    4. Adapter für Buderus KM200 (und eventuell auch anderen KMxxx)
    • werner2000x
      werner2000x @Omnedon last edited by werner2000x
      @omnedon Ich habe beide Adapter (KM200 und EMS_ESP) versucht und keiner geht.
      Folgender Fehler kommt im Log mit KM200:
      km200.0
      2022-04-01 15:32:57.041	info	Adapter km200 initialization finished with 8 states.
      km200.0
      2022-04-01 15:32:56.910	info	Update State system err: "KM200.get service parameter not as requested 'undefined'"
      km200.0
      2022-04-01 15:32:56.909	warn	KM200.get service parameter not as requested 'undefined'
      km200.0
      2022-04-01 15:32:56.904	info	Update State solarCircuits err: "KM200.get service parameter not as requested 'undefined'"
      km200.0
      2022-04-01 15:32:56.902	warn	KM200.get service parameter not as requested 'undefined'
      km200.0
      2022-04-01 15:32:56.896	info	Update State recordings err: "KM200.get service parameter not as requested 'undefined'"
      km200.0
      2022-04-01 15:32:56.895	warn	KM200.get service parameter not as requested 'undefined'
      km200.0
      2022-04-01 15:32:56.890	info	Update State notifications err: "KM200.get service parameter not as requested 'undefined'"
      km200.0
      2022-04-01 15:32:56.889	warn	KM200.get service parameter not as requested 'undefined'
      km200.0
      2022-04-01 15:32:56.883	info	Update State heatingCircuits err: "KM200.get service parameter not as requested 'undefined'"
      km200.0
      2022-04-01 15:32:56.882	warn	KM200.get service parameter not as requested 'undefined'
      km200.0
      2022-04-01 15:32:56.876	info	Update State heatSources err: "KM200.get service parameter not as requested 'undefined'"
      km200.0
      2022-04-01 15:32:56.873	warn	KM200.get service parameter not as requested 'undefined'
      km200.0
      2022-04-01 15:32:56.868	info	Update State gateway err: "KM200.get service parameter not as requested 'undefined'"
      km200.0
      2022-04-01 15:32:56.867	warn	KM200.get service parameter not as requested 'undefined'
      km200.0
      2022-04-01 15:32:56.854	info	Update State dhwCircuits err: "KM200.get service parameter not as requested 'undefined'"
      km200.0
      2022-04-01 15:32:56.853	warn	KM200.get service parameter not as requested 'undefined'
      km200.0
      2022-04-01 15:32:56.850	info	Slow Interval=6 hours, Slow-List:
      km200.0
      2022-04-01 15:32:56.850	info	Fast Interval=2 min, Fast-List:
      km200.0
      2022-04-01 15:32:56.849	info	Interval=30 min, Norm-list: dhwCircuits,gateway,heatSources,heatingCircuits,notifications,recordings,solarCircuits,system
      km200.0
      2022-04-01 15:32:56.846	info	KM200 found 8 states, get their values now.
      km200.0
      2022-04-01 15:32:56.337	info	Services found: 8
      km200.0
      2022-04-01 15:32:55.843	info	km200.0 address: http://192.168.198.32
      km200.0
      2022-04-01 15:32:55.840	info	km200 initialization started...
      km200.0
      2022-04-01 15:32:55.653	info	starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.km200, node: v14.19.1, js-controller: 4.0.21
      Ich habe das private Passwort aus der MyDevice App verwendet, verwende daneben auch die App "MyBuderus".
      Im Log des ems-esp Adapter kommt diese M eldung:
      ems-esp.0
      2022-04-01 15:44:08.501	error	error reading km200 gateway information (wrong passwords please re-enter) - stop km200 read
      ems-esp.0
      2022-04-01 15:44:08.333	info	starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.ems-esp, node: v14.19.1, js-controller: 4.0.21
      • werner2000x
        werner2000x @Ralf_N last edited by
        @ralf_n Soll man denn die "MyBuderus App" löschen bzw. deinstallieren?
          tp1de @werner2000x last edited by
          @werner2000x
          Die Meldung aus meinem ems-esp Adapter ist eindeutig.
          Eines der beiden Kennwörter ist falsch. Achte auf Leerstellen und gib das Gateway PW mit Bindestrichen ein.
