    4. js-controller 4.0.x jetzt für alle User im STABLE!
      hardy_01 @apollon77 last edited by hardy_01
      Bei mir hat sich beim Update irgendwas aufgehangen. Seit dem ist der broker nicht mehr erreichbar
      pi@raspberrypi-iob:~ $ iobroker upgrade self
      Update js-controller from @3.1.6 to @4.0.21
      NPM version: 6.14.16
      npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
      In file included from ../../nan/nan.h:56,
                       from ../src/unix_dgram.cc:5:
      /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),                          \
      /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
       NODE_MODULE(unix_dgram, Initialize)
       Objects 127.0.0.1:53902 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
       States 127.0.0.1:38688 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
       Objects 127.0.0.1:53902 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
       Objects 127.0.0.1:53902 Error from InMemDB: Error: scan NOT SUPPORTED
      /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
              throw e;
      ReplyError: Error scan NOT SUPPORTED
          at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
          at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      Emitted 'error' event on ScanStream instance at:
          at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
          at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
          at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
          at processTicksAndRejections (internal/process/task_queues.js:95:5) {
        command: {
          args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.js-controller@4.0.21 install: `node iobroker.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@4.0.21 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2022-03-29T16_38_52_007Z-debug.log
      host.raspberrypi-iob Cannot install iobroker.js-controller@4.0.21: 1
      iobroker update bringt
      pi@raspberrypi-iob:/opt/iobroker $ iobroker update
      internal/modules/cjs/loader.js:905
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
          at Function.Module._load (internal/modules/cjs/loader.js:746:27)
          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
          at internal/main/run_main_module.js:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Jemand eine Idee wo ich ansetzen kann?
      H apollon77 2 Replies Last reply Reply Quote 0
        hardy_01 @hardy_01 last edited by
        @hardy_01 said in js-controller 4.0.x jetzt für alle User im STABLE!:
                throw e;
          command: {
        npm ERR! errno 1
        npm ERR!
          throw err;
          requireStack: []
        pi@raspberrypi-iob:/opt/iobroker $ iobroker start
        pi@raspberrypi-iob:/opt/iobroker $ iobroker fix
        library: loaded
        Library version=2022-02-10
        ioBroker is not installed in /opt/iobroker! Cannot fix anything...
          crunchip Forum Testing Most Active @hardy_01 last edited by
          @hardy_01
          Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen.
            apollon77 @hardy_01 last edited by
            @hardy_01 naja Du kommst von der 3.1 ... Da steht oben das Du idealerweise zuerst die 3.2 installieren solltest bzw ja bei DIr wäre der direkte weg via npm der sinnvolle. Siehe letzter Post
              @apollon77
              Habe ich probiert, bekomme leider immer noch einen Fehler (Berechtigung).
              pi@raspberrypi-iob:~ $ sudo -H -u iobroker npm install iobroker.js-controller
              npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
              npm WARN deprecated har-validator@5.1.5: this library is no longer supported
              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
              npm WARN checkPermissions Missing write access to /home/pi
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
              npm WARN pi No description
              npm WARN pi No repository field.
              npm WARN pi No README data
              npm WARN pi No license field.
              npm ERR! code EACCES
              npm ERR! syscall access
              npm ERR! path /home/pi
              npm ERR! errno -13
              npm ERR! Error: EACCES: permission denied, access '/home/pi'
              npm ERR!  [Error: EACCES: permission denied, access '/home/pi'] {
              npm ERR!   errno: -13,
              npm ERR!   code: 'EACCES',
              npm ERR!   syscall: 'access',
              npm ERR!   path: '/home/pi'
              npm ERR! }
              npm ERR!
              npm ERR! The operation was rejected by your operating system.
              npm ERR! It is likely you do not have the permissions to access this file as the current user
              npm ERR!
              npm ERR! If you believe this might be a permissions issue, please double-check the
              npm ERR! permissions of the file and its containing directories, or try running
              npm ERR! the command again as root/Administrator.
              npm ERR!     /home/iobroker/.npm/_logs/2022-03-29T20_06_59_453Z-debug.log
                Thomas Braun Most Active @hardy_01 last edited by Thomas Braun
                @hardy_01
                Du stehst im falschen Verzeichnis...
                cd /opt/iobroker
                Und dann die direkte Installation wie schon versucht.
                  hardy_01 @Thomas Braun last edited by
                  Herzlichen Dank an alle, hat funktioniert 😊
                    Jack01 last edited by Jack01
                    Moin,
                    heute habe ich mal allen Mut gefasst und auf die aktuelle Version upgedatet.
