    4. js-controller 4.0.x jetzt für alle User im STABLE!
      hardy_01 @Thomas Braun last edited by
      Herzlichen Dank an alle, hat funktioniert 😊
        Jack01 last edited by Jack01
        Moin,
        heute habe ich mal allen Mut gefasst und auf die aktuelle Version upgedatet.
        Es sieht so aus, als ob alles funktioniert hat.
        Es allerdings ein paar Meldungen, die von dem Beispiel im ersten Thread abweichen
        pi@raspberrypi:/opt/iobroker $ iobroker upgrade self
        Update js-controller from @3.3.22 to @4.0.21
        NPM version: 6.14.16
        npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
        In file included from ../src/unix_dgram.cc:5:
        ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
        ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
        In file included from ../../nan/nan.h:56,
        ../src/unix_dgram.cc: At global scope:
        /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
               (node::addon_register_func) (regfunc),                          \
        /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(unix_dgram, Initialize)
        Server Objects 127.0.0.1:41112 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
        Server Objects 127.0.0.1:41112 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
        Server Objects 127.0.0.1:41112 Error from InMemDB: Error: Unknown LUA script load
        Server Objects 127.0.0.1:41112 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
        Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
        Muss ich hier noch etwas unternehmen oder ist das so OK?
        Hans-Jürgen
        Nachtrag:
        meine Datenbanken sehen jetzt so aus:
        pi@raspberrypi:/opt/iobroker $ iob status
        Objects type: jsonl
        States  type: redis
          Thomas Braun Most Active @Jack01 last edited by
          @jack01
          Schaut okay aus.
            lacknelu last edited by lacknelu
            Hallo!
            Habe heute versucht auf den js-controller 4.0.x upzugraden - leider bin ich gescheitert ... Habe mich durch die infos im thread garbeitet und auch einiges ausprobiert, jedoch haben alle Lösungen nicht funktioniert bzw. immer wieder zu demselben Problem / Error geführt:
            pi@PI4IOBroker:/opt/iobroker $ iobroker upgrade self
            Update js-controller from @3.1.6 to @4.0.21
            NPM version: 7.24.2
             Objects 127.0.0.1:56176 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
             States 127.0.0.1:43884 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
             Objects 127.0.0.1:56176 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
             Objects 127.0.0.1:56176 Error from InMemDB: Error: scan NOT SUPPORTED
            npm ERR! code 1
            npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
            npm ERR! command failed
            npm ERR! command sh -c node iobroker.js setup first
            npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            npm ERR!         throw e;
            npm ERR!         ^
            npm ERR!
            npm ERR! ReplyError: Error scan NOT SUPPORTED
            npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
            npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
            npm ERR! Emitted 'error' event on ScanStream instance at:
            npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
            npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
            npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
            npm ERR!     at processTicksAndRejections (internal/process/task_queues.js:95:5) {
            npm ERR!   command: {
            npm ERR!     name: 'scan',
            npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
            npm ERR!   }
            npm ERR! }
            npm ERR!     /home/iobroker/.npm/_logs/2022-04-01T21_26_30_838Z-debug.log
            Starting node restart.js
            Die zuletzt probierte Prozedur war folgende:
            iobroker update
            iobroker stop
            iobroker upgrade
            iobroker fix
            iobroker start
            Hat jemand eine idee woran es liegen könnte? Leider kann ich mit den Error Log auf keinen grünen Zweig kommen 😞
            Der Log beinhaltet folgendes:
            0 verbose cli [
            0 verbose cli   '/usr/local/bin/node',
            0 verbose cli   '/usr/local/bin/npm',
            0 verbose cli   'install',
            0 verbose cli   'iobroker.js-controller@4.0.21',
            0 verbose cli   '--loglevel',
            0 verbose cli   'error',
            0 verbose cli   '--unsafe-perm',
            0 verbose cli   '--prefix',
            0 verbose cli   '/opt/iobroker'
            0 verbose cli ]
            1 info using npm@7.24.2
            2 info using node@v14.19.1
            3 timing npm:load:whichnode Completed in 1ms
            4 timing config:load:defaults Completed in 5ms
            5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 4ms
            6 timing config:load:builtin Completed in 4ms
            7 timing config:load:cli Completed in 8ms
            8 timing config:load:env Completed in 0ms