            @werner2000x myBuderus App geht über Cloud Account. Kann parallel verwendet werden
              mwolle @tp1de last edited by
              @tp1de
              Ich glaube Bosch hat wieder ein Firmwareupdate gemacht?! Auf jeden Fall hing mein MB LAN wieder, nach Neustart waren wieder alle Daten da, ABER ich kann mein Heizprogramm nicht mehr wegschreiben. Ich bekomme im iobroker nun diese Meldung:
              info km200.0 Could not find state for heatingCircuits.hc2.activeSwitchProgram
              Wenn ich den Parameter über den EMS-ESP Adapter laufen lasse, bekomme ich gar keine Meldung, aber der Wert wird auch nicht in den Regler geschrieben (Junkers FW200). Hat jemand ähnliche Phänomene? Das ist erst seit 2-3 Tagen so, vorher war alles gut.
                tp1de @mwolle last edited by tp1de
                @mwolle Mein letztes Update war am 2.2.2022 auf FW 04.08.02. Noch funktioniert bei mir alles .
                Meine Buderus Heizung läuft jetzt 44 Monate mit ioBroker Anbindung. Es gab einige FW Updates. Dabei "verschwanden" immer wieder Felder.
                Das war einer der Gründe, warum ich mir den EMS-ESP zugelegt habe.
                  @tp1de ich hatte mir den EMS-ESP ja auch besorgt, Problem ist aber das hier:
                  Kein Write bei genau dem FW200 😕 Mit dem Original MB-LAN hat das bis vorgestern noch funktioniert...jetzt nicht mehr, auch über den EMS-ESP Adapter von dir scheint es nicht zu klappen (es gibt aber auch keine Fehlermeldung raus)
                    @mwolle was genau meinst du? Hast du das Ems-Esp Hardware von BBQKees oder nur meinen Adapter?
                    Und hast Du den ems-esp adapter neu gestartet mit Neuanlage der States und gibt es dann die gesuchten States?
                      @tp1de : Es ist nicht ganz so einfach 🙂 ich hatte den EMS Adapter von Kees, und damit auch deinen Adapter + dem "KM200" (oder in der Junkerswelt der MB-LAN 2) + den KM200 Adapter. Zwischenzeitlich ist der EMS Adapter von Kees wieder gegangen, somit ist der MB LAN 2 noch da + KM200 Adapter und dein Adapter.
                      Bisher habe ich über MB LAN 2 und KM200 Adapter den Regler FW 200 mit einem Heizprogramm nach Wetterprognose beschrieben -> das hat bis Vorgestern einwandfrei geklappt, nun kommt obige Meldung im Protokoll.
                      Gestern habe ich versucht das gleiche über dein Adapter zu vollziehen:
                      Im Adapter hat er das Heizprogramm auch beschrieben F(5), aber am FW 200 steht noch das D(3), siehe Bild oben. Es wurde also nicht weggeschrieben.
                        @mwolle Die States-Attribute z.B. read only oder writable kommen von der jeweiligen API.
                        In meinem Adapter werden diese nur dann neu geschrieben, wenn ein Neustart mit Löschen der Zustände erfolgt. Dann sollten auch keine ems-States mehr da sein.
                        Mach das bitte mal und poste die States Details:
                        "type": "state",
                        "id": "heatingCircuits.hc1.activeSwitchProgram",
                        "common": {
                        "name": "km200:heatingCircuits.hc1.activeSwitchProgram",
                        "type": "number",
                        "unit": "",
                        "read": true,
                        "write": true,
                        "role": "level",
                        "states": {
                        "0": "A",
                        "1": "B"
                        "min": 0,
                        "max": 1
                        "native": {
                        "km200": {
                        "id": "/heatingCircuits/hc1/activeSwitchProgram",
                        "type": "stringValue",
                        "writeable": 1,
                        "recordable": 0,
                        "value": "A",
                        "allowedValues": [
                        "A",
                        "B"
                        "valIs": "states"
                        "ems_km200": "heatingCircuits.hc1.activeSwitchProgram"
                        "_id": "ems-esp.0.heatingCircuits.hc1.activeSwitchProgram",
                        "from": "system.adapter.ems-esp.0",
                        "user": "system.user.admin",
                        "ts": 1647545350374,
                        "acl": {
                        "object": 1636,
                        "state": 1636,
                        "owner": "system.user.admin",
                          @tp1de sieht eigentlich vernünftig aus:
                            "common": {
                              "name": "heatingCircuits.hc2.activeSwitchProgram",
                              "read": true,
                              "write": true,
                              "state": "state",
                              "role": "level",
                              "type": "number",
                              "unit": "",
                              "states": "0:A;1:B;2:C;3:D;4:E;5:F",
                              "min": 0,
                              "max": 5
                            "type": "state",
                            "_id": "km200.0.heatingCircuits.hc2.activeSwitchProgram",
                            "native": {
                              "km200": {
                                "id": "/heatingCircuits/hc2/activeSwitchProgram",
                                "writeable": 1,
                                "recordable": 1,
                                "value": "F",
                                "allowedValues": [
                                  "A",
                                  "B",