                    Es sieht so aus, als ob alles funktioniert hat.
                    Es allerdings ein paar Meldungen, die von dem Beispiel im ersten Thread abweichen
                    pi@raspberrypi:/opt/iobroker $ iobroker upgrade self
                    Update js-controller from @3.3.22 to @4.0.21
                    In file included from ../src/unix_dgram.cc:5:
                    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                    ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                    ../src/unix_dgram.cc: At global scope:
                    Server Objects 127.0.0.1:41112 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                    Server Objects 127.0.0.1:41112 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                    Server Objects 127.0.0.1:41112 Error from InMemDB: Error: Unknown LUA script load
                    Server Objects 127.0.0.1:41112 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                    Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                    Muss ich hier noch etwas unternehmen oder ist das so OK?
                    Hans-Jürgen
                    Nachtrag:
                    meine Datenbanken sehen jetzt so aus:
                    pi@raspberrypi:/opt/iobroker $ iob status
                    Objects type: jsonl
                    States  type: redis
                      Thomas Braun Most Active @Jack01 last edited by
                      @jack01
                      Schaut okay aus.
                        lacknelu last edited by lacknelu
                        Hallo!
                        Habe heute versucht auf den js-controller 4.0.x upzugraden - leider bin ich gescheitert ... Habe mich durch die infos im thread garbeitet und auch einiges ausprobiert, jedoch haben alle Lösungen nicht funktioniert bzw. immer wieder zu demselben Problem / Error geführt:
                        pi@PI4IOBroker:/opt/iobroker $ iobroker upgrade self
                        NPM version: 7.24.2
                         Objects 127.0.0.1:56176 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                         States 127.0.0.1:43884 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                         Objects 127.0.0.1:56176 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                         Objects 127.0.0.1:56176 Error from InMemDB: Error: scan NOT SUPPORTED
                        npm ERR! code 1
                        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                        npm ERR! command failed
                        npm ERR! command sh -c node iobroker.js setup first
                        npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                        npm ERR!         throw e;
                        npm ERR!         ^
                        npm ERR!
                        npm ERR! ReplyError: Error scan NOT SUPPORTED
                        npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                        npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                        npm ERR! Emitted 'error' event on ScanStream instance at:
                        npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                        npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                        npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                        npm ERR!     at processTicksAndRejections (internal/process/task_queues.js:95:5) {
                        npm ERR!   command: {
                        npm ERR!     name: 'scan',
                        npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
                        npm ERR!   }
                        npm ERR! }
                        npm ERR!     /home/iobroker/.npm/_logs/2022-04-01T21_26_30_838Z-debug.log
                        Starting node restart.js
                        Die zuletzt probierte Prozedur war folgende:
                        iobroker update
                        iobroker stop
                        iobroker upgrade
                        iobroker fix
                        iobroker start
                        Hat jemand eine idee woran es liegen könnte? Leider kann ich mit den Error Log auf keinen grünen Zweig kommen 😞
                        Der Log beinhaltet folgendes:
                        0 verbose cli [
                        0 verbose cli   '/usr/local/bin/node',
                        0 verbose cli   '/usr/local/bin/npm',
                        0 verbose cli   'install',
                        0 verbose cli   'iobroker.js-controller@4.0.21',
                        0 verbose cli   '--loglevel',
                        0 verbose cli   'error',
                        0 verbose cli   '--unsafe-perm',
                        0 verbose cli   '--prefix',
                        0 verbose cli   '/opt/iobroker'
                        0 verbose cli ]
                        1 info using npm@7.24.2