            9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
            10 timing config:load:project Completed in 2ms
            11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
            12 timing config:load:user Completed in 1ms
            13 timing config:load:file:/opt/iobroker/etc/npmrc Completed in 0ms
            14 timing config:load:global Completed in 0ms
            15 timing config:load:validate Completed in 1ms
            16 timing config:load:credentials Completed in 3ms
            17 timing config:load:setEnvs Completed in 3ms
            18 timing config:load Completed in 28ms
            19 timing npm:load:configload Completed in 28ms
            20 timing npm:load:setTitle Completed in 0ms
            21 timing npm:load:setupLog Completed in 2ms
            22 timing config:load:flatten Completed in 9ms
            23 timing npm:load:cleanupLog Completed in 6ms
            24 timing npm:load:configScope Completed in 0ms
            25 timing npm:load:projectScope Completed in 1ms
            26 timing npm:load Completed in 47ms
            27 timing arborist:ctor Completed in 2ms
            28 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.zwave2
            29 timing idealTree:init Completed in 6038ms
            30 timing idealTree:userRequests Completed in 24ms
            31 silly idealTree buildDeps
            32 silly fetch manifest iobroker.js-controller@4.0.21
            33 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 7421ms (cache revalidated)
            34 silly placeDep ROOT iobroker.js-controller@4.0.21 REPLACE for: iobroker.inst@2.0.3 want: 4.0.21
            35 silly fetch manifest @alcalzone/esbuild-register@^2.5.1-1
            36 silly fetch manifest @iobroker/db-objects-file@4.0.21
            37 silly fetch manifest @iobroker/db-objects-jsonl@4.0.21
            38 silly fetch manifest @iobroker/db-objects-redis@4.0.21
            39 silly fetch manifest @iobroker/db-states-file@4.0.21
            40 silly fetch manifest @iobroker/db-states-jsonl@4.0.21
            41 silly fetch manifest @iobroker/db-states-redis@4.0.21
            42 silly fetch manifest @iobroker/js-controller-adapter@4.0.21
            43 silly fetch manifest @iobroker/js-controller-cli@4.0.21
            44 silly fetch manifest @iobroker/js-controller-common@4.0.21
            45 silly fetch manifest @iobroker/js-controller-common-db@4.0.21
            46 silly fetch manifest @iobroker/plugin-base@~1.2.1
            47 silly fetch manifest @iobroker/plugin-sentry@~1.2.0
            48 silly fetch manifest axios@^0.24.0
            Vielen Dank für eure Hilfe.
            LG Lukas
            Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
              crunchip Forum Testing Most Active last edited by crunchip
              @lacknelu denke du müsstest erst mal dein node und npm richtig installieren
              wenn das erledigt ist und dennoch kein upgrade funktioniert, dann im ersten Thread den Abschnitt "Bei Fehlern:" nochmal lesen
                Thomas Braun Most Active @lacknelu last edited by
                @lacknelu
                Ja, nodeJS und das Drumherum ist komplett schief.
                Das zuerst in Ordnung bringen. Siehe in meiner Signatur.
                  apollon77 @lacknelu last edited by apollon77
                  @lacknelu naja, du springst von der 3.1 über 3.2 und 3.3 zur 4.0 ... das ist ein "weiterer Weg" ... lies mal oben im ersten Post ... Mach einen "npm" install des 4er controller wie oben angegeben dann geht es auch
                  PS: Hättest auch einfach mal ein paar Posts nach oben scrollen können, da gabs schon einen zweiten User mit genau dem gleichen problem 😞
                    Aiouh last edited by
                    Mein Update ist absolut problemlos gelaufen, wieder einmal prima Arbeit von den Verantwortlichen. DANKE dafür.
                    Eine Frage habe ich aber noch - Ich bekomme seit dem Update die Meldung
                    influxdb.0 2022-04-02 17:38:44.229	warn	No connection to DB
                    Das ist erst einmal nicht tragisch, da ich eigentlich nur noch die influxdb.1 benutze. Die influxdb.0 zeigt auf eine externe db die es seit kurzem nicht mehr gibt und nicht mehr genutzt wird. Bisher hatte ich dazu keine Fehlermeldungen bekommen, erst nach dem Update.
                    Meine Frage ist nun wie ich herausbekommen kann ob ich doch noch Objekte mit der alten influxdb.0 verknüpft habe.
                    Würde ich Fehlermeldungen bekommen wenn dem so wäre? Dann lege ich mich dazu gleich wieder ganz beruhigt hin.
                    apollon77 E 2 Replies Last reply Reply Quote 0
                      apollon77 @Aiouh last edited by
                      @aiouh sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                      Wie meinst Du das?
                        Einstein67 @Aiouh last edited by Einstein67
                        @aiouh said in js-controller 4.0.x jetzt für alle User im STABLE!:
                        Einfach die Objekte öffnen und dann rechts oben bei Einstellungen "influxdb.0" auswählen.
                        Dann werden nur mehr Objekte angezeigt, die nach influxdb.0 speichern.
