.0
        2022-03-30 12:41:53.966	error	unhandled promise rejection: Server didn't returned any result.
        webuntis.0
        2022-03-30 12:41:53.965	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        webuntis.0
        2022-03-30 12:41:53.629	info	starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.webuntis, node: v12.22.6, js-controller: 4.0.21
        host.raspberrypi
        2022-03-30 12:41:51.171	info	instance system.adapter.webuntis.0 started with pid 6637
        host.raspberrypi
        2022-03-30 12:41:50.811	info	"system.adapter.webuntis.0" enabled
        host.raspberrypi
        2022-03-30 12:41:29.084	info	"system.adapter.webuntis.0" disabled
        host.raspberrypi
        2022-03-30 12:41:25.704	info	Restart adapter system.adapter.webuntis.0 because enabled
        host.raspberrypi
        2022-03-30 12:41:25.703	error	instance system.adapter.webuntis.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        webuntis.0
        2022-03-30 12:41:24.980	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        webuntis.0
        2022-03-30 12:41:24.979	info	terminating
        webuntis.0
        2022-03-30 12:41:24.965	error	Server didn't returned any result.
        webuntis.0
        2022-03-30 12:41:24.965	error	Error: Server didn't returned any result. at WebUntis._request (/opt/iobroker/node_modules/webuntis/index.js:643:42) at processTicksAndRejections (internal/process/task_queues.js:97:5) at async WebUntis.getOwnTimetableForToday (/opt/iobroker/node_modules/webuntis/index.js:300:16)
        webuntis.0
        2022-03-30 12:41:24.964	error	unhandled promise rejection: Server didn't returned any result.
        webuntis.0
        2022-03-30 12:41:24.963	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        webuntis.0
        2022-03-30 12:41:24.485	info
        Newan 1 Reply Last reply Reply Quote 0
        • Newan
          Newan @jwedenig last edited by
          @jwedenig welche Version ist das ?
          Sind die Daten eingetragen? Sehr komisches Fehlermeldung
            jwedenig Most Active @Newan last edited by
            @newan
            Die version ist 0.3.1
            Liebe Grüße
            Jürgen
            • Newan
              @jwedenig teste mal 0.3.2 aus dem latest zweig
                @newan
                ja das wars, danke!
                Gibt es schon eine Vis zum Testen?
                Würde mich freuen!
                Liebe Grüße
                Jürgen
                • ioT4db
                  ioT4db last edited by
                  Hallo zusammen und erstmal vielen Dank für den Adapter 👍
                  Im zweiten Anlauf hat es nun geklappt und ich wollte kurz schildern welches Problem ich hatte. Vielleicht hilft es ja.
                  Warum es nun geht kann ich auch nur vermuten.
                  Adapter-Version 0.3.2
                  • Also ich habe 2 Kinder an der selben Schule > ergo 2 Webuntis Zugänge
                  • Basic-URL und Schul-Secret "ermittelt" und Zugangsdaten für erstes Kind in Instanz hinterlegt
                  • Anmeldung schlug fehl wegen "Error: Failed to login. {"jsonrpc":"2.0","id":"Awesome","error":{"message":"bad credentials","code":-8504}}"
                  • alles geprüft > Daten passen
                  • zweites Kind eingetragen > funktionierte sofort
                  • Unterschied zwischen Kind1 und Kind2 ist nur, dass bei Kind1 ein Underline im Nutzernamen steht, also abc_abc und bei Kind2 nicht!
                  Kann es da Probleme mit "_" geben? Hat das schonmal jemand anderes Probleme damit?
                  VG
                  • Newan
                    Newan @ioT4db last edited by
                    @friesenjung Normal nicht, wenn du mir den Zugang per Chat zusendest prüfe ich das gerne.
                      Hi!
                      Also, ich habe mich ein wenig beschäftigt und mein erstes Kind "funktioniert" und der Stundenplan ist fertig (siehe Bild) Stundenplan.jpeg
                      Habe nun eine 2. Instanz für meine Tochter installiert, hier komme ich aber nicht rein:
                      Irgendwer eine Idee?
                      Liebe Grüße
                      Jürgen
                      • Newan
                        @jwedenig habe nie 2 Instanzen getestet. Check mal ob die erste mit den Daten der 2. läuft. Dann wäre der Account funktional.
                          @newan
                          Hi!