                        2 info using node@v14.19.1
                        3 timing npm:load:whichnode Completed in 1ms
                        4 timing config:load:defaults Completed in 5ms
                        5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 4ms
                        6 timing config:load:builtin Completed in 4ms
                        7 timing config:load:cli Completed in 8ms
                        8 timing config:load:env Completed in 0ms
                        9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
                        10 timing config:load:project Completed in 2ms
                        11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                        12 timing config:load:user Completed in 1ms
                        13 timing config:load:file:/opt/iobroker/etc/npmrc Completed in 0ms
                        14 timing config:load:global Completed in 0ms
                        15 timing config:load:validate Completed in 1ms
                        16 timing config:load:credentials Completed in 3ms
                        17 timing config:load:setEnvs Completed in 3ms
                        18 timing config:load Completed in 28ms
                        19 timing npm:load:configload Completed in 28ms
                        20 timing npm:load:setTitle Completed in 0ms
                        21 timing npm:load:setupLog Completed in 2ms
                        22 timing config:load:flatten Completed in 9ms
                        23 timing npm:load:cleanupLog Completed in 6ms
                        24 timing npm:load:configScope Completed in 0ms
                        25 timing npm:load:projectScope Completed in 1ms
                        26 timing npm:load Completed in 47ms
                        27 timing arborist:ctor Completed in 2ms
                        28 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.zwave2
                        29 timing idealTree:init Completed in 6038ms
                        30 timing idealTree:userRequests Completed in 24ms
                        31 silly idealTree buildDeps
                        32 silly fetch manifest iobroker.js-controller@4.0.21
                        33 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 7421ms (cache revalidated)
                        34 silly placeDep ROOT iobroker.js-controller@4.0.21 REPLACE for: iobroker.inst@2.0.3 want: 4.0.21
                        35 silly fetch manifest @alcalzone/esbuild-register@^2.5.1-1
                        36 silly fetch manifest @iobroker/db-objects-file@4.0.21
                        37 silly fetch manifest @iobroker/db-objects-jsonl@4.0.21
                        38 silly fetch manifest @iobroker/db-objects-redis@4.0.21
                        39 silly fetch manifest @iobroker/db-states-file@4.0.21
                        40 silly fetch manifest @iobroker/db-states-jsonl@4.0.21
                        41 silly fetch manifest @iobroker/db-states-redis@4.0.21
                        42 silly fetch manifest @iobroker/js-controller-adapter@4.0.21
                        43 silly fetch manifest @iobroker/js-controller-cli@4.0.21
                        44 silly fetch manifest @iobroker/js-controller-common@4.0.21
                        45 silly fetch manifest @iobroker/js-controller-common-db@4.0.21
                        46 silly fetch manifest @iobroker/plugin-base@~1.2.1
                        47 silly fetch manifest @iobroker/plugin-sentry@~1.2.0
                        48 silly fetch manifest axios@^0.24.0
                        Vielen Dank für eure Hilfe.
                        LG Lukas
                        Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                          crunchip Forum Testing Most Active last edited by crunchip
                          @lacknelu denke du müsstest erst mal dein node und npm richtig installieren
                          wenn das erledigt ist und dennoch kein upgrade funktioniert, dann im ersten Thread den Abschnitt "Bei Fehlern:" nochmal lesen
                            Thomas Braun Most Active @lacknelu last edited by
                            @lacknelu
                            Ja, nodeJS und das Drumherum ist komplett schief.
                            Das zuerst in Ordnung bringen. Siehe in meiner Signatur.
                              apollon77 @lacknelu last edited by apollon77
                              @lacknelu naja, du springst von der 3.1 über 3.2 und 3.3 zur 4.0 ... das ist ein "weiterer Weg" ... lies mal oben im ersten Post ... Mach einen "npm" install des 4er controller wie oben angegeben dann geht es auch
                              PS: Hättest auch einfach mal ein paar Posts nach oben scrollen können, da gabs schon einen zweiten User mit genau dem gleichen problem 😞
                                Aiouh last edited by
                                Mein Update ist absolut problemlos gelaufen, wieder einmal prima Arbeit von den Verantwortlichen. DANKE dafür.