                          @apollon77, @Thomas Braun, @crunchip
                          Danke für eure Unterstützung. Bin noch einmal alles durchgegangen und habe Node richtig gestellt. Zwischenzeitlich ist dann nichts mehr gegangen weil ich einfach leider viel zu wenig über die Thematik verstehe 😞
                          IOBroker läuft mittlerweile wieder und ich upgrade mich sukzessive in Richtung 4.X
                          Danke & LG
                          Lukas
                            Aiouh @apollon77 last edited by
                            @apollon77
                            Wie meine ich das: Ich habe in den Anfängen meines ioBroker bei einigen Objekten die influxdb.0 als history DB verwendet.
                            Ich habe dann auf die lokale influxdb.1 umgestellt und "glaube" auch, dass ich alle Objekte umgestellt habe, ich bin mir aber eben leider nicht sicher.
                            Bevor ich nun irgendwann eine Überraschung erlebe dass die history Daten eines Objekts fehlen dachte ich mir es wäre gut wenn ich, ohne jedes Objekt einzeln zu öffnen, irgendwie eine Übersicht ziehen könnte welches Objekt welcher influxdb zugeordnet ist.
                            Ich hoffe das war klarer ausgedrückt.
                              @aiouh Jupp danke. @Einstein67 hatte doch ja wohl dann richtig verstanden 🙂
                                flubb last edited by
                                habe noch eine etwas ältere Installation am laufen (js-controller 2.x) und würde diese gern updaten. Wie empfohlen würde ich das gerne über einen Zwischenstopp bei der 3.3 machen und dann erstmal Node.js updaten.
                                Leider scheitere ich jedoch bei der Installation vom js-controller 3.3:
                                pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@3.3
                                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                npm ERR! code ENOTSUP
                                npm ERR! notsup Unsupported engine for winston@3.7.2: wanted: {"node":">= 12.0.0"} (current: {"node":"10.18.1","npm":"6.13.4"})
                                npm ERR! notsup Not compatible with your version of node/npm: winston@3.7.2
                                npm ERR! notsup Required: {"node":">= 12.0.0"}
                                npm ERR! notsup Actual:   {"npm":"6.13.4","node":"10.18.1"}
                                npm ERR!     /home/pi/.npm/_logs/2022-04-07T18_31_35_248Z-debug.log
                                Dachte der js-controller 3.3 ist noch mit Node.js 10 kompatibel? Der Versuch auf den js.controller 3.2 upzudaten führt zum gleichen Problem. Hat jmd. einen Tipp für mich?
                                mikeal created this issue in request/request
                                open Request’s Past, Present and Future #3142
                                  Thomas Braun Most Active @flubb last edited by
                                  @flubb
                                  Installier doch zunächst eine aktuelle nodeJS-Version?
                                  Ich würde gleich auf node14 gehen.
                                    apollon77 @flubb last edited by
                                    @flubb alternativ geh über die 3.2 vom Controller.
                                      Sonnenkind last edited by
                                      Hallo in die Runde,
                                      ich hätte mal folgende Frage, wollte jetzt auch updaten, dabei kommt bei der Abfrage von Node und Node js immer die gleiche Version 14.19.1 wie in derInfo angezeigt, aber gleichzeitig sagt er da mein Host ist noch a3376e83-d290-40af-a6a4-4d23d030e639-image.png
                                      das verstehe ich nicht ganz , bin abernoch immer kein Linux Profi eventuell würde mir jemand einen Tip geben können?
                                      Danke schon mal ?Ach es läuft eigentlich alles soweit, lediglich der matt leget keine Objekte an aber das nur nebenbei muss auch damit nix zu tun haben.Danke auf jeden Fall und einen schönen Sonntag noch
                                        @sonnenkind sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                                        wenn du die Version drauf hast, was soll dann anderes angezeigt werden, bei einer Abfrage?
                                        richtig, und diesen kannst du updaten
                                        was ist das? mqtt?
                                          Sonnenkind @crunchip last edited by
                                          @crunchip danke Dir, also muss ich nur den admin noch updaten? Das andere meine mqtt, Adapter der ist da un läuft, auch sehe ich das Lan aktiv ist vom Sender aber es werden keine Objekte angelegt angezeigt, in dem Fall ist es ein Esp mit einen sensor für Co, temp, und feuchte .
                                          Nochmal zu der Abfrage, ich dachte wenn ich die abfrage node -v bzw nodejs -v mache, werden unterschiedliche Versionen angezeigt ? Jetzt noch die letzte Frage gibt es ne Info wie ich js-controller update?Danke
                                          Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                            Thomas Braun Most Active @Sonnenkind last edited by
                                            @sonnenkind
                                            Check:
                                            sudo ln -s /usr/bin/node /usr/bin/nodejs
                                            which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                            iobroker stop
                                            iobroker update
                                            iobroker upgrade
                                            iobroker start
                                            501
                                            139520