                          Nein, der Zugang meiner Tochter funktioniert auch mit der ersten Instanz nicht!
                          ioT4db 1 Reply Last reply Reply Quote 0
                          • ioT4db
                            ioT4db @jwedenig last edited by
                            @jwedenig versuch mal das 2. Kind in der instanz 0 einzutragen, ob das geht.
                            Ich hatte ja weiter oben beschrieben, dass ich bei Kind1 mit dem "_" im Probleme hatte.
                            Danach habe ich in der gleichen Instanz die Benutzerdaten gegen die von Kind2 getauscht und das ging sofort.
                            Jetzt habe ich nochmal versucht wieder auf Kind1 (pure Neugier) zu wechseln und siehe da nun ging auch Kind1. Vorher habe ich die Instanz gestoppt und den ganzen Objektbaum gelöscht, um sauber zu starten.
                            Keine Ahnung warum, aber es lag definitiv nicht an nem falschen Passwort oder so, die hole ich mir direkt aus meinem Passwort-Manager.
                            @Newan ich kann Dir gern noch die Anmeldedaten zusenden, aber mittlerweile geht das ja mit dem "_" im Anmeldenamen von Kind1.
                              jwedenig Most Active @ioT4db last edited by
                              @friesenjung
                              Hi!
                              Ja, wie schon gesagt funktioniert der Zugang meiner Tochter bei keiner Instanz, und "_" gibt es auch nicht im Benutzernamen
                                @newan
                                Ich habe einen "-" im Schulnamen, könnte das das Problem sein?
                                Wenn ich statt dem "-" ein Leerzeichen schreibe, habe ich grünen Hacken genau umgekehrt, sprich Verbunden mit Host und Lebenszeichen sind grün, aber Verbunden mit Gerät oder Dienst hat ein rotes Kreuz!
                                • Newan
                                  @jwedenig Schick mal den Account pls
                                    Larrysansan last edited by Larrysansan
                                    Hi danke für diesen Adapter. Ich würde mich freuen wenn man den Stundenplan für die komplette aktuelle Woche (Mo-So) abrufen kann. Da ich in die Abendschule gehe und leider jeden Tag unter der Woche Schule habe. Es aber meistens schon 4 Tage vorher bekannt ist wenn ein Unterricht entfällt oder online stattfindet.
                                    Des weiteren ist mir bei der Instalation noch ein Fehler in der Doku aufgefallen der nicht ganz schlüssig ist.Screenshot 2022-04-07 225724.png
                                      elektrickser.de @Larrysansan last edited by
                                      @larrysansan sagte in TESTER: Neuer Adapter Webuntis:
                                      Das passt schon so.
                                      Wenn im Schoolsecret ein "-" steht wird dies 1:1 so übernommen.
                                      Sollte ein "+" im Schoolsecret stehen sollte muss das "+" durch ein Leerzeichen " " ersetzt werden.
                                        wowbagger @elektrickser.de last edited by
                                        hat es schon jemand hinbekommen eine ganze Woche darzustellen?
                                        Was bei mir auch noch nicht funktioniert ist die Anzeige des jeweiligen Wochentags oberhalb der Untis Tabelle. Wie habt ihr das umgesetzt?
                                        Ansonsten: Coole Idee das so darzustellen. Ich benutze das mit einem Samsung Tablett mit FullyBrowser.
                                        Andreas
                                          Martin-72 last edited by
                                          Hallo Newan,
                                          vielen Dank für Deinen Adapter. Ich habe nun auch WebUntis-Zugangsdaten und sie direkt im Adapter eingetragen. Das sieht soweit auch gut aus:
                                          Wenn ich speichere und schließe, bin ich jedoch etwas irritiert:
                                          In den Objekten wird zwar etwas angezeigt, aber so recht bin ich mir nicht sicher ob das so richtig und vollständig ist:
                                          Also, der Eintrag erscheint wirklich auf der "Heute"-Seite_
                                          Wie komme ich denn nun an den Stundenplan und seine Änderungen?
                                          Vielen Dank
                                          Martin
                                          • Newan
                                            Newan @wowbagger last edited by
                                            @wowbagger Nein ganze Woche geht nicht, hatte bisher die Anforderung nicht. Wenn da bedarf besteht, bitte Request auf github
                                            31.7k
                                            79.8k
                                            191
                                            22593