                                Eine Frage habe ich aber noch - Ich bekomme seit dem Update die Meldung
                                influxdb.0 2022-04-02 17:38:44.229	warn	No connection to DB
                                Das ist erst einmal nicht tragisch, da ich eigentlich nur noch die influxdb.1 benutze. Die influxdb.0 zeigt auf eine externe db die es seit kurzem nicht mehr gibt und nicht mehr genutzt wird. Bisher hatte ich dazu keine Fehlermeldungen bekommen, erst nach dem Update.
                                Meine Frage ist nun wie ich herausbekommen kann ob ich doch noch Objekte mit der alten influxdb.0 verknüpft habe.
                                Würde ich Fehlermeldungen bekommen wenn dem so wäre? Dann lege ich mich dazu gleich wieder ganz beruhigt hin.
                                apollon77 E 2 Replies Last reply Reply Quote 0
                                  apollon77 @Aiouh last edited by
                                  @aiouh sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                                  Wie meinst Du das?
                                    Einstein67 @Aiouh last edited by Einstein67
                                    @aiouh said in js-controller 4.0.x jetzt für alle User im STABLE!:
                                    Einfach die Objekte öffnen und dann rechts oben bei Einstellungen "influxdb.0" auswählen.
                                    Dann werden nur mehr Objekte angezeigt, die nach influxdb.0 speichern.
                                      @apollon77, @Thomas Braun, @crunchip
                                      Danke für eure Unterstützung. Bin noch einmal alles durchgegangen und habe Node richtig gestellt. Zwischenzeitlich ist dann nichts mehr gegangen weil ich einfach leider viel zu wenig über die Thematik verstehe 😞
                                      IOBroker läuft mittlerweile wieder und ich upgrade mich sukzessive in Richtung 4.X
                                      Danke & LG
                                      Lukas
                                        Aiouh @apollon77 last edited by
                                        @apollon77
                                        Wie meine ich das: Ich habe in den Anfängen meines ioBroker bei einigen Objekten die influxdb.0 als history DB verwendet.
                                        Ich habe dann auf die lokale influxdb.1 umgestellt und "glaube" auch, dass ich alle Objekte umgestellt habe, ich bin mir aber eben leider nicht sicher.
                                        Bevor ich nun irgendwann eine Überraschung erlebe dass die history Daten eines Objekts fehlen dachte ich mir es wäre gut wenn ich, ohne jedes Objekt einzeln zu öffnen, irgendwie eine Übersicht ziehen könnte welches Objekt welcher influxdb zugeordnet ist.
                                        Ich hoffe das war klarer ausgedrückt.
                                          @aiouh Jupp danke. @Einstein67 hatte doch ja wohl dann richtig verstanden 🙂
                                            flubb last edited by
                                            habe noch eine etwas ältere Installation am laufen (js-controller 2.x) und würde diese gern updaten. Wie empfohlen würde ich das gerne über einen Zwischenstopp bei der 3.3 machen und dann erstmal Node.js updaten.
                                            Leider scheitere ich jedoch bei der Installation vom js-controller 3.3:
                                            pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@3.3
                                            npm ERR! code ENOTSUP
                                            npm ERR! notsup Unsupported engine for winston@3.7.2: wanted: {"node":">= 12.0.0"} (current: {"node":"10.18.1","npm":"6.13.4"})
                                            npm ERR! notsup Not compatible with your version of node/npm: winston@3.7.2
                                            npm ERR! notsup Required: {"node":">= 12.0.0"}
                                            npm ERR! notsup Actual:   {"npm":"6.13.4","node":"10.18.1"}
                                            npm ERR!     /home/pi/.npm/_logs/2022-04-07T18_31_35_248Z-debug.log
                                            Dachte der js-controller 3.3 ist noch mit Node.js 10 kompatibel? Der Versuch auf den js.controller 3.2 upzudaten führt zum gleichen Problem. Hat jmd. einen Tipp für mich?
                                            501
                                            138918