                                  "C",
                                  "D",
                                  "E",
                                  "F"
                                "valIs": "states"
                            "from": "system.adapter.km200.0",
                            "ts": 1646935809160,
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                          Dein EMS Adapter sagt:
                            "type": "state",
                            "id": "heatingCircuits.hc2.activeSwitchProgram",
                            "common": {
                              "name": "km200:heatingCircuits.hc2.activeSwitchProgram",
                              "type": "number",
                              "unit": "",
                              "read": true,
                              "write": true,
                              "role": "level",
                              "min": 0,
                              "max": 5
                            "native": {
                              "km200": {
                                "writeable": 1,
                                "recordable": 1,
                                "value": "D",
                                "allowedValues": [
                                  "A",
                                  "B",
                                  "C",
                                  "D",
                                  "E",
                                  "F"
                                "valIs": "states"
                              "ems_km200": "heatingCircuits.hc2.activeSwitchProgram"
                            "_id": "ems-esp.0.heatingCircuits.hc2.activeSwitchProgram",
                            "ts": 1645340442038,
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                          Dennoch
                          km200.0
                          2022-04-04 20:26:47.780	info	Could not find state for heatingCircuits.hc2.activeSwitchProgram
                          km200.0
                          2022-04-04 20:26:45.770	info	Set km200.0.heatingCircuits.hc2.activeSwitchProgram to 3
                            @mwolle wenn die States neu angelegt wurden und das Schreiben nicht geht, dann ist das ein Fehler im Gateway.
                              @tp1de danke für den Tipp, Neu angelegt, ich habe den mal gelöscht und neu anlegen lassen...nun geht es wieder...verrückt.
                                @mwolle ne nicht verrückt... nach meiner Erfahrung notwendig nach Firmware Updates.
                                  mwolle @tp1de last edited by mwolle
                                  @tp1de : Anbei mal meine Config um die Statistiken zu bekommen mit dem KM200:
                                  Im EMS-ESP:
                                  Protokoll:
                                  ems-esp.0
                                  2022-04-06 21:49:27.115	error	error read efficiency:TypeError: Cannot read property 'val' of null
                                  sql.0
                                  2022-04-06 21:49:27.114	info	No Data
                                  sql.0
                                  2022-04-06 21:49:27.111	info	No Data
                                  sql.0
                                  2022-04-06 21:49:27.109	info	No Data
                                  Ich würde das tatsächlich gerne komplett zum Laufen bekommen.
                                    @mwolle
                                    So wie es aussieht benutzt Du nicht die letzte Version 1.4.0. Dann sollte die States-Struktur so aussehen:
                                    Aber unabhängig davon, sollten mySQL-Datensätze im dem _Months, _Days, _Hours States da sein. Die könntest Du mit Flot oder Grafana darstellen. Überprüfe mal die Monatswerte _Months in den benutzerdefinierten Einstellungen im Objekt-Browser .
                                    Das sollte dann so aussehen:
                                      @tp1de also die 1.4.0 Version ist installiert und ich habe auch die gleiche State Struktur wie du. Ich glaube was mir noch fehlt, welche Werte müssen in die SQL DB rein, damit die Berechnung klappt. Sind das die km200 recordings (die allesamt in die SQL DB müssen)? Oder welche müssen in der SQL Datenbank historisiert werden?
                                      Die Statistics über Brennerstarts etc. läuft wie? Da habe ich auch nur 0 Werte.
                                        @mwolle
                                        wir sollten die Diskussion im ems-esp Forum weiterführen:
                                        https://forum.iobroker.net/topic/45862/neuer-adapter-ems-esp-für-bosch-heizungen/180?_=1649329552411
                                        Torsten Schwaar 1 Reply Last reply Reply Quote 0
                                        • Torsten Schwaar
                                          Torsten Schwaar @tp1de last edited by
                                          Hallo Kann mir jemand sagen wie ich im blockly dem Wert "km200.0.heatingCircuits.hc1.temporaryRoomSetpoint" den Wert 0,-1 oder off setzen kann?
                                          bei den Zahlen 0 und -1 wird der Wert 5 gesetzt, bei "off" als string bekomme ich auch einen Fehler:
                                            tp1de @Torsten Schwaar last edited by
                                            @torsten-schwaar sagte in Adapter für Buderus KM200 (und eventuell auch anderen KMxxx):
                                            Ändere den erlaubten Minimalwert des States auf -1.
                                            686
                                            185869
